    4. [Vorlage] Konfigurierte Script um States zu zahlen [lowbat, dimmer, shutter, chromecast, etc]
      pix last edited by
      hab mir das Skript nun auch installiert und bin sehr zufrieden. Gutes Skript!
      Ich habe die Ausklammerung eines HM-Geräts jetzt auch hinbekommen. Oben habe ich's schon editiert, der Abfangcode funktioniert nur in der Subscription ( selektor.on() ).
      Hier das neue Skript:
      // http://forum.iobroker.net/viewtopic.php?f=21&t=2651#p23393
      ! //Add device rules
      addDeviceCounter("lowbat", $('channel[state.id=.LOWBAT]'), true);
      addDeviceCounter("sticky_unreach", $('channel[state.id=
      .STICKY_UNREACH]'), true);
      addDeviceCounter("unreach", $('channel[state.id=.UNREACH]'), true);
      addDeviceCounter("config_pending", $('channel[state.id=
      .CONFIG_PENDING]'), true);
      addDeviceCounter("open_windows", $('channel{TYPE=SHUTTER_CONTACT}[state.id=.STATE]'), true);
      addDeviceCounter("on_lights", $('channel{TYPE=DIMMER}[state.id=
      .LEVEL]'), function(state){return state>0;});
      addDeviceCounter("open_shutters", $('channel{TYPE=BLIND}[state.id=.LEVEL]'), function(state){return state>0;});
      addDeviceCounter("playing_music", $('channel[state.id=audio-.playing]'), true);
      • Code - do not change anything bellow this line *
      ! function addDeviceCounter(name, selector, val_to_count) {
      ! //Total amount of devices found by selector
      var state_total = 'deviceCounter.' + name + '.total';
      createState(state_total, 0);
      //List of devices that match condition
      var state_list = 'deviceCounter.' + name + '.list';
      createState(state_list, "");
      //Number of devices that match condition
      var state_counter = 'deviceCounter.' + name + '.counter';
      createState(state_counter, 0);
      ! function countDevs(obj) {
      var d_count = 0;
      var d_list = [];
      ! selector.each(function (id, i) {
      var status = getState(id).val;
      var obj = getObject(id);
      if ((typeof val_to_count === 'function' && val_to_count(status)) ||
      (typeof val_to_count === 'boolean' && val_to_count == status)) {
      //Get parent object
      var parentChannelId = id.slice(id.lastIndexOf("."));
      var parentDevicelId = id.split(".").slice(0,-2).join(".");
      var deviceObject = getObject(parentDevicelId);
      //remember device name
      d_list.push(deviceObject.common.name);
      ++d_count; // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
      ! log(name + "(" + d_count + "): " + d_list);
      ! setState(state_list, d_list.join('
      setState(state_counter, d_list.length);
      setState(state_total, d_count);
      ! //Re-evaluate when a device status changes
      selector.on(function(obj) { // bei Zustandänderung . LOWBAT in allen Gewerken
      if (getObject(obj.deviceId).native.TYPE !=="HM-SCI-3-FM") { // Hier ggf. mit OR || weitere Geräte einfügen
      countDevs(obj);
      } else log('Gerät ' + getObject(obj.deviceId).native.TYPE + ' wird nicht mitgezählt');
      ! //Re-evaluate each hour
      schedule("
      /60 * * * *", countDevs);
      //Evaluate for the first time
      countDevs();
      Pix
        Smartuser last edited by
        @pix:
        var d_count = 0;
        var d_list = [];
        //Get parent object
        countDevs(obj);
        schedule("
        countDevs();
        Pix `
        Pix … danke für deine Arbeit.
        Leider wird das "HM-SCI-3-FM - Device" bei mir immer noch mit gezählt.
        Muss ich noch etwas beachten?
          tesso last edited by
          Schönes Skript.
          Mir fehlen die Fensterdrehgriffkontakte HM-Sec-RHS.
          Ich sehe im Skript die Abfrage
          addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
          Woher weiß ich welche Geräte vom Type Shutter_Contact sind und welcher Typ der Drehgriff ist?
          Dann würde ich versuchen das Skript zu erweitern.
            @Smartuser:
            @pix:
            var d_count = 0;
            var d_list = [];
            //Get parent object
            countDevs(obj);
            schedule("
            countDevs();
            Pix `
            Gruß `
            Hallo Pix,
            könntest du da bitte nochmal drüberschauen?
            Bei mir funktioniert das "ausklammern" nicht.
              pix last edited by
              hier dann noch eine angepasste Version des Skriptes. Es werden nun für den Fenster-Zähler nur RHS (Rotate-Handle-Sensor) berücksichtigt, <u>keine</u> optischen oder magnetischen Tür-Fenster-Kontakte (TFK, Typen: HM-Sec-SCo, HM-Sec- SC2, HM-Sec- SC).
              Ausserdem gibt es nun eine Blacklist, in welcher die nicht zu beachtenden Typen aufgelistet werden (bitte selbst editieren). Zum Test ist hier der Typ HM-Sec-RHS auch eingetragen. Es macht natürlich keinen Sinn, erst das Skript auf RHS umzubiegen und diese Sensoren dann auszuklammern. "HM-Sec-RHS" steht also nur zum Debug in der Blacklist. Also bitte nach den ersten Test rausnehmen…
              /* Test Zähler
              ! http://forum.iobroker.net/viewtopic.php?f=21&t=2651#p23393
              ! von Vegetto
              ! 17.07.2017 eingebaut
              30.07.2017 Blacklist
              RHS Typ
              ! const logging = true;
              ! const blacklist = ['HM-SCI-3-FM', 'HM-Sec-RHS']; //Hier Gerätetyp eintragen, der nicht beachtet werden soll
              .LOWBAT]'), true);
              addDeviceCounter("sticky_unreach", $('channel[state.id=.STICKY_UNREACH]'), true);
              .UNREACH]'), true);
              addDeviceCounter("config_pending", $('channel[state.id=.CONFIG_PENDING]'), true);
              //addDeviceCounter("open_windows", $('channel{TYPE=SHUTTER_CONTACT}[state.id=
              .STATE]'), true);
              addDeviceCounter("open_windows", $('channel{TYPE=ROTARY_HANDLE_SENSOR}[state.id=.STATE]'), function(state){return state>0;}); // liefert 0,1,2
              var state_total = 'System.deviceCounter.' + name + '.total';
              var state_list = 'System.deviceCounter.' + name + '.list';
              var state_counter = 'System.deviceCounter.' + name + '.counter';
              var d_count = 0;
              var d_list = [];
              //Get parent object
              ! if (logging) log(name + "(" + d_count + "): " + d_list);
              var device_type = getObject(obj.deviceId).native.TYPE;
              if (logging) log('Zähler Skript - Auslösender Aktor vom Typ: ' + device_type);
              var dontcount = (blacklist.indexOf(device_type) != -1) ? true : false;
              if (dontcount) log('Geräte vom Typ ' + device_type + ' stehen in der Blacklist und werden nicht gezählt');
              else countDevs(obj);
              schedule("
              countDevs();
              ! Edit: logging nach den ersten Tests bitte auf false stellen
              Pix
                @pix:
                /* Test Zähler
                ! von Vegetto
                RHS Typ
                .LOWBAT]'), true);
                .UNREACH]'), true);
                .STATE]'), true);
                var d_count = 0;
                var d_list = [];
                //Get parent object
                schedule("
                countDevs();
                Pix `
                Hallo Pix,
                keine Ahnung woran es liegt, aber bei mir wird auch mit dem aktellen Script das "HM-SCI-3-FM - Device" mitgezählt 😐
                Sonst funktioniert das Script 1a.
                Hier der Log beim Starten:
                18:38:00.088	[info]	javascript.0 Stop script script.js.Scripte.State_Counter
                18:38:00.971	[info]	javascript.0 Start javascript script.js.Scripte.State_Counter
                18:38:00.972	[info]	javascript.0 script.js.Scripte.State_Counter: lowbat(42):
                18:38:00.973	[info]	javascript.0 script.js.Scripte.State_Counter: sticky_unreach(32):
                18:38:00.973	[info]	javascript.0 script.js.Scripte.State_Counter: unreach(32):
                18:38:00.974	[info]	javascript.0 script.js.Scripte.State_Counter: config_pending(32):
                18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: open_windows(17): Eingangstür,Alarmanlagen Melder,Alarmanlagen Melder,Alarmanlagen Melder,Fenster Badezimmer,Fenster Ben,Fenster Gäste-WC,Fenster Partyzimmer 2
                18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: on_lights(0):
                18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: open_shutters(6): Rollladen Küche,Rollladen Schlafzimmer,Rollladen Wohnzimmer,Rollladen Gäste-WC,Rollladen Esszimmer,Rollladen Partyzimmer
                18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: playing_music(0):
                18:38:00.976	[info]	javascript.0 script.js.Scripte.State_Counter: registered 161 subscriptions and 8 schedules
                Hier noch beim Öffnen eines zusätzlichen Fensters
                18:38:42.327	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-Sec-SCo
                18:38:42.328	[info]	javascript.0 script.js.Scripte.State_Counter: open_windows(17): Eingangstür,Alarmanlagen Melder,Alarmanlagen Melder,Alarmanlagen Melder,Fenster Badezimmer,Fenster Ben,Fenster Gäste-WC,Fenster Wohnzimmer 1,Fenster Partyzimmer 2
                Wie du siehst werden immer die 3 Kanäle des "HM-SCI-3-FM - Device" mitgezählt (Alarmanlagen Melder,Alarmanlagen Melder,Alarmanlagen Melder)
                  pix last edited by
                  kann es denn sein, dass der Typ evtl nicht HM-SCI-3-FM ist? Ich kann nirgends eine Debugausgabe sehen. Kannst du den Alarmanlagenmelder mal den Status wechseln lassen?
                  Pix
                    @pix:
                    Pix `
                    hab ich eben etwa 4x gemacht.
                    Hier der Log:
                    22:58:00.110	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
                    22:58:00.112	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
                    22:58:00.838	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
                    22:58:00.839	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
                    22:58:02.345	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
                    22:58:02.347	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
                    22:58:03.852	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
                    22:58:03.853	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
                      tempestas last edited by
                      Mal eine blöde Frage:
                      gibt es eine elegante Lösung, von HmIP duie LOW_BAT (nicht LOWBAT) Stato abzufragen, aber mit in den lowbat counter aufzunehmen? Geht bestimmt einfach, ich bin leider gescheitert.
                        @Pix
                        Kannst du dir das bitte nochmal anschauen?
                        http://forum.iobroker.net/viewtopic.php?p=77860#p77860
                        Hilft dir der Log weiter?
                          pix last edited by
                          Ja manchmal sieht man den Wald vor Bäumen nicht! :lol:
                          Die von mir abgeänderte Subscription prüft, ob das auslösende Gerät in der Blacklist steht. Wenn nicht, startet es die Funktion countDev(). Allerdings wird diese Funktion auch standardmäßig bei Skriptstart und jede Stunde gestartet. Und zwar ohne vorherige Prüfung. Deshalb der Fehler.
                          Auf die Schnelle bitte am Schluss erstmal die beiden Zeilen auch och auskommentieren:
                          //schedule("*/60 * * * *", countDevs);
                          //countDevs();
                          Man müsste also die Abfrage nach der Blacklist eigentlich in die Funktion countDev() packen.
                          Pix
                            pix last edited by
                            Hallo,@tempestas:
                            gibt es eine elegante Lösung, von HmIP duie LOW_BAT (nicht LOWBAT) Stato abzufragen, aber mit in den lowbat counter aufzunehmen? Geht bestimmt einfach, ich bin leider gescheitert. `
                            schon mal versucht, das Skript oben um diese Zeile zu ergänzen?
                            addDeviceCounter("lowbat",         $('channel[state.id=*.LOW_BAT]'),                           true);
                            Pix
                              @pix:
                              //countDevs();
                              Pix `
                              Ok, danke … ich habe beide Zeilen auskommentiert.
                              Den Rest mit "deinen" Funktionen ist mir zu hoch :lol:
                                FuXXz last edited by
                                ist es möglich Homematic IP Geräte mit einzuschließen? Ich habe z.B. den HM IP Fensterkontakt HmIP-SWDO-I
                                Viele Grüße
                                • Dutchman
                                  @FuXXz:
                                  Viele Grüße `
                                  sind die datenpunkte fuer IP den anders als welche im script benutzt werden ?
                                  addDeviceCounter("lowbat",         $('channel[state.id=*.LOWBAT]'),                      true);
                                  addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
                                  addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
                                  addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
                                  addDeviceCounter("on_lights",      $('channel{TYPE=DIMMER}[state.id=*.LEVEL]'),          function(state){return state>0;});
                                  addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
                                  addDeviceCounter("playing_music",  $('channel[state.id=*audio-*.playing]'),              true);
                                    Homematic IP hat als Datenpunkt für Lowbat LOW_BAT
                                    Ja, kann man einschließen.
                                    • Dutchman
                                      @tempestas:
                                      Ja, kann man einschließen. `
                                      Ich hab mal ueber das script geschaut und sehe das alles ueber device rules gebaut ist, daher solltes es quick & durty reichen diese linie ein zu fuegen:
                                      addDeviceCounter("lowbat_IP",      $('channel[state.id=*.LOW_BAT]'),                     true);
                                      Das gesammte script sieht dan so aus:
                                      //Add device rules
                                       * Code - do not change anything bellow this line *
                                              var d_count = 0;
                                              var d_list  = [];
                                                      //Get parent object
                                          selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
                                              countDevs(obj);
                                          countDevs();
                                      wobei low_bat von IP devices jetzt seperat gezaehlt wird:
                                      javascript.0	2017-11-06 14:57:00.785	info	script.js.common.Low_Bat: lowbat(28):
                                      javascript.0	2017-11-06 14:57:00.763	info	script.js.common.Low_Bat: lowbat_IP(0):
                                      Es geht noch besser um die IP_low bat auf den jetzigen Low_bat hinzu zu zaehlen hab aber so schnell nicht die zeit um das zu verbauen (eventueel jemand andders 🙂
                                      (ich habe keine IP devices)
                                        Pix hatte auf meine Frage damals schon gesschrieben:
                                        damit sollte dann der counter lowbat sowohl auf LOWBAT als auch LOW_BAT getriggert werden, oder?
                                        Habs nie ausprobiert
                                        • Dutchman
                                          @tempestas:
                                          Habs nie ausprobiert `
                                          jah werden sie siehe meinen vorige post…. 😉
                                            @Dutchman:
                                            @tempestas:
                                            jah werden sie siehe meinen vorige post…. 😉 `
                                            ich hatte auf genau das Posting geantwortet. Du hattest geschrieben:
                                            > Es geht noch besser um die IP_low bat auf den jetzigen Low_bat hinzu zu zaehlen hab aber so schnell nicht die zeit um das zu verbauen (eventueel jemand andders :)
                                            Darauf war meine Antwort bezogen.
                                            45
                                            9707
