    4. Test Adapter Govee v0.0.x
    • Olli_M
      Olli_M @kimukao last edited by
      @kimukao
      Hi, mit welchem Befehl steuerst du denn über Alexa? über eine erstellte Szene über die Tap to Run funktion? wenn ja wie?
      Ich bekomme zwar die Szene über Alexa an aber nicht mehr aus 😞
        jensven @jensven last edited by jensven
        @nbuenger
        govee.0
        2022-11-22 20:15:25.279	error	Error: Request failed with status code 429
        govee.0
        2022-11-22 20:15:15.182	error	Error: Request failed with status code 429
        govee.0
        2022-11-22 20:15:05.196	error	Error: Request failed with status code 429
        govee.0
        2022-11-22 20:14:55.201	error	Error: Request failed with status code 429
        govee.0
        2022-11-22 20:14:45.225	error	Error: Request failed with status code 429
        govee.0
        2022-11-22 20:14:35.306	error	Error: Request failed with status code 429
        govee.0
        2022-11-22 20:14:25.211	error	Error: Request failed with status code 429
        govee.0
        2022-11-22 20:14:15.223	error	Error: Request failed with status code 429
        govee.0
        2022-11-22 20:14:05.177	error	Error: Request failed with status code 429
        Der Adapter füllt mir gerade den Log mit diesem Error. Die Lichtleiste war dabei die ganze Zeit in Aktion (Ambilight)
        (edit)
        Habe jetzt mal noch den "Expert " eingeschaltet
        govee.0
        2022-11-22 20:18:48.413	error	Error: Request failed with status code 429
        govee.0
        2022-11-22 20:18:48.109	info	check group user admin group admin: false
        govee.0
        2022-11-22 20:18:48.103	info	check user admin pw iobroker: true,system.user.admin
        govee.0
        2022-11-22 20:18:47.827	info	Govee API Key: *******************************7904
        govee.0
        2022-11-22 20:18:47.826	info	Refresh interval set to: 10 seceonds
        govee.0
        2022-11-22 20:18:47.824	info	Private mode is enabled (senstive data will not shown in log output)
        govee.0
        2022-11-22 20:18:47.823	info	Expert log enabled
        govee.0
        2022-11-22 20:18:47.776	info	starting. Version 0.0.6 (non-npm: nbuenger/ioBroker.govee#73ec80b6350890015d95428dd3bbd3f72417a073) in /opt/iobroker/node_modules/iobroker.govee, node: v16.18.1, js-controller: 4.0.23
        Edit die 2.
        Nachdem der Adapter neu gestartet wurde kam die Fehlermeldung nur einmalig. Werde mich morgen diesbezüglich nochmals melden
        nbuenger 1 Reply Last reply Reply Quote 0
        • nbuenger
          nbuenger Developer @Olli_M last edited by
          @olli_m
          Leider verstehst du das Richtig. Ich kann nur die API nutzen um die Daten abzufragen und die sind wieso auch immer bei Govee eingeschränkt. der Alexa Support wurde von Govee selbst integriert daher geht dort natürlich mehr.
          Hoffe trotzdem das der neue Adapter eure Anforderungen erfüllen wird.
          • nbuenger
            nbuenger Developer @jensven last edited by
            @jensven
            Der Adapter wirft bei dir den Fehler 429 aus. Das bedeutet das die Maximale Anzahl an API Requests erreicht wurde. Die API ist auf 10000 Requests pro Tag pro API Key reduziert. Zusätzlich kann man nur Maximal 10 Anfrage pro Minute pro Gerät stellen.
            Diese wirst du leider erreicht haben. Ich arbeite aber an einer Lösung diesen Fehler zu vermeiden damit die Logs nicht mehr zugemüllt werden.
            Den Adapter den du jetzt gerade nutzt ist nicht mehr auf dem aktuellen Stand. Das heißt Fehler können leider noch auftreten.
              kimukao @Olli_M last edited by kimukao
              @olli_m Ich steuere aktuell über Alexa TextCommand im Blockly (zB „lyra an“). Nicht schön, aber funktioniert…
              Olli_M 1 Reply Last reply Reply Quote 0
              • Olli_M
                @kimukao
                Aber aus bekommt man die Szene nicht oder kann das sein ?
                • nbuenger
                  nbuenger Developer last edited by nbuenger
                  Moin an alle,
                  kurzes Update für euch:
                  Wenn ich jetzt alles hin bekomme dann sollte im laufe der Woche das API Testing Tool online gehen.
                  Da könnt ihr eure API Keys einmal durchjagen.
                  Dort werden euch dann eure Geräte angezeigt und noch ein paar Infos.
                  Im Hintergrund hängt eine Datenbank bei der ihr die Möglichkeit habt mit einen Button Klick eure Geräte zu speichern. Modelle die einmal bereits von einer Person übermittelt wurden könnt ihr nicht noch einmal eintragen lassen.
                  Diese Datenbank ist wichtig denn dadurch kann ich erfassen welches Gerät was kann dies wurde im ersten Adapter automatisch ermittelt. Das hat aber nicht immer so gut funktioniert.
                  Euch wird in dem Tool auch euer Gerätename und die ID angezeigt. Diese werden selbstverständlich nicht von mir gespeichert.
                  Folgende Daten werden gespeichert wenn ihr diese übermittelt: Das Model, Ob das Gerät steuerbar ist, ob das Gerät den aktuellen Status übermittelt kann, welche Befehle das Gerät unterstützt und wenn es die Funktion hat die Farbtemperatur zu ändern dann werden die Min und Max Werte gespeichert.
                  Mit jedem Gerät was in der Datenbank aufgenommen wird wird der Adapter ein Stück besser. Ich werde nur Geräte in den Adapter aufnehmen die in der Datenbank sind. Damit der Adapter bestmöglich funktionieren kann.
                  Lasst mir gerne eure Gedanken da und dann hört ihr im laufe der Woche von mir.
                  Schönen Abend euch allen.
                  Jens Krimmel Olli_M H 3 Replies Last reply Reply Quote 3
                  • Jens Krimmel
                    Jens Krimmel @nbuenger last edited by
                    @nbuenger
                    Was für ein Zufall. War gerade auf der Suche nach einem Adapter und habe diesen Thread gefunden.
                    Stelle mich auch gerne zum Testen zur Verfügung (habe derzeit „nur“ eine Lyra, aber da kommt sicher noch was nach 😉
                    • Olli_M
                      Olli_M @nbuenger last edited by Olli_M
                      @nbuenger
                      ja super vielen Dank 🙂
                      Darf ich mal in die Runde frage wer mit Alexa Command aktuell noch steuert?
                      Vor allem diese Befehle:
                      Alexa, set [device] to[scene]
                      Alexa, set Music mode of [device name] to [music mode name]
                      Alexa, set Scene mode of [device name] to [scene mode name]
                      Bekomme ich auf deutsch für Alexa nicht hin, hat die schon jemand versucht?
                      Olli_M 1 Reply Last reply Reply Quote 1
                      • Olli_M
                        Olli_M @Olli_M last edited by Olli_M
                        Auch interessant:
                        https://github.com/towlerj/govee_api
                        https://pypi.org/project/govee-api-ble/
                        Hier arbeiten sogar mehre dran:
                        https://github.com/bwp91/homebridge-govee/tree/c4790f81de4071b17b4b2671630a9e30904301bb
                        Vielleicht lässt sich daraus zusammen was machen oder mehr informationen sammeln, wenn eh schon andere Leute auch daran arbeiten. Der letzte sogar mit Userdaten.
                          helfi9999 @nbuenger last edited by
                          @nbuenger sagte in Test Adapter Govee v0.0.x:
                          Moin an alle,
                          Hi hat sich bei dir schon was getan kann man schon testen ??
                          • nbuenger
                            nbuenger Developer @helfi9999 last edited by
                            @helfi9999
                            Moin ich hatte leider etwas Probleme mit dem Server für das API Tool die Datenbank ist leider Fehlerhaft. Ich hoffe das ich die Fehler heute behoben bekomme dann geht das API Tool online.
                            Der Adapter dauert derzeit noch etwas länger ich bin mit Govee in Kontakt wegen der API Beschränkungen.
                            Da warte ich noch auf eine Rückmeldung. Wenn ich da Neues habe lasse ich euch das sofort wissen.
                            Olli_M 3 Replies Last reply Reply Quote 1
                            • Olli_M
                              @nbuenger
                              Ja super
                              Hab dir mal als pn noch die Login Adresse von govee geschickt
                              Hab nur zu wenig Ahnung wie man da Daten abrufen und senden kann sonst würde ich es selbst probieren
                              • Olli_M
                                @nbuenger
                                Guten Morgen,
                                ich hab jetzt mal etwas selbst rumprobiert und mir Postman auf dem Handy installiert, was die HTTP Request trackt.
                                HTTP/1.1 200 OK
                                Date: Sat, 03 Dec 2022 08:59:23 GMT
                                Content-Type: application/json; charset=utf-8
                                Content-Length: 3235
                                Connection: keep-alive
                                Vary: Origin
                                Access-Control-Allow-Origin: *
                                X-RTime: 2ms
                                X-traceId: XXXXXX
                                  "message": "",
                                  "status": 200,
                                  "data": {
                                    "curColors": [
                                        "colorSet": [
                                          -1092313
                                        "brightnessSet": [],
                                        "effectName": ""
                                        "colorSet": [
                                          -65536
                                        "effectName": ""
                                        "colorSet": [
                                          -7667457
                                        "effectName": ""
                                        "colorSet": [
                                          -65536,
                                          -7667457,
                                          -65536,
                                          -7667457,
                                          -65536,
                                          -7667457,
                                          -7667457,
                                          -65536,
                                          -7667457,
                                          -65536
                                        "brightnessSet": [
                                          100,
                                          1,
                                          100,
                                          1,
                                          100,
                                          1,
                                          1,
                                          100,
                                          1,
                                          100
                                        "effectName": "Lichteffekt WPL"
                                        "colorSet": [
                                          -1536,
                                          -1769423,
                                          -1935104,
                                          -1935104,
                                          -1935104,
                                          -1769423,
                                          -1536
                                        "effectName": "Lichteffekt oPX"
                                        "colorSet": [
                                          -5083375,
                                          -4958880,
                                          -4834129,
                                          -4643841,
                                          -4834129,
                                          -4958880,
                                          -5083375
                                        "effectName": "Lichteffekt JL4"
                                        "colorSet": [
                                          -65341,
                                          -65405,
                                          -65469,
                                          -65532,
                                          -65469,
                                          -65405,
                                          -65341
                                        "effectName": "Lichteffekt E4M"
                                        "colorSet": [
                                          -5556,
                                          -17575,
                                          -29594,
                                          -5933646,
                                          -11772161,
                                          -10904577,
                                          -10036993
                                        "effectName": "Lichteffekt tl5"
                                        "colorSet": [
                                          -908135,
                                          -8842676,
                                          -12709255,
                                          -8575758,
                                          -12709255,
                                          -9301383,
                                          -1825550
                                        "effectName": "Lichteffekt jW5"
                                        "colorSet": [
                                          -3191553,
                                          -15701787,
                                          -3191553,
                                          -15701787,
                                          -3191553,
                                          -15701787,
                                          -3191553
                                        "effectName": "Lichteffekt SX8"
                                        "colorSet": [
                                          -5083375,
                                          -4643841,
                                          -5083375,
                                          -4643841,
                                          -5083375,
                                          -4643841,
                                          -5083375
                                        "effectName": "Lichteffekt smB"
                                        "colorSet": [
                                          -7995572,
                                          -5757723,
                                          -7995572,
                                          -5757723,
                                          -7995572,
                                          -5757723,
                                          -7995572,
                                          -5757723,
                                          -7995572,
                                          -5757723
                                        "effectName": "Lichteffekt EPD"
                                        "colorSet": [
                                          -45236,
                                          -114856,
                                          -184476,
                                          -253839,
                                          -5085054,
                                          -9850732,
                                          -14616154,
                                          -13698365,
                                          -12715039,
                                          -11731713
                                        "effectName": "Lichteffekt Kh8"
                                        "colorSet": [
                                          -917249,
                                          -1434398,
                                          -1886010,
                                          -2337367,
                                          -2788979,
                                          -3240591,
                                          -3691948,
                                          -4143560,
                                          -4595172,
                                          -5046528
                                        "effectName": "Lichteffekt ojF"
                                        "colorSet": [
                                          -12262014,
                                          -45828,
                                          -12262014,
                                          -45828,
                                          -12262014,
                                          -45828,
                                          -12262014,
                                          -45828,
                                          -12262014,
                                          -45828
                                        "effectName": "Lichteffekt Cml"
                                        "colorSet": [
                                          -1,
                                          -466241,
                                          -866945,
                                          -1333185,
                                          -1733888,
                                          -2293966,
                                          -1769627,
                                          -1179752,
                                          -589877,
                                          -1
                                        "effectName": "Lichteffekt 2og"
                                        "colorSet": [
                                          -1825550
                                        "effectName": ""
                                        "colorSet": [
                                          -908135
                                        "effectName": ""
                                        "colorSet": [
                                          -8575758
                                        "effectName": ""
                                        "colorSet": [
                                          -1536,
                                          -336640,
                                          -606208,
                                          -941312,
                                          -1210880,
                                          -1480448,
                                          -1750016
                                        "effectName": "Lichteffekt 3As"
                                        "colorSet": [
                                          -8842640,
                                          -4908120,
                                          -908063,
                                          -8842640,
                                          -11660679,
                                          -6544142,
                                          -11660679,
                                          -8842691,
                                          -908166,
                                          -8842691
                                        "effectName": "Lichteffekt c0G"
                                        "colorSet": [
                                          -12763
                                        "effectName": ""
                                        "colorSet": [
                                          -13844225
                                        "effectName": ""
                                        "colorSet": [
                                          -29549
                                        "effectName": ""
                                        "colorSet": [
                                          -12451934
                                        "effectName": ""
                                        "colorSet": [
                                          -8235521
                                        "effectName": ""
                                        "colorSet": [
                                          -38510
                                        "effectName": ""
                                        "colorSet": [
                                          -12763,
                                          -16841,
                                          -21175,
                                          -25509,
                                          -29843,
                                          -34177,
                                          -38510
                                        "effectName": "Lichteffekt HwI"
                                        "colorSet": [
                                          -12763,
                                          -15567,
                                          -18371,
                                          -21175,
                                          -23979,
                                          -27039,
                                          -29843,
                                          -32647,
                                          -35451,
                                          -38510
                                        "effectName": "Lichteffekt x6q"
                                        "colorSet": [
                                          -5107439,
                                          -5233621,
                                          -5294267,
                                          -5354912,
                                          -5415558,
                                          -5476203,
                                          -5536849,
                                          -5597494,
                                          -5658140,
                                          -5718785
                                        "effectName": "Lichteffekt d0T"
                                Also man kommt an die Informationen irgendwie ran 🙂
                                • Olli_M
                                  @olli_m
                                  Hier noch eine Ausgabe der DIY Szenen:
                                  Text-CB72E1706D37-1.txt
                                  • Olli_M
                                    @nbuenger
                                    das govee team wird dir da nicht helfen, das hatten andere auf discord auch schon versucht... und ich auch.. 😞
                                    • nbuenger
                                      Moin an alle,
                                      ich habe das API Testing Tool nun fertig.
                                      Es ist nur ein kleines Web Tool welches dabei hilft die Geräte zu klassifizieren.
                                      Wenn Ihr die Zeit habt Jagd doch mal eure API Keys da durch.
                                      Ich habe bereits in einem älteren Post mitgeteilt welche Daten dort in der Datenbank landen wenn Ihr diese dort speichert.
                                      Ich mache es hier aber gerne noch einmal:
                                      Nach der Eingabe des API Keys werden euch eure Geräte aufgelistet.
                                      Dort stehen alle Infos über eurer Gerät die von der API bereit gestellt werden.
                                      Das wären:
                                      Der Name eures Gerätes
                                      Die Device ID
                                      Das Model
                                      Ob es Steuerbar durch die API ist oder nicht
                                      Ob es Daten von der API zurückgibt
                                      Und die unterstützen Befehle
                                      Wenn der Befehl ColorTem unterstützt wird steht doch auch in welchem Spektrum
                                      Wenn ihr nun auf den Button "Daten übermitteln" klickt werden folgende Daten in der Datenbank gespeichert:
                                      Das Model
                                      Ob es Steuerbar ist oder nicht
                                      Die unterstützen Befehle
                                      Wenn der Befehl ColorTem unterstützt wird wird auch das Spektrum in form von min und max übermittelt.
                                      Ganz Wichtig: Es werden keine sensiblen Daten eurer Geräte oder der API KEYS gespeichert.
                                      Gebt mir gerne euer Feedback und Verbesserungsvorschläge.
                                      Umso mehr Geräte in der Datenbank sind umso stabiler wird der Adapter.
                                      Das API Testing Tool findet ihr hier: https://smarthome-selfmade.de/api/
                                      VG Nick
                                      H andiko2 J Olli_M 4 Replies Last reply Reply Quote 0
                                        Moin an alle,
                                        Das wären:
                                        Die Device ID
                                        Das Model
                                        Das Model
                                        VG Nick
                                        testen hat geklappt:
                                        ist auch schon eingetragen
                                        gruss
                                        helfi
                                        • andiko2
                                          andiko2 @nbuenger last edited by
                                          @nbuenger Meine Temperatur und Luftfeuchtesensoren werden nicht gefunden. da bleibt alles leer.
                                            jensven @nbuenger last edited by jensven
                                            @nbuenger
                                            super Sache von dir 👍
                                            habe gerade meine daten Übermittelt
                                            Habe übrigens das Problem mit den Request gelöst, indem ich in blockly ein script gebaut habe welches den Adapter nur einschaltet wenn es Abends ist und ich den TV einschalte. Somit läuft der Adapter nur Abends wenn er benötigt wird und die Request sind somit minimiert.
                                            312
                                            68179
