    4. Test Adapter vis 2.0 (Alpha)
      apollon77 @bahnuhr last edited by
      @bahnuhr Und ds hier sieht voll ok aus ... die "INFO" ist was es sagt eine "INFO" 🙂
      • bahnuhr
        energy
        dieter@iobroker:/opt/iobroker$ npm i iobroker.vis-2-widgets-energy
        added 1 package in 12s
        163 packages are looking for funding
          run `npm fund` for details
        dieter@iobroker:/opt/iobroker$ iob add vis-2-widgets-energy
        host.iobroker install adapter vis-2-widgets-energy
        upload [0] vis-2-widgets-energy.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-energy/admin/vis-2-widgets-energy.png vis-2-widgets-energy.png image/png
        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-2-widgets-energy/www" was not found! Nothing was uploaded or deleted.
        Adapter "system.adapter.vis.0" restarted.
        Adapter "system.adapter.vis-2-beta.0" restarted.
        host.iobroker object system.adapter.vis-2-widgets-energy created/updated
        host.iobroker create instance vis-2-widgets-energy
        host.iobroker object system.adapter.vis-2-widgets-energy.0 created
        • bahnuhr
          gauges
          dieter@iobroker:/opt/iobroker$ npm i iobroker.vis-2-widgets-gauges
          dieter@iobroker:/opt/iobroker$ iob add vis-2-widgets-gauges
          host.iobroker install adapter vis-2-widgets-gauges
          upload [0] vis-2-widgets-gauges.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-gauges/admin/vis-2-widgets-gauges.png vis-2-widgets-gauges.png image/png
          INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-2-widgets-gauges/www" was not found! Nothing was uploaded or deleted.
          host.iobroker object system.adapter.vis-2-widgets-gauges created/updated
          host.iobroker create instance vis-2-widgets-gauges
          host.iobroker object system.adapter.vis-2-widgets-gauges.0 created
          • bahnuhr
            bahnuhr Forum Testing Most Active last edited by bahnuhr
            Und irgendwie hab ich diese material jetzt 4 x bei den Instanzen.
            Kann doch nicht stimmen.
            Edit:
            Habe 3 x gelöscht.
              @bahnuhr Naja das "add" darfste am ende nur einmal pro adapter ausführen weil es sonst immer eine neue Instanz anlegt.
              • bahnuhr
                bahnuhr Forum Testing Most Active @apollon77 last edited by
                @apollon77 sagte in Test Adapter vis 2.0 (Alpha):
                Jo, hab ich dann auch gemerkt.
                • bahnuhr
                  So, ganz adhoc was mir aufgefallen ist.
                  Die ca. 50 views in meiner main hat er wohl komplett übernommen.
                  Es war aber nur 1 sichtbar.
                  Links oben konnte man dann die einzelnen wieder sichtbar machen.
                  Bei vis.1 konnte man mit dem Mausrädchen in den views nach rechts oder links fahren:
                  Dies geht nun nicht mehr.
                  Wie kommt man nun an die rechten views ?
                  Nachtrag:
                  Das geht so gar nicht.
                  Damit kann man nicht mehr vernünftig arbeiten.
                  (oder ich habs nicht gerafft)
                  bahnuhr apollon77 2 Replies Last reply Reply Quote 0
                  • bahnuhr
                    auch wurden keine css Befehle übernommen.
                    Ich hatte da in vis1 jede Menge drin.
                    In vis2 steht gar nichts.
                    • bahnuhr
                      auch stehen jetzt überall die widget Nr.
                      Wo kann man dies ausschalten.
                      liv-in-sky apollon77 3 Replies Last reply Reply Quote 1
                        liv-in-sky @bahnuhr last edited by
                        @bahnuhr
                        da 🙂
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @bahnuhr last edited by
                          @bahnuhr sagte in Test Adapter vis 2.0 (Alpha):
                          Nachtrag:
                          Nochmal. Es kann doch nicht sein, dass ich erst 30 Views ausschalten muss um an die rechten Views zu kommen !
                          Überseh ich irgendwas ?
                            @bahnuhr
                            dafür weiß ich nicht, wie man den roten balken wegbekommt - zeigt wohl die breite der seite an
                            bahnuhr crunchip 2 Replies Last reply Reply Quote 0
                              liv-in-sky last edited by
                              wie schauen eure hintergründe aus ?
                              etwas seltsam bei mir
                              bahnuhr 1Topf 2 Replies Last reply Reply Quote 0
                              • Feuersturm
                                Feuersturm last edited by
                                Schau einmal, ob dir dieses issue weiterhilft und wenn es thematisch passt gerne dort einen Daumen hoch oder es ergänzen
                                https://github.com/ioBroker/ioBroker.vis/issues/579
                                Feuer-sturm created this issue in ioBroker/ioBroker.vis
                                open Add Button for switching < > between different views and switch focus to selected page #17
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @Feuersturm last edited by
                                  @feuersturm
                                  Ja, habe auch meinen Text dort hin geschrieben.
                                  Daumen hoch habe ich nicht gefunden, wo ist dies ?
                                  • bahnuhr
                                    bahnuhr Forum Testing Most Active @liv-in-sky last edited by
                                    @liv-in-sky sagte in Test Adapter vis 2.0 (Alpha):
                                    Bei mir steht da black. Und so ist es auch.
                                    • bahnuhr
                                      @bahnuhr
                                      roten Balken hab ich nicht.
                                      • bahnuhr
                                        nochwas; hab ja eben vis-2 widgets installiert:
                                        Aber müsste ich diese nicht auch in vis-2 finden ?
                                        Alle 3 sind nicht in der Liste.
                                        apollon77 H 2 Replies Last reply Reply Quote 0
                                          crunchip Forum Testing Most Active @liv-in-sky last edited by
                                          @liv-in-sky wird wohl ein widget sein
                                            liv-in-sky @crunchip last edited by
                                            @crunchip könnte sein, da es nur auf dieser seite ist
                                            780
                                            261889
