    2. English
    3. ioBroker general
    4. iObroker not accessible
      Thomas Braun Most Active @Vraanaa last edited by
      @vraanaa
      The 'Buster' release has reached its End of Life.
      Please install the actual stable Release 'Bullseye'
      Vraanaa 2 Replies Last reply Reply Quote 0
      • Vraanaa
        Vraanaa @Thomas Braun last edited by Vraanaa
        @thomas-braun thank you for you help so far - can you help me little bit with this Bullseye? How exactly I should install it?
          @vraanaa
          In german language only:
          https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
          But I'm sure that there are plenty of instructions out there in English or even your native language.
          Vraanaa 1 Reply Last reply Reply Quote 0
          • Vraanaa
            @thomas-braun kein problem - ich kann auch Deutch verstehen 👍
            Vielen Dank - probiere ich und melde.
            So nach Bullseye instalation soll alles OK sein oder muss ich noch ewas anderes zu tun?
              @vraanaa
              Nein, der iobroker wird nach einem Upgrade auf Bullseye immer noch kaputt sein. Aber dann ist die Basis schonmal aktuell und stabil.
              • Vraanaa
                @thomas-braun I did all as per manual. can we check if everything is ok before next steps?
                  @vraanaa
                  sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                  uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  what is the feedback to this chain of commands?
                  • Vraanaa
                    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                    armv7l
                    Kein Docker
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.18.1
                    v16.18.1
                    8.19.2
                    node:internal/modules/cjs/loader:988
                      throw err;
                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                        at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                        at node:internal/main/run_main_module:22:47 {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: []
                    pi@raspberrypi:~ $
                      Thomas Braun Most Active @Vraanaa last edited by Thomas Braun
                      @vraanaa sagte in iObroker not accessible:
                      • Vraanaa
                        @thomas-braun kommt diese
                        pi@raspberrypi:~ $ whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                        x11
                        LXDE-pi
                        /home/pi
                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:3 https://dl.yarnpkg.com/debian stable InRelease
                        Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Reading package lists... Done
                        Building dependency tree... Done
                        All packages are up to date.
                        nodejs:
                          Installed: 16.18.1-deb-1nodesource1
                          Candidate: 16.18.1-deb-1nodesource1
                          Version table:
                         *** 16.18.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                100 /var/lib/dpkg/status
                             12.22.12~dfsg-1~deb11u1 500
                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                        pi@raspberrypi:~ $
                          @vraanaa
                          Turn the Desktop OFF.
                          A server is running headless. Always.
                          • Vraanaa
                            @thomas-braun meinst du dass ich remote vnc desktop benutzen nicht?
                            kann ich auch durch putty zum ssh gehen.
                              @vraanaa
                              Nein, auch kein remote DESKTOP.
                              NO DESKTOP.
                              sudo raspi-config
                              Menu:
                              1 System Options
                              S5 Boot / Auto Login
                              B1 Console
                              • Vraanaa
                                @thomas-braun I did it:
                                pi@raspberrypi:~ $ whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_S        ESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy n        odejs
                                pi
                                pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                                tty
                                /home/pi
                                Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Hit:4 https://dl.yarnpkg.com/debian stable InRelease
                                nodejs:
                                  Version table:
                                  Homoran Global Moderator Administrators @Vraanaa last edited by
                                    @vraanaa
                                    iobroker status
                                    • Vraanaa
                                      @thomas-braun gleiche
                                      pi@raspberrypi:~ $ iobroker status
                                        throw err;
                                        requireStack: []
                                        @vraanaa
                                        cd /opt/iobroker
                                        sudo -H -u iobroker npm install iobroker.js-controller
                                        • Vraanaa
                                          pi@raspberrypi:~ $ cd /opt/iobroker
                                          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                          npm ERR! code 24
                                          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                          npm ERR! command failed
                                          npm ERR! command sh -c -- node iobroker.js setup first
                                          npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-12-12T22_41_51_919Z-debug-0.log
                                            systemctl status iobroker.service
                                            sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                                            3481
