    3. Einsteigerfragen
    4. gelöst: Shelly 2.5 in shuttercontrol einbinden Hilfe
      woupi @crunchip last edited by woupi
      @crunchip
      Habe ich gemacht, gebracht hat es leider aber nichts.
      Über shelly funktioniert es über shuttercontrol leider nicht.
      shuttercontrol.0
      2022-12-06 05:40:00.005	debug	Sun Elevation: -23.6°
      shuttercontrol.0
      2022-12-06 05:40:00.004	debug	Sun Azimut: 97.1°
      shuttercontrol.0
      2022-12-06 05:40:00.004	debug	calculate astrodata ...
      shuttercontrol.0
      2022-12-06 05:39:51.348	debug	Shuttercontrol save all shutter states
      shuttercontrol.0
      2022-12-06 05:39:47.809	debug	Shuttercontrol save all shutter states
      shuttercontrol.0
      2022-12-06 04:39:44.681	debug	shutterUpButton Position already up at: 100% - setting current action: up
      shuttercontrol.0
      2022-12-06 04:39:44.678	debug	start buttonAction
      shuttercontrol.0
      2022-12-06 04:39:41.347	debug	shutterUpButton Position already up at: 100% - setting current action: up
      shuttercontrol.0
      2022-12-06 04:39:41.344	debug	start buttonAction
      shuttercontrol.0
      2022-12-06 04:39:37.815	debug	Position Old value = 101. New value = 100. automatic is active
      shuttercontrol.0
      2022-12-06 04:39:37.815	debug	Shutter state changed: Position old value = 101 new value = 100
      shuttercontrol.0
      2022-12-06 04:39:37.815	debug	#0 wait for shutter check end
      shuttercontrol.0
      2022-12-06 04:39:37.808	debug	shutterUpButton Position old height: 101% new height: 100%
      shuttercontrol.0
      2022-12-06 04:39:37.804	debug	#0 wait for shutter check started
      shuttercontrol.0
      2022-12-06 04:39:37.802	info	Button openAll Set ID: Position value: 100%
      shuttercontrol.0
      2022-12-06 04:39:37.801	debug	start buttonAction
      shuttercontrol.0
      2022-12-06 04:39:37.657	debug	#0 wait for shutter check end
      shuttercontrol.0
      2022-12-06 04:39:37.646	debug	#0 wait for shutter check started
      shuttercontrol.0
      2022-12-06 04:39:35.888	debug	Shuttercontrol save all shutter states
      shuttercontrol.0
      2022-12-06 04:39:33.337	debug	shutterDownButton Position already down at: 0% - setting current action: down
      shuttercontrol.0
      2022-12-06 04:39:33.334	debug	start buttonAction
      shuttercontrol.0
      2022-12-06 04:39:25.895	debug	Position Old value = 101. New value = 0. automatic is active
      shuttercontrol.0
      2022-12-06 04:39:25.895	debug	Shutter state changed: Position old value = 101 new value = 0
      shuttercontrol.0
      2022-12-06 04:39:25.895	debug	#0 wait for shutter check end
      shuttercontrol.0
      2022-12-06 04:39:25.886	debug	shutterDownButton Position old height: 101% new height: 0%
      shuttercontrol.0
      2022-12-06 04:39:25.884	debug	#0 wait for shutter check started
      shuttercontrol.0
      2022-12-06 04:39:25.882	info	Button closeAll Set ID: Position value: 0%
      shuttercontrol.0
      2022-12-06 04:39:25.881	debug	start buttonAction
        crunchip Forum Testing Most Active @woupi last edited by crunchip
        @woupi zeig mal das ganze debug log ab start vom adapter
        und zeig mal das Raw vom Datenpunkt, siehe screen, rechts auf den Bleistift
        welche Firmware hat dein shelly?
        W 2 Replies Last reply Reply Quote 0
          @crunchip
          Vielen Dank, ich werde es aber leider erst heute Abend schaffen (bin auf der Arbeit).
            @crunchip
            Ich fang mal mit der Firmware an:
            20221027-092056/v1.12.1-ga9117d3
            Bei dem zweiten hoffe ich, dass Du das meinst:
            Hier dann noch der log, von gestern, gesamt bekomme ich den aber nicht hier rein, der ist zu groß. Wie kann ich den denn selektieren, so das nur der Teil kopiert werden kann, der was mit dem shuttercotrol zu tun hat?
            2022-12-05 18:24:51.321  - info: shuttercontrol.0 (22020) Got terminate signal TERMINATE_YOURSELF
            2022-12-05 18:24:51.321  - info: shuttercontrol.0 (22020) cleaned everything up...
            2022-12-05 18:24:51.322  - info: shuttercontrol.0 (22020) terminating
            2022-12-05 18:24:51.322  - info: shuttercontrol.0 (22020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-12-05 18:24:54.741  - debug: shuttercontrol.0 (73840) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2022-12-05 18:24:54.773  - debug: shuttercontrol.0 (73840) Objects client ready ... initialize now
            2022-12-05 18:24:54.774  - debug: shuttercontrol.0 (73840) Objects create System PubSub Client
            2022-12-05 18:24:54.774  - debug: shuttercontrol.0 (73840) Objects create User PubSub Client
            2022-12-05 18:24:54.798  - debug: shuttercontrol.0 (73840) Objects client initialize lua scripts
            2022-12-05 18:24:54.801  - debug: shuttercontrol.0 (73840) Objects connected to redis: 127.0.0.1:9001
            2022-12-05 18:24:54.815  - debug: shuttercontrol.0 (73840) Redis States: Use Redis connection: 127.0.0.1:9000
            2022-12-05 18:24:54.822  - debug: shuttercontrol.0 (73840) States create System PubSub Client
            2022-12-05 18:24:54.823  - debug: shuttercontrol.0 (73840) States create User PubSub Client
            2022-12-05 18:24:54.836  - debug: shuttercontrol.0 (73840) States connected to redis: 127.0.0.1:9000
            2022-12-05 18:24:54.915  - debug: shuttercontrol.0 (73840) Plugin sentry Initialize Plugin (enabled=true)
            2022-12-05 18:24:55.114  - info: shuttercontrol.0 (73840) starting. Version 1.4.18 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.21.1, js-controller: 4.0.21
            2022-12-05 18:24:55.130  - debug: shuttercontrol.0 (73840) shutter Config Check started
            2022-12-05 18:24:55.130  - debug: shuttercontrol.0 (73840) shutter Config Check successfully completed
            2022-12-05 18:24:55.132  - debug: shuttercontrol.0 (73840) Shutter State: shelly.0.SHSW-25#3494547C201A#1.Shutter.Position
            2022-12-05 18:24:55.138  - debug: shuttercontrol.0 (73840) Position: save settings
            2022-12-05 18:24:58.209  - debug: shuttercontrol.0 (73840) Travel times of the shutters are calculated
            2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) calculate astrodata ...
            2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) goldenHourEnd today: 08:14
            2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) goldenHour today: 14:28
            2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) current day: 1
            2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Sunrise today: 07:16
            2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Sunset today: 15:26
            2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Starting up shutters GoldenHour area: 08:44
            2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Shutdown shutters GoldenHour area: 14:58
            2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Starting up shutters Sunrise area: 07:46
            2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Shutdown shutters Sunset area: 15:56
            2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 08:00
            2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 05:00
            2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) yes, IsLater : 07:46 05:00
            2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) check IsEarlier : 07:46 08:00
            2022-12-05 18:24:58.231  - debug: shuttercontrol.0 (73840) yes, IsEarlier : 07:46 08:00
            2022-12-05 18:24:58.231  - debug: shuttercontrol.0 (73840) Starting up shutters living area: 07:46 debug 5
            2022-12-05 18:24:58.235  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 06:30
            2022-12-05 18:24:58.236  - debug: shuttercontrol.0 (73840) yes, IsLater : 07:46 06:30
            2022-12-05 18:24:58.236  - debug: shuttercontrol.0 (73840) Starting up shutters sleep area: 06:30 debug 4
            2022-12-05 18:24:58.239  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 06:30
            2022-12-05 18:24:58.239  - debug: shuttercontrol.0 (73840) yes, IsLater : 07:46 06:30
            2022-12-05 18:24:58.239  - debug: shuttercontrol.0 (73840) Starting up shutters children area: 06:30 debug 4
            2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) check IsLater : 15:56 22:00
            2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) check IsEarlier : 15:56 22:00
            2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) yes, IsEarlier : 15:56 22:00
            2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) Shutdown shutters living area: 15:56 debug 7
            2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) shutterDownLiving
            2022-12-05 18:24:58.249  - debug: shuttercontrol.0 (73840) Shutdown shutters children area: 15:56 debug 7
            2022-12-05 18:24:58.254  - debug: shuttercontrol.0 (73840) Shutdown shutters sleep area: 15:56 debug 7
            2022-12-05 18:24:58.271  - debug: shuttercontrol.0 (73840) complete down at 22:00
            2022-12-05 18:25:00.015  - debug: shuttercontrol.0 (73840) calculate astrodata ...
            2022-12-05 18:25:00.015  - debug: shuttercontrol.0 (73840) Sun Azimut: 267.4°
            2022-12-05 18:25:00.015  - debug: shuttercontrol.0 (73840) Sun Elevation: -27.2°
            2022-12-05 18:25:07.710  - debug: shuttercontrol.0 (73840) start buttonAction
            2022-12-05 18:25:07.711  - info: shuttercontrol.0 (73840) Button openAll Set ID: Position value: 100%
            2022-12-05 18:25:07.714  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
            2022-12-05 18:25:07.718  - debug: shuttercontrol.0 (73840) shutterUpButton Position old height: 101% new height: 100%
            2022-12-05 18:25:07.724  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
            2022-12-05 18:25:07.725  - debug: shuttercontrol.0 (73840) Shutter state changed: Position old value = 101 new value = 100
            2022-12-05 18:25:07.725  - debug: shuttercontrol.0 (73840) Position Old value = 101. New value = 100. automatic is active
            2022-12-05 18:25:17.719  - debug: shuttercontrol.0 (73840) Shuttercontrol save all shutter states
            2022-12-05 18:25:23.808  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
            2022-12-05 18:25:23.818  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
            2022-12-05 18:25:25.868  - debug: shuttercontrol.0 (73840) start buttonAction
            2022-12-05 18:25:25.869  - info: shuttercontrol.0 (73840) Button openAll Set ID: Position value: 100%
            2022-12-05 18:25:25.874  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
            2022-12-05 18:25:25.878  - debug: shuttercontrol.0 (73840) shutterUpButton Position old height: 101% new height: 100%
            2022-12-05 18:25:25.884  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
            2022-12-05 18:25:25.888  - debug: shuttercontrol.0 (73840) Shutter state changed: Position old value = 101 new value = 100
            2022-12-05 18:25:25.888  - debug: shuttercontrol.0 (73840) Position Old value = 101. New value = 100. automatic is active
            2022-12-05 18:25:35.878  - debug: shuttercontrol.0 (73840) Shuttercontrol save all shutter states
            2022-12-05 18:25:53.817  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
            2022-12-05 18:25:53.828  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
              crunchip Forum Testing Most Active last edited by crunchip
              @woupi ich hab keinen Plan woher bei dir die 101% her kommt
              was zeigt den der Datenpunkt level an, wenn
              • ganz oben
              • ganz unten
                @crunchip
                Den Datenpunkt level finde ich weder beim shelly noch bei shuttercontrol.
                Oder meinst Du position level.blind?
                Der zeigt immer 101% egal ob ganz oben oder ganz unten
                  @woupi sagte in Shelly 2.5 in shuttercontrol einbinden Hilfe:
                  eben, das zeigt auch das log
                  kalibriert hast du ja und Haken ist auch gesetzt?
                    @crunchip
                    Ja, genau
                      @woupi also entweder liegt das an der aktuellen Firmware, (ich hab noch die vorherige) oder das stimmt irgendwas anderes nicht.
                      hab nur das dazu gefunden
                      https://forum.iobroker.net/post/292970
                      heisst, noch mal kalibrieren
                      andernfalls, würde ich den shelly mal komplett zurück setzen und neu konfigurieren
                        @crunchip
                        Ok, danke für deine Hilfe, das werde ich dann am besten am WE, in Ruhe, machen.
                          @woupi kalibrier doch erstmal neu, vllt hilft es ja schon
                            @crunchip
                            Das habe ich zwischendurch, natürlich, schon mehrfach versucht, ohne Erfolg.
                              @woupi ok, was wird den im shelly bei % angezeigt? wenn du ihn verfährst
                                @crunchip
                                Ich habe in der app gesucht, über die ip auf der WEB Oberfläche, aber ich finde keine Info über die Position in Prozent,
                                  @woupi sieht das nicht so aus?
                                    @crunchip
                                    Bis auf die Prozentanzeige, doch.
                                    An der Stelle steht bei mir, dass ich kalibrieren soll.
                                    Das hab ich jetzt aber sicher schon mind. 20mal gemacht.
                                      na die Info hast bis jetzt nicht gegeben
                                      shelly mal neu gestartet
                                      oder auch das debug log mal ansehen im shelly
                                        @crunchip
                                        Ich habe jetzt noch ein paar Mal versucht zu Kalibriert, dabei ist mir gerade folgende Fehlermeldung aufgefallen:
                                        Calibration faild - minimum power of 4W not reached
                                        sie ist aber nur ein zwei sekunden da.
                                          dann tippe ich mal auf ein Problem mit der Firmware oder der shelly selbst hat nen Treffer
                                          allerdings habe ich noch das gefunden
                                          Then open your PC or phone browser and enter:
                                          http://DeviceIP/settings/roller/0?off_power=X where Device IP is the IP from the Device Information (192.168.0.21 in example) and X is the power consumption when roller reaches end point + 2W. If you roller has 3W consumption, when final point is reached you need to set 5.
                                          hab ich hier gefunden https://www.facebook.com/legacy/notes/2064850700280950/
                                          du kannst auch mal manuell hoch und runter fahren und dabei jeweils die Zeit stoppen, diese trägst du dann anstatt des automatischen kalibrieren ein.
                                          • da_Woody
                                            da_Woody @crunchip last edited by
                                            @crunchip sagte in Shelly 2.5 in shuttercontrol einbinden Hilfe:
                                            ist schon ewig her seit dem letzten 2.5er. allerdings war damals doppelte zeit vor dem kalibrieren einzutragen...
                                            danach dann die kali machen. soweit ich mich erinnern kann, ist das teil dann einmal komplett runter, rauf und dann irgendwo stehn geblieben. dann war nix mehr mit failed.
                                            1907
