    3. Einsteigerfragen
    4. langsamer IObroker auf Raspberry
      Thomas Braun Most Active @gluecksmann last edited by
      @gluecksmann
      Bring dein System halt auf den aktuellen Stand. nodejs@16/npm@8 ist angesagt.
        @arteck
        Skript v.0.0.8
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Architecture:   armv7l
        Docker:         false
        Virtualization: none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
        05:26:33 up 22 days, 19:48,  1 user,  load average: 0.73, 0.50, 0.46
        CPU threads: 4
        *** Time and Time Zones ***
        Sun Dec  4 04:26:33 UTC 2022
        Sun Dec  4 05:26:33 CET 2022
        CET +0100
        Europe/Berlin
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           7.9G        1.6G        3.9G        435M        2.4G        5.8G
        Swap:           99M         99M        0.0K
        Total:         8.0G        1.7G        3.9G
                7898 M total memory
                1597 M used memory
                 754 M active memory
                2964 M inactive memory
                3933 M free memory
                 196 M buffer memory
                2171 M swap cache
                  99 M total swap
                  99 M used swap
                   0 M free swap
        *** FILESYSTEM ***
        /dev/root      ext4       29G  8.0G   20G  29% /
        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     3.9G  436M  3.5G  12% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
        Show mounted filesystems (real ones only):
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=4
        /var:
        351M    /var/
        117M    /var/lib
        76M     /var/cache
        69M     /var/lib/apt/lists
        69M     /var/lib/apt
        /opt/iobroker/backups:
        94M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        497M    /opt/iobroker/iobroker-data/
        229M    /opt/iobroker/iobroker-data/files
        135M    /opt/iobroker/iobroker-data/backup-objects
        79M     /opt/iobroker/iobroker-data/sonosCache
        48M     /opt/iobroker/iobroker-data/files/javascript.admin
        21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chu        nk.js.map
        17M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/objects.json.migrated
        12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33        b.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v16.18.1
        /usr/bin/node           v16.18.1
        /usr/bin/npm            8.19.2
        nodejs:
         Installed: 16.18.1-deb-1nodesource1
         Candidate: 16.18.1-deb-1nodesource1
         Version table:
        *** 16.18.1-deb-1nodesource1 500
               500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
               100 /var/lib/dpkg/status
            10.24.0~dfsg-1~deb10u2 500
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.23
        admin:          6.2.23
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/ca        seless
        npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/req        uest
        npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types        /tough-cookie
        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
        npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
        npm ERR! invalid: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/i        obroker.icons-ultimate-png
        npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR!     /home/pi/.npm/_logs/2022-12-04T04_26_47_566Z-debug-0.log
        Adapters from github:   2
        + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
        + system.adapter.hue.0                    : hue                   : raspberrypi        -  enabled, port: 443
        + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi        -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi        -  enabled, port: /dev/ttyACM0
        ioBroker-Repositories
        Active repo(s): stable
        ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.2.23   , installed 6.2.23
        Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
        Adapter    "alias-manager": 1.2.4    , installed 1.2.6
        Adapter    "backitup"     : 2.5.4    , installed 2.5.4
        Adapter    "ble"          : 0.13.0   , installed 0.13.0
        Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
        Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
        Adapter    "devices"      : 1.0.12   , installed 1.0.12
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hue"          : 3.7.1    , installed 3.7.1
        Adapter    "ical"         : 1.13.1   , installed 1.13.1
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.9   , installed 1.11.9
        Adapter    "javascript"   : 6.0.3    , installed 6.0.3
        Adapter    "meross"       : 1.14.0   , installed 1.14.0
        Adapter    "mielecloudservice": 6.4.0, installed 6.4.0
        Adapter    "musiccast"    : 0.1.5    , installed 0.2.2
        Adapter    "netatmo"      : 2.0.5    , installed 1.7.1  [Updatable]
        Adapter    "philips-air"  : 0.1.7    , installed 0.1.7
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
        Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
        Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
        Adapter    "socketio"     : 4.2.0    , installed 6.1.7
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "sonos"        : 2.2.3    , installed 2.2.3
        Adapter    "trashschedule": 2.0.3    , installed 2.0.3
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
        Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "web"          : 4.3.0    , installed 5.2.3
        Adapter    "ws"           : 1.3.0    , installed 2.1.2
        Adapter    "zigbee"       : 1.7.6    , installed 1.7.5  [Updatable]
        Objects and States
        Objects:        11128
        States:         8952
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
        Reading package lists... Done
        Pending Updates: 6
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18549      652/sshd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          202640585  24427/cupsd
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1184291    7301/io.sonoff.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1183169    7106/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1183162    7106/iobroker.js-co
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1184917    7136/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11996056   20757/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          18551      652/sshd
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          202640584  24427/cupsd
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       1184341    7322/io.sonos.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       1185129    7278/io.shelly.0
        udp        0      0 0.0.0.0:40506           0.0.0.0:*                           108        17622      399/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14851      641/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          202638011  24429/cups-browsed
        udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       1187178    7715/io.musiccast.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1184502    7409/io.chromecast.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17620      399/avahi-daemon: r
        udp6       0      0 :::47531                :::*                                108        17623      399/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14862      641/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        17621      399/avahi-daemon: r
          Homoran Global Moderator Administrators @gluecksmann last edited by
          @gluecksmann sagte in langsamer IObroker auf Raspberry:
          Swap: 99M 99M 0.0K
          was läuft da?
          der swap ist komplett verbraucht. Das bremst.
            gluecksmann @Homoran last edited by
            Nix außer dem IOBroker
              @gluecksmann
              Dann installier da ein 64bit Buster/Debian 11
                gluecksmann @Thomas Braun last edited by
                DAs wird an meinem fehlendem Fachwissen scheitern...
                wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                • wendy2702
                  wendy2702 @gluecksmann last edited by
                  @gluecksmann läuft nur Iobroker auf dem Pi?
                    @gluecksmann
                    Installieren, iobroker-Backup einspielen, fertig.
                    Irgendwie hast du ja dein 32bit Buster ja auch draufbekommen.
                      gluecksmann @wendy2702 last edited by
                      @wendy2702
                      Ja, nix anderes...
                        Sorry, habe nur mit Hilfe des Forums 3 Wochen gebraucht um nach einem "Vorfall" das Backup wieder funktionsfähig einzuspielen...
                          Thomas Braun Most Active @gluecksmann last edited by Thomas Braun
                          @gluecksmann
                          Dann hast du ja jetzt Übung.
                          Buster ist jedenfalls seit September offiziell tot.
                          370
