    4. Test Adapter vis 2.0 (Alpha)
      denjo @GiB64 last edited by denjo
      @gib64 ich habe gerade festgestellt das das widget das auch verusacht, also den weißen bildschirm meine ich.
      [{"tpl":"tplMfdShutterDialog","data":{"oid":"shelly.0.SHSW-25#40F5202DFA5C#1.Shutter.Position","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":"true","dialog_width":"450","dialog_height":"210","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"min":"0","max":"100","title":"Esszimmer Rollo","noHeader":true,"invert_value":false,"show_active":true,"invert_icon":false},"style":{"left":"300px","top":"440px","z-index":9},"widgetSet":"jqui-mfd"}]
        crunchip Forum Testing Most Active @Feuersturm last edited by crunchip
        @feuersturm ja und damit lief auch die v 2.0.9, allerdings mit einem Unterschied zu deinem
        Edit, hab jettzt mal auf integriert umgestellt, vis ist jetzt da
          Also ist meine Lösung, vis2 deinstallieren, alle Projekte aus Vis löschen und vis2 neu zu installieren?
            A Former User @sigi234 last edited by
            @sigi234 sagte in Test Adapter vis 2.0 (Alpha):
            Kann man die Seitenleiste wieder scrollbar machen?
            ich kann jetzt noch nichts zu einer Importierten VIS sagen, aber mit der aktuellen 2.0.10, kann ich die page anwählen und mit den cursor tasten nach links und recht durch scrollen und mit Enter auswählen, dann springt der Fokus auf diese Seite.
            VG
            Bernd
              Pegboy last edited by
              Ich habe heute vis 2.0.10 installiert, jedoch kommt beim Aufrufen der Webseite nur das drehende iobroker Zeichen. Kann da jemand weiterhelfen?
                crunchip Forum Testing Most Active @Pegboy last edited by
                @pegboy https://forum.iobroker.net/post/902673
                  Pegboy @crunchip last edited by
                  @crunchip nochmal zum Abgleich: web Adaper auf ws umstellen oder integriert?
                    @pegboy sagte in Test Adapter vis 2.0 (Alpha):
                    integriert
                      @crunchip funktioniert auch nicht. nur wenn "Reine Web-Sockets (iobroker.ws) verwenden" aktiviert ist wird die ViS geladen aber springt automatisch in ...../vis-2-beta/edit.html#01_Vorlagen und weißer Bildschirm
                      crunchip D 2 Replies Last reply Reply Quote 0
                        weißer Bildschirm
                        mögliche Ursache https://forum.iobroker.net/post/902466
                          @crunchip Danke. Ich konnte beim Laden schnell auf ein leeres Projekt umschalten. Mein main project funktioniert nicht. Gibt es eine Chance auf 2.0.9 umzusteigen?
                            @pegboy einfach mal etwas Geduld mitbringen, wir sind hier in der alpha/beta Phase, abgesehen davon, läuft doch deine normale Vis
                            • Chaot
                              Chaot last edited by
                              Ich bin jetzt schon eine Weile am Probieren.
                              Die 2.0.10 bekomme ich absolut nicht zum Laufen.
                              Auch schon umgestellt von WS auf intern. Dann startet zwar der Editor, aber der Ladestreifen links läuft dauernd munter weiter.
                              Mache mal morgen weiter. Mal schauen ob sich da was ändert.
                                dos1973 @Pegboy last edited by
                                @pegboy
                                ich habe das gleiche issue mit der v2.10
                                • Feuersturm
                                  Feuersturm last edited by Feuersturm
                                  Wenn vis nicht mehr nach dem Update auf 2.0.10 startet hängt euch bitte an dieses issue https://github.com/ioBroker/ioBroker.vis/issues/603 mit dran und postet dort eure Erkenntnisse (inkl. der Einstellung was mit und ohne websockets) geht.
                                  Bluefox lebt als Entwickler auf github und holt sich dort seine Infos her. Er wird sich vermutlich nicht durch 100te Beiträge durchwühlen und schauen welche Infos für ihn relevant sind 😉
                                  crunchip77 created this issue in ioBroker/ioBroker.vis
                                  closed Vis2 läd nicht mehr nach update von 2.0.9 auf 2.0.10 #603
                                  1 Reply Last reply Reply Quote 5
                                  • Feuersturm
                                    Vielleicht ist der folgende Workaround eine Möglichkeit, um VIS 2.0.10 wieder zum laufen zu bekommen, wenn euer VIS Editor versucht ein Projekt zu laden, welches sich aus noch unbekannten Gründen nicht mehr laden lässt.
                                    Achtung: Benutzung auf eigene Gefahr. Es leben die Backups 🙂
                                    @ice987 hat den Hinweis hierzu in diesem Issue gegeben https://github.com/ioBroker/ioBroker.vis/issues/607
                                    • Löscht im Datei Explorer vom Admin eure VIS2 Projekte
                                    • Vis2 Editor öffnen (VIS scheint sich noch den alten Projektnamen gemerkt zu haben, obwohl es das Projekt nicht mehr gibt)
                                    • Legt eine neue Seite an mit einem beliebigen Namen
                                    • Seite vom Vis Editor mit F5 neu laden
                                    • Über das Menü "Projekte verwalten" könnt ihr jetzt wieder neue Projekte anlegen.
                                    Feuer-sturm created this issue in ioBroker/ioBroker.vis
                                    closed Button for factory reset of vis2 during testing phase #607
                                    T bahnuhr 2 Replies Last reply Reply Quote 1
                                      sigi234 Forum Testing Most Active @apollon77 last edited by
                                      @apollon77
                                      Funktioniert bei wem das weather widget?
                                        tobrog @Feuersturm last edited by
                                        @feuersturm Löschen der Vis2 Projekte hat geholfen, Vis2 startet jetzt wieder. 👍
                                          juggi1962 @tobrog last edited by juggi1962
                                          Sorry hab mich vertan wollte nicht dir Antworten
                                            juggi1962 last edited by
                                            Hallo an Alle Spezialisten.
                                            Ich habe in meinen VIS Projekten sehr viele Materialdesign Widgets,
                                            aber nach der Installation der neuen VIS 2 Materialdesign Widgets erscheinen diese nicht in der VIS 2.
                                            Gibt es dafür schon eine Lösung?
                                            Danke für eure Hilfe Gruß Jürgen
                                            crunchip ice987 2 Replies Last reply Reply Quote 0
                                            780
                                            227612
