    4. Welchen Luftgütesensor
      @Homoran:
      'BmeBoschwrapper' does not name a type
      Das kenne ich nicht. Wo steht bei Dir BmeBoschwrapper ? Im Sketch? Dann ist das ein anderes Sketch. Und wenn dort die Bosch-Lib schon eingebunden ist, dann sieht das gut aus. müssen nur noch die Parameter passen.
        aber das ist die einzige Stelle.
        • ich will ja Learnen beim Doing.
        Rainer
          @Homoran
          Zu den Parametern:
          Bei mir im Sketch steht:
            /*********** BME280 setup ***********  */
            /* excerpt from Bosch datasheet chapter 3.5.1 Weather monitoring
              Table 7: Settings and performance for weather monitoring
              Suggested settings for weather monitoring
              Sensor mode forced mode, 1 sample / minute
              Oversampling settings pressure *1, temperature *1, humidity *1
              IIR filter settings filter off
              Performance for suggested settings
              Current consumption 0.16 μA
              RMS Noise 3.3 Pa / 30 cm, 0.07 %RH
              Data output rate 1/60 Hz
            * ** End excerpt from Bosch datasheet chapter 3.5.1 Weather monitoring **/
            byte chipID = 0; // for BME280 Cip IF
            chipID = BME280.readChipId();
          #ifdef FSDEBUG
            DBG_OUTPUT_PORT.print (F("BME280 Chip Id (0x): "));
            DBG_OUTPUT_PORT.println (chipID, HEX);
          #endif // FSDEBUG
            // need to read the NVM compensation parameters
            BME280.readCompensationParams();
            // Need to turn on 1x oversampling, default is os_skipped, which means it doesn't measure anything
            BME280.writeOversamplingPressure(os1x);     // 1x over sampling (ie, just one sample)
            BME280.writeOversamplingTemperature(os1x);  // 1x over sampling (ie, just one sample)
            BME280.writeOversamplingHumidity(os1x);     // 1x over sampling (ie, just one sample)
            measuringTime = (int) (0.5 + (1.25 + (2.3 * 1) + (2.3 * 1 + 0.575) + (2.3 * 1 + 0.575))); // measuringTime is unsigned long
            /* in forced mode with oversampling=1 in all 3 values the max measuring time should be < 22.8ms
               in forced mode with all oversamplings to x16 (max value) the measring time should be <112,8
               for other oversampling settings refer Bosch datasheet chapter 9.1 Measurement time
               measuringTime = 1.25+(2.3*temp_os) + (2.3*humid_os + 0.575) + (2.3*press_os + 0.575)  */
            // init a forced sample.  After taking the measurement the chip goes back to sleep
            BME280.writeMode(smForced);
          Das mag bei Dir etwas anders heißen, wenn Du den BoschWrapper verwendest.
            Danke klassisch,
            dann bin ich tatsächlich leider raus 😞
            das ist (noch) zu hoch für mich.
            Danke nochmals
            Rainer
              @Homoran:
              • ich will ja Learnen beim Doing. `
                Wahrscheinlich ist Dein Sketch für diese Lib ausgelegt und an dieser Stelle wird diese Lib instanziert.
              Du hast jetzt 2 Möglichkeiten: Die Lib (mit dem Boschwrapper) mit Stupf und Stiel aus Deinem Sketch reissen und durch die andere (die auch ich verwende) ersetzen oder sie drinlassen und die Stellen aufsuchen, wo die Parameter eingestellt werden.
              Drinlassen könnte einfacher sein. Und wenn da wirklich die Original-Bosch-Lib drinsteckt, dann solte das auch möglich sein. Parameter stehen ja oben.
                Könnte sein, daß wir der Sache näher kommen.
                Verwendest Du diese Lib von Jan Wasserbauer:
                https://github.com/vodnik12/JWA_BME280/ … /README.md
                  Na, mach mir nur Mut.
                  @klassisch:
                  Wahrscheinlich ist Dein Sketch `
                  Der Sketch ist von Maik, und für mich ist das der erste Sketch überhaupt den ich mir mal ansehe 😉
                  http://forum.iobroker.net/viewtopic.php … 100#p78500
                  @klassisch:
                  und die Stellen aufsuchen, wo die Parameter eingestellt werden. `
                  Yeah :shock:
                  Mache ich jetzt - erst mal im Notepad++
                  Vielleicht wird ja doch noch mal was aus mir 😉
                  Rainer
                    @klassisch:
                    Ja!
                    Rainer
                      Dann schauen wir mal in seinem git, ob wir die Stelle sehen, wo die Parameter gesetzt werden. Er hat ja auch vom Temperaturunterschied gesprochen aber nicht in welche Richtung….
                        Steht bei Dir
                        Bme280BoschWrapper bme280(true);
                        ? Wenn ich das richtig verstanden habe, dann würde er im forced mode starten. Aber die anderen Parameter habe ich noch nicht gefunden. Und ich habe den Genauigkeitsgrad noch nicht gesehen. Der macht aber wahrscheinlich keine 3 bis 4 K aus. Bosch hat die Kompensationrechnung aus dem Sensor rausverlagert in den host-Rechner. Das macht es so kompliziert. Und weil Bosch gerne optimiert (manchmal bis zum Geiz) gibt es 3 Genauigkeitsklassen, wenn ich mich recht erinner. Je nach vorhandener Rechenleistung kann man eine passende Kompensationsrechnung verwenden. Für die WeMos habe ich immer die genaueste Rechnung verwendet. Die Dinger sind schnell genug. Aber wie gesagt, das sollte keine 3 bis 4 K ausmachen, denke ich.
                        Die von mir referenzierte Lib ermöglicht diese Wahl. Ein klassischer Arduino könnte aber bei der genaueren Rechnung ins Schwitzen kommen.
                          @klassisch:
                          Steht bei Dir `
                          Ja!
                          // BME280 initialisieren
                          unsigned long syncTime;
                          und da hatte ich gedacht es reicht den Namen auszutauschen gegen den der neuen Bibliothek.
                          habe gerade versucht das in github zu verstehen und dabei gemerkt, dass mein Vorhaben eine Schnapsidee war 😞
                          Rainer
                            Nochwas: In welchen Zeitabständen rufst Du
                            bme280.measure()
                            auf?
                              Wenn ich Maik richtig verstanden habe hat er das in der http://forum.iobroker.net/viewtopic.php?f=34&t=3954&start=100#p78500 von etwa 6 sec auf 60sec angehoben.
                              Rainer
                                6 Sekunden wäre zu häufig, 60 Sekunden ist o. k.
                                Gesendet von meinem ZTE A2016 mit Tapatalk
                                  MaikB85 last edited by
                                  Das mit den 60Sekunden hatte nur leider keine Auswirkung weil der BME280 so oft misst wie in den Settings eingestellt ist. Mit der library konnte man den BME280 aber überhaupt nicht so konfigurieren.
                                  Ich implementiere eben die MOD-1022 library und poste das sofort. dann kannst du das testen
                                    Super, vielen Dank!
                                    Settings habe ich oben gepostet. Falls Du noch was brauchst, einfach melden, dann schaue ich gschwind bei mir nach.
                                      So hier mal die geänderte Version. Wieder oben die Variablen für IP-Adresse usw. anpassen.
                                      `//#include <bme280boschwrapper.h>
                                      #include <ethernet.h>
                                      #include <stdlib.h>
                                      #include <avr pgmspace.h="">
                                      #include <pubsubclient.h>
                                      #include "Wire.h"
                                      ! #include <bme280_mod-1022.h>
                                      ! // Modultexte für MQTT Adapter
                                      char modul_name[] = "Raumsensor_Wohnzimmer";
                                      char humidity_str[] = "/Wohnzimmer/Luftfeuchtigkeit";
                                      char temperature_str[] = "/Wohnzimmer/Raumtemperatur";
                                      char pressure_str[] = "/Wohnzimmer/Luftdruck";
                                      char co2_str[] = "/Wohnzimmer/CO2";
                                      char status_str[] = "/Wohnzimmer/iAQ_Status";
                                      char resistance_str[] = "/Wohnzimmer/iAQ_Widerstand";
                                      char tvoc_str[] = "/Wohnzimmer/TVOC";
                                      ! //Setup Ethernet Library
                                      byte mac[] = { 0xAB, 0xAD, 0xBE, 0xEF, 0xEF, 0xDE }; //MAC Adresse des Ethernet Moduls
                                      IPAddress arduino_ip(192, 168, 178, 102); //IP des Teensy
                                      IPAddress server_ip(192, 168, 178, 100); //MQTT Broker (= Raspberry Pi)
                                      EthernetClient client;
                                      ! // BME280 initialisieren
                                      //Bme280BoschWrapper bme280(true);
                                      ! //IAQ Core C Setup
                                      #define iaqaddress 0x5A
                                      ! uint16_t predict;
                                      uint8_t statu;
                                      int32_t resistance;
                                      uint16_t tvoc;
                                      // Callback Funktion von MQTT. Die Funktion wird aufgerufen
                                      // wenn ein Wert empfangen wurde.
                                      void callback(char* topic, byte* payload, unsigned int length)
                                      //char message_buff[100];
                                      ! //Serial.print("Nachricht erhalten mit Topic: ");
                                      //Serial.println(topic);
                                      ! //// Kopieren der Nachricht und erstellen eines Bytes mit abschließender \0
                                      //unsigned int i = 0;
                                      //for (i = 0; i<length; 8/16/1883/i++)/{/message_buff[i]="payload[i];" }/;/serial.print("nachricht:/");/serial.println(message_buff);/mqtt/client/zur/kommunikation/mit/dem/server/server_ip/-/variable/des/types/byte/serveradresse/ist/der/standard/tcp/port/callback/function/wird/aufgerufen/wen/nachrichten/eintreffen/angabe/ethernet/clients/pubsubclient/mqttclient(server_ip,/1883,/callback,/client);/messdaten/vom/iaq/core/lesen/void/readallbytes()/wire.requestfrom(iaqaddress,/9);/predict="(Wire.read()" <</|/wire.read());/statu="Wire.read();" resistance="(Wire.read()" &/0x00)/(wire.read()/16)/tvoc="(Wire.read()" status/ermitteln/checkstatus()/if/(statu="=" 0x10)/serial.println("aufwärmphase...");/else/serial.println("bereit");/0x01)/serial.println("belegt");/0x80)/serial.println("fehler");/serial.println("kein/empfangen,/modul/prüfen");/setup()/ethernet.begin(mac,/arduino_ip);/delay(1000);/shield/zeit/geben/zum/initialisieren/serial.begin(115200);/wire.begin();/while/(!bme280.begini2c(0x76))/serial.println("sensor/nicht/gefunden.");/synctime="millis();" loop()/aufbau/verbindung/mqtt-broker/falls/diese/offen/ist./(!mqttclient.connected())/mqttclient.connect(modul_name);/abonieren/von/angegebenen/topic/mqttclient.subscribe("/wohnzimmer/settings/#");/schleife/für/(mqttclient.loop())/serial.println("verbunden");/need/to/read/the/nvm/compensation/parameters/bme280.readcompensationparams();/example/for/"indoor/navigation"/we'll/switch/into/normal/mode/regular/automatic/samples/bme280.writestandbytime(tsb_0p5ms);/tsb="0.5ms" bme280.writefiltercoefficient(fc_16);/iir/filter/coefficient/bme280.writeoversamplingpressure(os16x);/pressure/x16/bme280.writeoversamplingtemperature(os2x);/temperature/x2/bme280.writeoversamplinghumidity(os1x);/humidity/x1/bme280.writemode(smnormal);/(bme280.ismeasuring())/out/data/must/do/this/before/calling/getxxxxx/routines/bme280.readmeasurements();/char/tempbuffer[10];/dtostrf(bme280.gettemperaturemostaccurate(),/2,/tempbuffer);/mqttclient.publish(temperature_str,/delay(500);/dtostrf(bme280.gethumiditymostaccurate(),/3,/mqttclient.publish(humidity_str,/dtostrf(bme280.getpressuremostaccurate(),/4,/mqttclient.publish(pressure_str,/*unsigned/long/currentmillis="millis();" ((unsigned/long)(currentmillis/synctime)="">= 60000) //Alle 15sec ausf�hren
                                      // Bosch BME280 Messwerte senden
                                          if (bme280.measure())
                                      	    char tempBuffer[10];
                                      ! dtostrf((bme280.getTemperature() / 100.0), 2, 2, tempBuffer);
                                      mqttClient.publish(temperature_str, tempBuffer);
                                      ! delay(1000);
                                      ! dtostrf((bme280.getHumidity() / 1024.0), 3, 2, tempBuffer);
                                      mqttClient.publish(humidity_str, tempBuffer);
                                      ! delay(1000);
                                      ! dtostrf((bme280.getPressureDouble() / 100.0), 4, 2, tempBuffer);
                                      mqttClient.publish(pressure_str, tempBuffer);
                                      ! delay(1000);
                                      else
                                      Serial.println("Messung mit BME280 fehlgeschlagen.");
                                      ! syncTime = currentMillis;
                                      ! delay(1000);
                                      ! readAllBytes();
                                      checkStatus();
                                      //char tempBuffer[10];
                                      ! //CO2 Wert
                                      snprintf(tempBuffer, sizeof(tempBuffer), "%u", (predict));
                                      mqttClient.publish(co2_str, tempBuffer);
                                      ! //Status
                                      snprintf(tempBuffer, sizeof(tempBuffer), "%u", (statu));
                                      mqttClient.publish(status_str, tempBuffer);
                                      ! //Widerstandswert
                                      snprintf(tempBuffer, sizeof(tempBuffer), "%lu", (resistance));
                                      mqttClient.publish(resistance_str, tempBuffer);
                                      ! //TVOC Wert
                                      snprintf(tempBuffer, sizeof(tempBuffer), "%u", (tvoc));
                                      mqttClient.publish(tvoc_str, tempBuffer);
                                      ! delay(5000);
                                      }</length;></bme280_mod-1022.h></pubsubclient.h></avr></stdlib.h></ethernet.h></bme280boschwrapper.h>`
                                      ! Gruß Maik[/i][/i][/i]
                                        Vielen Dank!
                                        erste schnelle RM:
                                        BME280.writeMode(normal);
                                        ist das böse Teil-
                                        ````ist brav.
                                        example for indoor navigation liest den Drucksensor sehr genau aus und macht den Sensor warm.
                                        Ich arbeite mit
                                        measuringTime = 1.25+(2.3temp_os) + (2.3humid_os + 0.575) + (2.3*press_os + 0.575) */
                                        delay(measuringTime + 25); // wait until measurement is done. With oversampling=1 in all 3 values the max measuring time should be < 22.8ms
                                        // for other oversampling settings refer Bosch datasheet chapter 9.1 Measurement time
                                        BME280.readMeasurements();
                                        if (BME280.isMeasuring()) { // this should not happen becaus wait time is long enough
                                        BME280ReadError = 1;
                                          okay ich hatte jetzt einfach die settings für Innenraum Messung empfohlen von Bosch
                                          Wie hast du dann die settings für oversampling usw. ?
                                            habs oben nachgetragen
                                            Oder um es hier komplett zu machen:
                                            void initSensorBME280()
                                            /*********** BME280 setup *********** /
                                            • ** End excerpt from Bosch datasheet chapter 3.5.1 Weather monitoring **/
                                            ! byte chipID = 0; // for BME280 Cip IF
                                            #ifdef FSDEBUG
                                            #endif // FSDEBUG
                                            ! // Need to turn on 1x oversampling, default is os_skipped, which means it doesn't measure anything
                                            measuringTime = 1.25+(2.3temp_os) + (2.3humid_os + 0.575) + (2.3*press_os + 0.575) /
                                            ! // init a forced sample. After taking the measurement the chip goes back to sleep
                                            #ifdef FSDEBUG
                                            DBG_OUTPUT_PORT.println(F("Mode has been written down to BME280"));
                                            DBG_OUTPUT_PORT.println(F("BME280 Measuring or busy..."));
                                            #endif // FSDEBUG
                                            delay(measuringTime + 300);
                                            if (BME280.isMeasuring()) { // another try failed
                                            #ifdef FSDEBUG
                                            DBG_OUTPUT_PORT.print (F(" Contact to sensor has been lost no further transmission to CCU "));
                                            #endif //FSDEBUG
                                            } // end if 2n try failed
                                            else {
                                            BME280ReadError = 0;
                                            ! } // end if 1st trial to measure failed
                                            else {
                                            #ifdef FSDEBUG
                                            DBG_OUTPUT_PORT.println(F("BME280 init Done!"));
                                            #endif // FSDEBUG
                                            ! } // end else => no sensorReadoutError
                                            ******************* END Setup BME280 **************************/
                                            } // end void initSensorBME280
                                            226
                                            53634
