    3. Einsteigerfragen
    4. gelöst: Shelly 2.5 in shuttercontrol einbinden Hilfe
      crunchip Forum Testing Most Active @woupi last edited by
      @woupi sagte in Shelly 2.5 in shuttercontrol einbinden Hilfe:
      Gibt es dazu irgendwo eine Anleitung
      je nach dem welchen Rollo du hast, Endpunkte am Rollo einstellen und dann in der App Referenzfahrt machen
      W 2 Replies Last reply Reply Quote 0
        woupi @crunchip last edited by
        @crunchip
          woupi @crunchip last edited by woupi
          @crunchip
          Habe ich gemacht, gebracht hat es leider aber nichts.
          Über shelly funktioniert es über shuttercontrol leider nicht.
          shuttercontrol.0
          2022-12-06 05:40:00.005	debug	Sun Elevation: -23.6°
          shuttercontrol.0
          2022-12-06 05:40:00.004	debug	Sun Azimut: 97.1°
          shuttercontrol.0
          2022-12-06 05:40:00.004	debug	calculate astrodata ...
          shuttercontrol.0
          2022-12-06 05:39:51.348	debug	Shuttercontrol save all shutter states
          shuttercontrol.0
          2022-12-06 05:39:47.809	debug	Shuttercontrol save all shutter states
          shuttercontrol.0
          2022-12-06 04:39:44.681	debug	shutterUpButton Position already up at: 100% - setting current action: up
          shuttercontrol.0
          2022-12-06 04:39:44.678	debug	start buttonAction
          shuttercontrol.0
          2022-12-06 04:39:41.347	debug	shutterUpButton Position already up at: 100% - setting current action: up
          shuttercontrol.0
          2022-12-06 04:39:41.344	debug	start buttonAction
          shuttercontrol.0
          2022-12-06 04:39:37.815	debug	Position Old value = 101. New value = 100. automatic is active
          shuttercontrol.0
          2022-12-06 04:39:37.815	debug	Shutter state changed: Position old value = 101 new value = 100
          shuttercontrol.0
          2022-12-06 04:39:37.815	debug	#0 wait for shutter check end
          shuttercontrol.0
          2022-12-06 04:39:37.808	debug	shutterUpButton Position old height: 101% new height: 100%
          shuttercontrol.0
          2022-12-06 04:39:37.804	debug	#0 wait for shutter check started
          shuttercontrol.0
          2022-12-06 04:39:37.802	info	Button openAll Set ID: Position value: 100%
          shuttercontrol.0
          2022-12-06 04:39:37.801	debug	start buttonAction
          shuttercontrol.0
          2022-12-06 04:39:37.657	debug	#0 wait for shutter check end
          shuttercontrol.0
          2022-12-06 04:39:37.646	debug	#0 wait for shutter check started
          shuttercontrol.0
          2022-12-06 04:39:35.888	debug	Shuttercontrol save all shutter states
          shuttercontrol.0
          2022-12-06 04:39:33.337	debug	shutterDownButton Position already down at: 0% - setting current action: down
          shuttercontrol.0
          2022-12-06 04:39:33.334	debug	start buttonAction
          shuttercontrol.0
          2022-12-06 04:39:25.895	debug	Position Old value = 101. New value = 0. automatic is active
          shuttercontrol.0
          2022-12-06 04:39:25.895	debug	Shutter state changed: Position old value = 101 new value = 0
          shuttercontrol.0
          2022-12-06 04:39:25.895	debug	#0 wait for shutter check end
          shuttercontrol.0
          2022-12-06 04:39:25.886	debug	shutterDownButton Position old height: 101% new height: 0%
          shuttercontrol.0
          2022-12-06 04:39:25.884	debug	#0 wait for shutter check started
          shuttercontrol.0
          2022-12-06 04:39:25.882	info	Button closeAll Set ID: Position value: 0%
          shuttercontrol.0
          2022-12-06 04:39:25.881	debug	start buttonAction
            crunchip Forum Testing Most Active @woupi last edited by crunchip
            @woupi zeig mal das ganze debug log ab start vom adapter
            und zeig mal das Raw vom Datenpunkt, siehe screen, rechts auf den Bleistift
            welche Firmware hat dein shelly?
              @crunchip
              Vielen Dank, ich werde es aber leider erst heute Abend schaffen (bin auf der Arbeit).
                @crunchip
                Ich fang mal mit der Firmware an:
                20221027-092056/v1.12.1-ga9117d3
                Bei dem zweiten hoffe ich, dass Du das meinst:
                Hier dann noch der log, von gestern, gesamt bekomme ich den aber nicht hier rein, der ist zu groß. Wie kann ich den denn selektieren, so das nur der Teil kopiert werden kann, der was mit dem shuttercotrol zu tun hat?
                2022-12-05 18:24:51.321  - info: shuttercontrol.0 (22020) Got terminate signal TERMINATE_YOURSELF
                2022-12-05 18:24:51.321  - info: shuttercontrol.0 (22020) cleaned everything up...
                2022-12-05 18:24:51.322  - info: shuttercontrol.0 (22020) terminating
                2022-12-05 18:24:51.322  - info: shuttercontrol.0 (22020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-12-05 18:24:54.741  - debug: shuttercontrol.0 (73840) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2022-12-05 18:24:54.773  - debug: shuttercontrol.0 (73840) Objects client ready ... initialize now
                2022-12-05 18:24:54.774  - debug: shuttercontrol.0 (73840) Objects create System PubSub Client
                2022-12-05 18:24:54.774  - debug: shuttercontrol.0 (73840) Objects create User PubSub Client
                2022-12-05 18:24:54.798  - debug: shuttercontrol.0 (73840) Objects client initialize lua scripts
                2022-12-05 18:24:54.801  - debug: shuttercontrol.0 (73840) Objects connected to redis: 127.0.0.1:9001
                2022-12-05 18:24:54.815  - debug: shuttercontrol.0 (73840) Redis States: Use Redis connection: 127.0.0.1:9000
                2022-12-05 18:24:54.822  - debug: shuttercontrol.0 (73840) States create System PubSub Client
                2022-12-05 18:24:54.823  - debug: shuttercontrol.0 (73840) States create User PubSub Client
                2022-12-05 18:24:54.836  - debug: shuttercontrol.0 (73840) States connected to redis: 127.0.0.1:9000
                2022-12-05 18:24:54.915  - debug: shuttercontrol.0 (73840) Plugin sentry Initialize Plugin (enabled=true)
                2022-12-05 18:24:55.114  - info: shuttercontrol.0 (73840) starting. Version 1.4.18 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.21.1, js-controller: 4.0.21
                2022-12-05 18:24:55.130  - debug: shuttercontrol.0 (73840) shutter Config Check started
                2022-12-05 18:24:55.130  - debug: shuttercontrol.0 (73840) shutter Config Check successfully completed
                2022-12-05 18:24:55.132  - debug: shuttercontrol.0 (73840) Shutter State: shelly.0.SHSW-25#3494547C201A#1.Shutter.Position
                2022-12-05 18:24:55.138  - debug: shuttercontrol.0 (73840) Position: save settings
                2022-12-05 18:24:58.209  - debug: shuttercontrol.0 (73840) Travel times of the shutters are calculated
                2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) calculate astrodata ...
                2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) goldenHourEnd today: 08:14
                2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) goldenHour today: 14:28
                2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) current day: 1
                2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Sunrise today: 07:16
                2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Sunset today: 15:26
                2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Starting up shutters GoldenHour area: 08:44
                2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Shutdown shutters GoldenHour area: 14:58
                2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Starting up shutters Sunrise area: 07:46
                2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Shutdown shutters Sunset area: 15:56
                2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 08:00
                2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 05:00
                2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) yes, IsLater : 07:46 05:00
                2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) check IsEarlier : 07:46 08:00
                2022-12-05 18:24:58.231  - debug: shuttercontrol.0 (73840) yes, IsEarlier : 07:46 08:00
                2022-12-05 18:24:58.231  - debug: shuttercontrol.0 (73840) Starting up shutters living area: 07:46 debug 5
                2022-12-05 18:24:58.235  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 06:30
                2022-12-05 18:24:58.236  - debug: shuttercontrol.0 (73840) yes, IsLater : 07:46 06:30
                2022-12-05 18:24:58.236  - debug: shuttercontrol.0 (73840) Starting up shutters sleep area: 06:30 debug 4
                2022-12-05 18:24:58.239  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 06:30
                2022-12-05 18:24:58.239  - debug: shuttercontrol.0 (73840) yes, IsLater : 07:46 06:30
                2022-12-05 18:24:58.239  - debug: shuttercontrol.0 (73840) Starting up shutters children area: 06:30 debug 4
                2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) check IsLater : 15:56 22:00
                2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) check IsEarlier : 15:56 22:00
                2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) yes, IsEarlier : 15:56 22:00
                2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) Shutdown shutters living area: 15:56 debug 7
                2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) shutterDownLiving
                2022-12-05 18:24:58.249  - debug: shuttercontrol.0 (73840) Shutdown shutters children area: 15:56 debug 7
                2022-12-05 18:24:58.254  - debug: shuttercontrol.0 (73840) Shutdown shutters sleep area: 15:56 debug 7
                2022-12-05 18:24:58.271  - debug: shuttercontrol.0 (73840) complete down at 22:00
                2022-12-05 18:25:00.015  - debug: shuttercontrol.0 (73840) calculate astrodata ...
                2022-12-05 18:25:00.015  - debug: shuttercontrol.0 (73840) Sun Azimut: 267.4°
                2022-12-05 18:25:00.015  - debug: shuttercontrol.0 (73840) Sun Elevation: -27.2°
                2022-12-05 18:25:07.710  - debug: shuttercontrol.0 (73840) start buttonAction
                2022-12-05 18:25:07.711  - info: shuttercontrol.0 (73840) Button openAll Set ID: Position value: 100%
                2022-12-05 18:25:07.714  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
                2022-12-05 18:25:07.718  - debug: shuttercontrol.0 (73840) shutterUpButton Position old height: 101% new height: 100%
                2022-12-05 18:25:07.724  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
                2022-12-05 18:25:07.725  - debug: shuttercontrol.0 (73840) Shutter state changed: Position old value = 101 new value = 100
                2022-12-05 18:25:07.725  - debug: shuttercontrol.0 (73840) Position Old value = 101. New value = 100. automatic is active
                2022-12-05 18:25:17.719  - debug: shuttercontrol.0 (73840) Shuttercontrol save all shutter states
                2022-12-05 18:25:23.808  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
                2022-12-05 18:25:23.818  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
                2022-12-05 18:25:25.868  - debug: shuttercontrol.0 (73840) start buttonAction
                2022-12-05 18:25:25.869  - info: shuttercontrol.0 (73840) Button openAll Set ID: Position value: 100%
                2022-12-05 18:25:25.874  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
                2022-12-05 18:25:25.878  - debug: shuttercontrol.0 (73840) shutterUpButton Position old height: 101% new height: 100%
                2022-12-05 18:25:25.884  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
                2022-12-05 18:25:25.888  - debug: shuttercontrol.0 (73840) Shutter state changed: Position old value = 101 new value = 100
                2022-12-05 18:25:25.888  - debug: shuttercontrol.0 (73840) Position Old value = 101. New value = 100. automatic is active
                2022-12-05 18:25:35.878  - debug: shuttercontrol.0 (73840) Shuttercontrol save all shutter states
                2022-12-05 18:25:53.817  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
                2022-12-05 18:25:53.828  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
                  crunchip Forum Testing Most Active last edited by crunchip
                  @woupi ich hab keinen Plan woher bei dir die 101% her kommt
                  was zeigt den der Datenpunkt level an, wenn
                  • ganz oben
                  • ganz unten
                    @crunchip
                    Den Datenpunkt level finde ich weder beim shelly noch bei shuttercontrol.
                    Oder meinst Du position level.blind?
                    Der zeigt immer 101% egal ob ganz oben oder ganz unten
                      eben, das zeigt auch das log
                      kalibriert hast du ja und Haken ist auch gesetzt?
                        @crunchip
                        Ja, genau
                          @woupi also entweder liegt das an der aktuellen Firmware, (ich hab noch die vorherige) oder das stimmt irgendwas anderes nicht.
                          hab nur das dazu gefunden
                          https://forum.iobroker.net/post/292970
                          heisst, noch mal kalibrieren
                          andernfalls, würde ich den shelly mal komplett zurück setzen und neu konfigurieren
                            @crunchip
                            Ok, danke für deine Hilfe, das werde ich dann am besten am WE, in Ruhe, machen.
                              @woupi kalibrier doch erstmal neu, vllt hilft es ja schon
                                @crunchip
                                Das habe ich zwischendurch, natürlich, schon mehrfach versucht, ohne Erfolg.
                                  @woupi ok, was wird den im shelly bei % angezeigt? wenn du ihn verfährst
                                    @crunchip
                                    Ich habe in der app gesucht, über die ip auf der WEB Oberfläche, aber ich finde keine Info über die Position in Prozent,
                                      @woupi sieht das nicht so aus?
                                        @crunchip
                                        Bis auf die Prozentanzeige, doch.
                                        An der Stelle steht bei mir, dass ich kalibrieren soll.
                                        Das hab ich jetzt aber sicher schon mind. 20mal gemacht.
                                          na die Info hast bis jetzt nicht gegeben
                                          shelly mal neu gestartet
                                          oder auch das debug log mal ansehen im shelly
                                            @crunchip
                                            Ich habe jetzt noch ein paar Mal versucht zu Kalibriert, dabei ist mir gerade folgende Fehlermeldung aufgefallen:
                                            Calibration faild - minimum power of 4W not reached
                                            sie ist aber nur ein zwei sekunden da.
                                            1907
