    4. Test Adapter Garmin
    Test Adapter Garmin
      Thomas Braun Most Active @bommel_030 last edited by
      @bommel_030
      Das Log ist was kurz...
        bommel_030 @Thomas Braun last edited by
        Durchaus, vergessen den interessanten Teil anzufügen:
        162 verbose stack Error: Unsupported engine
        162 verbose stack     at checkEngine (/usr/lib/node_modules/npm/node_modules/npm-install-checks/lib/index.js:14:25)
        162 verbose stack     at Arborist.[checkEngineAndPlatform] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:228:11)
        162 verbose stack     at Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:214:42)
        162 verbose stack     at async Promise.all (index 1)
        162 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:153:5)
        162 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:145:5)
        162 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
        163 verbose pkgid iobroker.garmin@0.0.1
        164 verbose cwd /opt/iobroker
        165 verbose Linux 5.10.0-19-amd64
        166 verbose node v16.18.1
        167 verbose npm  v8.19.2
        168 error code EBADENGINE
        169 error engine Unsupported engine
        170 error engine Not compatible with your version of node/npm: iobroker.garmin@0.0.1
        171 error notsup Not compatible with your version of node/npm: iobroker.garmin@0.0.1
        171 error notsup Required: {"node":">= 18"}
        171 error notsup Actual:   {"npm":"8.19.2","node":"v16.18.1"}
        172 verbose exit 1
        173 timing npm Completed in 3184ms
        174 verbose unfinished npm timer reify 1669873262280
        175 verbose unfinished npm timer reify:loadTrees 1669873262283
        176 verbose code 1
          Thomas Braun Most Active last edited by
          @bommel_030
          Steht doch da. Der Adapter verlangt nodejs18, du fährst aber 16. Passt also nicht.
            tombox @bommel_030 last edited by
            @bommel_030
            Also der Garmin adapter hat minimum engine v18 aber warum das relevant ist für andere Adapter beim aktualisieren ist eigenartig.
              Thomas Braun Most Active @tombox last edited by
              @tombox
              Weil NPM-Fehler die weitere Installation von irgendwas anderem verhindern, um das Chaos nicht noch größer werden zu lassen.
                @thomas-braun @tombox
                Mir ist klar dass der Adapter v18 verlangt. Deshalb habe ich ihn ja deaktiviert bevor ich wieder auf die v16 gegangen bin.
                Was mir nicht klar war ist die Tatsache, dass ein deaktivierter v18-Adapter unter v16 das Update eines anderen Adapters verhindert.
                Wenn das von NPM so gewollt ist dann ist ja alles geklärt und falls nochmal ein unwissender wie ich in diese Falle tappt liest er vielleicht den Post und weiß was zu tun ist.
                  Thomas Braun Most Active last edited by Thomas Braun
                  @bommel_030 sagte in Test Adapter Garmin:
                  Aber nicht deinstalliert. Die Installation verlangt ja immer noch nodejs18, ob da eine Instanz läuft oder nicht.
                  Ist im übrigen das gleiche Verhalten wie bei apt. Da geht auch nix mehr, wenn eine inkonsistente Situation festgestellt wird.
                    @bommel_030 Ich denke eher dass es ein iobroker problem statt npm. Denn die versions Nummer oder ähnliches hat sich nicht geändert es gibt kein Grund für iobroker den adapter anzufassen.
                    Thomas Braun B 2 Replies Last reply Reply Quote 0
                      @tombox
                      NPM-Fehler tritt auf, weitere Installationen werden geblockt.
                      Das ist kein Fehler, das ist das gewollte Verhalten.
                        johannes2704 @tombox last edited by
                        @tombox
                        Auf beiden Seiten klappt die Anmeldung ohne Probleme.
                          bommel_030 @tombox last edited by
                          @tombox
                          Ich hab gerade nochmal auf meine Testinstallation geschaut. Ich kann mich auch nicht mehr anmelden.
                          Kann leider nicht genau eingrenzen seit wann. Login über Webseite klappt ohne Probleme.
                          Und auch wenn er Node 18 anmeckert, es ist installiert....
                          host.iobtester 2022-12-01 09:25:13.467	warn	Do not restart adapter system.adapter.garmin.0 because restart loop detected
                          host.iobtester 2022-12-01 09:25:13.467	info	Restart adapter system.adapter.garmin.0 because enabled
                          host.iobtester 2022-12-01 09:25:13.466	error	instance system.adapter.garmin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          garmin.0 2022-12-01 09:25:12.942	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          garmin.0 2022-12-01 09:25:12.942	info	terminating
                          garmin.0 2022-12-01 09:25:12.941	error	Cannot read properties of undefined (reading 'displayName')
                          garmin.0 2022-12-01 09:25:12.941	error	TypeError: Cannot read properties of undefined (reading 'displayName') at Garmin.updateDevices (/opt/iobroker/node_modules/iobroker.garmin/main.js:297:32) at Garmin.onReady (/opt/iobroker/node_modules/iobroker.garmin/main.js:74:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                          garmin.0 2022-12-01 09:25:12.941	error	unhandled promise rejection: Cannot read properties of undefined (reading 'displayName')
                          garmin.0 2022-12-01 09:25:12.941	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          garmin.0 2022-12-01 09:25:12.940	error	{"clientMessage":"Reference Error ID in error logs for further information","errorId":"1566ba08-00c8-4c8f-93e2-a92e1495ac3e","error":"WebApplicationException"}
                          garmin.0 2022-12-01 09:25:12.940	error	AxiosError: Request failed with status code 403
                          garmin.0 2022-12-01 09:25:12.727	error	""
                          garmin.0 2022-12-01 09:25:12.727	error	AxiosError: Request failed with status code 401
                          garmin.0 2022-12-01 09:25:11.301	error	Please update node to version 18 or higher
                          garmin.0 2022-12-01 09:25:10.792	info	Login to Garmin
                          garmin.0 2022-12-01 09:25:10.777	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.garmin#016f743f623cdbba0a844db9623ab38046e7d24f) in /opt/iobroker/node_modules/iobroker.garmin, node: v18.12.1, js-controller: 4.0.23
                          host.iobtester 2022-12-01 09:25:10.233	info	instance system.adapter.garmin.0 started with pid 1143
                          host.iobtester 2022-12-01 09:24:40.204	info	Restart adapter system.adapter.garmin.0 because enabled
                          und
                          bommel@iobtester:/$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          /usr/bin/nodejs
                          v18.12.1
                          /usr/bin/node
                          v18.12.1
                          /usr/bin/npm
                          8.19.2
                          nodejs:
                            Installed: 18.12.1-deb-1nodesource1
                            Candidate: 18.12.1-deb-1nodesource1
                            Version table:
                           *** 18.12.1-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                                  100 /var/lib/dpkg/status
                               12.22.12~dfsg-1~deb11u1 500
                                  500 http://security.debian.org bullseye-security/main amd64 Packages
                               12.22.5~dfsg-2~11u1 500
                                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                          bommel@iobtester:/$
                            @bommel_030 Garmin hatte nochmal was geändert login sollte jetzt wieder gehen. Einfach neu installieren
                              @tombox
                              Danke, das wars, läuft wieder. Alle 12.583 states aktualisiert...
                              • dirk1962
                                dirk1962 last edited by
                                Hallo @tombox ,
                                vielen Dank für den Adapter. Ich nutze ihn mit zwei Instanzen. In der ersten Instanz ist eine Scale Index S2, ein Forerunner 235 und eine Vivoactive 3. In dieser Instanz ist alles okay. In der zweiten Instanz ist noch zusätzlich eine Vivoactive 4s und da habe ich folgende Fehlermeldungen:
                                2023-01-11 16:53:10.888 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray01
                                2023-01-11 16:53:10.888 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.934 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray02
                                2023-01-11 16:53:10.934 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.941 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray03
                                2023-01-11 16:53:10.941 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.944 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray04
                                2023-01-11 16:53:10.944 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.948 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray05
                                2023-01-11 16:53:10.948 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.953 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray06
                                2023-01-11 16:53:10.953 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.956 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray07
                                2023-01-11 16:53:10.956 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.960 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray08
                                2023-01-11 16:53:10.960 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.964 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray09
                                2023-01-11 16:53:10.964 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.967 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray10
                                2023-01-11 16:53:10.967 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.970 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray11
                                2023-01-11 16:53:10.970 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:10.974 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray12
                                2023-01-11 16:53:10.974 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.017 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray13
                                2023-01-11 16:53:11.017 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.021 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray14
                                2023-01-11 16:53:11.021 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.065 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray15
                                2023-01-11 16:53:11.065 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.069 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray16
                                2023-01-11 16:53:11.069 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.114 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray17
                                2023-01-11 16:53:11.115 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.117 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray18
                                2023-01-11 16:53:11.117 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.122 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray19
                                2023-01-11 16:53:11.122 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.126 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray20
                                2023-01-11 16:53:11.126 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.130 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray21
                                2023-01-11 16:53:11.130 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.134 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray22
                                2023-01-11 16:53:11.134 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.138 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray23
                                2023-01-11 16:53:11.138 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.142 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray24
                                2023-01-11 16:53:11.142 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.146 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray25
                                2023-01-11 16:53:11.146 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.151 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray26
                                2023-01-11 16:53:11.151 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.155 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray27
                                2023-01-11 16:53:11.155 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.182 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray28
                                2023-01-11 16:53:11.182 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.187 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray29
                                2023-01-11 16:53:11.187 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.192 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray30
                                2023-01-11 16:53:11.192 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.199 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray31
                                2023-01-11 16:53:11.199 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.204 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray32
                                2023-01-11 16:53:11.204 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.208 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray33
                                2023-01-11 16:53:11.208 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.213 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray34
                                2023-01-11 16:53:11.213 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.218 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray35
                                2023-01-11 16:53:11.218 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.223 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray36
                                2023-01-11 16:53:11.224 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.228 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray37
                                2023-01-11 16:53:11.229 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.234 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray38
                                2023-01-11 16:53:11.234 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.239 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray39
                                2023-01-11 16:53:11.239 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.246 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray40
                                2023-01-11 16:53:11.246 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.251 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray41
                                2023-01-11 16:53:11.251 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.255 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray42
                                2023-01-11 16:53:11.255 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.260 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray43
                                2023-01-11 16:53:11.260 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.264 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray44
                                2023-01-11 16:53:11.264 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.269 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray45
                                2023-01-11 16:53:11.269 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.274 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray46
                                2023-01-11 16:53:11.274 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.279 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray47
                                2023-01-11 16:53:11.279 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.284 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray48
                                2023-01-11 16:53:11.284 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.289 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray49
                                2023-01-11 16:53:11.289 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.294 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray50
                                2023-01-11 16:53:11.294 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.298 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray51
                                2023-01-11 16:53:11.298 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.303 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray52
                                2023-01-11 16:53:11.303 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.308 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray53
                                2023-01-11 16:53:11.308 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.313 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray54
                                2023-01-11 16:53:11.313 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.317 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray55
                                2023-01-11 16:53:11.317 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.322 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray56
                                2023-01-11 16:53:11.322 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.326 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray57
                                2023-01-11 16:53:11.327 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.332 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray58
                                2023-01-11 16:53:11.332 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.336 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray59
                                2023-01-11 16:53:11.336 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.342 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray60
                                2023-01-11 16:53:11.342 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.346 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray61
                                2023-01-11 16:53:11.346 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.352 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray62
                                2023-01-11 16:53:11.352 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.356 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray63
                                2023-01-11 16:53:11.356 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.361 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray64
                                2023-01-11 16:53:11.362 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.366 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray65
                                2023-01-11 16:53:11.366 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.371 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray66
                                2023-01-11 16:53:11.371 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.375 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray67
                                2023-01-11 16:53:11.375 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.381 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray68
                                2023-01-11 16:53:11.381 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.385 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray69
                                2023-01-11 16:53:11.385 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.391 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray70
                                2023-01-11 16:53:11.391 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.395 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray71
                                2023-01-11 16:53:11.395 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.407 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray72
                                2023-01-11 16:53:11.407 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.411 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray73
                                2023-01-11 16:53:11.412 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.418 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray74
                                2023-01-11 16:53:11.418 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.422 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray75
                                2023-01-11 16:53:11.422 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.428 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray76
                                2023-01-11 16:53:11.428 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.433 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray77
                                2023-01-11 16:53:11.433 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.440 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray78
                                2023-01-11 16:53:11.440 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.445 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray79
                                2023-01-11 16:53:11.445 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.452 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray80
                                2023-01-11 16:53:11.452 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.458 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray81
                                2023-01-11 16:53:11.458 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.464 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray82
                                2023-01-11 16:53:11.465 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.469 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray83
                                2023-01-11 16:53:11.469 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.476 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray84
                                2023-01-11 16:53:11.476 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.480 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray85
                                2023-01-11 16:53:11.480 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.487 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray86
                                2023-01-11 16:53:11.487 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.493 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray87
                                2023-01-11 16:53:11.493 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.497 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray88
                                2023-01-11 16:53:11.497 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.504 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray89
                                2023-01-11 16:53:11.504 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.509 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray90
                                2023-01-11 16:53:11.509 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.516 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray91
                                2023-01-11 16:53:11.516 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.521 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray92
                                2023-01-11 16:53:11.521 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.528 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray93
                                2023-01-11 16:53:11.528 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.532 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray94
                                2023-01-11 16:53:11.532 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.539 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray95
                                2023-01-11 16:53:11.539 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.543 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray96
                                2023-01-11 16:53:11.543 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.549 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray97
                                2023-01-11 16:53:11.549 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.554 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray98
                                2023-01-11 16:53:11.554 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.560 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray99
                                2023-01-11 16:53:11.561 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.565 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray100
                                2023-01-11 16:53:11.565 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.571 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray101
                                2023-01-11 16:53:11.571 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.575 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray102
                                2023-01-11 16:53:11.575 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.581 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray103
                                2023-01-11 16:53:11.581 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.585 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray104
                                2023-01-11 16:53:11.585 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.589 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray105
                                2023-01-11 16:53:11.589 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.595 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray106
                                2023-01-11 16:53:11.595 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.599 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray107
                                2023-01-11 16:53:11.599 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.604 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray108
                                2023-01-11 16:53:11.604 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.609 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray109
                                2023-01-11 16:53:11.609 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.613 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray110
                                2023-01-11 16:53:11.613 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.617 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray111
                                2023-01-11 16:53:11.617 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.622 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray112
                                2023-01-11 16:53:11.622 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.625 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray113
                                2023-01-11 16:53:11.625 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.629 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray114
                                2023-01-11 16:53:11.629 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.634 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray115
                                2023-01-11 16:53:11.634 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.637 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray116
                                2023-01-11 16:53:11.637 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.682 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray117
                                2023-01-11 16:53:11.682 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.686 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray118
                                2023-01-11 16:53:11.686 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.732 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray119
                                2023-01-11 16:53:11.732 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.735 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray120
                                2023-01-11 16:53:11.735 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.739 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray121
                                2023-01-11 16:53:11.739 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.785 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray122
                                2023-01-11 16:53:11.785 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.829 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray123
                                2023-01-11 16:53:11.829 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.833 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray124
                                2023-01-11 16:53:11.833 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.877 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray125
                                2023-01-11 16:53:11.877 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.922 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray126
                                2023-01-11 16:53:11.922 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.926 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray127
                                2023-01-11 16:53:11.926 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.980 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray128
                                2023-01-11 16:53:11.980 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.984 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray129
                                2023-01-11 16:53:11.984 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.988 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray130
                                2023-01-11 16:53:11.988 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.993 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray131
                                2023-01-11 16:53:11.993 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:11.997 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray132
                                2023-01-11 16:53:11.997 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.001 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray133
                                2023-01-11 16:53:12.001 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.045 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray134
                                2023-01-11 16:53:12.045 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.049 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray135
                                2023-01-11 16:53:12.049 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.052 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray136
                                2023-01-11 16:53:12.052 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.055 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray137
                                2023-01-11 16:53:12.055 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.059 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray138
                                2023-01-11 16:53:12.059 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.062 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray139
                                2023-01-11 16:53:12.062 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.065 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray140
                                2023-01-11 16:53:12.065 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.068 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray141
                                2023-01-11 16:53:12.069 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.072 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray142
                                2023-01-11 16:53:12.072 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.075 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray143
                                2023-01-11 16:53:12.075 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.078 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray144
                                2023-01-11 16:53:12.078 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.081 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray145
                                2023-01-11 16:53:12.081 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.085 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray146
                                2023-01-11 16:53:12.085 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.105 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray147
                                2023-01-11 16:53:12.105 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.108 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray148
                                2023-01-11 16:53:12.108 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.110 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray149
                                2023-01-11 16:53:12.111 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.158 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray150
                                2023-01-11 16:53:12.158 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.161 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray151
                                2023-01-11 16:53:12.161 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.164 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray152
                                2023-01-11 16:53:12.164 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.211 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray153
                                2023-01-11 16:53:12.211 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.214 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray154
                                2023-01-11 16:53:12.214 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                2023-01-11 16:53:12.217 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray155
                                2023-01-11 16:53:12.217 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
                                Hast Du eine Idee, was falsch läuft? Die Errors kommen nicht permanent, aber immer mal wieder.
                                  tombox @dirk1962 last edited by
                                  @dirk1962 kannst du bitte die GitHub version installieren da sollte der Fehler mehr details enthalten
                                  dirk1962 1 Reply Last reply Reply Quote 1
                                  • dirk1962
                                    dirk1962 @tombox last edited by
                                    @tombox ,
                                    Ich habe die aktuelle Version von Github installiert und das sind die Errors:
                                    2023-01-11 20:55:56.250 - error: garmin.1 (1986553) Cannot extract array dailystress.bodyBatteryValuesArray154
                                    2023-01-11 20:55:56.251 - error: garmin.1 (1986553) TypeError: Cannot convert undefined or null to object
                                    at Function.keys (<anonymous>)
                                    at Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:148:40)
                                    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:82:9)
                                    at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:256:9)
                                    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:92:11)
                                    2023-01-11 20:55:56.254 - error: garmin.1 (1986553) Cannot extract array dailystress.bodyBatteryValuesArray155
                                    2023-01-11 20:55:56.254 - error: garmin.1 (1986553) TypeError: Cannot convert undefined or null to object
                                    Ich hoffe, dass es Dir hilft.
                                      @dirk1962 Bitte neue github version testen ob der Fehler weg ist
                                      dirk1962 1 Reply Last reply Reply Quote 0
                                      • dirk1962
                                        @tombox Auch mit neuer Github Version habe ich die Errors.
                                        2023-01-12 18:56:52.435 - error: garmin.1 (2080293) https://connect.garmin.com/modern/proxy/userstats-service/wellness/daily/Nicki_1966?fromDate=2023-01-06
                                        2023-01-12 18:56:52.435 - error: garmin.1 (2080293) Error: read ECONNRESET
                                        2023-01-12 18:56:52.798 - info: linux-control.0 (1970948) getting data from iobroker-Test (192.168.1.173:22)
                                        2023-01-12 18:56:53.712 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray01
                                        2023-01-12 18:56:53.713 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                                        at Function.keys ()
                                        2023-01-12 18:56:53.715 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray02
                                        2023-01-12 18:56:53.715 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                                        at Function.keys ()
                                        2023-01-12 18:57:01.048 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray360
                                        2023-01-12 18:57:01.048 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                                        at Function.keys ()
                                        2023-01-12 18:57:01.092 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray361
                                        2023-01-12 18:57:01.092 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                                        at Function.keys ()
                                        2023-01-12 18:57:01.096 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray362
                                        2023-01-12 18:57:01.096 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                                        at Function.keys ()
                                        2023-01-12 18:57:01.144 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray363
                                        2023-01-12 18:57:01.144 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                                        2023-01-12 18:57:01.145 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                                        at Function.keys ()
                                        2023-01-12 18:57:01.148 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray364
                                        2023-01-12 18:57:01.148 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                                        Ich habe zwischendurch Fehlermeldungen rausgenommen, weil es sonst mehr als die zulässigen 100.000 Zeichen sind.
                                          @dirk1962 Dann wurde nicht richtig neu installiert oder die Instanz nicht neugestartet
                                          • dirk1962
                                            @tombox Habe den Adapter nochmals von Github geladen und beide Instanzen neu gestartet. Seitdem gibt es keine Fehlermeldungen mehr 👍 . Vielen Dank für Deine Hilfe.
                                            31.7k
                                            79.8k
                                            141
                                            15946
