    4. SD-Karte läuft im Verzeichnis /dev/root voll
      Homoran Global Moderator Administrators @Kenji last edited by
      @kenji sagte in SD-Karte läuft im Verzeichnis /dev/root voll:
      Sorry das ich hier parallel fahre (Discord/Forum)
      ist nicht optimal, da die linke nicht die Informationen hat, die die rechte hat.
      Kenji Meister Mopper 2 Replies Last reply Reply Quote 1
      • Kenji
        Kenji @Thomas Braun last edited by
        @thomas-braun Dankeschön für die präzise Hilfe 🤗
        Habe beide Befehle eingeben können. Hier die Ausgabe vom zweiten Befehl:
        pi@raspberrypi:~ $ tail -n 30 /var/log/syslog.1
        Dec  7 15:24:52 raspberrypi systemd[1]: Stopping CUPS Scheduler.
        Dec  7 15:24:52 raspberrypi systemd[1]: Listening on CUPS Scheduler.
        Dec  7 15:24:52 raspberrypi systemd[1]: Starting CUPS Scheduler...
        Dec  7 15:24:52 raspberrypi systemd[1]: Started CUPS Scheduler.
        Dec  7 15:24:52 raspberrypi systemd[1]: Started Make remote CUPS printers availa        ble locally.
        Dec  7 15:24:52 raspberrypi bluetoothd[695]: Bluetooth daemon 5.55
        Dec  7 15:24:52 raspberrypi systemd[1]: Started Bluetooth service.
        Dec  7 15:24:52 raspberrypi systemd[1]: Reached target Bluetooth.
        Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Successfully made thread 654 of p        rocess 654 owned by '1000' high priority at nice level -11.
        Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Supervising 1 threads of 1 proces        ses of 1 users.
        Dec  7 15:24:53 raspberrypi bluetoothd[695]: Starting SDP server
        Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Successfully made thread 655 of p        rocess 655 owned by '1000' high priority at nice level -11.
        Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Supervising 2 threads of 2 proces        ses of 1 users.
        Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Successfully made thread 660 of p        rocess 654 owned by '1000' RT at priority 20.
        Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Supervising 3 threads of 2 proces        ses of 1 users.
        Dec  7 15:24:53 raspberrypi kernel: [   33.527732] Bluetooth: BNEP (Ethernet Emu        lation) ver 1.3
        Dec  7 15:24:53 raspberrypi kernel: [   33.527759] Bluetooth: BNEP filters: prot        ocol multicast
        Dec  7 15:24:53 raspberrypi kernel: [   33.527787] Bluetooth: BNEP socket layer        initialized
        Dec  7 15:24:53 raspberrypi bluetoothd[695]: Bluetooth management interface 1.21        initialized
        Dec  7 15:24:53 raspberrypi kernel: [   33.568521] NET: Registered PF_ALG protoc        ol family
        Dec  7 15:24:53 raspberrypi kernel: [   33.669986] cryptd: max_cpu_qlen set to 1        000
        Dec  7 15:24:53 raspberrypi systemd[586]: Started D-Bus User Message Bus.
        Dec  7 15:24:53 raspberrypi bluetoothd[695]: profiles/sap/server.c:sap_server_re        gister() Sap driver initialization failed.
        Dec  7 15:24:53 raspberrypi bluetoothd[695]: sap-server: Operation not permitted        (1)
        Dec  7 15:24:53 raspberrypi bluetoothd[695]: Failed to set mode: Blocked through        rfkill (0x12)
        Dec  7 15:24:53 raspberrypi kernel: [   34.096992] Bluetooth: RFCOMM TTY layer i        nitialized
        Dec  7 15:24:53 raspberrypi kernel: [   34.097017] Bluetooth: RFCOMM socket laye        r initialized
        Dec  7 15:24:53 raspberrypi kernel: [   34.097035] Bluetooth: RFCOMM ver 1.11
        pi@raspberrypi:~ $
          Thomas Braun Most Active @Kenji last edited by Thomas Braun
          @kenji
          Der zweite Befehl greift offenbar zu kurz.
          Dann mal mehr Output:
          tail -n 300 /var/log/syslog.1
          Und mach bitte dein puTTY-Fenster größer.
          Kenji 1 Reply Last reply Reply Quote 0
          • Kenji
            Kenji @Homoran last edited by
            @homoran Entschuldigung wird nicht mehr vorkommen. Schreibe nächstes Mal direkt hier im Forum. Gruß Matze 🙂
            • Kenji
              @thomas-braun Ich hoffe das ist groß genug bin grade am Laptop.
              pi@raspberrypi:~ $ tail -n 300 /var/log/syslog.1
              Dec  6 12:17:11 raspberrypi kernel: [    3.025544]     splash
              Dec  6 12:17:11 raspberrypi kernel: [    3.025557]   with environment:
              Dec  6 12:17:11 raspberrypi kernel: [    3.025569]     HOME=/
              Dec  6 12:17:11 raspberrypi kernel: [    3.025581]     TERM=linux
              Dec  6 12:17:11 raspberrypi kernel: [    4.489622] NET: Registered PF_INET6 protocol family
              Dec  6 12:17:11 raspberrypi kernel: [    4.491382] Segment Routing with IPv6
              Dec  6 12:17:11 raspberrypi kernel: [    4.491426] In-situ OAM (IOAM) with IPv6
              Dec  6 12:17:11 raspberrypi kernel: [    6.640012] fuse: init (API version 7.34)
              Dec  6 12:17:11 raspberrypi kernel: [    6.862416] i2c_dev: i2c /dev entries driver
              Dec  6 12:17:11 raspberrypi kernel: [    7.491840] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
              Dec  6 12:17:11 raspberrypi kernel: [   11.657586] mc: Linux media interface: v0.10
              Dec  6 12:17:11 raspberrypi kernel: [   11.795183] videodev: Linux video capture interface: v2.00
              Dec  6 12:17:11 raspberrypi kernel: [   11.843047] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   11.857533] bcm2835_audio bcm2835_audio: card created with 8 channels
              Dec  6 12:17:11 raspberrypi kernel: [   11.948828] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   11.957733] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   11.958590] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
              Dec  6 12:17:11 raspberrypi kernel: [   11.958616] [vc_sm_connected_init]: start
              Dec  6 12:17:11 raspberrypi kernel: [   11.959252] [vc_sm_connected_init]: installed successfully
              Dec  6 12:17:11 raspberrypi kernel: [   11.971423] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   12.024522] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   12.024757] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   12.024761] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   12.095319] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   12.112372] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
              Dec  6 12:17:11 raspberrypi kernel: [   12.112909] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
              Dec  6 12:17:11 raspberrypi kernel: [   12.113419] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
              Dec  6 12:17:11 raspberrypi kernel: [   12.113756] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
              Dec  6 12:17:11 raspberrypi kernel: [   12.113787] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
              Dec  6 12:17:11 raspberrypi kernel: [   12.113811] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
              Dec  6 12:17:11 raspberrypi kernel: [   12.113834] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
              Dec  6 12:17:11 raspberrypi kernel: [   12.113870] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
              Dec  6 12:17:11 raspberrypi kernel: [   12.117721] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
              Dec  6 12:17:11 raspberrypi kernel: [   12.118190] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
              Dec  6 12:17:11 raspberrypi kernel: [   12.118581] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
              Dec  6 12:17:11 raspberrypi kernel: [   12.118912] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
              Dec  6 12:17:11 raspberrypi kernel: [   12.118942] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
              Dec  6 12:17:11 raspberrypi kernel: [   12.118967] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
              Dec  6 12:17:11 raspberrypi kernel: [   12.118989] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
              Dec  6 12:17:11 raspberrypi kernel: [   12.119011] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
              Dec  6 12:17:11 raspberrypi kernel: [   12.119185] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
              Dec  6 12:17:11 raspberrypi kernel: [   12.125528] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   12.134051] rpivid feb10000.codec: Device registered as /dev/video19
              Dec  6 12:17:11 raspberrypi kernel: [   12.138147] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   12.154714] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
              Dec  6 12:17:11 raspberrypi kernel: [   12.154765] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
              Dec  6 12:17:11 raspberrypi kernel: [   12.157966] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
              Dec  6 12:17:11 raspberrypi kernel: [   12.158014] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
              Dec  6 12:17:11 raspberrypi kernel: [   12.162789] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
              Dec  6 12:17:11 raspberrypi kernel: [   12.169866] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
              Dec  6 12:17:11 raspberrypi kernel: [   12.169915] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
              Dec  6 12:17:11 raspberrypi kernel: [   12.177384] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
              Dec  6 12:17:11 raspberrypi kernel: [   12.177432] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
              Dec  6 12:17:11 raspberrypi kernel: [   12.187919] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
              Dec  6 12:17:11 raspberrypi kernel: [   12.187968] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
              Dec  6 12:17:11 raspberrypi kernel: [   12.417865] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
              Dec  6 12:17:11 raspberrypi kernel: [   12.424127] [drm] No displays found. Consider forcing hotplug if HDMI is attached
              Dec  6 12:17:11 raspberrypi kernel: [   12.424163] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
              Dec  6 12:17:11 raspberrypi kernel: [   12.428048] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
              Dec  6 12:17:11 raspberrypi kernel: [   16.039488] uart-pl011 fe201000.serial: no DMA platform data
              Dec  6 12:17:11 raspberrypi kernel: [   16.649362] 8021q: 802.1Q VLAN Support v1.8
              Dec  6 12:17:11 raspberrypi kernel: [   17.115931] cfg80211: Loading compiled-in X.509 certificates for regulatory database
              Dec  6 12:17:11 raspberrypi kernel: [   17.129574] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
              Dec  6 12:17:11 raspberrypi dhcpcd[355]: forked to background, child pid 466
              Dec  6 12:17:11 raspberrypi systemd[1]: Started DHCP Client Daemon.
              Dec  6 12:17:11 raspberrypi rngd[471]: rngd 2.2 starting up...
              Dec  6 12:17:11 raspberrypi systemd[1]: Started LSB: rng-tools (Debian variant).
              Dec  6 12:17:11 raspberrypi rngd[471]: entropy feed to the kernel ready
              Dec  6 12:17:12 raspberrypi kernel: [   17.908243] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
              Dec  6 12:17:12 raspberrypi udisksd[363]: udisks daemon version 2.9.2 starting
              Dec  6 12:17:13 raspberrypi systemd[1]: Finished Check for glamor.
              Dec  6 12:17:13 raspberrypi systemd[1]: Finished Check for v3d driver.
              Dec  6 12:17:13 raspberrypi dhcpcd[466]: eth0: waiting for carrier
              Dec  6 12:17:13 raspberrypi kernel: [   19.117523] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
              Dec  6 12:17:13 raspberrypi kernel: [   19.119139] bcmgenet fd580000.ethernet eth0: Link is Down
              Dec  6 12:17:13 raspberrypi dphys-swapfile[344]: want /var/swap=100MByte, restricting to 50% of remaining disk size: 12MBytes, checking existing: deleting wrong size file (26214400), generating swapfile ... of 12MBytes
              Dec  6 12:17:13 raspberrypi systemd[1]: Finished dphys-swapfile - set up, mount/unmount, and delete a swap file.
              Dec  6 12:17:13 raspberrypi kernel: [   19.172313] Adding 12284k swap on /var/swap.  Priority:-2 extents:1 across:12284k SSFS
              Dec  6 12:17:13 raspberrypi rpi-eeprom-update[359]: Skipping automatic bootloader upgrade. current 1599135103 >= min 1599135103
              Dec  6 12:17:13 raspberrypi systemd[1]: Started User Login Management.
              Dec  6 12:17:13 raspberrypi dbus-daemon[342]: [system] Successfully activated service 'org.freedesktop.systemd1'
              Dec  6 12:17:13 raspberrypi systemd[1]: Started Telephony service.
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Successfully called chroot().
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Successfully dropped remaining capabilities.
              Dec  6 12:17:13 raspberrypi wpa_supplicant[364]: Successfully initialized wpa_supplicant
              Dec  6 12:17:13 raspberrypi systemd[1]: Started Connection service.
              Dec  6 12:17:13 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
              Dec  6 12:17:13 raspberrypi systemd[1]: Started DUN service.
              Dec  6 12:17:13 raspberrypi systemd[1]: Started WPA supplicant.
              Dec  6 12:17:13 raspberrypi systemd[1]: Reached target Network.
              Dec  6 12:17:13 raspberrypi systemd[1]: Starting CUPS Scheduler...
              Dec  6 12:17:13 raspberrypi systemd[1]: Started ioBroker Server.
              Dec  6 12:17:13 raspberrypi connmand[343]: Connection Manager version 1.36
              Dec  6 12:17:13 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
              Dec  6 12:17:13 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: No service file found in /etc/avahi/services.
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: New relevant interface lo.IPv6 for mDNS.
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: New relevant interface lo.IPv4 for mDNS.
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Network interface enumeration completed.
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Registering new address record for ::1 on lo.*.
              Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Registering new address record for 127.0.0.1 on lo.IPv4.
              Dec  6 12:17:13 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
              Dec  6 12:17:13 raspberrypi systemd[1]: Starting Permit User Sessions...
              Dec  6 12:17:13 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
              Dec  6 12:17:13 raspberrypi systemd[1]: Finished Permit User Sessions.
              Dec  6 12:17:13 raspberrypi systemd[1]: Starting Light Display Manager...
              Dec  6 12:17:13 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
              Dec  6 12:17:14 raspberrypi udisksd[363]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
              Dec  6 12:17:14 raspberrypi udisksd[363]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
              Dec  6 12:17:14 raspberrypi kernel: [   20.137426] Bluetooth: Core ver 2.22
              Dec  6 12:17:14 raspberrypi kernel: [   20.137494] NET: Registered PF_BLUETOOTH protocol family
              Dec  6 12:17:14 raspberrypi kernel: [   20.137501] Bluetooth: HCI device and connection manager initialized
              Dec  6 12:17:14 raspberrypi kernel: [   20.137516] Bluetooth: HCI socket layer initialized
              Dec  6 12:17:14 raspberrypi kernel: [   20.137525] Bluetooth: L2CAP socket layer initialized
              Dec  6 12:17:14 raspberrypi kernel: [   20.137543] Bluetooth: SCO socket layer initialized
              Dec  6 12:17:14 raspberrypi avahi-daemon[340]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 970382656.
              Dec  6 12:17:14 raspberrypi udisksd[363]: Failed to load the 'mdraid' libblockdev plugin
              Dec  6 12:17:14 raspberrypi udisksd[363]: Failed to load the 'crypto' libblockdev plugin
              Dec  6 12:17:14 raspberrypi dbus-daemon[342]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.8' (uid=0 pid=363 comm="/usr/libexec/udisks2/udisksd ")
              Dec  6 12:17:14 raspberrypi systemd[1]: Starting Authorization Manager...
              Dec  6 12:17:14 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
              Dec  6 12:17:14 raspberrypi lightdm[520]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
              Dec  6 12:17:14 raspberrypi polkitd[537]: started daemon version 0.105 using authority implementation `local' version `0.105'
              Dec  6 12:17:14 raspberrypi dbus-daemon[342]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
              Dec  6 12:17:14 raspberrypi systemd[1]: Started Authorization Manager.
              Dec  6 12:17:15 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 185 (plymouthd).
              Dec  6 12:17:15 raspberrypi systemd[1]: Finished Hold until boot process finishes up.
              Dec  6 12:17:15 raspberrypi systemd[1]: Started Getty on tty1.
              Dec  6 12:17:15 raspberrypi systemd[1]: Reached target Login Prompts.
              Dec  6 12:17:15 raspberrypi systemd[1]: Started Light Display Manager.
              Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: carrier acquired
              Dec  6 12:17:16 raspberrypi systemd[1]: Started Disk Manager.
              Dec  6 12:17:16 raspberrypi kernel: [   22.231956] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
              Dec  6 12:17:16 raspberrypi kernel: [   22.231987] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
              Dec  6 12:17:16 raspberrypi udisksd[363]: Acquired the name org.freedesktop.UDisks2 on the system message bus
              Dec  6 12:17:16 raspberrypi dhcpcd[466]: DUID 00:01:00:01:27:5a:4f:d3:b8:27:eb:5f:f2:dd
              Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: IAID 32:3a:c3:f5
              Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: adding address fe80::f040:6593:7196:c74d
              Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: adding address fd51:42f8:caae:d92e::ff/64
              Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: adding route to fd51:42f8:caae:d92e::/64
              Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: probing address 192.168.178.3/24
              Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::f040:6593:7196:c74d.
              Dec  6 12:17:16 raspberrypi avahi-daemon[340]: New relevant interface eth0.IPv6 for mDNS.
              Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Registering new address record for fe80::f040:6593:7196:c74d on eth0.*.
              Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::f040:6593:7196:c74d.
              Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface eth0.IPv6 with address fd51:42f8:caae:d92e::ff.
              Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Registering new address record for fd51:42f8:caae:d92e::ff on eth0.*.
              Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Withdrawing address record for fe80::f040:6593:7196:c74d on eth0.
              Dec  6 12:17:16 raspberrypi connmand[343]: Checking loopback interface settings
              Dec  6 12:17:16 raspberrypi connmand[343]: System hostname is raspberrypi
              Dec  6 12:17:16 raspberrypi systemd[1]: Started CUPS Scheduler.
              Dec  6 12:17:16 raspberrypi systemd[1]: Started Make remote CUPS printers available locally.
              Dec  6 12:17:16 raspberrypi connmand[343]: lo {newlink} index 1 address 00:00:00:00:00:00 mtu 65536
              Dec  6 12:17:16 raspberrypi connmand[343]: lo {newlink} index 1 operstate 0 <UNKNOWN>
              Dec  6 12:17:16 raspberrypi dbus-daemon[342]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.4' (uid=0 pid=343 comm="/usr/sbin/connmand -n ")
              Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {create} index 2 type 1 <ETHER>
              Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {RX} 0 packets 0 bytes
              Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {TX} 3 packets 258 bytes
              Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {update} flags 69699 <UP,RUNNING,LOWER_UP>
              Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {newlink} index 2 address DC:A6:32:3A:C3:F5 mtu 1500
              Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {newlink} index 2 operstate 6 <UP>
              Dec  6 12:17:16 raspberrypi systemd[1]: Starting Hostname Service...
              Dec  6 12:17:16 raspberrypi connmand[343]: Adding interface eth0 [ ethernet ]
              Dec  6 12:17:16 raspberrypi connmand[343]: The name net.connman.vpn was not provided by any .service files
              Dec  6 12:17:16 raspberrypi dbus-daemon[342]: [system] Successfully activated service 'org.freedesktop.hostname1'
              Dec  6 12:17:16 raspberrypi systemd[1]: Started Hostname Service.
              Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]: BOOTLOADER: up to date
              Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
              Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:     LATEST: Di 26. Apr 10:24:28 UTC 2022 (1650968668)
              Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
              Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:             Use raspi-config to change the release.
              Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:   VL805_FW: Dedicated VL805 EEPROM
              Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:      VL805: up to date
              Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:    CURRENT: 000138a1
              Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:     LATEST: 000138a1
              Dec  6 12:17:17 raspberrypi systemd[1]: Finished Check for Raspberry Pi EEPROM updates.
              Dec  6 12:17:17 raspberrypi systemd[1]: Reached target Multi-User System.
              Dec  6 12:17:17 raspberrypi systemd[1]: Reached target Graphical Interface.
              Dec  6 12:17:17 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
              Dec  6 12:17:17 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
              Dec  6 12:17:17 raspberrypi systemd[1]: Finished Update UTMP about System Runlevel Changes.
              Dec  6 12:17:17 raspberrypi dhcpcd[466]: eth0: soliciting an IPv6 router
              Dec  6 12:17:18 raspberrypi connmand[343]: eth0 {add} address fd51:42f8:caae:d92e::ff/64 label (null) family 10
              Dec  6 12:17:21 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
              Dec  6 12:17:21 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
              Dec  6 12:17:21 raspberrypi systemd[1]: Finished User Runtime Directory /run/user/1000.
              Dec  6 12:17:21 raspberrypi systemd[1]: Starting User Manager for UID 1000...
              Dec  6 12:17:22 raspberrypi dhcpcd[466]: eth0: using static address 192.168.178.3/24
              Dec  6 12:17:22 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.178.3.
              Dec  6 12:17:22 raspberrypi avahi-daemon[340]: New relevant interface eth0.IPv4 for mDNS.
              Dec  6 12:17:22 raspberrypi connmand[343]: eth0 {add} address 192.168.178.3/24 label eth0 family 2
              Dec  6 12:17:22 raspberrypi avahi-daemon[340]: Registering new address record for 192.168.178.3 on eth0.IPv4.
              Dec  6 12:17:22 raspberrypi dhcpcd[466]: eth0: adding route to 192.168.178.0/24
              Dec  6 12:17:22 raspberrypi dhcpcd[466]: eth0: adding default route via 192.168.178.1
              Dec  6 12:17:22 raspberrypi connmand[343]: eth0 {add} route 0.0.0.0 gw 192.168.178.1 scope 0 <UNIVERSE>
              Dec  6 12:17:22 raspberrypi avahi-daemon[340]: Registering new address record for 192.168.178.38 on eth0.IPv4.
              Dec  6 12:17:22 raspberrypi systemd-xdg-autostart-generator[618]: Configuration file /etc/xdg/autostart/pprompt.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
              Dec  7 15:24:48 raspberrypi connmand[343]: eth0 {add} address 192.168.178.38/24 label eth0 family 2
              Dec  7 15:24:48 raspberrypi connmand[343]: eth0 {add} route 192.168.178.1 gw 0.0.0.0 scope 253 <LINK>
              Dec  7 15:24:48 raspberrypi connmand[343]: eth0 {add} route 0.0.0.0 gw 192.168.178.1 scope 0 <UNIVERSE>
              Dec  7 15:24:48 raspberrypi connmand[343]: ntp: adjust (jump): +97645.640944 sec
              Dec  7 15:24:48 raspberrypi connmand[343]: Failed to find URL:http://ipv4.connman.net/online/status.html
              Dec  7 15:24:48 raspberrypi connmand[343]: eth0 {add} route 82.165.8.211 gw 192.168.178.1 scope 0 <UNIVERSE>
              Dec  7 15:24:48 raspberrypi systemd[586]: Queued start job for default target Main User Target.
              Dec  7 15:24:48 raspberrypi systemd[586]: Created slice User Application Slice.
              Dec  7 15:24:48 raspberrypi systemd[586]: Reached target Paths.
              Dec  7 15:24:48 raspberrypi systemd[586]: Reached target Timers.
              Dec  7 15:24:48 raspberrypi systemd[586]: Starting D-Bus User Message Bus Socket.
              Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG network certificate management daemon.
              Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
              Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
              Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
              Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG cryptographic agent and passphrase cache.
              Dec  7 15:24:48 raspberrypi systemd[586]: Listening on Multimedia System.
              Dec  7 15:24:48 raspberrypi systemd[586]: Listening on debconf communication socket.
              Dec  7 15:24:48 raspberrypi systemd[586]: Listening on Sound System.
              Dec  7 15:24:49 raspberrypi systemd[1]: Starting Rotate log files...
              Dec  7 15:24:49 raspberrypi systemd[1]: Starting Daily man-db regeneration...
              Dec  7 15:24:49 raspberrypi systemd[586]: Listening on D-Bus User Message Bus Socket.
              Dec  7 15:24:49 raspberrypi systemd[586]: Reached target Sockets.
              Dec  7 15:24:49 raspberrypi systemd[586]: Reached target Basic System.
              Dec  7 15:24:49 raspberrypi systemd[1]: Started User Manager for UID 1000.
              Dec  7 15:24:49 raspberrypi systemd[1]: Started Session 1 of user pi.
              Dec  7 15:24:49 raspberrypi systemd[586]: Started Multimedia Service.
              Dec  7 15:24:49 raspberrypi systemd[586]: Starting Sound Service...
              Dec  7 15:24:49 raspberrypi dbus-daemon[342]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.22' (uid=1000 pid=654 comm="/usr/bin/pipewire ")
              Dec  7 15:24:49 raspberrypi systemd[1]: Starting RealtimeKit Scheduling Policy Service...
              Dec  7 15:24:49 raspberrypi dbus-daemon[342]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
              Dec  7 15:24:49 raspberrypi systemd[1]: Started RealtimeKit Scheduling Policy Service.
              Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Successfully called chroot.
              Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Successfully dropped privileges.
              Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Successfully limited resources.
              Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Canary thread running.
              Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Running.
              Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Watchdog thread running.
              Dec  7 15:24:51 raspberrypi kernel: [   31.831859] cam-dummy-reg: disabling
              Dec  7 15:24:51 raspberrypi kernel: [   32.060106] Bluetooth: HCI UART driver ver 2.3
              Dec  7 15:24:51 raspberrypi kernel: [   32.060130] Bluetooth: HCI UART protocol H4 registered
              Dec  7 15:24:51 raspberrypi kernel: [   32.061606] Bluetooth: HCI UART protocol Three-wire (H5) registered
              Dec  7 15:24:51 raspberrypi kernel: [   32.061906] Bluetooth: HCI UART protocol Broadcom registered
              Dec  7 15:24:51 raspberrypi btuart[385]: bcm43xx_init
              Dec  7 15:24:51 raspberrypi btuart[385]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
              Dec  7 15:24:51 raspberrypi btuart[385]: Set Controller UART speed to 3000000 bit/s
              Dec  7 15:24:51 raspberrypi btuart[385]: Device setup complete
              Dec  7 15:24:51 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
              Dec  7 15:24:51 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
              Dec  7 15:24:51 raspberrypi systemd[586]: Reached target Bluetooth.
              Dec  7 15:24:51 raspberrypi systemd[1]: Created slice system-bthelper.slice.
              Dec  7 15:24:51 raspberrypi systemd[1]: Starting Raspberry Pi bluetooth helper...
              Dec  7 15:24:52 raspberrypi bthelper[691]: Can't init device hci0: Operation not possible due to RF-kill (132)
              Dec  7 15:24:52 raspberrypi systemd[1]: bthelper@hci0.service: Main process exited, code=exited, status=1/FAILURE
              Dec  7 15:24:52 raspberrypi systemd[1]: bthelper@hci0.service: Failed with result 'exit-code'.
              Dec  7 15:24:52 raspberrypi systemd[1]: Failed to start Raspberry Pi bluetooth helper.
              Dec  7 15:24:52 raspberrypi systemd[1]: Starting Bluetooth service...
              Dec  7 15:24:52 raspberrypi systemd[1]: Stopping Make remote CUPS printers available locally...
              Dec  7 15:24:52 raspberrypi systemd[1]: cups-browsed.service: Succeeded.
              Dec  7 15:24:52 raspberrypi systemd[1]: Stopped Make remote CUPS printers available locally.
              Dec  7 15:24:52 raspberrypi systemd[1]: Stopping CUPS Scheduler...
              Dec  7 15:24:52 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
              Dec  7 15:24:52 raspberrypi systemd[1]: cups.service: Succeeded.
              Dec  7 15:24:52 raspberrypi systemd[1]: Stopped CUPS Scheduler.
              Dec  7 15:24:52 raspberrypi systemd[1]: cups.path: Succeeded.
              Dec  7 15:24:52 raspberrypi systemd[1]: cups.socket: Succeeded.
              Dec  7 15:24:52 raspberrypi systemd[1]: Closed CUPS Scheduler.
              Dec  7 15:24:52 raspberrypi systemd[1]: Started Make remote CUPS printers available locally.
              Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Successfully made thread 654 of process 654 owned by '1000' high priority at nice level -11.
              Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Supervising 1 threads of 1 processes of 1 users.
              Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Successfully made thread 655 of process 655 owned by '1000' high priority at nice level -11.
              Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Supervising 2 threads of 2 processes of 1 users.
              Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Successfully made thread 660 of process 654 owned by '1000' RT at priority 20.
              Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Supervising 3 threads of 2 processes of 1 users.
              Dec  7 15:24:53 raspberrypi kernel: [   33.527732] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
              Dec  7 15:24:53 raspberrypi kernel: [   33.527759] Bluetooth: BNEP filters: protocol multicast
              Dec  7 15:24:53 raspberrypi kernel: [   33.568521] NET: Registered PF_ALG protocol family
              Dec  7 15:24:53 raspberrypi kernel: [   33.669986] cryptd: max_cpu_qlen set to 1000
              Dec  7 15:24:53 raspberrypi bluetoothd[695]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
              Dec  7 15:24:53 raspberrypi kernel: [   34.096992] Bluetooth: RFCOMM TTY layer initialized
              Dec  7 15:24:53 raspberrypi kernel: [   34.097017] Bluetooth: RFCOMM socket layer initialized
              pi@raspberrypi:~ $
              Danke schonmal im Voraus
              • Meister Mopper
                Meister Mopper @Homoran last edited by
                @homoran sagte in SD-Karte läuft im Verzeichnis /dev/root voll:
                Habe die Anfrage deswegen nach hier fokussiert.
                  @kenji
                  Schalt den Desktop-Krempel aus.
                  • Kenji
                    @thomas-braun Würdest du mir da eine Hilfestellung geben oder ist das umfangreicher. Wie kann man diese Logs aktivieren oder deaktivieren?
                    Oder müssen die Prozesse dahinter einfach deaktiviert werden.
                    Ich habe eigentlich nur en IoBroker auf dem Pi installiert. Wie kommt eine so große Ansammlung zustande? Hat das mit dem Update zu tun was ich durchgeführt habe?
                    Gruß Matze 🙂
                      Offenbar entgegen der Empfehlung die Version mit vollem DesktopEnvironment.
                      Musst du in die logs schauen. Die bisher geposteten Auszüge zeigen (bis auf den hochgefahrenen Desktop) nicht genug.
                      Welches Update?
                      • Kenji
                        Achso also ist die Pi Version komplett ohne Desktop offiziell für den IoBroker empfohlen. Das könnte ich ja auf Dauer mal ändern. Vielen Dank für die Hilfe. Er läuft jetzt erstmal wieder und ich versuche mal mit einem Backup auf eine andere Pi Version ohne Desktop umzuziehen.
                        Das Update war Node 16v. und Pi Version "Bullseye".
                          Das ist die Version, die generell für Serverbetrieb vorgesehen ist.
                          Den Desktop kannst du in
                          sudo raspi-config
                          ausknipsen. In den Boot-Optionen auf 'Boot into CLI, LogIn required' oder so ähnlich umstellen.
                          Kenji 1 Reply Last reply Reply Quote 1
                          • Kenji
                            @thomas-braun Dankeschön habe ich umgestellt hat auch geklappt.
                            3664
