iObroker not accessible
@thomas-braun I did but it didnt update - strange - I stopped iobroker before:
Edit - sorry I forgot to run sudo apt install -y nodejspi@raspberrypi:~ $ node -v v14.21.1 pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash - ## Installing the NodeSource Node.js 16.x repo... ## Populating apt-get cache... + apt-get update Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 https://deb.nodesource.com/node_16.x buster InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease Reading package lists... Done ## Confirming "buster" is supported... + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release' ## Adding the NodeSource signing key to your keyring... + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg' ## Creating apt sources list file for the NodeSource Node.js 16.x repo... + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list ## Running `apt-get update` for you... + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Hit:3 https://deb.nodesource.com/node_16.x buster InRelease Reading package lists... Done ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn pi@raspberrypi:~ $ node -v v14.21.1 pi@raspberrypi:~ $ -
@vraanaa
What does this command do?sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs -
@thomas-braun now is on version 16
pi@raspberrypi:~ $ node -v v16.18.1 pi@raspberrypi:~ $ iobroker start pi@raspberrypi:~ $ iobroker update node:internal/modules/cjs/loader:988 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15) at Function.Module._load (node:internal/modules/cjs/loader:833:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } pi@raspberrypi:~ $ iobroker fix library: loaded Library version=2022-06-15 ioBroker is not installed in /opt/iobroker! Cannot fix anything... pi@raspberrypi:~ $ -
The 'Buster' release has reached its End of Life.
Please install the actual stable Release 'Bullseye' -
@thomas-braun thank you for you help so far - can you help me little bit with this Bullseye? How exactly I should install it?
In german language only:
https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
But I'm sure that there are plenty of instructions out there in English or even your native language.
@thomas-braun kein problem - ich kann auch Deutch verstehen
Vielen Dank - probiere ich und melde.
So nach Bullseye instalation soll alles OK sein oder muss ich noch ewas anderes zu tun? -
Nein, der iobroker wird nach einem Upgrade auf Bullseye immer noch kaputt sein. Aber dann ist die Basis schonmal aktuell und stabil.
@thomas-braun I did all as per manual. can we check if everything is ok before next steps?
sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejswhat is the feedback to this chain of commands?
pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l Kein Docker /usr/bin/nodejs /usr/bin/node /usr/bin/npm v16.18.1 v16.18.1 8.19.2 node:internal/modules/cjs/loader:988 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15) at Function.Module._load (node:internal/modules/cjs/loader:833:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } pi@raspberrypi:~ $ -
@vraanaa sagte in iObroker not accessible:
@thomas-braun kommt diese
pi@raspberrypi:~ $ whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker x11 LXDE-pi /home/pi Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://dl.yarnpkg.com/debian stable InRelease Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. nodejs: Installed: 16.18.1-deb-1nodesource1 Candidate: 16.18.1-deb-1nodesource1 Version table: *** 16.18.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages pi@raspberrypi:~ $ -
Turn the Desktop OFF.
A server is running headless. Always. -
@thomas-braun meinst du dass ich remote vnc desktop benutzen nicht?
kann ich auch durch putty zum ssh gehen. -
@vraanaa
Nein, auch kein remote DESKTOP.
NO DESKTOP.sudo raspi-configMenu: 1 System Options S5 Boot / Auto Login B1 Console -
@thomas-braun I did it:
pi@raspberrypi:~ $ whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_S ESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy n odejs pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g pio i2c spi iobroker tty /home/pi Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease Hit:4 https://dl.yarnpkg.com/debian stable InRelease Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. nodejs: Installed: 16.18.1-deb-1nodesource1 Candidate: 16.18.1-deb-1nodesource1 Version table: *** 16.18.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages -
iobroker status -
@thomas-braun gleiche
pi@raspberrypi:~ $ iobroker status node:internal/modules/cjs/loader:988 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15) at Function.Module._load (node:internal/modules/cjs/loader:833:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] }
