    4. Test Adapter vis 2.0 (Alpha)
    • amg_666
      amg_666 @liv-in-sky last edited by
      @liv-in-sky sagte in Test Adapter vis 2.0 (Alpha):
      da passiert bei mir leider nix ! weder seite verwalten - noch das plus zeigt irgendwelche reaktionen
      Bei mir genauso, nix passiert 😞
      Feuersturm 1 Reply Last reply Reply Quote -1
        denjo @apollon77 last edited by
        @apollon77 bei mir klappt das importieren immer noch nicht und dann schwarzer bildschirm
        web.0
        2022-11-27 12:58:40.000	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
        web.0
        2022-11-27 12:58:39.998	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
        web.0
        2022-11-27 12:58:39.997	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
        web.0
        2022-11-27 12:58:39.995	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
        web.0
        2022-11-27 12:58:39.982	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:850:27)
        web.0
        2022-11-27 12:58:39.981	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
        web.0
        2022-11-27 12:58:39.979	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
        web.0
        2022-11-27 12:58:39.978	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
        web.0
        2022-11-27 12:58:39.976	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
        web.0
        2022-11-27 12:58:39.975	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
        web.0
        2022-11-27 12:58:39.974	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
        web.0
        2022-11-27 12:58:39.972	error	can't render tplMfdShutterDialog w00022 on "Tabs":
        web.0
        2022-11-27 12:58:39.961	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
        web.0
        2022-11-27 12:58:39.960	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
        web.0
        2022-11-27 12:58:39.959	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
        web.0
        2022-11-27 12:58:39.958	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
        web.0
        2022-11-27 12:58:39.957	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:850:27)
        web.0
        2022-11-27 12:58:39.955	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
        web.0
        2022-11-27 12:58:39.953	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
        web.0
        2022-11-27 12:58:39.950	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
        web.0
        2022-11-27 12:58:39.949	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
        web.0
        2022-11-27 12:58:39.947	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
        web.0
        2022-11-27 12:58:39.945	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
        web.0
        2022-11-27 12:58:39.944	error	can't render tplMfdShutterDialog w00020 on "Tabs":
        web.0
        2022-11-27 12:58:39.940	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
        web.0
        2022-11-27 12:58:39.939	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
        web.0
        2022-11-27 12:58:39.938	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
        web.0
        2022-11-27 12:58:39.936	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
        web.0
        2022-11-27 12:58:39.934	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:850:27)
        web.0
        2022-11-27 12:58:39.933	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
        web.0
        2022-11-27 12:58:39.932	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
        web.0
        2022-11-27 12:58:39.931	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
        web.0
        2022-11-27 12:58:39.929	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
        web.0
        2022-11-27 12:58:39.928	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
        web.0
        2022-11-27 12:58:39.927	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
        web.0
        2022-11-27 12:58:39.926	error	can't render tplMfdShutterDialog w00018 on "Tabs":
        web.0
        2022-11-27 12:58:39.924	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
        web.0
        2022-11-27 12:58:39.923	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
        web.0
        2022-11-27 12:58:39.921	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
        web.0
        2022-11-27 12:58:39.920	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
        web.0
        2022-11-27 12:58:39.919	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:850:27)
        web.0
        2022-11-27 12:58:39.917	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
        web.0
        2022-11-27 12:58:39.912	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
        web.0
        2022-11-27 12:58:39.894	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
        web.0
        2022-11-27 12:58:39.893	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
        web.0
        2022-11-27 12:58:39.891	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
        web.0
        2022-11-27 12:58:39.889	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
        web.0
        2022-11-27 12:58:39.888	error	can't render tplMfdShutterDialog w00017 on "Tabs":
        web.0
        2022-11-27 12:58:39.884	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
        web.0
        2022-11-27 12:58:39.858	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
        web.0
        2022-11-27 12:58:39.857	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
        web.0
        2022-11-27 12:58:39.854	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
        web.0
        2022-11-27 12:58:39.852	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:853:22)
        web.0
        2022-11-27 12:58:39.851	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
        web.0
        2022-11-27 12:58:39.847	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
        web.0
        2022-11-27 12:58:39.834	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
        web.0
        2022-11-27 12:58:39.833	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
        web.0
        2022-11-27 12:58:39.831	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
        web.0
        2022-11-27 12:58:39.829	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
        web.0
        2022-11-27 12:58:39.827	error	can't render tplMfdShutterDialog w00015 on "Tabs":
        web.0
        2022-11-27 12:58:39.823	error	10 - at Qe.componentDidMount (http://192.168.178.98:8082/vis-2-beta/static/js/363.1c471ab3.chunk.js:16:51349)
        web.0
        2022-11-27 12:58:39.821	error	9 - at Qe.renderWidget (http://192.168.178.98:8082/vis-2-beta/static/js/363.1c471ab3.chunk.js:16:67700)
        web.0
        2022-11-27 12:58:39.818	error	8 - at e.view.e.template (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1401:47)
        web.0
        2022-11-27 12:58:39.816	error	7 - at Function.renderAs (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1465:39)
        web.0
        2022-11-27 12:58:39.813	error	6 - at Function.renderTo (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
        web.0
        2022-11-27 12:58:39.812	error	5 - at r (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1370:29)
        web.0
        2022-11-27 12:58:39.810	error	4 - at t.template.fn (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2223:26)
        web.0
        2022-11-27 12:58:39.808	error	3 - at n.render (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2229:46)
        web.0
        2022-11-27 12:58:39.806	error	2 - at Object.eval (tplTwSimpleClock.js:3:34)
        web.0
        2022-11-27 12:58:39.805	error	1 - at Object.startTime (<anonymous>:170:17)
        web.0
        2022-11-27 12:58:39.803	error	0 - ReferenceError: _setTimeout is not definedReferenceError: _setTimeout is not defined
        web.0
        2022-11-27 12:58:39.801	error	can't render tplTwSimpleClock w00009 on "Tabs":
        web.0
        2022-11-27 12:58:35.045	error	Cannot find search "chart" in "system"
        web.0
        2022-11-27 12:58:27.525	error	Cannot find search "chart" in "system"
        web.0
        2022-11-27 12:57:44.959	error	Cannot find search "chart" in "system"
        • Feuersturm
          Feuersturm @amg_666 last edited by
          @amg_666 ist ja auch erst in der 2.0.8 gefixt die noch nicht auf npm liegt.
          • Feuersturm
            Feuersturm last edited by
            @sigi234 sagte in Test Adapter vis 2.0 (Alpha):
            Die neuen Widgets tauchen bei mir nicht auf (bei Palette). Wurden installiert, update gemacht unter Adapter sind sie aber da.
            Ist bei mir mit vis-2-beta v2.0.7 auch so. Legst du ein issue an?
              GiB64 last edited by GiB64
              ich habe beim installieren irgendwas von Info: www not found gesehen, da es Info war, ignoriert. Wenn ich Vis starte kann ich irgendwie keine Widgets und Co aufrufen. Irgenwie scheinen Icons zu fehlen und nach klicken passiert auch nichts...
              VG GiB
              edit: es sieht irgendwie komisch aus und mit den Icons ist auch nicht viel nazufangen. Sehen alle 3 auch gleich aus in den Eigenschaften... Wie kann ich die Installation am besten wiederholen bzw. reparieren?
                @apollon77 so ich habe den fehler gefunden warum ich immer ein schwarzen bildschirm bekomme wenn ich es importiere.
                ich habe mehrere widgets gruppiert, zu einem.
                wenn ich die gruppierung aufhebe klappt auch alles, man darf es nicht gruppiert exportieren und dann importieren.
                Chaot apollon77 joergeli 3 Replies Last reply Reply Quote 0
                • Chaot
                  Chaot @denjo last edited by
                  @denjo Autsch! Dann wird das bei mir auch so sein. Ich habe fast überall mit Gruppen gearbeitet.
                    denjo @Chaot last edited by
                    @chaot ja ich auch viel, und guck gerade was ich alles gruppiert habe aber finde nicht alles 😄
                    • Feuersturm
                      Hmm, ich habe bei mir auch einige Elemente gruppiert und keine Probleme beim Import gehabt. Ergänze aber mal deine Infos beim issue das bluefox sich das noch einmal näher ansehen kann.
                        denjo @Feuersturm last edited by
                        @feuersturm ja hab ich schon gemacht. ich habe es bei mir mehrfach ausprobiert und es klappt nicht wenn es gruppiert ist
                        • Chaot
                          @denjo Ich habe auch sehr viel mit den vis-inventwo Widgets gearbeitet. Dort werden die Widgets allesamt fehlerhaft übernommen. Alle eingebauten Bindings sind weg usw.
                          Sieht in dem Fall nach einem kompletten Neubau aus.
                          @apollon77 Wie im Eröffnungstread beschrieben soll VIS2 einfacher und leichter werden. Den Eindruck habe ich ehrlich gesagt nicht so. Es wirkt eher komplizierter und überladener. Mal schauen wie das wirkt wenn ich mal versuchen werde eine komplette View neu zu erstellen.
                          Was ich allerdings jetzt schon vermisse ist ein deutlich sichtbarer Knopf zum zwischenspeichern.
                          Ich habe auch das Konzept noch nicht so ganz verstanden. Meine Projekte sind jeweils Views mit einer Navigationsstruktur. Hier scheinen die Projekte immer die Einzelseiten zu sein oder verstehe ich das falsch?
                          In dem Fall kann bei mir der Import kaum klappen. Ich habe innerhalb der Projekte alle einzelnen Views mit dem gleichen Namen angelegt. Also die Startseite heißt immer "Info", hat aber unterschiedliche Inhalte, je nach Gerät.
                          D apollon77 2 Replies Last reply Reply Quote 0
                            @chaot ja sehe ich fast genau so wie du.
                            ich finde es bis jetzt auch komplizierter aber wollen wir mal abwarten.
                            für mich kommt ein ganz neuer aufbau nicht wirklich in frage.
                            seid dem ich iobroker habe baue ich meine vis immer hin und her und das war nun mal jahre lange arbeit.
                            entweder der import klappt reibungsfrei oder dann eben nicht.
                            aber wie gesagt mal abwarten.
                              apollon77 @GiB64 last edited by
                              @gib64 www nor found wäre ok
                                apollon77 @denjo last edited by
                                @denjo bitte auf github melden als issue
                                  @apollon77 hab ich in mein issus hinzugefügt
                                    @denjo und vllt ans issue so ein gruppiertes Projekt file mal anhängen was nicht geht.
                                      apollon77 @Chaot last edited by
                                      @chaot formal ist vis2 allen voran ein rewrite auf neuer technischer Basis weil vis1 leider auch „in die Jahre gekommen war“. Heutzutage ist die Technik im einiges weiter - erst recht für Widgets.
                                      Jetzt müssen wir gemeinsam schauen das alles wieder funktioniert. Also bitte gebt euer Feedback konstruktiv als GitHub issues.
                                      Ich denke das ein gewisser Teil der Themen auch (wieder) daher kommt das Vis 1 sehr viel ermöglicht hat und die Profis von euch auch alle Optionen ausgenutzt haben 😉 wie sich das mit den Herausforderungen der neuen Technik passt ist jetzt etwas was man sehen muss.
                                        @denjo @Chaot was genau ist denn das was „komplizierter“ ist?
                                        • Chaot
                                          Chaot @apollon77 last edited by
                                          @apollon77 Ich habe noch nicht verstanden wie ich meinen bisherigen Aufbau der Projekte umsetzen kann.
                                          Das ist nach meinem Gefühl alles Andere als Intuitiv aufgebaut.
                                          Wie macht man jetzt eine VIS mit Unterseiten?
                                          Ist das so wie ich oben geschrieben habe das die Unterseiten jetzt Projekte sind?
                                          Ich verstehe ja auch das das veraltet war und neu gemacht werden sollte. Vor allem die responsive Anpassung ist hier wirklich interessant. Das ist auch wirklich kein Vorwurf von mir wenn ich das momentan noch als schwierig ansehe.
                                          Mein Gefühl sagt mir aber das es wohl zu einigen "Verlusten" kommen wird was aus der alten VIS nicht umsetzbar sein wird.
                                          Ist aber auch nicht so schlimm wenn es dann besser wird.
                                          apollon77 Feuersturm 2 Replies Last reply Reply Quote 1
                                            apollon77 @Chaot last edited by apollon77
                                            @chaot sagte in Test Adapter vis 2.0 (Alpha):
                                            ich bin ehrlich: Da ich kein "vis power user bin" kann ich leider zu Deiner Frage nichts sagen. Ich schaue mal ob Bluefox es versteht ... sonst gilt denke ich "Bilder > 1000 Worte" 🙂
                                            EDIT: Antwort Bluefox: die Einzelseiten zu sein oder verstehe ich das falsch? => das funktioniert noch nicht das mann zwischen views umschalten kann. Deswegen vermutlich ... klingt so als kommt da noch was 🙂 -> Issue anlegen bitte
                                            780
                                            261729
