langsamer IObroker auf Raspberry
Skript v.0.0.8 *** BASE SYSTEM *** Model : Raspberry Pi 4 Model B Rev 1.4 Architecture: armv7l Docker: false Virtualization: none Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster PRETTY_NAME="Raspbian GNU/Linux 10 (buster)" NAME="Raspbian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" Systemuptime and Load: 05:26:33 up 22 days, 19:48, 1 user, load average: 0.73, 0.50, 0.46 CPU threads: 4 *** Time and Time Zones *** Sun Dec 4 04:26:33 UTC 2022 Sun Dec 4 05:26:33 CET 2022 CET +0100 Europe/Berlin *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g pio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 7.9G 1.6G 3.9G 435M 2.4G 5.8G Swap: 99M 99M 0.0K Total: 8.0G 1.7G 3.9G 7898 M total memory 1597 M used memory 754 M active memory 2964 M inactive memory 3933 M free memory 196 M buffer memory 2171 M swap cache 99 M total swap 99 M used swap 0 M free swap *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 8.0G 20G 29% / devtmpfs devtmpfs 3.7G 0 3.7G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 3.9G 436M 3.5G 12% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 790M 0 790M 0% /run/user/1000 Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=4 Files in neuralgic directories: /var: 351M /var/ 117M /var/lib 76M /var/cache 69M /var/lib/apt/lists 69M /var/lib/apt /opt/iobroker/backups: 94M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 497M /opt/iobroker/iobroker-data/ 229M /opt/iobroker/iobroker-data/files 135M /opt/iobroker/iobroker-data/backup-objects 79M /opt/iobroker/iobroker-data/sonosCache 48M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 21M /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chu nk.js.map 17M /opt/iobroker/iobroker-data/objects.jsonl 12M /opt/iobroker/iobroker-data/objects.json.migrated 12M /opt/iobroker/iobroker-data/objects.json.bak.migrated 12M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33 b.chunk.js.map *** NodeJS-Installation *** /usr/bin/nodejs v16.18.1 /usr/bin/node v16.18.1 /usr/bin/npm 8.19.2 nodejs: Installed: 16.18.1-deb-1nodesource1 Candidate: 16.18.1-deb-1nodesource1 Version table: *** 16.18.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u2 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 4.0.23 admin: 6.2.23 npm ERR! code ELSPROBLEMS npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/ca seless npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/req uest npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types /tough-cookie npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee npm ERR! invalid: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/i obroker.icons-ultimate-png npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-12-04T04_26_47_566Z-debug-0.log Adapters from github: 2 Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admi n + system.adapter.hue.0 : hue : raspberrypi - enabled, port: 443 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admi n + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/ttyACM0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable ioBroker-Instances Used repository: stable Adapter "admin" : 6.2.23 , installed 6.2.23 Adapter "alexa2" : 3.21.0 , installed 3.21.0 Adapter "alias-manager": 1.2.4 , installed 1.2.6 Adapter "backitup" : 2.5.4 , installed 2.5.4 Adapter "ble" : 0.13.0 , installed 0.13.0 Adapter "chromecast" : 2.3.1 , installed 2.3.1 Adapter "daswetter" : 3.1.4 , installed 3.1.4 Adapter "devices" : 1.0.12 , installed 1.0.12 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "ecovacs-deebot": 1.4.4 , installed 1.4.4 Adapter "fullybrowser" : 2.1.2 , installed 2.1.2 Adapter "gruenbeck" : 0.0.42 , installed 0.0.42 Adapter "history" : 2.2.0 , installed 2.2.0 Adapter "hue" : 3.7.1 , installed 3.7.1 Adapter "ical" : 1.13.1 , installed 1.13.1 Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 6.0.3 Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "meross" : 1.14.0 , installed 1.14.0 Adapter "mielecloudservice": 6.4.0, installed 6.4.0 Adapter "musiccast" : 0.1.5 , installed 0.2.2 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "netatmo" : 2.0.5 , installed 1.7.1 [Updatable] Adapter "philips-air" : 0.1.7 , installed 0.1.7 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.0.0 , installed 6.0.0 Adapter "shuttercontrol": 1.4.18 , installed 1.4.18 Adapter "simple-api" : 2.7.0 , installed 2.7.2 Adapter "smartcontrol" : 1.2.1 , installed 1.2.1 Adapter "socketio" : 4.2.0 , installed 6.1.7 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "sonos" : 2.2.3 , installed 2.2.3 Adapter "trashschedule": 2.0.3 , installed 2.0.3 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "vis-colorpicker": 1.2.0 , installed 1.2.0 Adapter "vis-hqwidgets": 1.3.0 , installed 1.3.0 Adapter "vis-icontwo" : 0.90.0 , installed 0.90.0 Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1 Adapter "vis-material-advanced": 1.7.2, installed 1.7.2 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.4.2, installed 3.4.2 Adapter "web" : 4.3.0 , installed 5.2.3 Adapter "ws" : 1.3.0 , installed 2.1.2 Adapter "zigbee" : 1.7.6 , installed 1.7.5 [Updatable] Objects and States Please stand by - This may take a while Objects: 11128 States: 8952 *** OS-Repositories and Updates *** Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 https://deb.nodesource.com/node_16.x buster InRelease Reading package lists... Done Pending Updates: 6 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 18549 652/sshd tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 202640585 24427/cupsd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 1184291 7301/io.sonoff.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 1183169 7106/iobroker.js-co tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 1183162 7106/iobroker.js-co tcp6 0 0 :::8081 :::* LISTEN 1001 1184917 7136/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 11996056 20757/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 18551 652/sshd tcp6 0 0 ::1:631 :::* LISTEN 0 202640584 24427/cupsd tcp6 0 0 :::3500 :::* LISTEN 1001 1184341 7322/io.sonos.0 udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 1185129 7278/io.shelly.0 udp 0 0 0.0.0.0:40506 0.0.0.0:* 108 17622 399/avahi-daemon: r udp 0 0 0.0.0.0:68 0.0.0.0:* 0 14851 641/dhcpcd udp 0 0 0.0.0.0:631 0.0.0.0:* 0 202638011 24429/cups-browsed udp 0 0 0.0.0.0:41100 0.0.0.0:* 1001 1187178 7715/io.musiccast.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 1184502 7409/io.chromecast. udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 17620 399/avahi-daemon: r udp6 0 0 :::47531 :::* 108 17623 399/avahi-daemon: r udp6 0 0 :::546 :::* 0 14862 641/dhcpcd udp6 0 0 :::5353 :::* 108 17621 399/avahi-daemon: r
@gluecksmann sagte in langsamer IObroker auf Raspberry:
Swap: 99M 99M 0.0K
was läuft da?
der swap ist komplett verbraucht. Das bremst. -
Nix außer dem IOBroker
Dann installier da ein 64bit Buster/Debian 11
DAs wird an meinem fehlendem Fachwissen scheitern...
@gluecksmann läuft nur Iobroker auf dem Pi?
Installieren, iobroker-Backup einspielen, fertig.
Irgendwie hast du ja dein 32bit Buster ja auch draufbekommen.
Ja, nix anderes...
Sorry, habe nur mit Hilfe des Forums 3 Wochen gebraucht um nach einem "Vorfall" das Backup wieder funktionsfähig einzuspielen...
