    4. [2.5.9 Fehler existiert] - Backup-Adapter erzeugt Fehler
      skinni @Homoran last edited by
      2022-12-10 02:30:07.382 - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
      2022-12-10 02:40:22.019 - error: backitup.0 (16301) [iobroker/iobroker] node:internal/bootstrap/switches/does_own_process_state:126
      2022-12-10 02:40:22.035 - error: backitup.0 (16301) [iobroker/iobroker] cachedCwd = rawMethods.cwd();
      2022-12-10 02:40:22.036 - error: backitup.0 (16301) [iobroker/iobroker] ^
      2022-12-10 02:40:22.036 - error: backitup.0 (16301) [iobroker/iobroker] Error: ENOENT: no such file or directory, uv_cwd
      2022-12-10 02:40:22.037 - error: backitup.0 (16301) [iobroker/iobroker] at process.wrappedCwd (node:internal/bootstrap/switches/does_own_process_state:126:28)
      2022-12-10 02:40:22.037 - error: backitup.0 (16301) [iobroker/iobroker] at Object.process.cwd (/opt/iobroker/node_modules/graceful-fs/polyfills.js:10:19)
      2022-12-10 02:40:22.038 - error: backitup.0 (16301) [iobroker/iobroker] at fe.Yargs (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:61304)
      2022-12-10 02:40:22.038 - error: backitup.0 (16301) [iobroker/iobroker] at Argv (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:12:16)
      2022-12-10 02:40:22.039 - error: backitup.0 (16301) [iobroker/iobroker] at Object. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:7:1)
      2022-12-10 02:40:22.040 - error: backitup.0 (16301) [iobroker/iobroker] at Module._compile (node:internal/modules/cjs/loader:1155:14)
      2022-12-10 02:40:22.041 - error: backitup.0 (16301) [iobroker/iobroker] at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
      2022-12-10 02:40:22.041 - error: backitup.0 (16301) [iobroker/iobroker] at Module.load (node:internal/modules/cjs/loader:1033:32)
      2022-12-10 02:40:22.042 - error: backitup.0 (16301) [iobroker/iobroker] at Function.Module._load (node:internal/modules/cjs/loader:868:12)
      2022-12-10 02:40:22.043 - error: backitup.0 (16301) [iobroker/iobroker] at Module.require (node:internal/modules/cjs/loader:1057:19) {
      2022-12-10 02:40:22.044 - error: backitup.0 (16301) [iobroker/iobroker] errno: -2,
      2022-12-10 02:40:22.044 - error: backitup.0 (16301) [iobroker/iobroker] code: 'ENOENT',
      2022-12-10 02:40:22.044 - error: backitup.0 (16301) [iobroker/iobroker] syscall: 'uv_cwd'
      2022-12-10 02:40:22.045 - error: backitup.0 (16301) [iobroker/iobroker] }
      2022-12-10 03:00:00.044 - info: javascript.0 (20131) script.js.common.Tageszeiten_NEU: Astro: Gültige Zeiten: [aktueller Tag: 13] | [nächster Tag: 1] | [Aktualisiert: 0] | Aktuelle Tageszeit: Mitternacht | Kommende Tageszeit: Früher Morgen
      2022-12-10 03:00:00.198 - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 24405
        Thomas Braun Most Active @skinni last edited by
        @skinni
        Mal irgendwann Verzeichnisse umbenannt/verschoben/gelöscht?
        Mal irgendwann npm manuell angepackt?
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        sagt?
          skinni @Thomas Braun last edited by
          @thomas-braun Ich vermute es ist seit dem node.js update von 14 auf 16, denn das war die einzige Änderung in den letzten Wochen, abgesehen von den normalen Adapter Updates.
          pi@iobroker:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          Kein Docker
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.18.1
          v16.18.1
          8.19.2
          4.0.23
          pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          tty
          /home/pi
          Hit:1 http://phoscon.de/apt/deconz buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 http://archive.raspberrypi.org/debian buster InRelease
          Hit:4 https://repos.influxdata.com/debian buster InRelease
          Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
          Hit:6 https://www.pivccu.de/piVCCU stable InRelease
          Reading package lists... Done
          Building dependency tree
          7 packages can be upgraded. Run 'apt list --upgradable' to see them.
          nodejs:
            Installed: 16.18.1-deb-1nodesource1
            Candidate: 16.18.1-deb-1nodesource1
            Version table:
           *** 16.18.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u2 500
            @skinni
            Buster ist tot. Installier da das aktuelle stable release 'Bullseye'.
              Siggi0904 last edited by
              Bei mir tritt das Problem auf, sobald ich einen Adapter aktualisiert habe.
              Dann hilft nur ein Neustart des ganzen Systems.
                @thomas-braun hab jetzt auch im backup adapter den Fehler, das bullseye upgrade werde ich dieses WE angehen, erst mal sd-card klonen
                ted iobroker ...
                [DEBUG] [mount] - mount activ... umount is started before mount!!
                [DEBUG] [mount] - umount successfully completed
                [DEBUG] [mount] - noserverino option: false
                [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=pi,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.88.110/PIBackup /opt/iobroker/backups"
                [DEBUG] [mount] - mount successfully completed
                [DEBUG] [mount] - done
                [ERROR] [iobroker] - node:internal/bootstrap/switches/does_own_process_state:126
                    at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:7:1)
                  errno: -2,
                  code: 'ENOENT',
                  syscall: 'uv_cwd'
                  Siggi0904 @skinni last edited by
                  @skinni Start mal den Rechner neu. Du wirst sehen, dann ist der Fehler weg.
                    skinni @Siggi0904 last edited by
                    @siggi0904 Der Fehler verschwindet auch von alleine, genauso wie er kommt. Das soll nicht meine Lösung sein. Hab jetzt mal das Update auf bullseye gemacht, das lief überraschend gut. Hab mich dabei an die Anleitung https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye gehalten
                    Thomas Braun S 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @skinni last edited by Thomas Braun
                      @skinni
                      Jag den Fixer mal drüber.
                      iob stop
                      iob fix
                      iob start
                      Und wie startest du das Backup?
                        @thomas-braun Die Frage versteh ich nicht. Ich starte das Backup eigentlich gar nicht, das macht ja der backitup Adapter jede Nacht und ist dabei erfolgreich, oder manchmal auch nicht. Das da oben hatte ich im backitup Adapter manuell gestartet durch Klick auf "Jetzt sichern" unter iobroker im backitup Adapter. Das funktioniert jetzt aktuell auch gerade wieder - bis es dann in ein paar Tragen vermutlich nicht mehr geht 😉
                        Den fixer hatte ich heute nach dem bullseye upgrade schon drüber laufen lassen, sicher ist sicher.
                        Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                          @skinni sagte in [wieder geöffnet] - Backup-Adapter erzeugt Fehler:
                          Das war genau die Frage. Die Meldung kommt eigentlich wenn man da mit einem user in einem Verzeichnis steht, dieses verändert wird und das dann alles 'in der Luft' hängt.
                            @skinni Bei mir verschwindet der Fehler nicht automatisch.
                            Wenn er einmal auftritt, bleibt er bis zum Neustart stehen.
                              skinni last edited by skinni
                              Lief jetzt bis heute ohne Probleme, musste aber erstmal zurück auf buster weil mein conbee II nicht mehr funktioniert hat 😕
                                Das ist kein Grund, der läuft natürlich auch unter 'bullseye'.
                                • simatec
                                  simatec Developer Most Active @Siggi0904 last edited by
                                  @siggi0904 Tritt der Fehler in v2.5.9 bei dir noch auf?
                                  S 3 Replies Last reply Reply Quote 0
                                  • simatec
                                    simatec Developer Most Active @skinni last edited by
                                    @skinni Welche Version von Backitup ist installiert? In v2.5.9 ist etwas eingebaut, um den fehler abzufangen.
                                    Wenn der Fehler auftreten sollte, starte mal den Adapter neu und poste den Debug Log
                                      Siggi0904 @simatec last edited by
                                      @simatec Ich habe erst gerade die neue Version erhalten.
                                      Das muss ich erst testen. Danke für den Hinweis.
                                        @simatec Tests sind durch, auch die automatischen Backups liefen heute ohne Probleme durch.
                                        Ich hatte bei der alten Version den Fehler, ohne Neustart mit der neuen Version läuft alles super.
                                        Ich setze das Thema auf erledigt.
                                          @simatec Das Problem ist heute wieder aufgetreten. 😠
                                          • simatec
                                            @siggi0904 Kannst du bitte den Log posten?
                                            Das Problem muss tiefer liegen und mit großer Wahrscheinlichkeit in nodejs liegen
                                            5651
