    2. English
    3. ioBroker general
    4. iObroker not accessible
    • Vraanaa
      Vraanaa @Thomas Braun last edited by
      @thomas-braun meinst du dass ich remote vnc desktop benutzen nicht?
      kann ich auch durch putty zum ssh gehen.
        Thomas Braun Most Active @Vraanaa last edited by
        @vraanaa
        Nein, auch kein remote DESKTOP.
        NO DESKTOP.
        sudo raspi-config
        Menu:
        1 System Options
        S5 Boot / Auto Login
        B1 Console
        Vraanaa 1 Reply Last reply Reply Quote 0
        • Vraanaa
          @thomas-braun I did it:
          pi@raspberrypi:~ $ whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_S        ESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy n        odejs
          pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
          tty
          /home/pi
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
          Hit:4 https://dl.yarnpkg.com/debian stable InRelease
          Reading package lists... Done
          Building dependency tree... Done
          All packages are up to date.
          nodejs:
            Installed: 16.18.1-deb-1nodesource1
            Candidate: 16.18.1-deb-1nodesource1
            Version table:
           *** 16.18.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u1 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            Homoran Global Moderator Administrators @Vraanaa last edited by
            @vraanaa sagte in iObroker not accessible:
              @vraanaa
              iobroker status
              • Vraanaa
                @thomas-braun gleiche
                pi@raspberrypi:~ $ iobroker status
                node:internal/modules/cjs/loader:988
                  throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                    at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                    at node:internal/main/run_main_module:22:47 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                  @vraanaa
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                  • Vraanaa
                    pi@raspberrypi:~ $ cd /opt/iobroker
                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                    npm ERR! code 24
                    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                    npm ERR! command failed
                    npm ERR! command sh -c -- node iobroker.js setup first
                    npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                    npm ERR!     /home/iobroker/.npm/_logs/2022-12-12T22_41_51_919Z-debug-0.log
                      Thomas Braun Most Active @Vraanaa last edited by Thomas Braun
                      systemctl status iobroker.service
                      sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                      • Vraanaa
                        pi@raspberrypi:/opt/iobroker $ systemctl status iobroker.servicesystemctl status iobroker.service
                        Unit iobroker.servicesystemctl.service could not be found.
                        Unit status.service could not be found.
                        * iobroker.service - ioBroker Server
                             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                             Active: active (running) since Mon 2022-12-12 23:46:34 CET; 550ms ago
                               Docs: http://iobroker.net
                           Main PID: 7175 (node)
                              Tasks: 7 (limit: 4915)
                                CPU: 534ms
                             CGroup: /system.slice/iobroker.service
                                     `-7175 /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/controller.js
                        pro 12 23:46:35 raspberrypi bash[7175]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
                        pro 12 23:46:35 raspberrypi bash[7175]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                        pro 12 23:46:35 raspberrypi bash[7175]:     at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                        pro 12 23:46:35 raspberrypi bash[7175]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                        pro 12 23:46:35 raspberrypi bash[7175]:     at node:internal/main/run_main_module:22:47 {
                        pro 12 23:46:35 raspberrypi bash[7175]:   code: 'MODULE_NOT_FOUND',
                        pro 12 23:46:35 raspberrypi bash[7175]:   requireStack: []
                        pro 12 23:46:35 raspberrypi bash[7175]: }
                        pro 12 23:46:35 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                        pro 12 23:46:35 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                        pi@raspberrypi:/opt/iobroker $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                             Active: activating (auto-restart) (Result: exit-code) since Mon 2022-12-12 23:48:20 CET; 654ms ago
                            Process: 7409 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
                           Main PID: 7409 (code=exited, status=1/FAILURE)
                                CPU: 657ms
                          @vraanaa
                          sudo systemctl disable iobroker.service
                          sudo systemctl stop iobroker.service
                          cd /opt/iobroker
                          • Vraanaa
                            pi@raspberrypi:~ $ sudo systemctl disable iobroker.service
                            pi@raspberrypi:~ $ sudo systemctl stop iobroker.service
                            npm ERR! code 22
                            npm ERR! No connection to databases possible ...
                            npm ERR!     /home/iobroker/.npm/_logs/2022-12-12T23_22_21_375Z-debug-0.log
                              @vraanaa
                              No idea.
                              • Vraanaa
                                @thomas-braun Thank you anyway. Youre the best - I have a backup image of my iobroker - maybe to completely reinstall entire system...
                                Maybe will help.
                                If I will install entire RPI - new installation will come with Bullseye - or what I need to take care of if I renew entire installation?
                                Thank you for your time and support
                                  @vraanaa
                                  If you want to completely reinstall:
                                  Download the Raspberry OS Imager at their site and choose the 64bit Lite Version.
                                  3488
