    2. English
    3. ioBroker general
    4. iObroker not accessible
      Thomas Braun Most Active @Vraanaa last edited by
      @vraanaa
      iobroker status
      Vraanaa 1 Reply Last reply Reply Quote 0
      • Vraanaa
        Vraanaa @Thomas Braun last edited by
        @thomas-braun gleiche
        pi@raspberrypi:~ $ iobroker status
        node:internal/modules/cjs/loader:988
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
            at Function.Module._load (node:internal/modules/cjs/loader:833:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
            at node:internal/main/run_main_module:22:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
          @vraanaa
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
          • Vraanaa
            pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm ERR! code 24
            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR! command failed
            npm ERR! command sh -c -- node iobroker.js setup first
            npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
            npm ERR!     /home/iobroker/.npm/_logs/2022-12-12T22_41_51_919Z-debug-0.log
              Thomas Braun Most Active @Vraanaa last edited by Thomas Braun
              @vraanaa sagte in iObroker not accessible:
              systemctl status iobroker.service
              sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
              • Vraanaa
                pi@raspberrypi:/opt/iobroker $ systemctl status iobroker.servicesystemctl status iobroker.service
                Unit iobroker.servicesystemctl.service could not be found.
                Unit status.service could not be found.
                * iobroker.service - ioBroker Server
                     Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                     Active: active (running) since Mon 2022-12-12 23:46:34 CET; 550ms ago
                       Docs: http://iobroker.net
                   Main PID: 7175 (node)
                      Tasks: 7 (limit: 4915)
                        CPU: 534ms
                     CGroup: /system.slice/iobroker.service
                             `-7175 /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/controller.js
                pro 12 23:46:35 raspberrypi bash[7175]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
                pro 12 23:46:35 raspberrypi bash[7175]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                pro 12 23:46:35 raspberrypi bash[7175]:     at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                pro 12 23:46:35 raspberrypi bash[7175]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                pro 12 23:46:35 raspberrypi bash[7175]:     at node:internal/main/run_main_module:22:47 {
                pro 12 23:46:35 raspberrypi bash[7175]:   code: 'MODULE_NOT_FOUND',
                pro 12 23:46:35 raspberrypi bash[7175]:   requireStack: []
                pro 12 23:46:35 raspberrypi bash[7175]: }
                pro 12 23:46:35 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                pro 12 23:46:35 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                pi@raspberrypi:/opt/iobroker $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                     Active: activating (auto-restart) (Result: exit-code) since Mon 2022-12-12 23:48:20 CET; 654ms ago
                    Process: 7409 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
                   Main PID: 7409 (code=exited, status=1/FAILURE)
                        CPU: 657ms
                  @vraanaa
                  sudo systemctl disable iobroker.service
                  sudo systemctl stop iobroker.service
                  cd /opt/iobroker
                  • Vraanaa
                    pi@raspberrypi:~ $ sudo systemctl disable iobroker.service
                    pi@raspberrypi:~ $ sudo systemctl stop iobroker.service
                    npm ERR! code 22
                    npm ERR! No connection to databases possible ...
                    npm ERR!     /home/iobroker/.npm/_logs/2022-12-12T23_22_21_375Z-debug-0.log
                      @vraanaa
                      No idea.
                      • Vraanaa
                        @thomas-braun Thank you anyway. Youre the best - I have a backup image of my iobroker - maybe to completely reinstall entire system...
                        Maybe will help.
                        If I will install entire RPI - new installation will come with Bullseye - or what I need to take care of if I renew entire installation?
                        Thank you for your time and support
                          @vraanaa
                          If you want to completely reinstall:
                          Download the Raspberry OS Imager at their site and choose the 64bit Lite Version.
                          3480
