      Matze_HH @Armilar last edited by
      @armilar said in SONOFF NSPanel mit Lovelace UI:
      FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.6.0.tft
      Ok dann mache ich es schon richtig, bekomme aber einen riesen Haufen Fehler 😞
      javascript.0 (689) script.js.NSPanel.Panel_1_3_5: TypeScript compilation failed: "yAxis": "Gas [kWh]", ^ ERROR: Type '{ type: "cardChart"; heading: string; useColor: true; subPage: false; parent: undefined; yAxis: string; yAxisTicks: number[]; items: PageItem[]; }' is not assignable to type 'PageChart'. Object literal may only specify known properties, and '"yAxis"' does not exist in type 'PageChart'. await createAliasAsync(config.weatherEntity + '.ICON', 'accuweather.0.Current.WeatherIcon', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ICON' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP', 'accuweather.0.Current.Temperature', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature', name: 'TEMP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP_MIN', 'accuweather.0.Daily.Day1.Temperature.Minimum', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature.forecast.0', name: 'TEMP_MIN' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP_MAX', 'accuweather.0.Daily.Day1.Temperature.Maximum', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature.max.forecast.0', name: 'TEMP_MAX' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessDay.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_brightnessDay', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessDay.SET', NSPanel_Path + 'NSPanel_Dimmode_brightnessDay', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourDay.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_hourDay', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourDay.SET', NSPanel_Path + 'NSPanel_Dimmode_hourDay', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessNight.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_brightnessNight', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessNight.SET', NSPanel_Path + 'NSPanel_Dimmode_brightnessNight', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourNight.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_hourNight', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourNight.SET', NSPanel_Path + 'NSPanel_Dimmode_hourNight', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'autoUpdate.ACTUAL', NSPanel_Path + 'NSPanel_autoUpdate', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'autoUpdate.SET', NSPanel_Path + 'NSPanel_autoUpdate', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'ipAddress.ACTUAL', NSPanel_Path + 'NSPanel_ipAddress', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.BerryDriver.ACTUAL', NSPanel_Path + 'Berry_Driver.currentVersion', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Uptime.ACTUAL', NSPanel_Path + 'Tasmota.Uptime', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Version.ACTUAL', NSPanel_Path + 'Tasmota.Version', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Hardware.ACTUAL', NSPanel_Path + 'Tasmota.Hardware', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.AP.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.AP', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.SSId.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.SSId', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.BSSId.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.BSSId', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Channel.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Channel', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Mode.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Mode', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.RSSI.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.RSSI', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Signal.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Signal', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.TFTVersion.ACTUAL', NSPanel_Path + 'Display_Firmware.currentVersion', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.Model.ACTUAL', NSPanel_Path + 'NSPanel_Version', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + '.Player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + '.Player.currentAlbum', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + '.Player.currentArtist', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + '.Player.currentTitle', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + '.Player.controlNext', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + '.Player.controlPrevious', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + '.Player.controlPlay', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + '.Player.controlPause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + '.Commands.deviceStop', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + '.Player.currentState', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + '.Player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + 'player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + 'player.album', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + 'player.artistName', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + 'player.trackName', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.CONTEXT_DESCRIPTION', dpPath + 'player.contextDescription', true, <iobJS.StateCommon>{ type: 'string', role: 'media.station', name: 'CONTEXT_DESCRIPTION' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + 'player.skipPlus', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + 'player.skipMinus', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + 'player.play', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + 'player.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + 'player.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + 'player.isPlaying', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + 'player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + '.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + '.current_album', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + '.current_artist', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + '.current_title', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.CONTEXT_DESCRIPTION', dpPath + '.current_station', true, <iobJS.StateCommon>{ type: 'string', role: 'media.station', name: 'CONTEXT_DESCRIPTION' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + '.next', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + '.prev', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + '.play', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + '.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + '.stop', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + '.state_simple', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + '.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. scrSvrBGCol = rgb_dec565(scbackgroundInd1); ^ ERROR: Cannot find name 'scbackgroundInd1'. scrSvrBGCol = rgb_dec565(scbackgroundInd2); ^ ERROR: Cannot find name 'scbackgroundInd2'. scrSvrBGCol = rgb_dec565(scbackgroundInd3); ^ ERROR: Cannot find name 'scbackgroundInd3'. await createAliasAsync(AliasPath + 'Sensor.ANALOG.Temperature.ACTUAL', NSPanel_Path + 'Sensor.ANALOG.Temperature', true, <iobJS.StateCommon>{ type: 'number', 'unit': '°C' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Sensor.ESP32.Temperature.ACTUAL', NSPanel_Path + 'Sensor.ESP32.Temperature', true, <iobJS.StateCommon>{ type: 'number', 'unit': '°C' }); ^ ERROR: Cannot find name 'createAliasAsync'.
      • Armilar
        Armilar Most Active Forum Testing @Matze_HH last edited by Armilar
        @matze_hh
        Ja perfekt. Das Beispiel ist zwar schon drin, aber die cardChart ist noch nicht in der TFT-Firmware. Daher mit der cardChart noch ein wenig warten. Das TS-Script kann das schon, aber das NSPanel ist noch nicht so weit.
        Mit anderen Worten. Die cardChart darf aktuell noch nicht in den Seiten aufgerufen werden.
          @armilar ah, ok. Es läuft aber so erstmal?! 🙂
          Armilar 2 Replies Last reply Reply Quote 0
          • Armilar
            @matze_hh
            Ja, sollte alles wie gewohnt, auch erst abwärtskompatibel laufen.
            Alle anderen beschriebenen Funktionen kannst du natürlich einbauen oder testen. Nur halt die Charts noch nicht.
            In der HMI-DEV ist die schon drin, aber in dem aktuellen TFT-Release noch nicht...
            Kann aber nicht mehr lang dauern.
            • Armilar
              @matze_hh
              Hast du es auch genauso gemacht?
              Den unteren Teil ausgetauscht und nur oben die 3 Screensaver Konstanten hinzugefügt?
              Es dürfte am rechten Rand nichts rot sein.
              Deine alten Variablen und Config bleiben so wie sie sind. Ist dann höchstens 5 Minuten Umstellung auf die neue Version...
              • berlinchris81
                berlinchris81 @Armilar last edited by
                Hi Leute gute Arbeit die Ihr macht - Respect. Ich hab jetzt alle Einstellungen 3 mal gemacht - aber es funktiert nicht - ich hab folgens im log kann aber damit nichts anfangen - icon mapping habe ich eingebunden es wird auch nicht rot unterschrichen. zum einen habe ich ein "Waiting for content" sceen und ich bekommen folgendes im log angezeigt - ich verzweifle langsam
                LG Chris! Ich nutze den IOBroker.2022-11-28 22_39_07-logs - iobroker-iobroker1.png MeineConfig.txt
                K Armilar 2 Replies Last reply Reply Quote 0
                  Kuckuckmann @berlinchris81 last edited by
                  @berlinchris81
                  Hallo und willkommen hier im Forum 🙂
                  Du hast in deiner Config eine cardEntities die keinen Inhalt hat, insofern kann auch nichts angezeigt werden.
                  Da auch dadurch keine Icons definiert sind, kommt es zu Fehlermeldungen. Heißt aber auch im Umkehrschluss, Du hast schon ganz viel richtig gemacht, von Flashen bis hin zu MQTT und so.
                  Schau dir doch mal im Wiki an, wie man so eine Seite mit einem Alias und Icons, etc. bestückt.
                  Wenn Du nicht weiter kommt, gerne nochmal melden.
                  LG
                  • Armilar
                    Armilar Most Active Forum Testing @berlinchris81 last edited by
                    @berlinchris81
                    Irgendwie wird das global-Script des IconsSelector nicht geladen. Das wird auch der Grund sein, warum du aus dem "Waiting for Content" nicht raus kommst. Das TypeScript kompiliert nicht.
                    Mache jetzt Schluss für heute. Ab wann bist du morgen wieder verfügbar? Dann gehen wir es mal zusammen durch und bringen es zum Laufen...
                    Wenn du aus dem Log postest, dann kannst du die Code-Tags 7f6d0fc8-6d7b-4a38-8068-13f5dfecef64-image.png oben in der Menüleiste benutzen. Wird dann für uns einfacher es zu lesen.
                    Wäre noch Interessant zu wissen, welche node.js-Version und welche JS-Adapter-Version du aktuell nutzt.
                    Nach welcher Anleitung bist du vorgegangen?
                    Falls die:
                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation
                    dann hast du die richtige.
                    Ab Punkt 8 wird das IconScript beschrieben. Es muss im "global"-Verzeichnis liegen. Unter github liegen zwei. Ein IconScript für TypeScript (muss als TypeScript angelegt sein) oder alternativ ein IconScript für JS (muss dann als JavaScript angelegt sein, es wurde für eine fehlerbehaftete Version des JS-Adapters abgelegt). Könntest sonst mal beide Varianten versuchen.
                    Auf der anderen Seite, möchte der Kompiler eine Version aus dem Speicher benutzen. Sagt mir an erster Stelle mal, dass es schon mal funktioniert hat. Stimmt das?
                    berlinchris81 1 Reply Last reply Reply Quote 0
                    • berlinchris81
                      berlinchris81 @Armilar last edited by berlinchris81
                      @armilar
                      Der Tipp mit der icons Datei hat funktioniert - er ist aus dem scenn raus. Danke schön. Jetzt kann ich weiter probieren. Toll. Aller Dings nur mit der Notlösung ... JS Script und ich habe jetzt neue Warnungen drin, die sind zwar "nur" Warungen aber vielleicht interessierts euch.
                      JS Adapter: v6.14
                      Node JS weiß ich nicht läuft in nem Docker container.
                      Ich muss jetzt erstmal Arbeiten - melde mich dann.
                      • Markus S.
                        Markus S. @Wuschl last edited by
                        @wuschl Leider auch kein Erfolg, trotzdem Danke! Es scheint, dass das Display keine Antwort mehr gibt...
                          carlos @Armilar last edited by
                          @armilar
                          Super, danke funktioniert wieder alles wie vorher.
                          Gute Arbeit, ich muss hier auch mal ein großes Lob loswerden
                          • Markus S.
                            Markus S. last edited by
                            Danke an @joBr99 - es geht wieder! Jetzt kann ich weiter machen!
                            J M 2 Replies Last reply Reply Quote 0
                              SuFra last edited by
                              Hallo
                              Ich versuche gerade ein 2. Panel in Betrieb zu nehmen scheitere aber massiv.
                              Das erste läuft mit der Script Version v3.4.0.5 problemlos.
                              Das 2. habe ich jetzt mit der neuen Version versucht, bekomme jedoch jede Menge Compiler Fehler.
                              Ich denke es liegt an meiner Javasript Version, V6.0.3.
                              Ich möchte jedoch nicht auf eine Beta des Javascript Adapters umsteigen.
                              Welche Möglichkeit habe ich das 2. Panel in Betrieb zu nehmen?
                              • Armilar
                                Armilar Most Active Forum Testing @SuFra last edited by
                                @sufra
                                Musst du auch nicht. Habe auch unterschiedlichste Versionen im Einsatz, jedoch sollte die JS-Adapter-Version ab Script 3.5.0.5 mindestens 6.1.3 sein. Es werden im TS-Script Funktionen genutzt, die erst ab v6.1.3 zur Verfügung stehen.
                                Ich würde den aber in jedem Fall Updaten, denn deine 6.0.3 Version ist bei Type-Script fehlerbehaftet.
                                Also in Kombination damit sollte deine node.js bestenfalls auch aktuell auf der 16.18.1 sein.
                                Da die JS-Adapter-Version 6.1.4 bereits raus ist, kann dich die gar nicht sagen, ob die 6.1.3 überhaupt noch eine BETA ist?
                                Als Alternative kannst du natürlich auch eine ältere Version des TS-Scriptes verwenden. Wäre dann die 3.5.0.4 aus der Historie:
                                https://github.com/joBr99/nspanel-lovelace-ui/tree/2bf1c9b49c0fc874bef29df8ffebebec59e6499d/ioBroker
                                  SuFra @Armilar last edited by
                                  @armilar
                                  node.js ist auf v16.18.1
                                  Als Stable wird nur die V6.0.3 des JS Adapters angezeigt.
                                  Probiere mal die 3.5.0.4, Danke
                                  • Armilar
                                    @sufra
                                    Ja, habe eben auch noch nachgesehen
                                      joBr99 last edited by
                                      Hey,
                                      als Warnung mit der aktuellen DEV Version von Tasmota funktioniert das Flashen der Nextion Firmware nicht mehr. Aktuelles Release (12.2.0) funktioniert noch.
                                      https://github.com/joBr99/nspanel-lovelace-ui/issues/601
                                      joBr99 created this issue in joBr99/nspanel-lovelace-ui
                                      closed [BUG] Flashing Issues on Tasmota >= 12.2.0.3 #601
                                      Armilar J 2 Replies Last reply Reply Quote 1
                                      • Armilar
                                        Armilar Most Active Forum Testing @joBr99 last edited by
                                        @jobr99 sagte in SONOFF NSPanel mit Lovelace UI:
                                        mit der aktuellen DEV Version (12.2.0.3) von Tasmota funktioniert das Flashen der Nextion Firmware nicht
                                        Danke für die Info... wird ne Menge Fragen klären... 👍
                                          @armilar
                                          Danke erstmal.
                                          Das 2. Panel zeigt was an 🙂
                                          Ist zwar noch ne Warnung im Log, lüppt aber.
                                          • Armilar
                                            @sufra
                                            Welche Warnung?
                                            lovelace ui nspanel sonoff
                                            271
                                            7725
                                            6639540
