    4. Test Adapter vis 2.0 (Alpha)
    • bahnuhr
      energy
      dieter@iobroker:/opt/iobroker$ npm i iobroker.vis-2-widgets-energy
      added 1 package in 12s
      163 packages are looking for funding
        run `npm fund` for details
      dieter@iobroker:/opt/iobroker$ iob add vis-2-widgets-energy
      host.iobroker install adapter vis-2-widgets-energy
      upload [0] vis-2-widgets-energy.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-energy/admin/vis-2-widgets-energy.png vis-2-widgets-energy.png image/png
      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-2-widgets-energy/www" was not found! Nothing was uploaded or deleted.
      Adapter "system.adapter.vis.0" restarted.
      Adapter "system.adapter.vis-2-beta.0" restarted.
      host.iobroker object system.adapter.vis-2-widgets-energy created/updated
      host.iobroker create instance vis-2-widgets-energy
      host.iobroker object system.adapter.vis-2-widgets-energy.0 created
      • bahnuhr
        gauges
        dieter@iobroker:/opt/iobroker$ npm i iobroker.vis-2-widgets-gauges
        dieter@iobroker:/opt/iobroker$ iob add vis-2-widgets-gauges
        host.iobroker install adapter vis-2-widgets-gauges
        upload [0] vis-2-widgets-gauges.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-gauges/admin/vis-2-widgets-gauges.png vis-2-widgets-gauges.png image/png
        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-2-widgets-gauges/www" was not found! Nothing was uploaded or deleted.
        host.iobroker object system.adapter.vis-2-widgets-gauges created/updated
        host.iobroker create instance vis-2-widgets-gauges
        host.iobroker object system.adapter.vis-2-widgets-gauges.0 created
        • bahnuhr
          bahnuhr Forum Testing Most Active last edited by bahnuhr
          Und irgendwie hab ich diese material jetzt 4 x bei den Instanzen.
          Kann doch nicht stimmen.
          Edit:
          Habe 3 x gelöscht.
            apollon77 @bahnuhr last edited by
            @bahnuhr Naja das "add" darfste am ende nur einmal pro adapter ausführen weil es sonst immer eine neue Instanz anlegt.
            • bahnuhr
              bahnuhr Forum Testing Most Active @apollon77 last edited by
              @apollon77 sagte in Test Adapter vis 2.0 (Alpha):
              Jo, hab ich dann auch gemerkt.
              • bahnuhr
                So, ganz adhoc was mir aufgefallen ist.
                Die ca. 50 views in meiner main hat er wohl komplett übernommen.
                Es war aber nur 1 sichtbar.
                Links oben konnte man dann die einzelnen wieder sichtbar machen.
                Bei vis.1 konnte man mit dem Mausrädchen in den views nach rechts oder links fahren:
                Dies geht nun nicht mehr.
                Wie kommt man nun an die rechten views ?
                Nachtrag:
                Das geht so gar nicht.
                Damit kann man nicht mehr vernünftig arbeiten.
                (oder ich habs nicht gerafft)
                bahnuhr apollon77 2 Replies Last reply Reply Quote 0
                • bahnuhr
                  auch wurden keine css Befehle übernommen.
                  Ich hatte da in vis1 jede Menge drin.
                  In vis2 steht gar nichts.
                  • bahnuhr
                    auch stehen jetzt überall die widget Nr.
                    Wo kann man dies ausschalten.
                    liv-in-sky apollon77 3 Replies Last reply Reply Quote 1
                      liv-in-sky @bahnuhr last edited by
                      @bahnuhr
                      da 🙂
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @bahnuhr last edited by
                        @bahnuhr sagte in Test Adapter vis 2.0 (Alpha):
                        Nachtrag:
                        Nochmal. Es kann doch nicht sein, dass ich erst 30 Views ausschalten muss um an die rechten Views zu kommen !
                        Überseh ich irgendwas ?
                          @bahnuhr
                          dafür weiß ich nicht, wie man den roten balken wegbekommt - zeigt wohl die breite der seite an
                          bahnuhr crunchip 2 Replies Last reply Reply Quote 0
                            liv-in-sky last edited by
                            wie schauen eure hintergründe aus ?
                            etwas seltsam bei mir
                            bahnuhr 1Topf 2 Replies Last reply Reply Quote 0
                            • Feuersturm
                              Feuersturm last edited by
                              Schau einmal, ob dir dieses issue weiterhilft und wenn es thematisch passt gerne dort einen Daumen hoch oder es ergänzen
                              https://github.com/ioBroker/ioBroker.vis/issues/579
                              Feuer-sturm created this issue in ioBroker/ioBroker.vis
                              open Add Button for switching < > between different views and switch focus to selected page #17
                              • bahnuhr
                                bahnuhr Forum Testing Most Active @Feuersturm last edited by
                                @feuersturm
                                Ja, habe auch meinen Text dort hin geschrieben.
                                Daumen hoch habe ich nicht gefunden, wo ist dies ?
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @liv-in-sky last edited by
                                  @liv-in-sky sagte in Test Adapter vis 2.0 (Alpha):
                                  Bei mir steht da black. Und so ist es auch.
                                  • bahnuhr
                                    @bahnuhr
                                    roten Balken hab ich nicht.
                                    • bahnuhr
                                      nochwas; hab ja eben vis-2 widgets installiert:
                                      Aber müsste ich diese nicht auch in vis-2 finden ?
                                      Alle 3 sind nicht in der Liste.
                                      apollon77 H 2 Replies Last reply Reply Quote 0
                                        crunchip Forum Testing Most Active @liv-in-sky last edited by
                                        @liv-in-sky wird wohl ein widget sein
                                          liv-in-sky @crunchip last edited by
                                          @crunchip könnte sein, da es nur auf dieser seite ist
                                            @crunchip du hast recht - ist ein image widget mit sichtbarkeit und einem binding in der css klasse
                                            780
                                            261972
