contrib tts lässt sich nicht installieren
@mickym said in contrib tts lässt sich nicht installieren:
folgende mitteilung bekomm ich aus der Konsole
Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.15.60-1-pve x86_64) * Documentation: https://help.ubuntu.com * Management: https://landscape.canonical.com * Support: https://ubuntu.com/advantage Last login: Mon Dec 12 13:43:08 CET 2022 on tty1 root@ioBroker:~# cd /opt/iobroker/iobroker-data/node-red root@ioBroker:/opt/iobroker/iobroker-data/node-red# rm -r node_modules root@ioBroker:/opt/iobroker/iobroker-data/node-red# npm install npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead. npm WARN deprecated formidable@1.2.2: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: https://bit.ly/2ZEqIau npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410 npm WARN deprecated node-red-contrib-sonospollytts@2.0.8: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info. added 294 packages, and audited 295 packages in 38s 57 packages are looking for funding run `npm fund` for details 7 vulnerabilities (4 moderate, 3 high) To address all issues (including breaking changes), run: npm audit fix --force Run `npm audit` for details. npm notice npm notice New major version of npm available! 8.19.2 -> 9.2.0 npm notice Changelog: https://github.com/npm/cli/releases/tag/v9.2.0 npm notice Run npm install -g npm@9.2.0 to update! npm notice -
@saranger Das muss nichts heißen. Geht Dein Node Red wieder?
Nicht als root agieren. Insbesondere nicht in den Verzeichnissen.
Nie, nie, niemals als root! -
@thomas-braun sagte in contrib tts lässt sich nicht installieren:
Nie, nie, niemals als root!Da hast Du natürlich Recht - da hab ich wieder mal nicht drauf geachtet. Danke für Hinweis. Dann auf jeden Fall nochmal machen - ich hoffe es hat mit den Rechten nichts zerschossen.
ah das hab ich auch nicht auf dem schirm gehabt, ich hab glaube gar keinen anderen user.
anbei wieder die meldung und nodered geht nicht
----------------------------------------------------------- 2022-12-12T13:16:47.946Z Installieren : node-red-contrib-tts-ultimate 1.0.52 2022-12-12T13:16:47.964Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-tts-ultimate@1.0.52 2022-12-12T13:16:48.245Z [err] npm 2022-12-12T13:16:48.245Z [err] WARN config production Use `--omit=dev` instead. 2022-12-12T13:16:57.529Z [err] npm 2022-12-12T13:16:57.530Z [err] WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. -
@saranger sagte in contrib tts lässt sich nicht installieren:
Das ist das erste was man in einem neuen Ubuntu tut. Eigentlich ist das in einer üblichen Installation eh schon im Installer so vorgesehen. Bei virtuellen Kisten wie gesagt die erste Aktion: User anlegen.
@thomas-braun said in contrib tts lässt sich nicht installieren:
iob fix
user hab ich jetzt angelegt und die beiden befehle hab ich auch ausgeführt
Ja ich glaube auch, dass da mit den Rechten insgesamt was nicht stimmt. Da übergebe ich lieber an @Thomas-Braun. Ich schau mal, ob ich auf meinem Testsystem die Node installieren kann.
iob diag
bash: line 1: syntax error near unexpected token `<' bash: line 1: `<!doctype html><html lang="en"><head><meta charset="utf-8"/><link rel="icon" href="/www/favicon.ico"/><meta name="viewport" content="width=device-width,initial-scale=1"/><meta name="theme-color" content="#2196F3"><meta name="description" content="Remote access to personal ioBroker server via ioBroker.cloud"/><link rel="apple-touch-icon" href="/www/logo192.png"/><link rel="manifest" href="/www/manifest.json"/><title>ioBroker Cloud</title><style>#root,body,html{height:100%;width:100%;display:flex;overflow:hidden}</style><script defer="defer" src="/www/static/js/main.ae982c84.js"></script><link href="/www/static/css/main.59da0ebb.css" rel="stylesheet"></head><body><noscript>You need to enable JavaScript to run this app.</noscript><div id="root"></div></body></html>' -
@saranger Also auf meinem Testsystem konnte ich die Node installieren.
Die Meldungen ansonsten sind aber normal - habe hier mal das Log über die Installation über den Palletten-Manager:
----------------------------------------------------------- 2022-12-12T13:31:52.224Z Installieren : node-red-contrib-tts-ultimate 1.0.52 2022-12-12T13:31:52.226Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-tts-ultimate@1.0.52 2022-12-12T13:31:52.406Z [err] npm 2022-12-12T13:31:52.406Z [err] WARN config production Use `--omit=dev` instead. 2022-12-12T13:31:53.776Z [err] npm 2022-12-12T13:31:53.776Z [err] 2022-12-12T13:31:53.776Z [err] WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead. 2022-12-12T13:31:53.779Z [err] npm 2022-12-12T13:31:53.779Z [err] WARN deprecated formidable@1.2.2: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: https://bit.ly/2ZEqIau 2022-12-12T13:31:53.792Z [err] npm 2022-12-12T13:31:53.792Z [err] WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. 2022-12-12T13:32:06.791Z [out] 2022-12-12T13:32:06.791Z [out] added 169 packages in 14s 2022-12-12T13:32:06.800Z rc=0Das heisst diese Math.random Warnung kann man ignorieren.
Bei Dir fehlt nur die Erfolgsmeldung dass 169 Pakete installiert wurden. Vielleicht Geduld?
@mickym ok gut zu wissen, vielleicht lässt sich das andere ja noch lösen
danke Dir.
anbei mal die Meldung noch im IObroker Log nach dem Versuch diese node zu installieren und das crashen von nodered
FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory 2022-12-12 14:58:41.183 - warn: node-red.0 (2527) 1: 0xb06730 node::Abort() [node-red] 2022-12-12 14:58:41.183 - warn: node-red.0 (2527) 2: 0xa1b6d0 [node-red] 2022-12-12 14:58:41.184 - warn: node-red.0 (2527) 3: 0xce1e60 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node-red] 2022-12-12 14:58:41.185 - warn: node-red.0 (2527) 4: 0xce2207 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red] 2022-12-12 14:58:41.185 - warn: node-red.0 (2527) 5: 0xe99875 [node-red] 2022-12-12 14:58:41.186 - warn: node-red.0 (2527) 6: 0xea953d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node-red] 2022-12-12 14:58:41.187 - warn: node-red.0 (2527) 7: 0xeac23e v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node-red] 2022-12-12 14:58:41.187 - warn: node-red.0 (2527) 8: 0xe6d4b2 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node-red] 2022-12-12 14:58:41.188 - warn: node-red.0 (2527) 9: 0xe65ac4 v8::internal::FactoryBase::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [node-red] 2022-12-12 14:58:41.189 - warn: node-red.0 (2527) 10: 0xe67d22 v8::internal::FactoryBase::NewDescriptorArray(int, int, v8::internal::AllocationType) [node-red] 2022-12-12 14:58:41.189 - warn: node-red.0 (2527) 11: 0x10b5d77 v8::internal::DescriptorArray::CopyUpTo(v8::internal::Isolate*, v8::internal::Handle, int, int) [node-red] 2022-12-12 14:58:41.191 - warn: node-red.0 (2527) 12: 0x10a3eb1 v8::internal::Map::CopyAddDescriptor(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Descriptor*, v8::internal::TransitionFlag) [node-red] 13: 0x10a446c v8::internal::Map::CopyWithField(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::Representation, v8::internal::TransitionFlag) [node-red] 2022-12-12 14:58:41.192 - warn: node-red.0 (2527) 14: 0x10a6298 v8::internal::Map::TransitionToDataProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::StoreOrigin) [node-red] 2022-12-12 14:58:41.192 - warn: node-red.0 (2527) 15: 0x1094df2 v8::internal::LookupIterator::PrepareTransitionToDataProperty(v8::internal::Handle, v8::internal::Handle, v8::internal::PropertyAttributes, v8::internal::StoreOrigin) [node-red] 2022-12-12 14:58:41.193 - warn: node-red.0 (2527) 16: 0x10b827a v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::PropertyAttributes, v8::Maybe, v8::internal::StoreOrigin) [node-red] 2022-12-12 14:58:41.194 - warn: node-red.0 (2527) 17: 0x10bc7a3 v8::internal::Object::SetProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red] 2022-12-12 14:58:41.195 - warn: node-red.0 (2527) 18: 0x11efce6 v8::internal::Runtime::SetObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red] 2022-12-12 14:58:41.195 - warn: node-red.0 (2527) 19: 0x11f1269 v8::internal::Runtime_SetKeyedProperty(int, unsigned long*, v8::internal::Isolate*) [node-red] 2022-12-12 14:58:41.196 - warn: node-red.0 (2527) 20: 0x15da159 [node-red] 2022-12-12 14:58:41.208 - info: node-red.0 (2527) node-red exited with null 2022-12-12 14:58:46.208 - info: node-red.0 (2527) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js 2022-12-12 14:58:49.542 - warn: node-red.0 (2527) 12 Dec 14:58:49 - [warn] Projects disabled : editorTheme.projects.enabled=false 2022-12-12 14:58:50.138 - warn: node-red.0 (2527) <--- Last few GCs ---> [4805:0x5fcdf70] 3865 ms: Mark-sweep (reduce) 125.1 (131.4) -> 124.1 (131.4) MB, 50.5 / 0.0 ms (average mu = 0.147, current mu = 0.057) allocation failure scavenge might not succeed [4805:0x5fcdf70] 3916 ms: Mark-sweep (reduce) 125.2 (131.4) -> 124.3 (131.7) MB, 47.6 / 0.0 ms (average mu = 0.105, current mu = 0.061) allocation failure scavenge might not succeed <--- JS stacktrace ---> FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory 2022-12-12 14:58:50.138 - warn: node-red.0 (2527) 1: 0xb06730 node::Abort() [node-red] 2022-12-12 14:58:50.139 - warn: node-red.0 (2527) 2: 0xa1b6d0 [node-red] 2022-12-12 14:58:50.140 - warn: node-red.0 (2527) 3: 0xce1e60 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node-red] 2022-12-12 14:58:50.141 - warn: node-red.0 (2527) 4: 0xce2207 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red] 2022-12-12 14:58:50.142 - warn: node-red.0 (2527) 5: 0xe99875 [node-red] 2022-12-12 14:58:50.143 - warn: node-red.0 (2527) 6: 0xea953d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node-red] 2022-12-12 14:58:50.145 - warn: node-red.0 (2527) 7: 0xeac23e v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node-red] 2022-12-12 14:58:50.146 - warn: node-red.0 (2527) 8: 0xe6d4b2 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node-red] 2022-12-12 14:58:50.147 - warn: node-red.0 (2527) 9: 0xe67dcc v8::internal::FactoryBase::AllocateRawArray(int, v8::internal::AllocationType) [node-red] 2022-12-12 14:58:50.148 - warn: node-red.0 (2527) 10: 0xe67ea5 v8::internal::FactoryBase::NewFixedArrayWithFiller(v8::internal::Handle, int, v8::internal::Handle, v8::internal::AllocationType) [node-red] 2022-12-12 14:58:50.149 - warn: node-red.0 (2527) 11: 0x1016382 [node-red] 2022-12-12 14:58:50.150 - warn: node-red.0 (2527) 12: 0x101650c [node-red] 2022-12-12 14:58:50.151 - warn: node-red.0 (2527) 13: 0x1016668 [node-red] 2022-12-12 14:58:50.151 - warn: node-red.0 (2527) 14: 0x10744b5 v8::internal::JSObject::AddDataElement(v8::internal::Handle, unsigned int, v8::internal::Handle, v8::internal::PropertyAttributes) [node-red] 2022-12-12 14:58:50.152 - warn: node-red.0 (2527) 15: 0x10b820e v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::PropertyAttributes, v8::Maybe, v8::internal::StoreOrigin) [node-red] 2022-12-12 14:58:50.153 - warn: node-red.0 (2527) 16: 0x10bc7a3 v8::internal::Object::SetProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red] 2022-12-12 14:58:50.154 - warn: node-red.0 (2527) 17: 0x11efce6 v8::internal::Runtime::SetObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red] 2022-12-12 14:58:50.154 - warn: node-red.0 (2527) 18: 0x11f1269 v8::internal::Runtime_SetKeyedProperty(int, unsigned long*, v8::internal::Isolate*) [node-red] 2022-12-12 14:58:50.155 - warn: node-red.0 (2527) 19: 0x15da159 [node-red] 2022-12-12 14:58:50.168 - info: node-red.0 (2527) node-red exited with null 2022-12-12 14:58:55.168 - info: node-red.0 (2527) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js 2022-12-12 14:58:58.450 - warn: node-red.0 (2527) 12 Dec 14:58:58 - [warn] Projects disabled : editorTheme.projects.enabled=false 2022-12-12 14:58:58.949 - warn: node-red.0 (2527) <--- Last few GCs ---> [4827:0x6ac1f70] 3718 ms: Mark-sweep 125.1 (133.9) -> 123.5 (134.4) MB, 44.0 / 0.0 ms (average mu = 0.240, current mu = 0.109) allocation failure scavenge might not succeed [4827:0x6ac1f70] 3767 ms: Mark-sweep 125.6 (134.4) -> 124.0 (134.9) MB, 43.5 / 0.0 ms (average mu = 0.177, current mu = 0.105) allocation failure scavenge might not succeed <--- JS stacktrace ---> FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory 2022-12-12 14:58:58.951 - warn: node-red.0 (2527) 1: 0xb06730 node::Abort() [node-red] 2022-12-12 14:58:58.951 - warn: node-red.0 (2527) 2: 0xa1b6d0 [node-red] 3: 0xce1e60 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node-red] 2022-12-12 14:58:58.951 - warn: node-red.0 (2527) 4: 0xce2207 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red] 2022-12-12 14:58:58.955 - warn: node-red.0 (2527) 5: 0xe99875 [node-red] 6: 0xea953d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node-red] 7: 0xeac23e v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node-red] 8: 0xe6d77a v8::internal::Factory::NewFillerObject(int, bool, v8::internal::AllocationType, v8::internal::AllocationOrigin) [node-red] 9: 0x11e64e6 v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [node-red] 10: 0x15da159 [node-red] 2022-12-12 14:58:58.968 - info: node-red.0 (2527) node-red exited with null 2022-12-12 14:59:00.775 - error: rpi2.0 (2689) Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/loop0 16337788 3655048 11827496 24% / /1024 2022-12-12 14:59:00.776 - error: rpi2.0 (2689) Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/loop0 16337788 3655048 11827496 24% / -
@saranger hast du mal den speicherbedarf im Node-red Adapter erhöht?
@mickym nein du meinst den ram wenn ich im iobroker auf den noderedadapter gehe? Wieviel sollte man da geben?
Wie bist du denn da eigentlich insgesamt unterwegs?
free -ht sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs -
@saranger ich glaub Standard ist 128. ich hab 2048 weil ich viele flows habe, aber kannst ja mal mit 512 oder 1024 Testen.
saranger@ioBroker:~$ free -ht total used free shared buff/cache available Mem: 4.0Gi 1.3Gi 2.4Gi 0.0Ki 293Mi 2.7Gi Swap: 512Mi 0B 512Mi Total: 4.5Gi 1.3Gi 2.9Gi saranger@ioBroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null [sudo] password for saranger: Sorry, try again. [sudo] password for saranger: saranger@ioBroker:~$ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs x86_64 Kein Docker /usr/bin/nodejs /usr/bin/node /usr/bin/npm v16.18.1 v16.18.1 8.19.2 4.0.23 saranger saranger sudo iobroker /home/saranger Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB] Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB] Fetched 224 kB in 1s (228 kB/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. nodejs: Installed: 16.18.1-deb-1nodesource1 Candidate: 16.18.1-deb-1nodesource1 Version table: *** 16.18.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages 100 /var/lib/dpkg/status 12.22.9~dfsg-1ubuntu3 500 500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages saranger@ioBroker:~$ -
@mickym werd ich mal testen, ich muss dazu sagen das Ganze läuft auf Proxmox und ich habe seit dem auch immer probleme beim Deploy, teilweise muss ich 4 mal darauf klicken bis es funktioniert.
