    4. Test Adapter TibberConnect 0.0.x inkl. Tibber Pulse
      theGrinch last edited by
      Bevor ich da nen GitHub Issue von mache: hat noch jemand disconnects nach ca. 4 Minuten?
      tibberconnect.0 2022-11-26 21:16:26.814	debug	Tibber Feed: Disconnected from Tibber feed.
      tibberconnect.0 2022-11-26 21:16:26.809	debug	Tibber Feed: Disconnected from Tibber feed.
      tibberconnect.0 2022-11-26 21:12:14.862	debug	Tibber Feed: Connected to Tibber feed.
      tibberconnect.0 2022-11-26 21:12:14.858	debug	Tibber Feed: Connected to Tibber feed.
      tibberconnect.0 2022-11-26 21:12:14.517	debug	Websocket URL ermittelt: wss://websocket-api.tibber.com/v1-beta/gql/subscriptions
      tibberconnect.0 2022-11-26 21:12:14.409	debug	Websocket URL ermittelt: wss://websocket-api.tibber.com/v1-beta/gql/subscriptions
      tibberconnect.0 2022-11-26 21:12:14.065	debug	Ermittle Websocket URL für TibberFeed
      tibberconnect.0 2022-11-26 21:12:14.056	debug	Ermittle Websocket URL für TibberFeed
      tibberconnect.0 2022-11-26 21:12:13.563	debug	Schedule restart: */33 * * * *
      tibberconnect.0 2022-11-26 21:12:13.445	info	starting. Version 0.0.7 (non-npm: Codibris/ioBroker.tibberconnect#9afa849891c6184f7314e1ed174b728ed4d4d757) in /opt/iobroker/node_modules/iobroker.tibberconnect, node: v14.19.1, js-controller: 4.0.21
      Ich habe 16 Datenpunkte auf aktualisieren gesetzt. Rennt der Adapter da ggf. mit Anlauf in die neue API-Beschränkung?
      Rate limiting
      There is a rate limit of 100 requests in 5 minutes per IP address intended to protect the API. Note that prices are calculated once per day in the afternoon (for Norway and Sweden they are first preliminary and later finalized potentially with minor changes after currency rates are confirmed). You can use priceInfo.today and priceInfo.tomorrow for fetching them up front instead of only using priceInfo.current for the current hour.
      Thomas Braun C 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @theGrinch last edited by
        @thegrinch sagte in Test Adapter TibberConnect 0.0.x inkl. Tibber Pulse:
        Am Rande würde ich das System auf Stand bringen.
        NodeJS 16 und js-controller 4.0.23 sind (seit Monaten) angesagt.
          Codibris Developer @theGrinch last edited by
          @thegrinch kurios, dass der Ablauf und der Debug Output doppelt kommt - sieht aus, als würde der 2x laufen. Vom Ablauf her sind die Ausgaben korrekt - nur eigentlich nicht doppelt.
          Die Pulse Daten kommen von einer Websocket Verbindung - da steckt kein einzelner API Request hinter - das dürfte also auch nicht ins Limit zählen. Gucke mal ich mir aber auch noch mal an.
          Ich werde jetzt erstmal schauen, ob ich die Änderung bei den API Anfragen (error handling) in die Hauptversion überführen kann - vielleicht sehen wir dann noch mehr im Log, ob vor dem disconnect noch mehr passiert.
            Michaelnorge last edited by
            Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason automatisiert?
            Hab ich was verpasst? Ich habe nur zufällig in den logs gesehen, daß der Neustart des Adapters außerhalb meines Zeitplans erfolgte - ist das bei der neusten Version implementiert?
              Codibris Developer @Michaelnorge last edited by
              @michaelnorge In der Hauptanwendung ist die Anpassung zum Fehlerhandling mit der API noch nicht drin - daher stürzt der aktuell unverändert ab. Bei mir lief der jetzt mit meiner Anpassung eine Woche durch. Ich werde demnächst einen Release erstellen. Dann könnt ihr das auch testen.
                MikeRow last edited by
                Moin, für den alten Tibber Adapter hatte jemand für die VIS ein BarChart geschrieben. Hat jemand zufällig schon eine Chart Lösung mit diesem Adapter in Verwendung und könnte diesen mal vorstellen? Gruß Mike
                  theGrinch @MikeRow last edited by theGrinch
                  @mikerow ich hatte da die Google Charts von @Mic angepasst.
                  Hier ist die Anpassung für den hiesigen Adapter. Ich hatte noch keine Zeit zu forschen, warum vormittags die aktuelle Werte als die Werte von morgen angezeigt werden.
                  Evtl. noch was, wie der Adapter die Zahlen handelt @Codibris ? Aber wie gesagt, noch nicht näher geschaut.
                  Du musst an 4 Stellen "XXX" durch deine HomeID im Datenpunktpfad ersetzt.
                  • Script, um mittels Google Charts einen Wetter-Graph anzuzeigen
                  • Aktuelle Version: https://github.com/Mic-M/iobroker.google-charts-example/
                  • Support: https://forum.iobroker.net/topic/22779/vorlage-google-charts-beispiel
                  • Autor: Mic (ioBroker-Forum) / Mic-M (Github)
                  • changes for tibber: theGrinch (ioBroker-Forum), Tibber invite: https://invite.tibber.com/3ixvd5z5
                  • Change Log:
                  • 0.3.2 changed for tibberconnect adapter
                  • 0.3.1 show energy prices from tibber
                  • 0.3 Mic * Added line color - https://forum.iobroker.net/post/389919
                  • 0.2 Mic + Fix/improve file creation.
                  • 0.1 Mic - Initial Release
                  • Konfiguration
                  // Der Pfad der HTML-Datei, einfach entsprechend anpassen.
                  // Die Datei wird abgelegt unterhalb von '/opt/iobroker/iobroker-data/files/vis.0/'
                  const FILE_PATH = 'main/googleChartTibber.html';
                  // Schedule
                  const M_SCHEDULE = '2 * * * *'; // Jede Stunde +2 Minuten
                  // Ausgaben für Debug
                  const LOG_DEBUG = true;
                  • Global constants/variables
                    let mSchedule; // for the schedule
                  • Executed on every script start.
                    main();
                    function main() {
                    // Write the file initially on script start
                    writeGoogleHtml(function(success) {
                    if (LOG_DEBUG) log('[Debug] We are now in the callback of writeWeatherHtml().');
                    if (success) {
                    if (LOG_DEBUG) log('[Debug] Successfully executed writeWeatherHtml(), so we schedule the updates.');
                    clearSchedule(mSchedule);
                    mSchedule = schedule(M_SCHEDULE, writeGoogleHtml);
                    } else {
                    log('File not successfully created/updated, so we stop at this point.', 'error');
                  • Writing Google html file.
                  • @param {object} [callback] Optional: A callback function which is executed after proceeding this function.
                    function writeGoogleHtml(callback = undefined) {
                    let result = writeFile('vis.0', FILE_PATH, buildHTML(), function (error) {
                    if (error) {
                    log('[Error] Error while executing writeFile(): ' + error);
                    if (typeof callback === 'function') { // execute if a function was provided to parameter callback
                    if (LOG_DEBUG) log('[Debug] Function to callback parameter was provided');
                    return callback(false);
                    } else {
                    return;
                    } else {
                    if (LOG_DEBUG) log('[Debug] File successfully written: [' + FILE_PATH + ']');
                    return callback(true);
                    } else {
                    return;
                    return result;
                  function buildHTML() {
                  let html = '';
                  html += '<html>\n';
                  html += '<script type="text/javascript" src="https://www.gstatic.com/charts/loader.js"></script>\n';
                  html += '<script type="text/javascript">\n';
                  html += "google.charts.load('current', {'packages':['corechart']});\n";
                  html += "google.charts.setOnLoadCallback(drawChart);\n";
                  html += "function drawChart() {"; + "\n";
                  html += "var data = new google.visualization.DataTable();\n";
                  html += "data.addColumn('number', 'hour');\n";
                  html += "data.addColumn('number', 'today');\n";
                  html += "data.addColumn({type: 'number', role: 'annotation'});\n";
                  html += "data.addColumn('number', 'tomorrow');\n";
                  for (let i = 0; i <= 9; i++) {
                      let tLow = getState('tibberconnect.0.Homes.XXX.PricesToday.' + i + '.total').val;
                      let tHigh  = getState('tibberconnect.0.Homes.XXX.PricesTomorrow.' + i + '.total').val;
                      html += "    data.addRow([" + i + ", " + tLow + ", " + tLow + ", " + tHigh + ", " + tHigh + "]);\n";
                  for (let i = 10; i <= 23; i++) {
                  // See: https://developers.google.com/chart/interactive/docs/gallery/linechart#configuration-options
                  html += "var options = {\n";
                  // Line colors (HTML): lower    upper
                  html += "    colors: ['CornflowerBlue', 'DarkTurquoise'],\n";
                  html += "    curveType: 'function', backgroundColor: 'transparent', pointSize: 4,\n";
                  html += "    hAxis: { textStyle:{color:'black'}},\n";
                  html += "    vAxis: { textPosition: 'none', textStyle:{color:'red'},\n";
                  html += "    baselineColor:'transparent', gridlines:{count:0} }, legend: { position: 'bottom' },\n";
                  html += "    annotations: { stem: { length: 5, color: 'transparent' }, textStyle: {fontSize: 10, alwaysOutside: true, bold: false} }\n";
                  html += "};\n";
                  html += "var chart = new google.visualization.LineChart(document.getElementById('mychart'));\n";
                  html += "chart.draw(data, options);\n";
                  html += "}\n";
                  html += "</script>\n";
                  html += '<div id="mychart" style="width: 700px; height: 400px;"></div>\n';
                  html += '</html>\n';
                  return html;
                  /edit:
                  Hier sind noch die angepassten Widgets für die vis. Gleiches Thema: XXX durch die house-ID ersetzen.
                  [{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"CHEAP","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/main/img/ioBroker/icons8-coin-49 cheap.png","visibility-oid":"tibberconnect.0.Homes.XXX.CurrentPrice.level","name":"tibber-coin-cheap"},"style":{"left":"327px","top":"1452px","width":"49px","height":"49px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"tibberconnect.0.Homes.XXX.CurrentPrice.total","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Tibber current price"},"style":{"left":"324px","top":"1507px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"EXPENSIVE","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/main/img/ioBroker/icons8-coin-49 expensive.png","visibility-oid":"tibberconnect.0.Homes.XXX.CurrentPrice.level","name":"tibber-coin-expensive"},"style":{"left":"325px","top":"1452px","width":"49px","height":"49px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"NORMAL","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/main/img/ioBroker/icons8-coin-49.png","visibility-oid":"tibberconnect.0.Homes.XXX.CurrentPrice.level","name":"tibber-coin-normal"},"style":{"left":"325px","top":"1452px","width":"49px","height":"49px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"VERY_CHEAP","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/main/img/ioBroker/icons8-coin-49 very cheap.png","visibility-oid":"tibberconnect.0.Homes.XXX.CurrentPrice.level","name":"tibber-coin-very-cheap"},"style":{"left":"325px","top":"1452px","width":"49px","height":"49px","z-index":"5"},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"VERY_EXPENSIVE","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/vis.0/main/img/ioBroker/icons8-coin-49 very expensive.png","visibility-oid":"tibberconnect.0.Homes.XXX.CurrentPrice.level","name":"tibber-coin-very-expensive"},"style":{"left":"325px","top":"1452px","width":"49px","height":"49px","z-index":"5"},"widgetSet":"basic"}]
                  Grafiken:
                  icons8-coin-tibber.zip
                  Quelle: https://icons8.com/icons/set/euro
                  Pfad: /vis.0/main/img/ioBroker/
                    MikeRow @theGrinch last edited by
                    @thegrinch Sauber, vielen Dank. Vermutlich liegt der Fehler in den unterschiedlichen Namen der Datenpunkte. Im alten Adapter heißt es 01 und in diesem 1 für den DP der Stunde 1. Ich schau da auch mal drüber.
                      Codibris Developer last edited by Codibris
                      ich habe in gitHub jetzt eine v0.0.8 veröffentlicht. Dieser lief bei mir jetzt 2 Wochen durch - ohne restart. Allerdings habe ich heute im Log entdeckt, dass es doch noch Fehler bei der API gibt, denen ich noch auf die Spur kommen muss. Aber: die neue Version lief bei mir deutlich stabiler als die 0.0.7. Könnt jetzt gerne mit testen 🙂
                      Link für die Installation aus gitHub: https://github.com/Codibris/ioBroker.tibberconnect.git
                      So spart ihr das raussuchen ^^
                      M T M 3 Replies Last reply Reply Quote 1
                        Michaelnorge @Codibris last edited by
                        @codibris Ja gerne! Installiert und den 1/2stündigen Neustart gelöscht - mal schauen was passiert. Danke für Deine Arbeit !
                          theGrinch @Codibris last edited by
                          @codibris auch installiert und restart rausgenommen.
                          Ich habe im log aber weiterhin alles doppelt.
                          Sieht das bei euch (@Michaelnorge) auch so aus?
                            Michaelnorge @theGrinch last edited by
                            @thegrinch Was einst du mit Doppelt? Doppelte logs oder Adapter? Laufen bei dir vielleicht zwei Instanzen?
                              theGrinch @Michaelnorge last edited by
                              @michaelnorge genau im Log. Da habe ich alle Einträge bei der Verbindung doppelt. Bricht auch weiterhin nach 3-4min die Verbindung ab.
                              In der Adapter-Anzeige nur eine Instanz, bei den io-Prozessen im Raspbian auch nur 1x io.tibberconnect.
                              Habe jetzt den Adapter mal komplett deinstalliert, iob restart, neu installiert.
                              Bleibt leider bei doppelten Anzeigen im Log und Abruch.
                              tibberconnect.0 2022-12-02 22:19:32.974	debug	Tibber Feed: Disconnected from Tibber feed.
                              tibberconnect.0 2022-12-02 22:19:32.944	debug	Tibber Feed: Disconnected from Tibber feed.
                              tibberconnect.0 2022-12-02 22:16:28.442	debug	Tibber Feed: Connected to Tibber feed.
                              tibberconnect.0 2022-12-02 22:16:28.429	debug	Tibber Feed: Connected to Tibber feed.
                              tibberconnect.0 2022-12-02 22:16:27.701	debug	Websocket URL ermittelt: wss://websocket-api.tibber.com/v1-beta/gql/subscriptions
                              tibberconnect.0 2022-12-02 22:16:27.696	debug	Websocket URL ermittelt: wss://websocket-api.tibber.com/v1-beta/gql/subscriptions
                              tibberconnect.0 2022-12-02 22:16:27.291	debug	Ermittle Websocket URL für TibberFeed
                              tibberconnect.0 2022-12-02 22:16:27.283	debug	Ermittle Websocket URL für TibberFeed
                              tibberconnect.0 2022-12-02 22:16:25.849	info	starting. Version 0.0.8 (non-npm: Codibris/ioBroker.tibberconnect#cd1e39d75818c09c0c8601091091bae2bb36d672) in /opt/iobroker/node_modules/iobroker.tibberconnect, node: v16.18.1, js-controller: 4.0.23
                                MikeRow @Codibris last edited by
                                @codibris Hi, 0.0.8 installiert stürzt leider weiterhin ab
                                M C 3 Replies Last reply Reply Quote 0
                                  Michaelnorge @MikeRow last edited by
                                  @mikerow Hier läuft der Adapter recht gut....
                                    Codibris Developer @MikeRow last edited by Codibris
                                    @mikerow mist 😞 da muss noch irgendwo nen Fehler auftreten, dem ich noch nicht auf die Schliche gekommen bin. Ich bleibe dran…
                                      Codibris Developer @Schimi last edited by
                                      Habe oben meinen Einladungscode (https://invite.tibber.com/hgg53izs) eingefügt - falls also jemand wechseln möchte würde ich mich freuen, wenn ihr den Link nutzen würdet 🙂
                                        @mikerow hast du einen Pulse im Einsatz? Aktuell scheint es primär im Kontext der dauerhaften Verbindung zur API zu Fehlern zu kommen.
                                        Ich habe im gitHub einen Branch in dem ich übergangsweise das Logging ziemlich ausgeweitet habe.
                                        Falls ihr das bei euch noch mal untersuchen wollt, könnt ihr den Adapter über folgenden Link installieren:
                                        https://github.com/Codibris/ioBroker.tibberconnect/tree/83-adapter-stürzt-zyklisch-ab
                                        (!) Wenn ihr das Loglevel auf "silly / alles" stellt, dann wird pro Datensatz vom Pulse ein Eintrag im Log erstellt. Daher das vielleicht nur unter Beobachtung machen, da das Log recht voll wird. Sonst sollten im Level "debug" noch einige Einträge mehr erscheinen, die uns helfen können, dem Ganzen auf die Schliche zu kommen. Aber hier bitte beachten: Beim Abruf der 'homes' sind persönliche Daten enthalten.
                                        Ich lasse das auf meinem Testsystem mit dem Demotoken jetzt auch mal laufen - vielleicht komme ich der Sache so näher.
                                          Ich habe zur Zeit immer noch Ausfälle, jedoch viel weniger als vorher.
                                          Allerdings finde ich hierzu keinerlei Logeinträge (log auf "Info").
                                          Der Adapter schaltet sich einfach auf gelb und hört auf zu funktionieren.
                                          BTW: Gibt es einen Blockly/Adapter der meine Instanzen überwacht und meldet wenn es dort ein Problem gibt?
                                            @codibris Hi, ja ich nutze den Pulse. Ich werde heute Abend mal das Logging erweitern und mich dann melden. Vielen Dank fürs kümmern!
                                            360
                                            77669
