    4. Test Adapter Garmin
    Test Adapter Garmin
      johannes2704 @Thomas Braun last edited by
      Hab jetzt noch auf den neuesten 18 aktualisiert und bekomme nun zusätzlich die folgende Meldung:
      error TypeError: Cannot read properties of undefined (reading 'split')
      error Failed ticket please check username and password
      info Login to Garmin
      info starting. Version 0.0.1 (non-npm: TA2k/ioBroker.garmin#984658d0f0fe48beccd9bdc4906cb543e5784bd4) in /opt/iobroker/node_modules/iobroker.garmin, node: v18.12.1, js-controller: 4.0.23
        tombox @johannes2704 last edited by tombox
        @johannes2704
        kannst du dich hier einloggen?
        https://sso.garmin.com/sso/signin?service=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F&webhost=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F&source=https%3A%2F%2Fconnect.garmin.com%2Fsignin%2F&redirectAfterAccountLoginUrl=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F&redirectAfterAccountCreationUrl=https%3A%2F%2Fconnect.garmin.com%2Fmodern%2F&gauthHost=https%3A%2F%2Fsso.garmin.com%2Fsso&locale=en_GB&id=gauth-widget&cssUrl=https%3A%2F%2Fconnect.garmin.com%2Fgauth-custom-v1.2-min.css&privacyStatementUrl=https%3A%2F%2Fwww.garmin.com%2Fen-GB%2Fprivacy%2Fconnect%2F&clientId=GarminConnect&rememberMeShown=true&rememberMeChecked=false&createAccountShown=true&openCreateAccount=false&displayNameShown=false&consumeServiceTicket=false&initialFocus=true&embedWidget=false&socialEnabled=false&generateExtraServiceTicket=true&generateTwoExtraServiceTickets=true&generateNoServiceTicket=false&globalOptInShown=true&globalOptInChecked=false&mobile=false&connectLegalTerms=true&showTermsOfUse=false&showPrivacyPolicy=false&showConnectLegalAge=false&locationPromptShown=true&showPassword=true&useCustomHeader=false&mfaRequired=false&performMFACheck=false&rememberMyBrowserShown=true&rememberMyBrowserChecked=false#
        bzw hier
        https://connect.garmin.com/modern/
        B J 2 Replies Last reply Reply Quote 0
          bommel_030 @tombox last edited by
          @tombox @Thomas-Braun
          Ich hatte den Garmin Adapter erst auf einem Testsystem laufen und hab dann meinen produktiven iobroker auch auf v18 hochgezogen und den Adapter im produktiven System genutzt. Allerdings ist mir mit v18 der RAM Verbrauch von ~5GB auf >8 GB gestiegen. Hab den Adapter dann deaktiviert, RAM Verbrauch allerdings unverändert. Bin dann wieder auf v16 zurück und RAM Verbrauch wieder "normal" und Adapter wieder nur auf dem Testsystem laufen. Da verhält er sich unauffällig.
          Wollte heute einen anderen Adapter aktualisieren und bin kläglich gescheitert.
          npm ERR! code EBADENGINE
          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-12-01T05_41_02_195Z-debug-0.log
          Erst nachdem ich den deaktivierten Garmin Adapter gelöscht habe konnte ich wieder fehlerfrei den Zigbee-Adapter aktualisieren. Keine Ahnung ob das bei v18-Anforderung so sein soll oder ob einer von euch Profis damit was anfangen kann.
          Thomas Braun T 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @bommel_030 last edited by
            @bommel_030
            Das Log ist was kurz...
              bommel_030 @Thomas Braun last edited by
              Durchaus, vergessen den interessanten Teil anzufügen:
              162 verbose stack Error: Unsupported engine
              162 verbose stack     at checkEngine (/usr/lib/node_modules/npm/node_modules/npm-install-checks/lib/index.js:14:25)
              162 verbose stack     at Arborist.[checkEngineAndPlatform] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:228:11)
              162 verbose stack     at Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:214:42)
              162 verbose stack     at async Promise.all (index 1)
              162 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:153:5)
              162 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:145:5)
              162 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
              163 verbose pkgid iobroker.garmin@0.0.1
              164 verbose cwd /opt/iobroker
              165 verbose Linux 5.10.0-19-amd64
              166 verbose node v16.18.1
              167 verbose npm  v8.19.2
              168 error code EBADENGINE
              169 error engine Unsupported engine
              170 error engine Not compatible with your version of node/npm: iobroker.garmin@0.0.1
              171 error notsup Not compatible with your version of node/npm: iobroker.garmin@0.0.1
              171 error notsup Required: {"node":">= 18"}
              171 error notsup Actual:   {"npm":"8.19.2","node":"v16.18.1"}
              172 verbose exit 1
              173 timing npm Completed in 3184ms
              174 verbose unfinished npm timer reify 1669873262280
              175 verbose unfinished npm timer reify:loadTrees 1669873262283
              176 verbose code 1
                Thomas Braun Most Active last edited by
                @bommel_030
                Steht doch da. Der Adapter verlangt nodejs18, du fährst aber 16. Passt also nicht.
                  tombox @bommel_030 last edited by
                  @bommel_030
                  Also der Garmin adapter hat minimum engine v18 aber warum das relevant ist für andere Adapter beim aktualisieren ist eigenartig.
                    Thomas Braun Most Active @tombox last edited by
                    @tombox
                    Weil NPM-Fehler die weitere Installation von irgendwas anderem verhindern, um das Chaos nicht noch größer werden zu lassen.
                      @thomas-braun @tombox
                      Mir ist klar dass der Adapter v18 verlangt. Deshalb habe ich ihn ja deaktiviert bevor ich wieder auf die v16 gegangen bin.
                      Was mir nicht klar war ist die Tatsache, dass ein deaktivierter v18-Adapter unter v16 das Update eines anderen Adapters verhindert.
                      Wenn das von NPM so gewollt ist dann ist ja alles geklärt und falls nochmal ein unwissender wie ich in diese Falle tappt liest er vielleicht den Post und weiß was zu tun ist.
                        Thomas Braun Most Active last edited by Thomas Braun
                        @bommel_030 sagte in Test Adapter Garmin:
                        Aber nicht deinstalliert. Die Installation verlangt ja immer noch nodejs18, ob da eine Instanz läuft oder nicht.
                        Ist im übrigen das gleiche Verhalten wie bei apt. Da geht auch nix mehr, wenn eine inkonsistente Situation festgestellt wird.
                          @bommel_030 Ich denke eher dass es ein iobroker problem statt npm. Denn die versions Nummer oder ähnliches hat sich nicht geändert es gibt kein Grund für iobroker den adapter anzufassen.
                          Thomas Braun B 2 Replies Last reply Reply Quote 0
                            @tombox
                            NPM-Fehler tritt auf, weitere Installationen werden geblockt.
                            Das ist kein Fehler, das ist das gewollte Verhalten.
                              johannes2704 @tombox last edited by
                              @tombox
                              Auf beiden Seiten klappt die Anmeldung ohne Probleme.
                                @tombox
                                Ich hab gerade nochmal auf meine Testinstallation geschaut. Ich kann mich auch nicht mehr anmelden.
                                Kann leider nicht genau eingrenzen seit wann. Login über Webseite klappt ohne Probleme.
                                Und auch wenn er Node 18 anmeckert, es ist installiert....
                                host.iobtester 2022-12-01 09:25:13.467	warn	Do not restart adapter system.adapter.garmin.0 because restart loop detected
                                host.iobtester 2022-12-01 09:25:13.467	info	Restart adapter system.adapter.garmin.0 because enabled
                                host.iobtester 2022-12-01 09:25:13.466	error	instance system.adapter.garmin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                garmin.0 2022-12-01 09:25:12.942	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                garmin.0 2022-12-01 09:25:12.942	info	terminating
                                garmin.0 2022-12-01 09:25:12.941	error	Cannot read properties of undefined (reading 'displayName')
                                garmin.0 2022-12-01 09:25:12.941	error	TypeError: Cannot read properties of undefined (reading 'displayName') at Garmin.updateDevices (/opt/iobroker/node_modules/iobroker.garmin/main.js:297:32) at Garmin.onReady (/opt/iobroker/node_modules/iobroker.garmin/main.js:74:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                garmin.0 2022-12-01 09:25:12.941	error	unhandled promise rejection: Cannot read properties of undefined (reading 'displayName')
                                garmin.0 2022-12-01 09:25:12.941	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                garmin.0 2022-12-01 09:25:12.940	error	{"clientMessage":"Reference Error ID in error logs for further information","errorId":"1566ba08-00c8-4c8f-93e2-a92e1495ac3e","error":"WebApplicationException"}
                                garmin.0 2022-12-01 09:25:12.940	error	AxiosError: Request failed with status code 403
                                garmin.0 2022-12-01 09:25:12.727	error	""
                                garmin.0 2022-12-01 09:25:12.727	error	AxiosError: Request failed with status code 401
                                garmin.0 2022-12-01 09:25:11.301	error	Please update node to version 18 or higher
                                garmin.0 2022-12-01 09:25:10.792	info	Login to Garmin
                                garmin.0 2022-12-01 09:25:10.777	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.garmin#016f743f623cdbba0a844db9623ab38046e7d24f) in /opt/iobroker/node_modules/iobroker.garmin, node: v18.12.1, js-controller: 4.0.23
                                host.iobtester 2022-12-01 09:25:10.233	info	instance system.adapter.garmin.0 started with pid 1143
                                host.iobtester 2022-12-01 09:24:40.204	info	Restart adapter system.adapter.garmin.0 because enabled
                                und
                                bommel@iobtester:/$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                /usr/bin/nodejs
                                v18.12.1
                                /usr/bin/node
                                v18.12.1
                                /usr/bin/npm
                                8.19.2
                                nodejs:
                                  Installed: 18.12.1-deb-1nodesource1
                                  Candidate: 18.12.1-deb-1nodesource1
                                  Version table:
                                 *** 18.12.1-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                                        100 /var/lib/dpkg/status
                                     12.22.12~dfsg-1~deb11u1 500
                                        500 http://security.debian.org bullseye-security/main amd64 Packages
                                     12.22.5~dfsg-2~11u1 500
                                        500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                bommel@iobtester:/$
                                  @bommel_030 Garmin hatte nochmal was geändert login sollte jetzt wieder gehen. Einfach neu installieren
                                    @tombox
                                    Danke, das wars, läuft wieder. Alle 12.583 states aktualisiert...
                                    • dirk1962
                                      dirk1962 last edited by
                                      Hallo @tombox ,
                                      vielen Dank für den Adapter. Ich nutze ihn mit zwei Instanzen. In der ersten Instanz ist eine Scale Index S2, ein Forerunner 235 und eine Vivoactive 3. In dieser Instanz ist alles okay. In der zweiten Instanz ist noch zusätzlich eine Vivoactive 4s und da habe ich folgende Fehlermeldungen:
                                      2023-01-11 16:53:10.888 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray01
                                      2023-01-11 16:53:10.888 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.934 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray02
                                      2023-01-11 16:53:10.934 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.941 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray03
                                      2023-01-11 16:53:10.941 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.944 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray04
                                      2023-01-11 16:53:10.944 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.948 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray05
                                      2023-01-11 16:53:10.948 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.953 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray06
                                      2023-01-11 16:53:10.953 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.956 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray07
                                      2023-01-11 16:53:10.956 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.960 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray08
                                      2023-01-11 16:53:10.960 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.964 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray09
                                      2023-01-11 16:53:10.964 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.967 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray10
                                      2023-01-11 16:53:10.967 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.970 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray11
                                      2023-01-11 16:53:10.970 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:10.974 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray12
                                      2023-01-11 16:53:10.974 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.017 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray13
                                      2023-01-11 16:53:11.017 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.021 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray14
                                      2023-01-11 16:53:11.021 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.065 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray15
                                      2023-01-11 16:53:11.065 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.069 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray16
                                      2023-01-11 16:53:11.069 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.114 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray17
                                      2023-01-11 16:53:11.115 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.117 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray18
                                      2023-01-11 16:53:11.117 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.122 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray19
                                      2023-01-11 16:53:11.122 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.126 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray20
                                      2023-01-11 16:53:11.126 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.130 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray21
                                      2023-01-11 16:53:11.130 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.134 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray22
                                      2023-01-11 16:53:11.134 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.138 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray23
                                      2023-01-11 16:53:11.138 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.142 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray24
                                      2023-01-11 16:53:11.142 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.146 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray25
                                      2023-01-11 16:53:11.146 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.151 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray26
                                      2023-01-11 16:53:11.151 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.155 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray27
                                      2023-01-11 16:53:11.155 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.182 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray28
                                      2023-01-11 16:53:11.182 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.187 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray29
                                      2023-01-11 16:53:11.187 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.192 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray30
                                      2023-01-11 16:53:11.192 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.199 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray31
                                      2023-01-11 16:53:11.199 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.204 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray32
                                      2023-01-11 16:53:11.204 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.208 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray33
                                      2023-01-11 16:53:11.208 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.213 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray34
                                      2023-01-11 16:53:11.213 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.218 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray35
                                      2023-01-11 16:53:11.218 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.223 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray36
                                      2023-01-11 16:53:11.224 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.228 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray37
                                      2023-01-11 16:53:11.229 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.234 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray38
                                      2023-01-11 16:53:11.234 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.239 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray39
                                      2023-01-11 16:53:11.239 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.246 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray40
                                      2023-01-11 16:53:11.246 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.251 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray41
                                      2023-01-11 16:53:11.251 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.255 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray42
                                      2023-01-11 16:53:11.255 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.260 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray43
                                      2023-01-11 16:53:11.260 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.264 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray44
                                      2023-01-11 16:53:11.264 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.269 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray45
                                      2023-01-11 16:53:11.269 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.274 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray46
                                      2023-01-11 16:53:11.274 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.279 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray47
                                      2023-01-11 16:53:11.279 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.284 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray48
                                      2023-01-11 16:53:11.284 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.289 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray49
                                      2023-01-11 16:53:11.289 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.294 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray50
                                      2023-01-11 16:53:11.294 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.298 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray51
                                      2023-01-11 16:53:11.298 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.303 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray52
                                      2023-01-11 16:53:11.303 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.308 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray53
                                      2023-01-11 16:53:11.308 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.313 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray54
                                      2023-01-11 16:53:11.313 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.317 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray55
                                      2023-01-11 16:53:11.317 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.322 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray56
                                      2023-01-11 16:53:11.322 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.326 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray57
                                      2023-01-11 16:53:11.327 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.332 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray58
                                      2023-01-11 16:53:11.332 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.336 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray59
                                      2023-01-11 16:53:11.336 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.342 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray60
                                      2023-01-11 16:53:11.342 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.346 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray61
                                      2023-01-11 16:53:11.346 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.352 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray62
                                      2023-01-11 16:53:11.352 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.356 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray63
                                      2023-01-11 16:53:11.356 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.361 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray64
                                      2023-01-11 16:53:11.362 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.366 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray65
                                      2023-01-11 16:53:11.366 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.371 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray66
                                      2023-01-11 16:53:11.371 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.375 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray67
                                      2023-01-11 16:53:11.375 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.381 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray68
                                      2023-01-11 16:53:11.381 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.385 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray69
                                      2023-01-11 16:53:11.385 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.391 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray70
                                      2023-01-11 16:53:11.391 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.395 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray71
                                      2023-01-11 16:53:11.395 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.407 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray72
                                      2023-01-11 16:53:11.407 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.411 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray73
                                      2023-01-11 16:53:11.412 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.418 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray74
                                      2023-01-11 16:53:11.418 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.422 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray75
                                      2023-01-11 16:53:11.422 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.428 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray76
                                      2023-01-11 16:53:11.428 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.433 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray77
                                      2023-01-11 16:53:11.433 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.440 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray78
                                      2023-01-11 16:53:11.440 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.445 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray79
                                      2023-01-11 16:53:11.445 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.452 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray80
                                      2023-01-11 16:53:11.452 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.458 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray81
                                      2023-01-11 16:53:11.458 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.464 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray82
                                      2023-01-11 16:53:11.465 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.469 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray83
                                      2023-01-11 16:53:11.469 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.476 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray84
                                      2023-01-11 16:53:11.476 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.480 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray85
                                      2023-01-11 16:53:11.480 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.487 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray86
                                      2023-01-11 16:53:11.487 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.493 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray87
                                      2023-01-11 16:53:11.493 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.497 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray88
                                      2023-01-11 16:53:11.497 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.504 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray89
                                      2023-01-11 16:53:11.504 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.509 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray90
                                      2023-01-11 16:53:11.509 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.516 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray91
                                      2023-01-11 16:53:11.516 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.521 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray92
                                      2023-01-11 16:53:11.521 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.528 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray93
                                      2023-01-11 16:53:11.528 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.532 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray94
                                      2023-01-11 16:53:11.532 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.539 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray95
                                      2023-01-11 16:53:11.539 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.543 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray96
                                      2023-01-11 16:53:11.543 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.549 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray97
                                      2023-01-11 16:53:11.549 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.554 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray98
                                      2023-01-11 16:53:11.554 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.560 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray99
                                      2023-01-11 16:53:11.561 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.565 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray100
                                      2023-01-11 16:53:11.565 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.571 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray101
                                      2023-01-11 16:53:11.571 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.575 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray102
                                      2023-01-11 16:53:11.575 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.581 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray103
                                      2023-01-11 16:53:11.581 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.585 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray104
                                      2023-01-11 16:53:11.585 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.589 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray105
                                      2023-01-11 16:53:11.589 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.595 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray106
                                      2023-01-11 16:53:11.595 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.599 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray107
                                      2023-01-11 16:53:11.599 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.604 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray108
                                      2023-01-11 16:53:11.604 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.609 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray109
                                      2023-01-11 16:53:11.609 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.613 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray110
                                      2023-01-11 16:53:11.613 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.617 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray111
                                      2023-01-11 16:53:11.617 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.622 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray112
                                      2023-01-11 16:53:11.622 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.625 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray113
                                      2023-01-11 16:53:11.625 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.629 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray114
                                      2023-01-11 16:53:11.629 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.634 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray115
                                      2023-01-11 16:53:11.634 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.637 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray116
                                      2023-01-11 16:53:11.637 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.682 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray117
                                      2023-01-11 16:53:11.682 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.686 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray118
                                      2023-01-11 16:53:11.686 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.732 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray119
                                      2023-01-11 16:53:11.732 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.735 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray120
                                      2023-01-11 16:53:11.735 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.739 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray121
                                      2023-01-11 16:53:11.739 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.785 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray122
                                      2023-01-11 16:53:11.785 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.829 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray123
                                      2023-01-11 16:53:11.829 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.833 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray124
                                      2023-01-11 16:53:11.833 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.877 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray125
                                      2023-01-11 16:53:11.877 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.922 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray126
                                      2023-01-11 16:53:11.922 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.926 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray127
                                      2023-01-11 16:53:11.926 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.980 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray128
                                      2023-01-11 16:53:11.980 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.984 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray129
                                      2023-01-11 16:53:11.984 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.988 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray130
                                      2023-01-11 16:53:11.988 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.993 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray131
                                      2023-01-11 16:53:11.993 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:11.997 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray132
                                      2023-01-11 16:53:11.997 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.001 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray133
                                      2023-01-11 16:53:12.001 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.045 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray134
                                      2023-01-11 16:53:12.045 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.049 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray135
                                      2023-01-11 16:53:12.049 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.052 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray136
                                      2023-01-11 16:53:12.052 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.055 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray137
                                      2023-01-11 16:53:12.055 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.059 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray138
                                      2023-01-11 16:53:12.059 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.062 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray139
                                      2023-01-11 16:53:12.062 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.065 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray140
                                      2023-01-11 16:53:12.065 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.068 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray141
                                      2023-01-11 16:53:12.069 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.072 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray142
                                      2023-01-11 16:53:12.072 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.075 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray143
                                      2023-01-11 16:53:12.075 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.078 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray144
                                      2023-01-11 16:53:12.078 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.081 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray145
                                      2023-01-11 16:53:12.081 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.085 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray146
                                      2023-01-11 16:53:12.085 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.105 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray147
                                      2023-01-11 16:53:12.105 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.108 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray148
                                      2023-01-11 16:53:12.108 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.110 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray149
                                      2023-01-11 16:53:12.111 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.158 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray150
                                      2023-01-11 16:53:12.158 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.161 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray151
                                      2023-01-11 16:53:12.161 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.164 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray152
                                      2023-01-11 16:53:12.164 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.211 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray153
                                      2023-01-11 16:53:12.211 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.214 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray154
                                      2023-01-11 16:53:12.214 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      2023-01-11 16:53:12.217 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray155
                                      2023-01-11 16:53:12.217 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                      Hast Du eine Idee, was falsch läuft? Die Errors kommen nicht permanent, aber immer mal wieder.
                                        tombox @dirk1962 last edited by
                                        @dirk1962 kannst du bitte die GitHub version installieren da sollte der Fehler mehr details enthalten
                                        dirk1962 1 Reply Last reply Reply Quote 1
                                        • dirk1962
                                          dirk1962 @tombox last edited by
                                          @tombox ,
                                          Ich habe die aktuelle Version von Github installiert und das sind die Errors:
                                          2023-01-11 20:55:56.250 - error: garmin.1 (1986553) Cannot extract array dailystress.bodyBatteryValuesArray154
                                          2023-01-11 20:55:56.251 - error: garmin.1 (1986553) TypeError: Cannot convert undefined or null to object
                                          at Function.keys (<anonymous>)
                                          at Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:148:40)
                                          at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:82:9)
                                          at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:256:9)
                                          at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:92:11)
                                          2023-01-11 20:55:56.254 - error: garmin.1 (1986553) Cannot extract array dailystress.bodyBatteryValuesArray155
                                          2023-01-11 20:55:56.254 - error: garmin.1 (1986553) TypeError: Cannot convert undefined or null to object
                                          Ich hoffe, dass es Dir hilft.
                                            @dirk1962 Bitte neue github version testen ob der Fehler weg ist
                                            dirk1962 1 Reply Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            141
                                            15946
