Kein Zugriff auf Anwendungen
@homoran genau, der cloud adapter. mac os
@homoran Unter windows das gleiche Bild. Habe bereis den Raspi neu gestartet und iobroker auch. Ändert nichts.
Im Log steht dazu was?
Ich vermute dass da keine gültige Lizenz gefunden wird. -
@thomas-braun wie komme ich an die log Datei ohne Zugriff auf die Admin-Oberfläche?
@thomas-braun Dankeschön !
pi@iobroker:~ $ iobroker logs
2022-12-11 10:17:10.722 - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
2022-12-11 10:17:10.728 - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2022-12-11 10:17:10.730 - info: host.iobroker hostname: iobroker, node: v16.18.1
2022-12-11 10:17:10.731 - info: host.iobroker ip addresses: fe80::3f68:ee45:fc73:8604
2022-12-11 10:17:13.240 - info: host.iobroker connected to Objects and States
2022-12-11 10:17:13.283 - info: host.iobroker added notifications configuration of host
2022-12-11 10:17:14.407 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
2022-12-11 10:17:14.418 - info: host.iobroker 3 instances found
2022-12-11 10:17:14.433 - info: host.iobroker starting 3 instances
2022-12-11 10:17:14.549 - info: host.iobroker instance system.adapter.admin.0 started with pid 945
2022-12-11 10:17:14.566 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
2022-12-11 10:17:14.659 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
2022-12-11 10:17:14.687 - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
2022-12-11 10:17:14.717 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
2022-12-11 10:17:14.746 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
2022-12-11 10:17:14.776 - info: host.iobroker Some obsolete host states deleted.
2022-12-11 10:30:17.673 - error: admin.0 (945) admin.0 already running
2022-12-11 10:30:17.679 - warn: admin.0 (945) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-12-11 10:30:18.239 - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-12-11 10:30:18.240 - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
2022-12-11 10:30:18.711 - info: host.iobroker instance system.adapter.discovery.0 started with pid 1378
2022-12-11 10:30:20.184 - error: discovery.0 (1378) discovery.0 already running
2022-12-11 10:30:20.190 - warn: discovery.0 (1378) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-12-11 10:30:20.745 - error: host.iobroker instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-12-11 10:30:20.747 - info: host.iobroker Restart adapter system.adapter.discovery.0 because enabled
2022-12-11 10:30:22.694 - info: host.iobroker instance system.adapter.backitup.0 started with pid 1852
2022-12-11 10:30:24.182 - error: backitup.0 (1852) backitup.0 already running
2022-12-11 10:30:24.186 - warn: backitup.0 (1852) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-12-11 10:30:24.734 - error: host.iobroker instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-12-11 10:30:24.735 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
2022-12-11 10:30:48.306 - info: host.iobroker instance system.adapter.admin.0 started with pid 1876
2022-12-11 10:30:50.164 - info: admin.0 (1876) starting. Version 6.2.23 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.1, js-controller: 4.0.23
2022-12-11 10:30:50.218 - info: admin.0 (1876) requesting all states
2022-12-11 10:30:50.219 - info: admin.0 (1876) requesting all objects
2022-12-11 10:30:50.675 - info: admin.0 (1876) received all objects
2022-12-11 10:30:50.782 - info: host.iobroker instance system.adapter.discovery.0 started with pid 1899
2022-12-11 10:30:50.840 - info: admin.0 (1876) Request actual repository...
2022-12-11 10:30:50.906 - info: admin.0 (1876) http server listening on port 8081
2022-12-11 10:30:50.907 - info: admin.0 (1876) Use link "http://localhost:8081" to configure.
2022-12-11 10:30:50.918 - info: admin.0 (1876) socket.io server listening on port 8081
2022-12-11 10:30:51.232 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
2022-12-11 10:30:53.852 - info: admin.0 (1876) Repository received successfully.
2022-12-11 10:30:54.158 - info: discovery.0 (1899) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.1, js-controller: 4.0.23
2022-12-11 10:30:54.780 - info: host.iobroker instance system.adapter.backitup.0 started with pid 1918
2022-12-11 10:30:56.392 - info: backitup.0 (1918) starting. Version 2.5.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
2022-12-11 10:30:56.459 - info: backitup.0 (1918) [iobroker] backup was activated at 02:40 every 1 day(s)
2022-12-11 16:15:06.041 - info: admin.0 (1876) terminating http server on port 8081
2022-12-11 16:15:06.042 - info: backitup.0 (1918) cleaned everything up...
2022-12-11 16:15:06.055 - info: host.iobroker received SIGTERM
2022-12-11 16:15:06.062 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
2022-12-11 16:15:06.063 - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
2022-12-11 16:15:06.063 - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
2022-12-11 16:15:06.077 - info: admin.0 (1876) Got terminate signal TERMINATE_YOURSELF
2022-12-11 16:15:06.080 - info: backitup.0 (1918) Got terminate signal TERMINATE_YOURSELF
2022-12-11 16:15:06.082 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
2022-12-11 16:15:06.082 - info: admin.0 (1876) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-12-11 16:15:06.084 - info: backitup.0 (1918) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-12-11 16:15:06.085 - info: discovery.0 (1899) Got terminate signal TERMINATE_YOURSELF
2022-12-11 16:15:06.096 - info: discovery.0 (1899) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-12-11 16:15:06.124 - info: host.iobroker stopInstance system.adapter.discovery.0 send kill signal
2022-12-11 16:15:06.125 - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
2022-12-11 16:15:06.653 - info: host.iobroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-12-11 16:15:06.666 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-12-11 16:15:06.709 - info: host.iobroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-12-11 16:15:06.710 - info: host.iobroker All instances are stopped.
2022-12-11 16:15:06.901 - info: host.iobroker terminated
2022-12-11 16:15:08.993 - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
2022-12-11 16:15:09.000 - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2022-12-11 16:15:09.001 - info: host.iobroker hostname: iobroker, node: v16.18.1
2022-12-11 16:15:09.002 - info: host.iobroker ip addresses: 192.168.178.94 2a02:908:d80:aa80:e25b:e951:5000:a86f fe80::3f68:ee45:fc73:8604 192.168.178.189 2a02:908:d80:aa80:44b6:3b6a:e318:bf17 fe80::f8dd:f6dc:7e55:5a9f
2022-12-11 16:15:09.878 - info: host.iobroker connected to Objects and States
2022-12-11 16:15:09.901 - info: host.iobroker added notifications configuration of host
2022-12-11 16:15:10.268 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
2022-12-11 16:15:10.276 - info: host.iobroker 3 instances found
2022-12-11 16:15:10.285 - info: host.iobroker starting 3 instances
2022-12-11 16:15:10.334 - info: host.iobroker instance system.adapter.admin.0 started with pid 3386
2022-12-11 16:15:10.362 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
2022-12-11 16:15:10.377 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
2022-12-11 16:15:10.391 - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
2022-12-11 16:15:10.405 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
2022-12-11 16:15:10.420 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
2022-12-11 16:15:10.434 - info: host.iobroker Some obsolete host states deleted.
2022-12-11 16:15:12.276 - info: admin.0 (3386) starting. Version 6.2.23 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.1, js-controller: 4.0.23
2022-12-11 16:15:12.325 - info: admin.0 (3386) requesting all states
2022-12-11 16:15:12.326 - info: admin.0 (3386) requesting all objects
2022-12-11 16:15:12.698 - info: admin.0 (3386) received all objects
2022-12-11 16:15:12.898 - info: admin.0 (3386) Request actual repository...
2022-12-11 16:15:12.937 - info: admin.0 (3386) http server listening on port 8081
2022-12-11 16:15:12.938 - info: admin.0 (3386) Use link "http://localhost:8081" to configure.
2022-12-11 16:15:12.950 - info: admin.0 (3386) socket.io server listening on port 8081
2022-12-11 16:15:13.244 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
2022-12-11 16:15:15.654 - info: host.iobroker instance system.adapter.discovery.0 started with pid 3413
2022-12-11 16:15:15.835 - info: admin.0 (3386) Repository received successfully.
2022-12-11 16:15:17.238 - info: discovery.0 (3413) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.1, js-controller: 4.0.23
2022-12-11 16:15:18.322 - info: host.iobroker instance system.adapter.backitup.0 started with pid 3428
2022-12-11 16:15:20.033 - info: backitup.0 (3428) starting. Version 2.5.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
2022-12-11 16:15:20.098 - info: backitup.0 (3428) [iobroker] backup was activated at 02:40 every 1 day(s)
pi@iobroker:~ $ -
@mellus sagte in Kein Zugriff auf Anwendungen:
mach mal rin reboot vom pi
@homoran Problem bleibt
iob list instancesDa läuft ja auch gar nicht viel, wenn ich das richtig sehe .
Bitte für Konsolentext die CodeTags verwenden.
@thomas-braun Ja, ist ja auch ne taufrische Neuinstallation, weil das Problem besteht
@mellus
Den iot bzw. cloud-Adapter brauchst du schon. -
@thomas-braun werden diese Adapter nicht automatisch mit aufgespielt bei einer Neuinstallation?
Nein.
@thomas-braun ich habe noch nie nach einer Neuinstallation den Cloud-Adapter nachinstallieren müssen.
Vermutlich so:
npm install iobroker.cloudund dann manuell starten?
Und wie soll die Synchronisation zu iobroker.net/pro dann funktionieren?
der war noch nie in dem Installer dabei.
Vermutlich so:
npm install iobroker.cloudnein.
iobroker add cloud -
@homoran Ich habe mich hiernach gerichtet:
Da wird doch gar nicht auf zusätzliche Adapter und die Anbindung an iobroker.pro eingegangen.
dann ist ja gut
Vielen Dank für die intelligenten und überaus hilfreichen Antworten.
