    2. English
    3. ioBroker general
    4. iObroker not accessible
      Thomas Braun Most Active @Vraanaa last edited by Thomas Braun
      @vraanaa
      Try reinstalling
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      And please do not provide screenshots from terminal but post the text embedded in CodeTags.
      Vraanaa 1 Reply Last reply Reply Quote 0
      • Vraanaa
        Vraanaa @Thomas Braun last edited by
        @thomas-braun thank you for your reply
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.17
        > unix-dgram@2.0.6 install /opt/iobroker/node_modules/unix-dgram
        > node-gyp rebuild
        make: Ulazak u direktorij '/opt/iobroker/node_modules/unix-dgram/build'
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        In file included from ../../nan/nan.h:60,
                         from ../src/unix_dgram.cc:5:
        /home/iobroker/.cache/node-gyp/14.21.1/include/node/node.h:793:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/14.21.1/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
         NODE_MODULE(unix_dgram, Initialize)
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Izlazak iz direktorija '/opt/iobroker/node_modules/unix-dgram/build'
        > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
        npm WARN iobroker No description
        npm WARN iobroker No repository field.
        npm WARN iobroker No README data
        npm WARN iobroker No license field.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 24
        npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
        npm ERR! Exit status 24
        npm ERR!
        npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2022-12-11T11_39_21_489Z-debug.log
          @vraanaa
          First upgrade your nodejs to version 16.
          Vraanaa 2 Replies Last reply Reply Quote 0
          • Vraanaa
            Vraanaa @Thomas Braun last edited by Vraanaa
            @thomas-braun I did but it didnt update - strange - I stopped iobroker before:
            Edit - sorry I forgot to run sudo apt install -y nodejs
            pi@raspberrypi:~ $ node -v
            v14.21.1
            pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
            ## Installing the NodeSource Node.js 16.x repo...
            ## Populating apt-get cache...
            + apt-get update
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
            Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Reading package lists... Done
            ## Confirming "buster" is supported...
            + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
            ## Adding the NodeSource signing key to your keyring...
            + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
            gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
            ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
            + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
            + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
            ## Running `apt-get update` for you...
            + apt-get update
            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
            Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
            ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
            ## You may also need development tools to build native addons:
                 sudo apt-get install gcc g++ make
            ## To install the Yarn package manager, run:
                 curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                 echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                 sudo apt-get update && sudo apt-get install yarn
            v14.21.1
            pi@raspberrypi:~ $
              @vraanaa
              What does this command do?
              sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
              uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              • Vraanaa
                @thomas-braun now is on version 16
                v16.18.1
                pi@raspberrypi:~ $ iobroker start
                pi@raspberrypi:~ $ iobroker update
                node:internal/modules/cjs/loader:988
                  throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                    at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                    at node:internal/main/run_main_module:22:47 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                pi@raspberrypi:~ $ iobroker fix
                library: loaded
                Library version=2022-06-15
                ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                pi@raspberrypi:~ $
                  @vraanaa
                  The 'Buster' release has reached its End of Life.
                  Please install the actual stable Release 'Bullseye'
                  • Vraanaa
                    @thomas-braun thank you for you help so far - can you help me little bit with this Bullseye? How exactly I should install it?
                      @vraanaa
                      In german language only:
                      https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                      But I'm sure that there are plenty of instructions out there in English or even your native language.
                      • Vraanaa
                        @thomas-braun kein problem - ich kann auch Deutch verstehen 👍
                        Vielen Dank - probiere ich und melde.
                        So nach Bullseye instalation soll alles OK sein oder muss ich noch ewas anderes zu tun?
                          @vraanaa
                          Nein, der iobroker wird nach einem Upgrade auf Bullseye immer noch kaputt sein. Aber dann ist die Basis schonmal aktuell und stabil.
                          • Vraanaa
                            @thomas-braun I did all as per manual. can we check if everything is ok before next steps?
                              @vraanaa
                              what is the feedback to this chain of commands?
                              • Vraanaa
                                pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                armv7l
                                Kein Docker
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.18.1
                                v16.18.1
                                8.19.2
                                  throw err;
                                  requireStack: []
                                pi@raspberrypi:~ $
                                  @vraanaa sagte in iObroker not accessible:
                                  • Vraanaa
                                    @thomas-braun kommt diese
                                    pi@raspberrypi:~ $ whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                    x11
                                    LXDE-pi
                                    /home/pi
                                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:3 https://dl.yarnpkg.com/debian stable InRelease
                                    Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    Building dependency tree... Done
                                    All packages are up to date.
                                    nodejs:
                                      Installed: 16.18.1-deb-1nodesource1
                                      Candidate: 16.18.1-deb-1nodesource1
                                      Version table:
                                     *** 16.18.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                            100 /var/lib/dpkg/status
                                         12.22.12~dfsg-1~deb11u1 500
                                            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                    pi@raspberrypi:~ $
                                      @vraanaa
                                      Turn the Desktop OFF.
                                      A server is running headless. Always.
                                      • Vraanaa
                                        @thomas-braun meinst du dass ich remote vnc desktop benutzen nicht?
                                        kann ich auch durch putty zum ssh gehen.
                                          @vraanaa
                                          Nein, auch kein remote DESKTOP.
                                          NO DESKTOP.
                                          sudo raspi-config
                                          Menu:
                                          1 System Options
                                          S5 Boot / Auto Login
                                          B1 Console
                                          • Vraanaa
                                            @thomas-braun I did it:
                                            pi@raspberrypi:~ $ whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_S        ESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy n        odejs
                                            pi
                                            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                                            tty
                                            /home/pi
                                            Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                            Hit:4 https://dl.yarnpkg.com/debian stable InRelease
                                            nodejs:
                                              Version table:
                                            3479
