    4. Diskussion zum HowTo nodejs-Installation und upgrade
      Thomas Braun Most Active @knopers1 last edited by
      @knopers1
      Du bringst zunächst mal das abgekündigte Buster auf das Bullseye - Release.
        knopers1 @Thomas Braun last edited by knopers1
        etwa so?
        sudo apt full-upgrade
          Thomas Braun Most Active @knopers1 last edited by Thomas Braun
          @knopers1
          Nein, so:
          https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
          Die nodesource.list am besten erstmal aus dem Verkehr ziehen und im neuen System frisch reinholen. Dann stimmen auch die keys automatisch.
            @knopers1
            sudo rm /etc/apt/sources.list.d/nodesource.list
            curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
              pi@raspberrypi:/opt/iobroker $ sudo rm /etc/apt/sources.list.d/nodesource.list
              pi@raspberrypi:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
              ## Installing the NodeSource Node.js 16.x repo...
              ## Populating apt-get cache...
              + apt-get update
              OK:1 http://archive.raspberrypi.org/debian buster InRelease
              OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              ## Confirming "buster" is supported...
              + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
              ## Adding the NodeSource signing key to your keyring...
              + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
              gpg: WARNUNG: Unsicheres Besitzverhältnis des Home-Verzeichnis `/home/pi/.gnupg'
              ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
              + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
              + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
              ## Running `apt-get update` for you...
              + apt-get update
              Holen:3 https://deb.nodesource.com/node_16.x buster InRelease [4.584 B]
              Holen:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [781 B]
              Es wurden 5.365 B in 1 s geholt (3.662 B/s).
              ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
              ## You may also need development tools to build native addons:
                   sudo apt-get install gcc g++ make
              ## To install the Yarn package manager, run:
                   curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                   echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                   sudo apt-get update && sudo apt-get install yarn
                @knopers1
                sudo apt update
                apt policy nodejs
                Und dann kannst/solltest du den Schwung auf 'bullseye' machen.
                  pi@raspberrypi:/opt/iobroker $ sudo apt update
                  OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                  Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                  pi@raspberrypi:/opt/iobroker $ apt policy nodejs
                  nodejs:
                    Installiert:           12.22.12-deb-1nodesource1
                    Installationskandidat: 16.18.1-deb-1nodesource1
                    Versionstabelle:
                       16.18.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                   *** 12.22.12-deb-1nodesource1 100
                          100 /var/lib/dpkg/status
                       10.24.0~dfsg-1~deb10u2 500
                    @knopers1
                    Dann jetzt upgraden und dann halt wie in der Anleitung auf bullseye springen.
                      pi@raspberrypi:/opt/iobroker $ sudo apt upgrade
                      Paketaktualisierung (Upgrade) wird berechnet... Fertig
                      Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                        rpi-eeprom-images
                      Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                      Die folgenden Pakete werden aktualisiert (Upgrade):
                        nodejs
                      1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                      Es müssen 24,2 MB an Archiven heruntergeladen werden.
                      Nach dieser Operation werden 34,0 MB Plattenplatz zusätzlich benutzt.
                      Möchten Sie fortfahren? [J/n] j
                      Holen:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.18.1-deb-1nodesource1 [24,2 MB]
                      Es wurden 24,2 MB in 3 s geholt (7.030 kB/s).
                      Changelogs werden gelesen... Fertig
                      (Lese Datenbank ... 52692 Dateien und Verzeichnisse sind derzeit installiert.)
                      Vorbereitung zum Entpacken von .../nodejs_16.18.1-deb-1nodesource1_armhf.deb ...
                      Entpacken von nodejs (16.18.1-deb-1nodesource1) über (12.22.12-deb-1nodesource1) ...
                      nodejs (16.18.1-deb-1nodesource1) wird eingerichtet ...
                      Trigger für man-db (2.8.5-2) werden verarbeitet ...
                      pi@raspberrypi:/opt/iobroker $ ^C
                        knopers1 @knopers1 last edited by
                        @knopers1
                        Thomas weiter hiermit?
                        sudo sed -i 's/bullseye\/updates/bullseye-security/g' /etc/apt/sources.list
                        sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list
                        sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*
                          @knopers1
                          Ja, wie im entsprechenden HowTo drin.
                            was soll ich an dieser Stelle tun?
                              @knopers1
                              Weiter gehen. Ist halt der ReadMe-Kram bei Release-Upgrades.
                                mit Enter komm i9ch ja nicht weiter.... muss ich etwas eingeben?
                                  @knopers1
                                  q für quit mal versucht?
                                    ja, habe nicht gesehen, dass man den Kramm nach unten schieben kann....
                                    Auf yes nehme ich an?
                                      @knopers1
                                      Ja, es sei denn du willst das die SSH-Verbindung abreißt.
                                      Vermutlich willst du das aber nicht.
                                        puhh, ich möchte die Installation zu Ende bringen....
                                        Soll ich auf Yes drücken Thomas?
                                          @knopers1
                                          Ja, natürlich.
                                            läuft weiter.... Riesen Dank vorab... ich bin aber noch nicht durch 😧
                                            nodejs
                                            91
                                            844
                                            229358
