    4. JavaScript
    5. JS Denon Lautstärke bei bestimmten Eingang
    • Codierknecht
      Codierknecht Developer Most Active @Olli_M last edited by
      @olli_m
      Du hast nicht zufällig ein maximumVolume gesetzt?
      Ich frag' ja nur 😉
      Codierknecht Olli_M 2 Replies Last reply Reply Quote 0
      • Codierknecht
        Codierknecht Developer Most Active @Codierknecht last edited by Codierknecht
        @codierknecht
        Das Ding scheint 'ne echte Diva zu sein.
        Jetzt funzt es bei mir auch nicht mehr 😞
        Das hier tut's aber 😉
         <variables>
           <variable id="5~xh-?;TS9,5KS_/-07*">targetVolume</variable>
           <variable id="A.Rs{g/EU:Ph/71|CWS/">currentVolume</variable>
         </variables>
         <block type="on" id="Qg*QqD$8?8~`gt-#{+Uv" x="-762" y="213">
           <field name="OID">denon.0.zoneMain.selectInput</field>
             <block type="logic_switch_case" id="$-xT(}G!;^Rhfn~C+qXy">
               <mutation xmlns="http://www.w3.org/1999/xhtml" case="1" default="1"></mutation>
               <value name="CONDITION">
                 <block type="on_source" id="XOJ)BT,5+JK{Ep}u:DgJ">
               <value name="CASECONDITION0">
                 <block type="text" id="iKt?pT#y#d^t;(qBAP)?">
                   <field name="TEXT">TV</field>
               <statement name="CASE0">
                 <block type="variables_set" id="jXxO~utV|*?`t5D*P2!#">
                   <field name="VAR" id="5~xh-?;TS9,5KS_/-07*">targetVolume</field>
                     <block type="math_number" id="F4k;tW%`{9C_dbbFpW_A">
                       <field name="NUM">40</field>
               <value name="CASECONDITION1">
                 <block type="text" id="XoQU?]=`=brB~]w*fb43">
                   <field name="TEXT">BD</field>
               <statement name="CASE1">
                 <block type="variables_set" id="7,Tp8/8r|C`xu1(:A=|S">
                     <block type="math_number" id="9U[v4SCwpJluu:hhVsB-">
                       <field name="NUM">30</field>
               <statement name="ONDEFAULT">
                 <block type="variables_set" id="yoi3,CobN5s_TS.sqMyU">
                     <block type="math_number" id="u`,|ZlF]Q4bpcXd{*AuJ">
                       <field name="NUM">20</field>
                 <block type="variables_set" id="osxOG.[KLnSG7ncimK9K">
                   <field name="VAR" id="A.Rs{g/EU:Ph/71|CWS/">currentVolume</field>
                     <block type="get_value" id="tDKFWZ?Lnf!s;z]6duv*">
                       <field name="OID">denon.0.zoneMain.volume</field>
                     <block type="controls_if" id="o182j6K5HuPh(E!4_EL(">
                         <block type="logic_compare" id="/+c=)+r9,saKPF){J~2=">
                           <field name="OP">GT</field>
                             <block type="variables_get" id="d,pLx8:vD48M/mPL+-`|">
                             <block type="variables_get" id="kQP^9}$c@!|G9sJmz!3~">
                         <block type="controls_whileUntil" id="$OY{R7yrx9}CN!k+GO+)">
                           <field name="MODE">UNTIL</field>
                           <value name="BOOL">
                             <block type="logic_compare" id="{o,N/`w:sRh]!?h0nK9q">
                               <field name="OP">EQ</field>
                                 <block type="get_value" id="YFAPYX:=(~ttyJuG3d5z">
                                 <block type="variables_get" id="[BO/natbiL`R@ilrhUYx">
                           <statement name="DO">
                             <block type="toggle" id="5bw,3.`-PV)Sm8fj~k70">
                               <field name="OID">denon.0.zoneMain.volumeDown</field>
                                 <block type="timeouts_wait" id="Y+2p:Q$pK4q$.M}(QCU.">
                                   <field name="DELAY">100</field>
                                   <field name="UNIT">ms</field>
                       <value name="IF1">
                         <block type="logic_compare" id="Rix$S*%;kI3muhl7Ah+=">
                           <field name="OP">LT</field>
                             <block type="variables_get" id="X#R[CVv_rhh%BNV+I$u8">
                             <block type="variables_get" id="`W!Or8Z/78{7xR.,-=L2">
                       <statement name="DO1">
                         <block type="controls_whileUntil" id="hr8Ebj)B-o/FT{vM9I,H">
                           <value name="BOOL">
                             <block type="logic_compare" id="3D@j$ZP;OpY,wS!hL6N@">
                                 <block type="get_value" id="wcGqpl!UcW[#RE?xvKg^">
                                 <block type="variables_get" id="%Pd*+k/r`*,;$`jG]q#y">
                             <block type="toggle" id="-5=q)/:k|MSB6JztqYw2">
                               <field name="OID">denon.0.zoneMain.volumeUp</field>
                                 <block type="timeouts_wait" id="EyUqTy?kQq2]5Gx{PS;G">
        Olli_M 1 Reply Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Negalein last edited by
          @negalein sagte in JS Denon Lautstärke bei bestimmten Eingang:
          aber funktioniert mit Math nicht.
          Mit Text schon.
          jetzt habe ich mal in mein Uraltskript gesehen
          da ist ne Zahl, allerdings ohne Dezimale
          • Negalein
            Negalein Global Moderator @Homoran last edited by
            @homoran sagte in JS Denon Lautstärke bei bestimmten Eingang:
            komisch
            ich habs mit und ohne Komme probiert.
            Wollte mit Maths nicht. Mit Text schon.
            • Olli_M
              Olli_M @Codierknecht last edited by
              @codierknecht
              MaximumVolume ist eh gelockt was ich bei mir sehe
              • Olli_M
                @codierknecht
                also mit diesem hier geht es von dir. Allerdings dauert es halt bzw. sieht man wie er hochregelt. Er macht also keinen direkten Sprung auf die Zahl. Aber besser als nix. Danke dir 🙂
                mit dem anderen Fallsobjekt und egal ob Math oder Text Baustein hat der Denon bei mir auch nichts gemacht.
                • Olli_M
                  Olli_M @Negalein last edited by
                  @negalein
                  bei mir ging mit text leider auch nicht. Habe jetzt den Code von @Codierknecht genommen. da gehts irgendwie
                  • Codierknecht
                    @olli_m sagte in JS Denon Lautstärke bei bestimmten Eingang:
                    Wie gesagt: Ist 'ne kleine Diva.
                    Mal geht's - mal geht's nicht. Eine Regelmäßigkeit oder gar eine echte Ursache habe ich nicht herausgefunden.
                    Ich persönlich finde das mittlerweile sogar angenehmer 😉
                    Kannst ja mal mit den Timeouts spielen. Aber bei zu kleinen Werten kann's Probleme geben.
                    Olli_M 1 Reply Last reply Reply Quote 1
                    • Olli_M
                      @codierknecht
                      ja werde ich vielen Vielen dank nochmal für das Blockly.
                      • Negalein
                        Denon ist bestimmt ne Frau. 😉
                        Den ganzen Tag funktionierte es mit Text.
                        Jetzt bildet sie sich ein, sie will keinen Text mehr! 😂
                        You are assigning a string to the state "denon.0.zoneMain.volume" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
                        Echt so ne kleine Zicke! 😂😂😂
                        Dann bekommt sie eben jetzt den @Codierknecht an ihre Seite. 😉
                          emil70 last edited by
                          Wenn ich das hier Richtig gelesen habe, geht es um die Lautstärkenangabe mit z.B 45.x
                          Das geht bei mir mit
                          • Codierknecht
                            Codierknecht Developer Most Active @emil70 last edited by
                            @emil70 sagte in JS Denon Lautstärke bei bestimmten Eingang:
                            Ja, aber nur solange die Zicke mitspielt 😁
                            • Negalein
                              Negalein Global Moderator @Codierknecht last edited by
                              @codierknecht sagte in JS Denon Lautstärke bei bestimmten Eingang:
                              jetzt spinnt sie komplett. 😉
                              Sie regelt beim umschalten auf zB BD nicht auf die eingestellten 30, sondern fährt bis 0.
                              Musste das Blockli stoppen um wieder hochregeln zu können.
                              • Olli_M
                                @negalein
                                Ging mir gestern ähnlich sie wollte dauernd die Lautstärke erhöhen 😂😂😂
                                • Negalein
                                  Negalein Global Moderator @Olli_M last edited by
                                  da bin ich ja noch gut davon gekommen! Anders wären meine Eltern im Bett gestanden! 😂😂😂
                                  • Olli_M
                                    @negalein
                                    Also dieser Denon schafft mich 🙄
                                    Habe folgendes Blockly und wird aber nicht ausgeführt:
                                      <block type="on" id="la_5*4UcUDGwK2hyhAV_" x="113" y="213">
                                          <block type="controls_if" id="4oleqUtSvv)~3[WUWy-a">
                                              <block type="logic_compare" id="{0k_%qX)vT|(Rz`68lJ1">
                                                  <block type="on_source" id="]^)HCYFu$+N.H7~~-O/Y">
                                                    <field name="ATTR">id</field>
                                                  <block type="text" id="P;jKGrZYTEu[#!qM)-6{">
                                                    <field name="TEXT">GAME</field>
                                              <block type="control" id="KMz~?WBeT@Alyl-w@a,J">
                                                <field name="OID">alexa2.0.Smart-Home-Devices.ea6ac744-236f-46c4-acdf-b3ad24fe49f1.active</field>
                                                  <block type="logic_boolean" id="i6:+t,HdAn0BMvx!+w{o">
                                    • Olli_M
                                      Olli_M @Olli_M last edited by
                                      @olli_m
                                      habs auch gerade mit Wert statt Objekt Id probiert, funktioniert auch nicht...
                                      • Olli_M
                                        @olli_m
                                        okay mit dem Falls Objekt geht es... mhh verrückt 🙂
                                        • Olli_M
                                          @olli_m
                                          Wobei er jetzt doch wieder nicht geschalten hat, hat jemand eine Ahnung? Blockly falsch?
                                          Codierknecht E 2 Replies Last reply Reply Quote 0
                                          • Codierknecht
                                            Das Blockly ist so kurz - was soll daran falsch sein?
                                            Wobei ich persönlich für nur 1 Objekt den anderen Trigger verwenden würde
                                            Der Denon ist halt 'ne Diva ... mal mag er mit uns sprechen, mal nicht 😞
                                            1.0k
                                            5080
