    4. ZigBee neue Version 1.8.x
    • amg_666
      amg_666 @spotterblog last edited by
      Also ich hab jetzt über github die 1.8.7 installiert.
      Adapter ist grün, scheint auch zu funktionieren, aber im Log habe ich jede Menge Warnungen:
      zigbee.0
      	2022-12-01 23:32:10.003	warn	DeviceAvailability:Failed to ping 0x00124b00235279d6 ZB-CL01
      zigbee.0
      	2022-12-01 23:32:09.356	warn	DeviceAvailability:Failed to ping 0x00124b00234ca487 ZB-CL01
      zigbee.0
      	2022-12-01 23:31:46.707	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2022-12-01 23:31:46.707	warn	Object zigbee.0.84fd27fffecf6567.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2022-12-01 23:31:46.702	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2022-12-01 23:31:46.701	warn	Object zigbee.0.84fd27fffecf6567.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2022-12-01 23:31:46.534	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2022-12-01 23:31:46.533	warn	Object 84fd27fffecf6567.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2022-12-01 23:31:46.532	warn	This object will not be created in future versions. Please report this to the developer.
      zigbee.0
      	2022-12-01 23:31:46.531	warn	Object 84fd27fffecf6567.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      zigbee.0
      	2022-12-01 23:31:45.404	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
      zigbee.0
      	2022-12-01 23:31:45.401	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
      zigbee.0
      	2022-12-01 23:31:45.398	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
      zigbee.0
      	2022-12-01 23:31:45.395	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
      zigbee.0
      	2022-12-01 23:31:45.389	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
      zigbee.0
      	2022-12-01 23:31:45.386	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
      zigbee.0
      	2022-12-01 23:31:45.383	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
      zigbee.0
      	2022-12-01 23:31:45.380	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
      zigbee.0
      	2022-12-01 23:31:45.375	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
      zigbee.0
      	2022-12-01 23:31:45.353	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
      zigbee.0
      	2022-12-01 23:31:45.350	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
      zigbee.0
      	2022-12-01 23:31:45.347	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
      zigbee.0
      	2022-12-01 23:31:45.326	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
      zigbee.0
      	2022-12-01 23:31:45.312	info	Zigbee started
        Habe gerade zwei Aqara Wandschalter neu eingebunden.
        Bekomme direkt nach dem Einbinden ebenfalls Warnungen:
        zigbee.0
        2022-12-01 23:15:51.986	info	DeviceConfigure successful 0x54ef44100044c675 lumi.remote.b28ac1
        zigbee.0
        2022-12-01 23:15:46.436	warn	This object will not be created in future versions. Please report this to the developer.
        zigbee.0
        2022-12-01 23:15:46.435	warn	Object zigbee.0.54ef44100044c675.operation_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        zigbee.0
        2022-12-01 23:15:46.420	warn	This object will not be created in future versions. Please report this to the developer.
        zigbee.0
        2022-12-01 23:15:46.419	warn	Object zigbee.0.54ef44100044c675.click_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        zigbee.0
        2022-12-01 23:15:46.410	warn	This object will not be created in future versions. Please report this to the developer.
        zigbee.0
        2022-12-01 23:15:46.410	warn	Object 54ef44100044c675.operation_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        zigbee.0
        2022-12-01 23:15:46.409	warn	This object will not be created in future versions. Please report this to the developer.
        zigbee.0
        2022-12-01 23:15:46.409	warn	Object 54ef44100044c675.click_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        zigbee.0
        2022-12-01 23:15:46.302	info	Configuring 0x54ef44100044c675 lumi.remote.b28ac1
        zigbee.0
        2022-12-01 23:15:46.298	info	Device '0x54ef44100044c675' is supported, identified as: Xiaomi Aqara wireless remote switch H1 (double rocker) (WXKG15LM)
        zigbee.0
        2022-12-01 23:15:46.297	info	Successfully interviewed '0x54ef44100044c675', device has successfully been paired
        zigbee.0
        2022-12-01 23:15:37.480	info	Starting interview of '0x54ef44100044c675'
        zigbee.0
        2022-12-01 22:44:29.336	info	DeviceConfigure successful 0x54ef44100044c6af lumi.remote.b28ac1
        zigbee.0
        2022-12-01 22:44:23.092	warn	This object will not be created in future versions. Please report this to the developer.
        zigbee.0
        2022-12-01 22:44:23.092	warn	Object zigbee.0.54ef44100044c6af.operation_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        zigbee.0
        2022-12-01 22:44:23.084	warn	This object will not be created in future versions. Please report this to the developer.
        zigbee.0
        2022-12-01 22:44:23.084	warn	Object zigbee.0.54ef44100044c6af.click_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        zigbee.0
        2022-12-01 22:44:23.075	warn	This object will not be created in future versions. Please report this to the developer.
        zigbee.0
        2022-12-01 22:44:23.074	warn	Object 54ef44100044c6af.operation_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        zigbee.0
        2022-12-01 22:44:23.074	warn	This object will not be created in future versions. Please report this to the developer.
        zigbee.0
        2022-12-01 22:44:23.073	warn	Object 54ef44100044c6af.click_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        zigbee.0
        2022-12-01 22:44:22.998	info	Configuring 0x54ef44100044c6af lumi.remote.b28ac1
        zigbee.0
        2022-12-01 22:44:22.997	info	Device '0x54ef44100044c6af' is supported, identified as: Xiaomi Aqara wireless remote switch H1 (double rocker) (WXKG15LM)
        zigbee.0
        2022-12-01 22:44:22.997	info	Successfully interviewed '0x54ef44100044c6af', device has successfully been paired
        zigbee.0
        2022-12-01 22:44:08.708	info	Starting interview of '0x54ef44100044c6af'
          arteck Developer Most Active @amg_666 last edited by arteck
          @amg_666 sagte in ZigBee neue Version 1.8.x:
          84fd27fffecf6567
          zeig mal die Datenpunkte von dem und die Kachel mit der Infoseite
          für den Rest hier
          https://github.com/ioBroker/ioBroker.zigbee/wiki/Missing-icons-after-adatapter-Update
          @spotterblog
          54ef44100044c6af
          von dem auch Kachel und die Infoseite
            arteck Developer Most Active @spotterblog last edited by
            @spotterblog sagte in ZigBee neue Version 1.8.x:
            iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17))
            am conbee ?? dann mach erst ein firmwareupdate von dem Teil
              legro last edited by
              @arteck said in ZigBee neue Version 1.8.x:
              es ist mal wieder eine neue Version da..
              diesmal hat sich nicht viel getan..
              Heißt das auch, dass hinsichtlich der BITRON-Sirenen sich nichts getan hat? 😕 Dort funktioniert die Konfiguration der Geräte payload ja nicht mehr richtig.
                arteck Developer Most Active @legro last edited by
                @legro schau im chanege log..
                ich war an der Sirene nicht dran
                  A Former User @arteck last edited by
                  @arteck 1.8.7 ohne Mucken im Log, super, Danke!
                  Statesmapping auch wieder komplett richtig da.
                    Pap last edited by
                    1.8.7 läuft nicht. Sämtliche Silvercrast Steckdosenleisten werden als Steckdose angezeigt und lassen sich nicht mehr steuern.
                      arteck Developer Most Active @Pap last edited by
                      @pap das ist schön..ich hol mal die Glaskugel
                        Pap last edited by
                        @arteck
                        Die Lidl HG06338 Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) 2827565c-d139-457f-8162-63d45213ca49-image.png
                        wird als
                        Protokoll:
                        2022-12-02 09:33:15.545 - error: zigbee.1 (1460235) No state available for 'TS011F_plug_3' with key 'state_l2'
                        • amg_666
                          amg_666 @Pap last edited by amg_666
                          @pap Kann ich exakt so bestätigen 😞
                          Im Adapter wird die 3er Steckdose so angezeigt:
                          Brightness/Color temperature etc sind auch Unsinn bei einer Steckdose
                            ahh...schau ich später .. die hab ich auch hier verpackt
                            so installiert mal von GIT
                            ist ein Fehler im converter nicht bei uns..sollte aber wieder tun mit der GIT version
                            • amg_666
                              amg_666 @arteck last edited by
                              @arteck Mit der github Installation sieht das jetzt wieder besser aus:
                              Ich bin mir nicht sicher, aber ich glaube Color Temp etc war früher auch schon drin obwohl es keinen Sinn macht.
                                @amg_666 drückmal den hier
                                dann immer noch.. ??
                                  Lucky_ESA Developer Most Active @arteck last edited by
                                  @arteck Bist du so nett und fügst die 4 ICON noch hinzu. Dein automatischer upload funktioniert nicht da die nicht per writeFile() hinzugefügt werden. Muss das immer manuell machen😁
                                  https://www.zigbee2mqtt.io/images/devices/HG06620.jpg
                                  https://www.zigbee2mqtt.io/images/devices/HG06337.jpg
                                  https://www.zigbee2mqtt.io/images/devices/HG08383A.jpg
                                  https://www.zigbee2mqtt.io/images/devices/FB20-002.jpg
                                  Gruß//Lucky
                                    Pap last edited by
                                    @arteck State Cleanup wird die Steckdose wieder korrekt angezeigt, aber weiterhin kein schalten möglich.
                                    Wenn die Steckdosenleiste neu angelernt wird, dann wird sie korrekt erkannt und lässt sich wieder schalten
                                    • amg_666
                                      @arteck Yepp, jetzt sind die "orphan states" weg. 👍
                                        Pap last edited by
                                        einmal Iobroker fix (ob es was bringt). Danach Touchlink zurücksetzen und koppeln und Tada Lidl 3 Fach Steckdose korrekt angezeigt und schalten auch wieder.
                                          arteck Developer Most Active @Lucky_ESA last edited by
                                          @lucky_esa na so einfah ist es nicht..
                                          warum werden die nicht hinzugefügt ?? wie ist den der link zu zigbee2mqtt ?? der sollte im LOG stehen
                                            @arteck sagte in ZigBee neue Version 1.8.x:
                                            Stehen doch in meinem Beitrag. Wenn du Dateien mit fs speicherst werden diese nicht in die _data.json eingefügt und stehen somit auch nicht zur Verfügung.
                                            Gruß//Lucky
                                            81.1k
                                            385
                                            85388
