    4. Adapter "smartmeter"
      ChristianF last edited by
      Hallo Ingo,
      danke für Deine Hilfe. Habe Deinen Tipp probiert, leider ohne Erfolg:
      smartmeter.0	2017-07-31 19:53:56.815	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026262002fefe00fefefefefefefe02000000100600" -> null
      smartmeter.0	2017-07-31 19:53:56.810	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026262002fefe00fefefefefefefe" -> null
      smartmeter.0	2017-07-31 19:53:56.801	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026262002" -> null
      smartmeter.0	2017-07-31 19:53:56.790	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026" -> null
      smartmeter.0	2017-07-31 19:53:56.786	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220" -> null
      smartmeter.0	2017-07-31 19:53:56.782	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020" -> null
      smartmeter.0	2017-07-31 19:53:56.778	debug	MATCH-RESULT MESSAGE: "121212120000000064000000000000928266400040006042000064" -> null
      smartmeter.0	2017-07-31 19:53:56.774	debug	MATCH-RESULT MESSAGE: "121212120000000064000000000000928266400040006042" -> null
      smartmeter.0	2017-07-31 19:53:56.770	debug	MATCH-RESULT MESSAGE: "1212121200000000640000000000009282664000" -> null
      smartmeter.0	2017-07-31 19:53:56.765	debug	MATCH-RESULT MESSAGE: "121212120000000064000000000000" -> null
      smartmeter.0	2017-07-31 19:53:56.760	debug	MATCH-RESULT MESSAGE: "121212120000" -> null
      smartmeter.0	2017-07-31 19:53:56.144	debug	SET MESSAGE TIMEOUT TIMER: 120000
      smartmeter.0	2017-07-31 19:53:56.144	debug	SERIALPORT OPEN
      smartmeter.0	2017-07-31 19:53:56.144	debug	CREATE SERIALPORT: 9600 8 1 none
      smartmeter.0	2017-07-31 19:53:56.143	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"60","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"transportS
      smartmeter.0	2017-07-31 19:53:56.142	info	starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.8.4
      Schade 😞
        apollon77 last edited by
        Ich habe gerade nochmal gelesen was DU oben geschrieben hast: Du hast den Verbindungstest gemacht wie auf der Seite des Zählers beschrieben … und hast Dort Werte gepostet. Die entsprechen aber exakt denen von der volkszaehler-Seite. Also da passt was nicht.
        Wenn Du den test machst:Was genau kommt den da an wenn Du es ohne dem Adapter machst.
        Ansonsten ist das Log faktisch zu kurz.
        Wenn er lauscht und der Zähler sendet gerade dann kann es sein das die ersten Daten von einem "angefangenen Telegram" kommen. Also mal etwas warten und bitte dann nochmal langes log schicken.
          stimmt, weil ich nicht schnell genug war, um sie rauszukopieren, da hatte ich die Putty Session schon zu 😉
          Hier ein etwas längerer Log:
          root@raspi:~# cat /dev/ttyUSB0 | od -tx1
          0000000 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
          0000020 80 04 40 00 40 00 60 42 00 00 64 00 02 20 20 20
          0000040 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
          0000060 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
          0000100 20 40 00 64 00 00 00 00 00 00 92 80 06 40 00 40
          0000120 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
          0000140 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
          0000160 00 fe fe 60 40 00 40 00 04 0c 00 70 66 06 00 00
          0000200 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
          0000220 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
          0000240 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
          0000260 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 20
          0000300 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
          0000320 00 00 00 00 00 00 00 02 00 66 06 00 00 00 00 00
          0000340 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
          0000360 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
          0000400 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
          0000420 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
          0000440 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
          0000460 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
          0000500 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 20
          0000520 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
          0000540 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
          0000560 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
          0000600 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
          0000620 00 00 42 80 90 00 64 00 00 00 00 00 00 92 80 10
          0000640 40 00 40 00 60 42 00 00 60 00 42 80 00 00 00 00
          0000660 12 12 12 12 10 00 20 00 12 12 12 12 00 00 00 00
          0000700 64 00 00 00 00 00 00 92 80 10 40 00 40 00 60 42
          0000720 00 00 64 00 02 20 20 20 22 20 22 20 26 26 20 02
          0000740 fe fe fe fe fe fe fe fe fe fe 02 00 00 00 10 06
          0000760 00 00 1e 62 82 00 00 42 06 06 00 64 00 00 00 00
          0001000 00 00 92 80 10 40 00 40 00 60 42 06 00 66 02 20
          0001020 20 20 22 20 22 20 26 26 20 02 00 00 00 10 06 00
          0001040 00 1e 62 82 06 00 00 40 00 fe fe 60 40 00 40 00
          0001060 04 0c 00 70 66 06 00 00 86 00 02 fe 00 00 00 00
          0001100 00 00 10 06 00 66 06 00 00 00 00 00 fe 00 00 00
          0001120 00 02 00 00 00 10 06 00 00 1e 62 82 00 66 06 00
          0001140 00 00 00 00 fe 40 00 00 00 00 00 40 1c 00 fe 10
          0001160 00 00 00 00 00 00 00 24 00 66 06 00 00 00 00 00
          0001200 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 08
          0001220 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
          0001240 00 00 00 00 00 00 10 e0 00 66 06 00 00 00 00 00
          0001260 fe 40 00 00 00 00 00 40 1c 00 fe 10 00 00 00 00
          0001300 00 40 18 00 00 66 06 00 00 00 00 00 fe 00 00 40
          0001320 1c 00 fe 10 00 00 00 00 00 40 30 62 00 66 06 00
          0001340 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
          0001360 00 00 02 e6 00 66 06 00 00 0e 06 00 fe 00 00 40
          0001400 12 00 00 40 00 00 00 80 00 66 06 00 00 86 00 00
          0001420 fe 00 00 00 00 02 00 30 70 ce 40 20 00 04 00 08
          0001440 18 80 86 00 10 3e 06 44 06 0e 32 26 02 00 12 20
          0001460 00 20 90 10 06 08 10 00 00 00 0c 90 06 18 04 30
          0001500 78 8e c2 04 20 00 00 00 00 00 42 e2 80 00 64 00
          0001520 00 00 00 00 00 92 80 12 40 00 40 00 60 42 00 00
          0001540 60 00 42 64 10 00 00 00 12 12 12 12 10 00 08 08
          0001560 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
          0001600 80 18 40 00 40 00 60 42 00 00 64 00 02 20 20 20
          0001620 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
          0001640 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
          0001660 12 00 00 64 00 00 00 00 00 00 92 80 18 40 00 40
          0001700 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
          0001720 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
          0001740 00 fe fe 60 40 00 40 00 04 0c 04 70 66 06 00 00
          0001760 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
          0002000 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
          0002020 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
          0002040 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 26
          0002060 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
          0002100 00 00 00 00 00 00 00 08 00 66 06 00 00 00 00 00
          0002120 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
          0002140 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
          0002160 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
          0002200 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
          0002220 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
          0002240 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
          0002260 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 84
          0002300 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
          0002320 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
          0002340 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
          0002360 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
          0002400 00 00 42 1c 60 00 64 00 00 00 00 00 00 92 80 1c
          0002420 40 00 40 00 60 42 00 00 60 00 42 20 00 00 00 00
          0002440 12 12 12 12 10 00 80 c0 12 12 12 12 00 00 00 00
          0002460 64 00 00 00 00 00 00 92 80 1e 40 00 40 00 60 42
          0002500 00 00 64 00 02 20 20 20 22 20 22 20 26 26 20 02
          0002520 fe fe fe fe fe fe fe fe fe fe 02 00 00 00 10 06
          0002540 00 00 1e 62 82 00 00 42 00 38 00 64 00 00 00 00
          0002560 00 00 92 80 00 40 00 40 00 60 42 06 00 66 02 20
          0002600 20 20 22 20 22 20 26 26 20 02 00 00 00 10 06 00
          0002620 00 1e 62 82 06 00 00 40 00 fe fe 60 40 00 40 00
          0002640 04 0c 00 70 66 06 00 00 86 00 02 fe 00 00 00 00
          0002660 00 00 10 06 00 66 06 00 00 00 00 00 fe 00 00 00
          0002700 00 02 00 00 00 10 06 00 00 1e 62 82 00 66 06 00
          0002720 00 00 00 00 fe 40 00 00 00 00 00 40 1c 00 fe 10
          0002740 00 00 00 00 00 00 00 30 00 66 06 00 00 00 00 00
          0002760 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 0c
          0003000 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
          0003020 00 00 00 00 00 00 10 e0 00 66 06 00 00 00 00 00
          0003040 fe 40 00 00 00 00 00 40 1c 00 fe 10 00 00 00 00
          0003060 00 40 18 00 00 66 06 00 00 00 00 00 fe 00 00 40
          0003100 1c 00 fe 10 00 00 00 00 00 40 30 62 00 66 06 00
          0003120 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
          0003140 00 00 02 e6 00 66 06 00 00 0e 06 00 fe 00 00 40
          0003160 12 00 00 40 00 00 00 88 00 66 06 00 00 86 00 00
          0003200 fe 00 00 00 00 02 00 30 70 ce 40 20 00 04 00 08
          0003220 18 80 86 00 10 3e 06 44 06 0e 32 26 02 00 12 20
          0003240 00 20 90 10 06 08 10 00 00 00 0c 90 06 18 04 30
          0003260 78 8e c2 04 20 00 00 00 00 00 42 04 04 00 64 00
          0003300 00 00 00 00 00 92 80 00 40 00 40 00 60 42 00 00
          0003320 60 00 42 20 9c 00 00 00 12 12 12 12 10 00 30 1e
          0003340 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
          0003360 80 00 40 00 40 00 60 42 00 00 64 00 02 20 20 20
          0003400 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
          0003420 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
          0003440 00 04 00 64 00 00 00 00 00 00 92 80 02 40 00 40
          0003460 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
          0003500 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
          0003520 00 fe fe 60 40 00 40 00 04 0c 00 70 66 06 00 00
          0003540 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
          0003560 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
          0003600 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
          0003620 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 30
          0003640 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
          0003660 00 00 00 00 00 00 00 0e 00 66 06 00 00 00 00 00
          0003700 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
          0003720 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
          0003740 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
          0003760 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
          0004000 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
          0004020 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
          0004040 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 84
          0004060 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
          0004100 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
          0004120 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
          0004140 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
          0004160 00 00 42 00 04 00 64 00 00 00 00 00 00 92 80 00
          0004200 40 00 40 00 60 42 00 00 60 00 42 e0 80 00 00 00
          0004220 12 12 12 12 10 00 c6 00 12 12 12 12 00 00 00 00
          0004240 64 00 00 00 00 00 00 92 80 00 40 00 40 00 60 42
          0004260 00 00 64 00 02 20 20 20 22 20 22 20 26 26 20 02
          0004300 fe fe fe fe fe fe fe fe fe fe 02 00 00 00 10 06
          0004320 00 00 1e 62 82 00 00 42 00 00 00 64 00 00 00 00
          0004340 00 00 92 80 04 40 00 40 00 60 42 06 00 66 02 20
          0004360 20 20 22 20 22 20 26 26 20 02 00 00 00 10 06 00
          0004400 00 1e 62 82 06 00 00 40 00 fe fe 60 40 00 40 00
          0004420 04 0c 02 70 66 06 00 00 86 00 02 fe 00 00 00 00
          0004440 00 00 10 06 00 66 06 00 00 00 00 00 fe 00 00 00
          0004460 00 02 00 00 00 10 06 00 00 1e 62 82 00 66 06 00
          0004500 00 00 00 00 fe 40 00 00 00 00 00 40 1c 00 fe 10
          0004520 00 00 00 00 00 00 00 30 00 66 06 00 00 00 00 00
          0004540 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 00
          0004560 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
          0004600 00 00 00 00 00 00 10 e0 00 66 06 00 00 00 00 00
          0004620 fe 40 00 00 00 00 00 40 1c 00 fe 10 00 00 00 00
          0004640 00 40 18 00 00 66 06 00 00 00 00 00 fe 00 00 40
          0004660 1c 00 fe 10 00 00 00 00 00 40 30 62 00 66 06 00
          0004700 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
          0004720 00 00 02 e6 00 66 06 00 00 0e 06 00 fe 00 00 40
          0004740 12 00 00 40 00 00 00 90 00 66 06 00 00 86 00 00
          0004760 fe 00 00 00 00 02 00 30 70 ce 40 20 00 04 00 08
          0005000 18 80 86 00 10 3e 06 44 06 0e 32 26 02 00 12 20
          0005020 00 20 90 10 06 08 10 00 00 00 0c 90 06 18 04 30
          0005040 78 8e c2 04 20 00 00 00 00 00 42 9c 30 00 64 00
          0005060 00 00 00 00 00 92 80 06 40 00 40 00 60 42 00 00
          0005100 60 00 42 04 02 00 00 00 12 12 12 12 10 00 00 10
          0005120 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
          0005140 80 00 40 00 40 00 60 42 00 00 64 00 02 20 20 20
          0005160 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
          0005200 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
          0005220 00 92 00 64 00 00 00 00 00 00 92 80 00 40 00 40
          0005240 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
          0005260 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
          0005300 00 fe fe 60 40 00 40 00 04 0c 08 70 66 06 00 00
          0005320 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
          0005340 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
          0005360 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
          0005400 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 32
          0005420 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
          0005440 00 00 00 00 00 00 00 00 00 66 06 00 00 00 00 00
          0005460 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
          0005500 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
          0005520 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
          0005540 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
          0005560 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
          0005600 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
          0005620 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 9e
          0005640 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
          0005660 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
          0005700 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
          0005720 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
          0005740 00 00 42 20 48 00 64 00 00 00 00 00 00 92 80 00
          0005760 40 00 40 00 60 42 00 00 60 00 42 00 18 00 00 00
          Viele Grüße
          Christian
            Ok, damit sind dei Daten so wie Sie auch der smartmeter entfernt. Also irgendwas stimmt nicht mit den Seriellen einstellungen. Die musst Du rausfinden.
            Die 9600 baud sollte stimmen, probier mal mit anderen EInstellungen die es sonst so gibt. Oder ruf bei deinem Energieunternehmen oder beim Hersteller an.
            Es müsste bei Dir pro Sekunde 1 Telegram kommen.
              @apollon77:
              Es müsste bei Dir pro Sekunde 1 Telegram kommen. `
              Naja, unsere Stadtwerke vertreten die Einstellung "Am Zähler haben Sie nix zu suchen, Finger weg!".. Da ist wohl wenig Hilfe zu erwarten.. Ich werde mal ein bisschen Einstellungen fummeln, mal sehen was passiert…
              Übrigens, ist es richtig dass sich in den Objekten noch kein smartmeter.0 Ordner gebildet hat? Es gibt nur ein Systemobjekt smartmeter.0, aber mehr auch nicht...
                Das ist korrekt, da die Werte ja davon abhängen was der Zähler genau sendet. Sobald das erste Telegram sauber empfangen wurde dann wird das alles angelegt
                  So habe jetzt geschätzt 25 verschiedene Möglichkeiten ausprobiert, und bekomme mit keiner ein Bein an Deck. Werde morgen nochmal versuchen die DZG Jungs zu erreichen und irgendwas aus ihnen raus zu bekommen, bisher war da ausser "Fragen Sie Ihren MSB Provider" nix zu machen. Habe zudem gelesen dass der Zähler mglw. elektronisch kastriert ist und die interessanten Daten gar nicht auswirft, das wäre ja noch blöder…
                    Soo, es gibt ein Update von meiner Zählerfront zu vermelden 🙂
                    Als erstes mal die Erfolgsmeldung: LÄUFT 🙂
                    Hier ein Log:
                    smartmeter.0	2017-08-02 23:23:30.323	debug	SERIALPORT CLOSE
                    smartmeter.0	2017-08-02 23:23:30.320	debug	REMAINING DATA AFTER MESSAGE HANDLING:
                    smartmeter.0	2017-08-02 23:23:30.320	debug	SCHEDULE NEXT RUN IN 5s
                    smartmeter.0	2017-08-02 23:23:30.319	debug	SET MESSAGE TIMEOUT TIMER: 120000
                    smartmeter.0	2017-08-02 23:23:30.319	info	Received 10 values, 3 updated
                    smartmeter.0	2017-08-02 23:23:30.319	debug	Data for 129-129:199_130_5*255 unchanged
                    smartmeter.0	2017-08-02 23:23:30.319	debug	129-129:199.130.5*255: Forename/Public Key = b87aef6931549695ac9cd5c74a59bf976607af3bb70b559bb48032d998078c****************************
                    smartmeter.0	2017-08-02 23:23:30.319	debug	Set State 1-0:15_7_0*255.value = 486
                    smartmeter.0	2017-08-02 23:23:30.319	debug	Set State 1-0:15_7_0*255.rawvalue = undefined
                    smartmeter.0	2017-08-02 23:23:30.318	debug	1-0:15.7.0*255: Momentanwert (Total) = 486 W
                    smartmeter.0	2017-08-02 23:23:30.318	debug	Data for 1-0:2_8_2*255 unchanged
                    smartmeter.0	2017-08-02 23:23:30.318	debug	1-0:2.8.2*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T2) = 0.9207 kWh
                    smartmeter.0	2017-08-02 23:23:30.318	debug	Data for 1-0:2_8_1*255 unchanged
                    smartmeter.0	2017-08-02 23:23:30.318	debug	1-0:2.8.1*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T1) = 9113.4528 kWh
                    smartmeter.0	2017-08-02 23:23:30.318	debug	Data for 1-0:2_8_0*255 unchanged
                    smartmeter.0	2017-08-02 23:23:30.317	debug	1-0:2.8.0*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (Total) = 9115.9839 kWh
                    smartmeter.0	2017-08-02 23:23:30.317	debug	Data for 1-0:1_8_2*255 unchanged
                    smartmeter.0	2017-08-02 23:23:30.317	debug	1-0:1.8.2*255: Zählerstand 1 Summe Wirkarbeit Bezug + (T2) = 2.3029 kWh
                    smartmeter.0	2017-08-02 23:23:30.317	debug	Set State 1-0:1_8_1*255.value = 6783.7556
                    smartmeter.0	2017-08-02 23:23:30.317	debug	Set State 1-0:1_8_1*255.rawvalue = undefined
                    smartmeter.0	2017-08-02 23:23:30.317	debug	1-0:1.8.1*255: Zählerstand 1 Summe Wirkarbeit Bezug + (T1) = 6783.7556 kWh
                    smartmeter.0	2017-08-02 23:23:30.316	debug	Set State 1-0:1_8_0*255.value = 6787.5806
                    smartmeter.0	2017-08-02 23:23:30.316	debug	Set State 1-0:1_8_0*255.rawvalue = undefined
                    smartmeter.0	2017-08-02 23:23:30.316	debug	1-0:1.8.0*255: Zählerstand 1 Summe Wirkarbeit Bezug + (Total) = 6787.5806 kWh
                    smartmeter.0	2017-08-02 23:23:30.316	debug	Data for 1-0:0_0_9*255 unchanged
                    smartmeter.0	2017-08-02 23:23:30.316	debug	1-0:0.0.9*255: Device ID = 0901445a4700015f73c3
                    smartmeter.0	2017-08-02 23:23:30.316	debug	Data for 129-129:199_130_3*255 unchanged
                    smartmeter.0	2017-08-02 23:23:30.315	debug	129-129:199.130.3*255: Manufacturer ID = DZG
                    smartmeter.0	2017-08-02 23:23:30.315	debug	STORE DATA
                    smartmeter.0	2017-08-02 23:23:30.315	debug	SML MESSAGE: START SML-File START SmlMessage Transaction-ID: ��ay (8000000000e06179) Group-No: 0 Abort On Error: 0 Message-Body: SmlPublicOpenResponse Codepage: undefined Client-I
                    smartmeter.0	2017-08-02 23:23:30.315	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.314	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.313	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.312	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.311	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.310	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.309	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.308	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.235	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.232	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.230	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.227	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.224	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.222	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.219	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.216	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.213	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.210	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.207	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.205	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.202	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.199	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.196	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.193	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.190	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.188	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.185	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.182	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.178	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.164	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.161	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.158	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.155	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.152	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.149	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.146	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.143	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.140	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.137	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.134	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.131	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.128	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.125	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.122	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.119	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.114	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.113	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.112	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.111	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.109	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.073	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.070	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.068	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.065	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.062	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.059	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.056	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.053	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.050	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.047	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.045	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.042	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.039	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.036	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.033	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.030	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.027	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.024	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.022	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.019	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.016	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.013	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.010	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.008	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.005	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:30.002	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.999	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.996	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.994	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.991	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.988	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.985	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.982	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.979	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.977	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.974	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.971	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.968	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.966	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.963	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.960	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.957	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.954	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.951	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.949	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.946	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.943	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.940	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.938	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.935	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.932	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.929	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.927	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.924	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.921	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.918	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.916	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.913	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.910	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.907	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.905	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.902	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.896	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.894	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.891	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.888	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.885	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.883	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.880	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.877	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.874	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.872	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.869	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.866	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.863	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.861	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.858	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.855	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.853	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.850	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.847	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.844	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.841	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.839	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.836	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.833	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.829	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.826	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.822	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.819	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.815	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.812	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.808	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.805	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.801	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.798	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.794	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.791	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.788	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.784	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.781	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.777	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:29.773	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.093	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.089	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.086	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.083	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.079	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.075	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.072	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.068	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.065	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.062	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.059	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.053	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.050	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.046	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.043	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.040	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.037	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.034	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.030	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.027	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.024	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.021	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.018	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.015	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.011	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.008	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.005	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:28.002	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.999	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.995	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.992	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.989	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.986	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.983	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.980	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.977	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.974	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.971	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.967	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.964	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.961	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.959	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.956	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701770701000
                    smartmeter.0	2017-08-02 23:23:27.953	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f70177070100"
                    smartmeter.0	2017-08-02 23:23:27.950	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f7017707" ->
                    smartmeter.0	2017-08-02 23:23:27.947	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000000023f701" -> null
                    smartmeter.0	2017-08-02 23:23:27.944	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff59000000000000" -> null
                    smartmeter.0	2017-08-02 23:23:27.942	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900000000" -> null
                    smartmeter.0	2017-08-02 23:23:27.940	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff5900" -> null
                    smartmeter.0	2017-08-02 23:23:27.937	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101621e52ff" -> null
                    smartmeter.0	2017-08-02 23:23:27.933	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100020802ff0101" -> null
                    smartmeter.0	2017-08-02 23:23:27.930	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177070100" -> null
                    smartmeter.0	2017-08-02 23:23:27.922	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a400177" -> null
                    smartmeter.0	2017-08-02 23:23:27.919	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000056e9a" -> null
                    smartmeter.0	2017-08-02 23:23:27.915	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff5900000000" -> null
                    smartmeter.0	2017-08-02 23:23:27.911	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52ff59" -> null
                    smartmeter.0	2017-08-02 23:23:27.908	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff0101621e52" -> null
                    smartmeter.0	2017-08-02 23:23:27.904	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177070100020801ff01" -> null
                    smartmeter.0	2017-08-02 23:23:27.900	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f01770701000208" -> null
                    smartmeter.0	2017-08-02 23:23:27.897	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f017707" -> null
                    smartmeter.0	2017-08-02 23:23:27.893	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056efd1f0177" -> null
                    smartmeter.0	2017-08-02 23:23:27.889	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000056e" -> null
                    smartmeter.0	2017-08-02 23:23:27.886	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff5900000000" -> null
                    smartmeter.0	2017-08-02 23:23:27.883	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e52ff59" -> null
                    smartmeter.0	2017-08-02 23:23:27.879	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff650001018201621e" -> null
                    smartmeter.0	2017-08-02 23:23:27.876	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff6500010182" -> null
                    smartmeter.0	2017-08-02 23:23:27.872	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800ff65" -> null
                    smartmeter.0	2017-08-02 23:23:27.869	debug	MATCH-RESULT MESSAGE: "000000000059f50177070100020800" -> null
                    smartmeter.0	2017-08-02 23:23:27.865	debug	MATCH-RESULT MESSAGE: "000000000059f5017707" -> null
                    smartmeter.0	2017-08-02 23:23:27.861	debug	MATCH-RESULT MESSAGE: "000000000059f5" -> null
                    smartmeter.0	2017-08-02 23:23:27.857	debug	SET MESSAGE TIMEOUT TIMER: 120000
                    smartmeter.0	2017-08-02 23:23:27.856	debug	DONE SEND 0
                    smartmeter.0	2017-08-02 23:23:27.854	debug	INITIAL MESSAGES TO SEND: 0
                    smartmeter.0	2017-08-02 23:23:27.847	debug	SERIALPORT RESET BAUDRATE TO 9600
                    smartmeter.0	2017-08-02 23:23:27.838	debug	SERIALPORT OPEN
                    Finde ich schonmal SEHR GEIL und sage DANKE DANKE DANKE für den Adapter und den tollen Support hier!
                    Einziger Punkt, der für mich noch offen ist: woran erkenne ich, ob die Wirkleistung BEZUG oder ABGABE ist? Gibt es da einen Trick?
                    Im Moment wird gerade nichts für Abgabe produziert, aber ich werde morgen mal versuchen, das gegeneinander zu stellen, ob sich da was verändert.
                    Viele Grüße
                    Christian
                      apollon77 last edited by
                      die 1.8.x ist Bezug und 2.8.x ist Abgabe, steht auch so in den Namen der Datenpunkte.
                      Was war denn jetzt am Ende der Trick ?!
                        ChristianF last edited by
                        Das ist mir schon klar 🙂 Damit kann ich die <u>Zählerstände</u> auseinander halten.
                        Bei mir sieht das so aus:
                        Für den Punkt "<u>Momentanwert</u>" bekomme ich aber nicht heraus, <u>in welche Richtung jetzt gerade der Strom fließt (180 oder 280)</u>, also ob die hier gerade geleisteten 1237W gerade aus dem Netz bezogen oder ins Netz eingespeist werden. Oder bin ich nur zu blöd, das zu erkennen?
                        Der "Trick" war übrigens, dass man den Lesekopf schief auf das Feld aufsetzen muss. Habe ich auch nur zufällig rausgefunden. Damit kann man natürlich den Magneten nicht mehr richtig nutzen. Habe mir jetzt mit viel Klebeband beholfen, aber es funktioniert nun 🙂
                        Viele Grüße
                        Christian
                          @ChristianF:
                          Für den Punkt "<u>Momentanwert</u>" bekomme ich aber nicht heraus, <u>in welche Richtung jetzt gerade der Strom fließt (180 oder 280)</u>, also ob die hier gerade geleisteten 1237W gerade aus dem Netz bezogen oder ins Netz eingespeist werden. Oder bin ich nur zu blöd, das zu erkennen? `
                          Das hängt vom Zähler ab. Es gibt Zähler da wird der Wert negativ wenn Du abgibst. Es gibt andere, da kannst Du das nicht erkennen 😞 Musst mal schauen was deiner sagt.
                          @ChristianF:
                          Der "Trick" war übrigens, dass man den Lesekopf schief auf das Feld aufsetzen muss. Habe ich auch nur zufällig rausgefunden. Damit kann man natürlich den Magneten nicht mehr richtig nutzen. Habe mir jetzt mit viel Klebeband beholfen, aber es funktioniert nun 🙂 `
                          Lol 😞
                            schneidy76 last edited by
                            @apollon77:
                            @ChristianF:
                            @ChristianF:
                            Lol 😞 `
                            Wie meiner, der gibt auch nur positive Werte raus. Wir arbeiten gerade daran es irgendwie über den Vergleich mit dem Erzeugungszähler heraus zu bekommen.
                            VG Torsten
                              @schneidy76:
                              @apollon77:
                              @ChristianF:
                              @ChristianF:
                              Lol 😞 `
                              VG Torsten `
                              Ich weiß ja nicht wie genau Dein Zähler auflöst, aber bei mir gibt es vier (!) Nachkommastellen. Von daher war es das einfachste, zwei neue Datenpunkte anzulegen: Einspeisung und Netzbezug. Für Scripte etc. werden dann halt diese Datenpunkte genutzt.
                              Nun kommt oben drauf ein Javascript, das bei Änderung des 280-Werts den Power-Wert des Zählers in die Einspeisung schreibt und den Netzbezug auf 0 setzt:
                              on({id: "smartmeter.0.1-0:2_8_0*255.value"/*1-0:2_8_0*255.value*/, change: "ne"}, function (obj) {
                                var value = obj.state.val;
                                setState("javascript.0.Stromzaehler-Netzbezug"/*Stromzaehler-Netzbezug*/, 0, true);
                                setState("javascript.0.Stromzaehler-Einspeisung"/*Stromzaehler-Einspeisung*/, getState("smartmeter.0.1-0:15_7_0*255.value").val, true);
                              Analog ein zweites Script, das bei Änderung des 180 Werts den Power-Wert in den Netzbezug schreibt und die Einspeisung auf 0 setzt:
                              on({id: "smartmeter.0.1-0:1_8_0*255.value"/*1-0:1_8_0*255.value*/, change: "ne"}, function (obj) {
                                setState("javascript.0.Stromzaehler-Netzbezug"/*Stromzaehler-Netzbezug*/, getState("smartmeter.0.1-0:15_7_0*255.value").val, true);
                                setState("javascript.0.Stromzaehler-Einspeisung"/*Stromzaehler-Einspeisung*/, 0, true);
                              Das gibt bisher nur dann Probleme, wenn zwischen Netzbezug und Einspeisung geändert wird. Das dann aber auch nur im Zeitraum des Auslesefensters (bei mir 10sec). Die erzeugte Unschärfe ist daher überschaubar und meiner Meinung nach tragbar. Sollte sich der Verbrauch über längere Zeit zufällig immer um ein paar W an der Erzeugung bewegen, könnte es ebenfalls zu Unschärfen kommen, hier sind die W allerdings dann so gering dass das übers Jahr gesehen nicht mal eine kWh ausmachen dürfte, von daher verschmerze ich die 28ct dann gern 🙂
                              Durch die vier Nachkommastellen ändert sich der Zählerstand sogar im 10sek Takt, selbst wenn wir nur in der absoluten Grundlast liegen (was dann ca. 260W sind, darunter gibt es quasi nix außer Stromausfall 😉 ). Auch wenn sich nur die letzte Stelle ändert, es ändert sich der Wert, und damit ist der ioBroker Trigger erfüllt.
                              VG
                              Christian
                                Update:
                                heute beim Regen konnte man sehr gut beobachten wie Bezug und Einspeisung sich immer minimal abgelöst haben (z.T. ging es da um 10W Unterschied).
                                In diesen Situationen kommt die Unschärfe des Scripts tatsächlich raus. Zum Glück ist aber sowohl der Stromverbrauch im Haus als auch die Erzeugung über die PV so volatil, dass das meistens nur kurz anhält.
                                Ein weiterer Punkt: Das Script oben neigt dazu, manchmal den Vor-Wert zu übertragen, anstatt den neuen, frisch vom Zähler übermittelten Wert. Das liegt daran, dass der neue Wert manchmal noch nicht so schnell in die Datenbank geschrieben wurde, wie das Script ihn abfischt und weiterverwendet. Dieses Problem läßt sich aber elegant lösen, in dem man eine Verzögerung von 100ms einbaut.
                                So sieht es dann aus:
                                var timeout, timeout2;
                                  timeout = setTimeout(function () {
                                  }, 1000);
                                  timeout2 = setTimeout(function () {
                                  }, 1000);
                                VG
                                Christian
                                • N
                                  noxx last edited by
                                  funktioniert der Adapter auch mit ESPeasy und dem Pulse Counter?
                                  Oder gibt es Arduino Lösungen? Habe am Arduino im moment ein Read-Schalter, der
                                  Read-Schalter am Gaszähler.
                                  Ähnlich wie hier: https://voizchat.de/gaszaehler-verbrauc … erry-gpio/
                                    Der Adapter liest "smartmeter" aus, also solche die die Daten über ein Protokoll bereitstellen. Die Reed Schalter bei dir liefern an der Stelle "nur" einen S0 Zählimpuls. Dafür ist der Adapter nicht geeignet.
                                    Es gibt Geräte die s0 zählen und per sml oder d0 oder json Formate bereitstellen. Die könnte der Adapter wieder auslesen.
                                    • N
                                      noxx last edited by
                                      kann man mit nem Arduino (Nodemcu) nichts zaubern?
                                      • N
                                        noxx last edited by
                                        im übrigen spuckt ESPeasy auch was im JSON aus. Weiß nur
                                        nicht, ob man was damit anfangen kann
                                        Folgender Code
                                        http://192.168.1.43/json?tasknr=1
                                        liefert
                                        "TaskName": "Gaszaehler",
                                        "Count": 0.00,
                                        "Total": 5.00,
                                        "Time": 13251.00
                                          Bisher basiert die auswertelogik des Adapters auf OBIS-IDs. Das ist ein Standard um zählerwerte zu kodieren. Ein json Format kann er schon: vom efr Smart Grid hub. Format: http://www.mysmartshop.de/pdf/bedienung … eitung.pdf Seite 10 ... Bau das als Ausgabe nach und es tut ;-). Es müssen auch nicht die gleichen und alle der im Beispiel gezeigten OBIS Werte kommen. Halt das was man haben will ... das wäre das einfachste.
                                            Ps: einfaches auslesen so eines http Ziels ist aber auch mit iobroker JavaScript Mega simpel ohne Adapter. Der Adapter ist hier nur da weil er die Protokolle implementiert hat und das OBIS Mapping macht.
                                            3625
                                            2209342
