      TT-Tom @Vumer last edited by TT-Tom
      @vumer
      das Script ist vom mir. Poste bitte mal die Einstellungen von dem Script. Läuft der ical Adapter mit einem Abfallkalender? Hast du im Table-Ordner ein "JSON" mit den Daten?
      Vumer 1 Reply Last reply Reply Quote 0
      • Vumer
        @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
        Gerne, hilf mir bitte was genau.
        Das Script funktioniert
        Sobalt ein neuer Event auftaucht kommt diese FM
        • Vumer
          Vumer @TT-Tom last edited by Vumer
          @tt-tom
          host.iobroker
          	2022-12-05 22:08:00.330	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          javascript.0
          	2022-12-05 22:07:54.685	error	at processImmediate (node:internal/timers:466:21)
          javascript.0
          	2022-12-05 22:07:54.685	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
          javascript.0
          	2022-12-05 22:07:54.685	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
          javascript.0
          	2022-12-05 22:07:54.684	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
          javascript.0
          	2022-12-05 22:07:54.684	error	at Object.<anonymous> (script.js.common.NSPanel.Abfallkalender:61:18)
          javascript.0
          	2022-12-05 22:07:54.684	error	at subsequenceFromStartLast (script.js.common.NSPanel.Abfallkalender:52:24)
          javascript.0
          	2022-12-05 22:07:54.684	error	script.js.common.NSPanel.Abfallkalender: TypeError: Cannot read properties of null (reading 'length')
          host.iobroker
          	2022-12-05 22:07:51.554	info	instance system.adapter.ical.0 started with pid 14903
          host.iobroker
          	2022-12-05 22:07:51.539	info	instance scheduled system.adapter.ical.0 17 */6 * * *
          host.iobroker
          	2022-12-05 22:07:48.359	info	stopInstance canceled schedule system.adapter.ical.0
          host.iobroker
          	2022-12-05 22:07:48.359	info	stopInstance system.adapter.ical.0 (force=false, process=false)
          host.iobroker
          	2022-12-05 22:07:33.750	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          es reich dem iCal Adapter neu zu starten
          aber nur wenn das Script leuft
          • Armilar
            Armilar Most Active Forum Testing @Vumer last edited by Armilar
            @vumer
            ist die Tagesvorschau groß genug?
            Es sollten mindestens 4 Events erzeugt werden. Auch wenn die zum Teil über mehrere Wochen stattfinden.
            Da die einzige Längenermittlung im Skript ein Problem verursacht, könnte ich mir vorstellen, dass es bei der subsequenceFromStartLast stattfindet, jedoch kein 3. oder 4. Eintrag gefunden wird und dann der Fehler kommt. 🙄
            Vumer 1 Reply Last reply Reply Quote 1
            • Vumer
              Vumer @Armilar last edited by
              @armilar sagte in SONOFF NSPanel mit Lovelace UI:
              Das war es. Ich hatte 14 Tage
              Danke.
              Armilar T 2 Replies Last reply Reply Quote 0
              • Armilar
                @vumer
                Ja, hätte mich auch sonst gewundert 😉
                Jetzt noch die Warnungen (Aliase) drauflegen und ab ins Panel
                • Vumer
                  Was meinst du mit den Warnungen (Aliase)? Termine? Die sind schon lenger im Panel.
                  • Armilar
                    @vumer
                    Ach so, die sind schon drin. Na dann aber jetzt wieder alle 😊
                    • Vumer
                      @armilar
                      Ich hab nur Allergie auf rot im Log. Bei gelb gehts mir auch nicht gut
                      Armilar 1 Reply Last reply Reply Quote 1
                      • Armilar
                        Armilar Most Active Forum Testing @bean last edited by
                        @bean
                        https://youtu.be/qEbxVWK6y8U
                        Ist ja ein cooles Video. Und schon richtig viel drin... hatte ich vorhin gar nicht ganz wahrgenommen 👍
                        • Armilar
                          @vumer
                          rot ist auch nicht meine Farbe im Log. Mit gelb kann ich leben, wenns nicht von meinen Sachen kommt 😂
                            HI @vumer,
                            schön das es läuft. Viel Spass weiter mit dem Panel.
                            • V
                              valbuz last edited by
                              Hallo
                              Bin auch dabei meine Erfahrungen mit dem Panel zu sammeln.
                              Soweit läuft's auch.
                              Bin jedoch noch etwas mit dem Screensaver am verhandeln... 😑
                              Wer kann mir die einzelnen Einstellungen kurz erklären? Siehe Bild.
                              Ebenfalls ändert sich nichts wenn ich folgenden Wert in der Script Datei ändere:
                              dimmode: 8,
                              Wie verhalten sich all diese Einstellungen untereinander? 🙄
                              Danke 🙏
                                froitzheims @Armilar last edited by froitzheims
                                @armilar
                                vielen leben Dank
                                nach dem Update auf die 16.X gab es noch das Problem mit dem nicht angezeigten device Adapter.
                                Ich habe auf Ubuntu eine IOBROKER Test installation dort habe ich aus meinem Echtsystem einmal das Backup zurück gespielt.
                                Und siehe da man konnte dort den Device Adapter danach installieren.
                                Ich habe versucht heraus zu finden warum das so ist.
                                Bin aber nicht wirklich weitergekommen hatten den Sourceanalytics im Verdacht.
                                Heute habe ich dann einfach ein Backup auf meinem Echtsystem zurückgespielt.
                                Dan konnte ich den Device Adapter installieren und kann jetzt endlich weiter testen .
                                Gruß Marcus
                                • Armilar
                                  Armilar Most Active Forum Testing @valbuz last edited by Armilar
                                  @valbuz
                                  Ich mach es dann mal mit der Erklärung 😉
                                  Das Panel hat die Aliase vom Typ Slider erstellt, die wiederum greifen auf 4 Datenpunkte in 0_userdata (hat das Script dir ebenfalls erstellt) zu.
                                  0_userdata.0.NSPanel.1.NSPanel_Dimmode_brightnessDay ist die Helligkeit (bei dir aktuell 10) des Displays, die mit der Stunde Tag (bei dir aktuell 10:00 Uhr = hourDay) beginnt.
                                  0_userdata.0.NSPanel.1.NSPanel_Dimmode_brightnessDay ist die Helligkeit (bei dir aktuell 2) des Displays, die mit der Stunde Nacht (bei dir aktuell 5:00 Uhr = hourNight) beginnt.
                                  Deine aktuellen Einstellungen:
                                  Bei dir fängt der Abend/Nacht um 5:00 Uhr an. In dieser Zeit bis zum Tagesbeginn um 10:00 Uhr (d.h. 5 Stunden später) wird das Screensaver-Display auf Helligkeit 2% gestellt. Ab 10:00 Uhr fängt bei dir der Tag an. Das Display wechselt im Screensaver auf 10% Helligkeit.
                                  Der Parameter dimmode: 8, ist noch ein Relikt aus alten Zeiten (Als es noch keine DP's gab und das Panel nur einen Zustand kannte) und wird nirgendwo mehr im Code verwendet.
                                  Zu den definierten Stunden stellt jeweils ein Scheduler im Script die Helligkeiit um. Bei Start des Scriptes erfolgt ebenfalls eine initiale Überprüfung.
                                  //Subpage 2 von Subpages_2
                                         let NSPanel_Einstellungen: PageEntities =
                                             'type': 'cardEntities',
                                             'heading': 'Screensaver',
                                             'useColor': true,
                                             'subPage': true,
                                             'parent': Service,
                                             'items': [
                                                 <PageItem>{ id: AliasPath + 'Dimmode.brightnessDay', name: 'Brightness Tag', icon: 'brightness-5', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 5, maxValue: 10},
                                                 <PageItem>{ id: AliasPath + 'Dimmode.brightnessNight', name: 'Brightness Nacht', icon: 'brightness-4', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 4},
                                                 <PageItem>{ id: AliasPath + 'Dimmode.hourDay', name: 'Stunde Tag', icon: 'sun-clock', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23},
                                                 <PageItem>{ id: AliasPath + 'Dimmode.hourNight', name: 'Stunde Nacht', icon: 'sun-clock-outline', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23}
                                  In diesen pageItems findest du ebenfalls die Einstellungen für die Slider in Form von minValue und maxValue. Die können natürlich angepasst werden.
                                  • Armilar
                                    Armilar Most Active Forum Testing @froitzheims last edited by
                                    @froitzheims
                                    Sehr gerne. Noch ein Tipp für die Zukunft...
                                    Unter Info und dann unter Systeminformationen rechts:
                                    findest du die Node.js Version ebenfalls. Wenn die gelb oder rot wird, steht in der Regel auch die empfohlene Version dabei. Wenn es eine empfohlene Version gibt, sollte die nach Möglichkeit auch unmittelbar installiert werden. Die wird immer entsprechend korrekte Funktionalitäten für den ioBroker zur Verfügung stellen. Anderenfalls kann es zu Problemen in der Ausführung kommen!
                                    Der Satz "Never touch a running System" ist das dümmste was man in der Server-Welt machen kann. Die vorherige Version ist bereits fehlerbehaftet und die neue Version beinhaltet bereits das "Pflaster" für diese Fehler. Gilt auch für das Betriebssystem.
                                    Konntest du damit auch das Sprachthema erledigen?
                                    • V
                                      valbuz @Armilar last edited by
                                      @armilar Da Danke ich vielmals! 👍 😊
                                      Ja bei Relikten aus alten Zeiten, wird's schwierig um eine Logik zu finden 😳
                                      Danke nochmals.
                                      Pat
                                        Woffi1967 @joBr99 last edited by
                                        @jobr99 : Hallo jobr99,
                                        sorry wenn ich jetzt diesen Weg wähle.
                                        Leider finde ich keinen Button um ein neues Thema zu öffnen.
                                        Ich habe ein Problem, das Scritpt NSPanelTS.ts zu starten. Ich bekomme die Fehlermeldung
                                        javascript.0 (1433) script.js.common.NSPANEL_1_3_6_0_3 compile failed: at script.js.common.NSPANEL_1_3_6_0_3:166
                                        In der Zeile 166 steht folgender Befehl: let timeoutSlider: any;
                                        Würde mich über eine Hilfe freuen.
                                        Mfg Wolfgang
                                        Armilar 2 Replies Last reply Reply Quote 0
                                        • Armilar
                                          Armilar Most Active Forum Testing @Woffi1967 last edited by Armilar
                                          @woffi1967
                                          Hi und erstmal herzlich willkommen.
                                          Neues Thema ist gar nicht erforderlich und somit absolut korrekt gemacht. @joBr99 ist übrigens für die Nextion-TFT-Firmware und Home Assistant zuständig. Deshalb übernehme ich mal im Bereich TS-Script und ioBroker...
                                          Könntest du das Log mit den Fehlern kurz in Code-Tags posten? Oben in der Menüleiste f163ce7f-a28b-419e-b388-5c144fff3ec8-image.png
                                          Nur mit der Info des timeoutSlider kann ich erstmal alleine nichts anfangen.
                                          EDIT: Die Fehlersuche ist oft nicht einfach, da die Zeilennummern (in deinem Fall 166) nicht auf den Fehler hinweisen. Ist eher eine Näherung 😉
                                          • Armilar
                                            @woffi1967
                                            Ich tippe übrigens auf die IconSelector, also das 2. TypeScript, dass die Icons enthält und im global angelegt sein muss (und natürlich angeschaltet)
                                            Bist du nach dieser Anleitung vorgegangen?
                                            https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation
                                            lovelace ui nspanel sonoff
                                            270
                                            7630
                                            6285836
