    4. Test Adapter LG ThinQ
      Lucky_ESA Developer Most Active @freak9882 last edited by
      @freak9882 sagte in Test Adapter LG ThinQ v0.0.1:
      @lucky_esa DANKE, jetzt funktioniert es.
      Freut mich...
      Gruß//Lucky
        Lars0815 last edited by
        Guten Morgen, leider habe ich noch dem Update auf die aktuellste Version nur noch diese Meldung. Neuinstallieren brachte auch kein Erfolg.
        lg-thinq.0
        Zeit
        debug
        Nachricht
        lg-thinq.0
        2022-12-01 06:35:15.249 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v16.18.0, js-controller: 4.0.23
        lg-thinq.0
        2022-12-01 06:35:19.326 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
        lg-thinq.0
        2022-12-01 06:35:19.324 info terminating
        lg-thinq.0
        2022-12-01 06:35:19.316 error Cannot convert undefined or null to object
        lg-thinq.0
        2022-12-01 06:35:19.315 error TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at LgThinq.createAirRemoteStates (/opt/iobroker/node_modules/iobroker.lg-thinq/lib/air_conditioning.js:61:16) at processTicksAndRejections (node:internal/process/task_queues:96:5) at async LgThinq.getDeviceModelInfo (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:668:17) at async LgThinq.onReady (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:154:57)
        lg-thinq.0
        2022-12-01 06:35:19.314 error unhandled promise rejection: Cannot convert undefined or null to object
        lg-thinq.0
        2022-12-01 06:35:19.313 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        lg-thinq.0
        2022-12-01 06:35:18.861 info createAirRemoteStates: Cannot found ControlDevice
        lg-thinq.0
        2022-12-01 06:35:18.530 info Found: 1 devices
        lg-thinq.0
        2022-12-01 06:35:17.342 info Login successful
        M T L 3 Replies Last reply Reply Quote 0
          mmaric @Lars0815 last edited by
          @lars0815
          hast Du die Objekte mal gelöscht und dann die Instanz wieder gestartet ?
            tombox @Lars0815 last edited by
            @lars0815 Mit der Github version sollte es behoben sein was aber noch interessant wäre ist ein GitHub issue wo du aus dem debug log die information von deinem gerät reinschreibst
              Lucky_ESA Developer Most Active @Lars0815 last edited by
              @lars0815 Bitte ein issues HIER und dein Debug Log dort posten. Ich benötige immer den Inhalt vom DP modelJsonUri damit ich das implementieren kann.
              Gruß//Lucky
                Lars0815 @Lucky_ESA last edited by
                @lucky_esa
                Auch mit Version 1.3 folgendes Problem:
                2022-12-04 20:14:53.138 - info: lg-thinq.0 (5400) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                2022-12-04 20:14:53.412 - info: lg-thinq.0 (5400) starting. Version 0.1.3 (non-npm: TA2k/ioBroker.lg-thinq#c1c688b5321605dcab49f244ebdf0f707fffad0a) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v16.18.0, js-controller: 4.0.23
                2022-12-04 20:14:53.497 - info: smartmeter.0 (7177) Received 7 values, 3 updated
                2022-12-04 20:14:54.900 - info: lg-thinq.0 (5400) Login successful
                2022-12-04 20:14:55.784 - info: lg-thinq.0 (5400) Found: 1 devices
                2022-12-04 20:14:56.094 - info: lg-thinq.0 (5400) createAirRemoteStates: Cannot found ControlDevice
                2022-12-04 20:14:56.362 - error: lg-thinq.0 (5400) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2022-12-04 20:14:56.363 - error: lg-thinq.0 (5400) unhandled promise rejection: Cannot read properties of undefined (reading '0')
                2022-12-04 20:14:56.364 - error: lg-thinq.0 (5400) TypeError: Cannot read properties of undefined (reading '0')
                at LgThinq.getDeviceModelInfo (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:684:44)
                2022-12-04 20:14:56.365 - error: lg-thinq.0 (5400) Cannot read properties of undefined (reading '0')
                2022-12-04 20:14:56.371 - info: lg-thinq.0 (5400) terminating
                2022-12-04 20:14:56.373 - warn: lg-thinq.0 (5400) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2022-12-04 20:14:57.116 - error: host.rpi4 instance system.adapter.lg-thinq.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  @lars0815 kannst du mal den adapter in debug laufen lassen und den content nach
                  Get Device Model Info
                  posten
                    Lucky_ESA Developer Most Active last edited by Lucky_ESA
                    @lucky_esa sagte in Test Adapter LG ThinQ v0.0.1:
                    modelJsonUri
                    Wie bereits von mir beschrieben benötige ich den Inhalt vom Datenpunkt modelJsonUri. Du hast wahrscheinlich ein thinq1 Geräte was auf dem GIT nicht gefixt ist.
                    Edit1: Issue auf GIT erstellt..Danke..
                    Gruß//Lucky
                      @lucky_esa Es hat aber bis zum letzten Update wunderbar funktioniert. 🤷‍♂️
                        @lars0815 sagte in Test Adapter LG ThinQ v0.0.1:
                        Ja, aber wie oben zu sehen, haben wir ein device 401 thinq2 hinzugefügt und du hast 401 thinq1. Das verursacht den Fehler.
                        Du kannst vom GIT laden, diese Version sollte wieder funktionieren.
                        Gruß//Lucky
                          g.pitzer last edited by
                          Ich bin soeben auf diesen Thread gestossen da ich zwei Klima Splitgeräte habe und diese steuern möchte. Leider habe ich auch thing1 Geräte welche nur gelesen und nicht gesteuert werden können.
                          Meine Frage: Wird daran noch gearbeitet? Kann man das irgendwie unterstützen?
                          Andere Frage welche nicht zum Thema passt, aber ich versuchs trotzdem: macht es Sinn mit der Klimaanlage bei einer PV mit Überschuss zu heizen und damit die Ölheizung zu entlassten?
                          Danke und lg
                            Lucky_ESA Developer Most Active @g.pitzer last edited by
                            @g-pitzer Bist du sicher das du nichts steuern kannst? Es sollte ein Ordner "remote" vorhanden sein. Wenn dieser fehlt wird dein Account benötigt.
                            Deine zweite Frage kann ich dir leider nicht beantworten.
                            Gruß//Lucky
                              shellyrulestheworld @Lucky_ESA last edited by shellyrulestheworld
                              @lucky_esa said in Test Adapter LG ThinQ v0.0.1:
                              Wer nur thinq2 Geräte hat kann nun sein Intervall auf 60 Minuten ändern
                              Hallöchen,
                              vielen Dank erst mal für die tolle Arbeit. Gerade die WAMA erfolgreich gestartet.
                              Habe aber noch 2 Fragen:
                              1. Wer nur thinq2 Geräte hat kann nun sein Intervall auf 60 Minuten ändern
                                --> ist damit das Intervall im Adapter gemeint? Ich habe da aktuell 1 Minute drin.
                              2. wie pausiere ich den Waschgang richtig? Möchte bei PV Überschuss starten bzw. stoppen (pausieren)
                                Und wie lange kann ich pausieren, bis ich die WAMA wieder am Gerät einschalten muss? Inkl. Fernstart aktivieren?
                              Nutzt diese "Pause"-Funktion schon jemand in einem Blockly / Script?
                                Lucky_ESA Developer Most Active @shellyrulestheworld last edited by
                                @peterschatz
                                Zu 1: Lass auf 1 Minute stehen. Habe noch Probleme mit der MQTT Verbindung. Habe das bereits gefixt und es läuft bei mir 5 Wochen fehlerfrei. Es wird bald ein Update kommen.
                                Zu 2: Für Pause gibt es lg-thinq.0.deviceID.remote.WMStop aber das habe ich noch nie getestet. Versuche es einfach mal...True für Pause und erneut True für weiter. Ja, Fernstart muss manuell aktiviert sein.
                                Gruß//Lucky
                                JackDaniel 1 Reply Last reply Reply Quote 1
                                  sudete @Lucky_ESA last edited by
                                  lg-thinq.0.xxx.remote.WMStart
                                  Hallo und vielen Dank für diesen super Lg ThinQ Adapter!
                                  Meine Klimaanlage funktioniert prima mit dem Adapter...nachdem der Adapter nun auch Thinq2-201 Geräte voll unterstützen soll,
                                  habe ich den Adapter mit meinem Signature-Waschtrockner probiert. Leider funktioniert die Remote Steuerung nur bedingt bzw. garnicht.
                                  Folgende Prozedure habe ich getestet:
                                  1.lg-thinq.0.xxx.remote.WMDownload_Select -> z.B.: EASYCARE_CS-STD
                                  2.lg-thinq.0.xxx.remote.WMDownload -> ca 2s auf true
                                  3.lg-thinq.0.xxx.remote.WMStart -> ca 2s auf true
                                  dann geht
                                  lg-thinq.0.xxx.remote.WMDownload_Select auf NOT_SELECTED
                                  und ich bekomme eine Warning vom Adapter
                                  Log Meldung: lg-thinq.0 2023-02-23 11:16:06.943 warn Datapoint WMDownload_Select is empty!
                                  Der Waschtrockner schaltet aus.
                                  hier noch ein paar Datenpunkt-Infos:
                                  lg-thinq.0.xxx.remote.Favorite -> false
                                  lg-thinq.0.xxx.remote.LastCourse -> NOT_SELECTED(0)
                                  lg-thinq.0.xxx.langPackModelUri -> https://objectcontent.lgthinq.com/e3faf059-253d-4fd4-8678-2a152427b355?hdnts=exp=1689396157~hmac=35abf699a63466d6efa493dda438e93a5f39b882974b79f031d5a62300a9970c
                                  lg-thinq.0.xxx.modelJsonUri -> https://objectcontent.lgthinq.com/4df5ecde-bf98-49d2-a562-4037df401c4e?hdnts=exp=1691553592~hmac=d711e49cb7702f9f49b5d09bd443e98f2099c83078b36703c453d3e51aa2f4a0
                                  lg-thinq.0.xxx.deviceType -> 201
                                  lg-thinq.0.xxx.platformType -> thinq2
                                  Hat jemand eine Idee?
                                  • JackDaniel
                                    JackDaniel @Lucky_ESA last edited by
                                    hust, mal nachgefragt wann "bald" eigentlich ist 🙂
                                      Lucky_ESA Developer Most Active @JackDaniel last edited by
                                      @jackdaniel Mach ich vielleicht heute noch
                                      @sudete Hier habe ich leider ein Problem. Meine Annahme war, dass das Model 201 eine Waschmaschine ist Du hast aber eine Kombi und daher passt das alles nicht. Jetzt fehlt mir die Idee wie ich festellen kann, ob es eine WA oder Kombi ist. Wahrscheinlich müsste uns auch @tombox helfen da ich nur vermuten kann welche Werte an das Kombi-Gerät gesendet werden....Auwaia...
                                      L T 2 Replies Last reply Reply Quote 0
                                        Lucky_ESA Developer Most Active @Lucky_ESA last edited by
                                        @sudete Hier habe ich leider ein Problem. Meine Annahme war, dass das Model 201 eine Waschmaschine ist Du hast aber eine Kombi und daher passt das alles nicht. Jetzt fehlt mir die Idee wie ich festellen kann, ob es eine WA oder Kombi ist. Wahrscheinlich müsste uns auch @tombox helfen da ich nur vermuten kann welche Werte an das Kombi-Gerät gesendet werden....Auwaia...Kannst du mal bitte auf debug stellen und mir das File zusenden github@luckyskills.de
                                          tombox @Lucky_ESA last edited by
                                          @JackDaniel @lucky_esa oder mal ein debug log via pn zusenden da sind auch alle infos drin
                                            Lucky_ESA Developer Most Active @JackDaniel last edited by Lucky_ESA
                                            @jackdaniel Habe es jetzt auf`m GIT
                                            @sudete Wie von tombox und mir beschrieben benötigen wir einen debuglog. Vielleicht finde ich dort eine Info womit ich erkennen kann, ob 201 WM oder 201 Kombi.
                                            1.2k
                                            908
                                            283310
