    2. English
    3. Scripting / Logic
    4. JavaScript
    5. Check if an element contains a class in JavaScript?
      roshan.sharma last edited by roshan.sharma
      Hi
      I'm not a big fan of dynamic programming languages, although I've written a lot of JavaScript code. I never quite understood the concept of prototype-based programming; does anyone know how it works?
      I was working on a JavaScript project with the source checking if an element contains a class.
      I'm currently doing this:
      code_text
      var test = document.getElementById("test");
      var testClass = test.className;
      switch (testClass) {
        case "class1":
          test.innerHTML = "I have class1";
          break;
        case "class2":
          test.innerHTML = "I have class2";
          break;
        case "class3":
          test.innerHTML = "I have class3";
          break;
        case "class4":
          test.innerHTML = "I have class4";
          break;
        default:
          test.innerHTML = "";
      <div id="test" class="class1"></div>
      The problem is when I change the HTML code to...
      <div id="test" class="class1 class5"></div>
      There is no longer an exact match, so I get the standard output of nothing (""). But I still want the output to be I have class1 because <div> still contains class .class1 .
      Can someone help me
      liv-in-sky OliverIO 2 Replies Last reply Reply Quote 0
        liv-in-sky @roshan.sharma last edited by
        @roshan-sharma
        I have tried this in a standard html widget:
        <div id="test" class="class1 class3"></div>
        <script>
        console.log(test.className);
        console.log(test.getAttribute('class'));
          case "class1":
            break;
          case "class2":
            break;
          case "class3":
            break;
          case "class4":
            break;
          default:
        if (test.classList.contains("class3")) {console.log("with class3");
                                                test.innerHTML = "I have class3";}
        if (test.classList.contains("class1")) {console.log("with class1");
                                                test.innerHTML += "<br> I have class1";}
        </script>
        the result is:
        the problem is the switch command !
        • OliverIO
          OliverIO @roshan.sharma last edited by OliverIO
          @roshan-sharma
          better is to use jquery
          https://api.jquery.com/hasclass/
          var test = $("#test");
          if ($(test).hasClass("class1")) {
             $(test).html("I have class1");
          if ($(test).hasClass("class2")) {
             $(test).html("I have class2");
          jquery is in vis already loaded
