    4. Welchen Luftgütesensor
      Vielen Dank!
      erste schnelle RM:
      BME280.writeMode(normal);
      ist das böse Teil-
      BME280.writeMode(smForced);
      ````ist brav.
      example for indoor navigation liest den Drucksensor sehr genau aus und macht den Sensor warm.
      Ich arbeite mit
      // Need to turn on 1x oversampling, default is os_skipped, which means it doesn't measure anything
      BME280.writeOversamplingPressure(os1x); // 1x over sampling (ie, just one sample)
      BME280.writeOversamplingTemperature(os1x); // 1x over sampling (ie, just one sample)
      BME280.writeOversamplingHumidity(os1x); // 1x over sampling (ie, just one sample)
      measuringTime = (int) (0.5 + (1.25 + (2.3 * 1) + (2.3 * 1 + 0.575) + (2.3 * 1 + 0.575))); // measuringTime is unsigned long
      /* in forced mode with oversampling=1 in all 3 values the max measuring time should be < 22.8ms
      in forced mode with all oversamplings to x16 (max value) the measring time should be <112,8
      for other oversampling settings refer Bosch datasheet chapter 9.1 Measurement time
      measuringTime = 1.25+(2.3temp_os) + (2.3humid_os + 0.575) + (2.3*press_os + 0.575) */
      // init a forced sample. After taking the measurement the chip goes back to sleep
      delay(measuringTime + 25); // wait until measurement is done. With oversampling=1 in all 3 values the max measuring time should be < 22.8ms
      // for other oversampling settings refer Bosch datasheet chapter 9.1 Measurement time
      BME280.readMeasurements();
      if (BME280.isMeasuring()) { // this should not happen becaus wait time is long enough
      BME280ReadError = 1;
        MaikB85 last edited by
        okay ich hatte jetzt einfach die settings für Innenraum Messung empfohlen von Bosch
        Wie hast du dann die settings für oversampling usw. ?
          habs oben nachgetragen
          Oder um es hier komplett zu machen:
          void initSensorBME280()
          /*********** BME280 setup *********** /
          excerpt from Bosch datasheet chapter 3.5.1 Weather monitoring
          Table 7: Settings and performance for weather monitoring
          Suggested settings for weather monitoring
          Sensor mode forced mode, 1 sample / minute
          Oversampling settings pressure *1, temperature *1, humidity *1
          IIR filter settings filter off
          Performance for suggested settings
          Current consumption 0.16 μA
          RMS Noise 3.3 Pa / 30 cm, 0.07 %RH
          Data output rate 1/60 Hz
          • ** End excerpt from Bosch datasheet chapter 3.5.1 Weather monitoring **/
          ! byte chipID = 0; // for BME280 Cip IF
          chipID = BME280.readChipId();
          #ifdef FSDEBUG
          DBG_OUTPUT_PORT.print (F("BME280 Chip Id (0x): "));
          DBG_OUTPUT_PORT.println (chipID, HEX);
          #endif // FSDEBUG
          // need to read the NVM compensation parameters
          BME280.readCompensationParams();
          ! // Need to turn on 1x oversampling, default is os_skipped, which means it doesn't measure anything
          measuringTime = 1.25+(2.3temp_os) + (2.3humid_os + 0.575) + (2.3*press_os + 0.575) /
          ! // init a forced sample. After taking the measurement the chip goes back to sleep
          #ifdef FSDEBUG
          DBG_OUTPUT_PORT.println(F("Mode has been written down to BME280"));
          DBG_OUTPUT_PORT.println(F("BME280 Measuring or busy..."));
          #endif // FSDEBUG
          delay(measuringTime + 300);
          if (BME280.isMeasuring()) { // another try failed
          #ifdef FSDEBUG
          DBG_OUTPUT_PORT.print (F(" Contact to sensor has been lost no further transmission to CCU "));
          #endif //FSDEBUG
          } // end if 2n try failed
          else {
          BME280ReadError = 0;
          ! } // end if 1st trial to measure failed
          else {
          #ifdef FSDEBUG
          DBG_OUTPUT_PORT.println(F("BME280 init Done!"));
          #endif // FSDEBUG
          ! } // end else => no sensorReadoutError
          ******************* END Setup BME280 **************************/
          } // end void initSensorBME280
            Danke!
            ist jetzt bei einem geflasht, der andere hat noch die alte library
            In der Zwischenzeit ist mir noch etwas aufgefallen.
            ich hatte schon vorher den Verdacht, jetzt war es wieder.
            In der Phase wo der/die IAQ kalibrieren haben anscheinend die Werte ein höheres Rauschen und die BME-Werte scheinen dann auch stärker voneionander abzuweichen.
            ist die Kalibrierung erst einmal abgeschlossen (=Fenster zu) werden die Kurven wieder ruhiger und die BME-Werte passen sich wieder aneinender an.
            Rainer
              achso gut. dann muss ich aber wieder die zeitliche geschichte mit rein nehmen alle 60sek. weil bei forced macht er ja nur eine Messung
                Ja, genau. Bei forced mißt er nur auf Befehl. Bei normal immer.
                Habe hier mal meine etwas überkandidelte weil fehlerabfangende Init:
                #ifdef FSDEBUG
                #endif // FSDEBUG
                #ifdef FSDEBUG
                #endif // FSDEBUG
                #ifdef FSDEBUG
                #endif //FSDEBUG
                else {
                else {
                #ifdef FSDEBUG
                #endif // FSDEBUG
                  Okay so dann:
                  `//#include <bme280boschwrapper.h>
                  #include <ethernet.h>
                  #include <stdlib.h>
                  #include <avr pgmspace.h="">
                  #include <pubsubclient.h>
                  #include "Wire.h"
                  ! #include <bme280_mod-1022.h>
                  ! // Modultexte für MQTT Adapter
                  char modul_name[] = "Raumsensor_Wohnzimmer";
                  char humidity_str[] = "/Wohnzimmer/Luftfeuchtigkeit";
                  char temperature_str[] = "/Wohnzimmer/Raumtemperatur";
                  char pressure_str[] = "/Wohnzimmer/Luftdruck";
                  char co2_str[] = "/Wohnzimmer/CO2";
                  char status_str[] = "/Wohnzimmer/iAQ_Status";
                  char resistance_str[] = "/Wohnzimmer/iAQ_Widerstand";
                  char tvoc_str[] = "/Wohnzimmer/TVOC";
                  ! //Setup Ethernet Library
                  byte mac[] = { 0xAB, 0xAD, 0xBE, 0xEF, 0xEF, 0xDE }; //MAC Adresse des Ethernet Moduls
                  IPAddress arduino_ip(192, 168, 178, 102); //IP des Teensy
                  IPAddress server_ip(192, 168, 178, 100); //MQTT Broker (= Raspberry Pi)
                  EthernetClient client;
                  ! // BME280 initialisieren
                  //Bme280BoschWrapper bme280(true);
                  unsigned long syncTime;
                  ! //IAQ Core C Setup
                  #define iaqaddress 0x5A
                  ! uint16_t predict;
                  uint8_t statu;
                  int32_t resistance;
                  uint16_t tvoc;
                  // Callback Funktion von MQTT. Die Funktion wird aufgerufen
                  // wenn ein Wert empfangen wurde.
                  void callback(char* topic, byte* payload, unsigned int length)
                  //char message_buff[100];
                  ! //Serial.print("Nachricht erhalten mit Topic: ");
                  //Serial.println(topic);
                  ! //// Kopieren der Nachricht und erstellen eines Bytes mit abschließender \0
                  //unsigned int i = 0;
                  //for (i = 0; i<length; 8/1883/i++)/{/message_buff[i]="payload[i];" }/;/serial.print("nachricht:/");/serial.println(message_buff);/mqtt/client/zur/kommunikation/mit/dem/server/server_ip/-/variable/des/types/byte/serveradresse/ist/der/standard/tcp/port/callback/function/wird/aufgerufen/wen/nachrichten/eintreffen/angabe/ethernet/clients/pubsubclient/mqttclient(server_ip,/1883,/callback,/client);/messdaten/vom/iaq/core/lesen/void/readallbytes()/wire.requestfrom(iaqaddress,/9);/predict="(Wire.read()" <</|/wire.read());/statu="Wire.read();" resistance="(Wire.read()" &/0x00)/(wire.read()/16)/tvoc="(Wire.read()" status/ermitteln/checkstatus()/if/(statu="=" 0x10)/serial.println("aufwärmphase...");/else/serial.println("bereit");/0x01)/serial.println("belegt");/0x80)/serial.println("fehler");/serial.println("kein/empfangen,/modul/prüfen");/setup()/ethernet.begin(mac,/arduino_ip);/delay(1000);/shield/zeit/geben/zum/initialisieren/serial.begin(115200);/wire.begin();/while/(!bme280.begini2c(0x76))/serial.println("sensor/nicht/gefunden.");/synctime="millis();" loop()/aufbau/verbindung/mqtt-broker/falls/diese/offen/ist./(!mqttclient.connected())/mqttclient.connect(modul_name);/abonieren/von/angegebenen/topic/mqttclient.subscribe("/wohnzimmer/settings/#");/schleife/für/(mqttclient.loop())/serial.println("verbunden");/unsigned/long/currentmillis="millis();" ((unsigned/long)(currentmillis/synctime)="">= 60000) //Alle 60sec ausf�hren
                  ! // Example for "indoor navigation"
                  // We'll switch into normal mode for regular automatic samples
                  BME280.writeStandbyTime(tsb_0p5ms); // tsb = 0.5ms
                  BME280.writeFilterCoefficient(fc_16); // IIR Filter coefficient 16
                  BME280.writeOversamplingPressure(os16x); // pressure x16
                  BME280.writeOversamplingTemperature(os2x); // temperature x2
                  BME280.writeOversamplingHumidity(os1x); // humidity x1
                    BME280.writeMode(smNormal);
                    // example of a forced sample.  After taking the measurement the chip goes back to sleep
                    while (BME280.isMeasuring())
                    // read out the data - must do this before calling the getxxxxx routines
                  ! char tempBuffer[10];
                  ! dtostrf(BME280.getTemperatureMostAccurate(), 2, 2, tempBuffer);
                  mqttClient.publish(temperature_str, tempBuffer);
                  ! delay(500);
                    dtostrf(BME280.getHumidityMostAccurate(), 3, 2, tempBuffer);
                    mqttClient.publish(humidity_str, tempBuffer);
                  ! delay(500);
                  ! dtostrf(BME280.getPressureMostAccurate(), 4, 2, tempBuffer);
                  mqttClient.publish(pressure_str, tempBuffer);
                  ! delay(500);
                  ! syncTime = currentMillis;
                  ! /*unsigned long currentMillis = millis();
                  if ((unsigned long)(currentMillis - syncTime) >= 60000) //Alle 15sec ausf�hren
                  // Bosch BME280 Messwerte senden
                      if (bme280.measure())
                  ! dtostrf((bme280.getTemperature() / 100.0), 2, 2, tempBuffer);
                  ! delay(1000);
                  ! dtostrf((bme280.getHumidity() / 1024.0), 3, 2, tempBuffer);
                  ! delay(1000);
                  ! dtostrf((bme280.getPressureDouble() / 100.0), 4, 2, tempBuffer);
                  ! delay(1000);
                  else
                  Serial.println("Messung mit BME280 fehlgeschlagen.");
                  ! delay(1000);
                  ! readAllBytes();
                  checkStatus();
                  ! //CO2 Wert
                  snprintf(tempBuffer, sizeof(tempBuffer), "%u", (predict));
                  mqttClient.publish(co2_str, tempBuffer);
                  ! //Status
                  snprintf(tempBuffer, sizeof(tempBuffer), "%u", (statu));
                  mqttClient.publish(status_str, tempBuffer);
                  ! //Widerstandswert
                  snprintf(tempBuffer, sizeof(tempBuffer), "%lu", (resistance));
                  mqttClient.publish(resistance_str, tempBuffer);
                  ! //TVOC Wert
                  snprintf(tempBuffer, sizeof(tempBuffer), "%u", (tvoc));
                  mqttClient.publish(tvoc_str, tempBuffer);
                  ! delay(5000);
                  }</length;></bme280_mod-1022.h></pubsubclient.h></avr></stdlib.h></ethernet.h></bme280boschwrapper.h>`
                  ! Aber letztendlich bringt das alles nix... Werte sind immer noch so.
                  ! Rainer das macht ja auch Sinn wenn du das Fenster öffnet oder nicht? Wenn da erstmal andere Luft ankommt.
                  ! Ich bin jetzt erstmal gespannt auf den neuen Sensor was der dann anzeigt. Ist auf jeden Fall schon mal als verschickt markiert...[/i][/i][/i]
                    @MaikB85:
                    das macht ja auch Sinn wenn du das Fenster öffnet oder nicht? Wenn da erstmal andere Luft ankommt. `
                    Aber die Sensoren stehen etwa eine Platinenbreite auseinander. die sollten schon den gleichen Wert haben (?)
                    Oder meinst du selbst die geringste Luftbewegung könnte das auslösen?
                    Rainer
                      @Homoran:
                      @MaikB85:
                      Rainer `
                      ja weiß ich nicht vielleicht… dann haben beide vielleicht noch unterschiedliche Genauigkeiten gegeneinander. Weiß ja nicht wie weit das schwankt bei dir
                      Aber ich finde das ja schon faszinierend, dass wir beide in etwa die gleiche Abweichung der Temperatur haben. Wo der Chinese die wohl her hatte...
                      [EDIT] Um nochmal auf das Thema Luftfeuchte zurück zu kommen hier:https://www.mikrocontroller.net/topic/398067 wird auch beschrieben mal den Abgleich mit einer gesättigten Kochsalzlösung zu machen. Soll wohl eine relativ genaue Referenz sein.
                        Oh man ich hab eine Lösung gefunden…(Nachdem auf microcontroller.net jemand etwas von störungen geschrieben hat)
                        Habe ein 20cm Kabel zwischen BME280 und Platine und siehe da Temperatur passt. Irgendwas stört den Sensor...
                        Habe jetzt knapp 24°C. vorher über 28°C...
                        Der Fehler ist eindeutig und reproduzierbar. sobald ich mit dem Sensor wieder nahe an die Platine gehe steigt die Temperatur. Hmm wie löst man das jetzt
                          Gerade wollte ich fragen wie Eure Aufbauten aussehen. Also Abstand zu anderen Wärmequellen.
                          Ich habe bis ca. 50cm Kabel zwischen BME und WMos. Vorwiegend aus thermischen Gründen wie oben schon geschrieben.
                          Ich verwende 4-pol Telefonleitung.
                          Und zur Feuchtekalibrierung: Siehe
                          http://kandrsmith.org/RJS/Misc/hygrometers.html
                          Hat mich schwer beeindruckt…
                            @klassisch:
                            Hat mich schwer beeindruckt… `
                            Wobei ich mir jetzt nicht unbedingt sicher bin ob es an der Platine "wärmer" ist. Vielleicht sind das auch Störfrequenzen. Werde da die Tage nochmal ein paar Sachen testen.
                            Sensor wohl umsonst bestellt… 😢
                              Jedenfalls Glückwunsch zum gelungenen Troubleshooting!
                              @MaikB85:
                              Sensor wohl umsonst bestellt… 😢 ` Nie! Noch ein WeMos dran, AP-Gehäuse Billignetzteil und fertig ist der Temperatursensor.
                              Der BME280 ist schon ein ordentlicher Sensor.
                              Meine erste Spekulation geht in Richtung thermischer Beeinflussung.
                              Kann aber da wenig dazu sagen, weil ich von Anfang an die Teile an eine 20cm bis 50cm lange Kabelpeitsche angeschlossen habe. Sieht man auch auch auf den Bildern im HM-Thread. Die WeMos ziehen 350 bis 400mW und das heizt schon auf. Insofern gab es bei mir da nie etwas nachzudenken, die Teile mußten einfach raus.
                              Ein I2C sollte nicht zu lang sein. Also muß man auf die Leitung achten. Also habe ich eine Stern-Vierer-Verseilung gewählt - zumal die als Telefonleitung auch billig erhältlich ist. Bei Pollin als Restposten https://www.pollin.de/p/telefon-install … 3-m-541988
                              Und wenn man schon eine lange Leitung hat, dann sollte auch ein Kondensator über der Versorgung sein. Also einen Tantal oder einen Kerko 10µF http://www.aliexpress.com/item/100pcs-lot-Multilayer-ceramic-capacitor-10uF-106-50V-106k/32455168081.html, wobe meine noch 0,4 EUR teurer waren. Egal waren schon sehr hilfreich, genauso wie die SMD Pendants.
                              Insofern hatte ich noch nie so ein Störproblem und kann damit auch nicht sagen woher es kommt. Wenn ich mch recht erinnere habe ich irgendwann mal routinemäßig die Versorgung und den I2C oszilloskopiert und das sah i.O. aus. Da bei den WeMos eh alles auf 3.3V läuft, gab es auch damit keine Probleme.
                                Stimmt der ist nicht weg.
                                Ich hoffe nicht, dass es ein thermisches Problem ist, weil dies mein ganzes Konzept durcheinander bringt. Wollte alles in eine Unterputzdose packen und dann eine Lautspecherabdeckung drüber. Aber wenn sich das da so erwärmt müssen die Sensoren davon weg. Vieleicht kann ich die einfach mit kurzen Leitungen nach vorne zur Abdeckung hin führen. Der Teensy läuft übrigens auch nur mit 3,3V.
                                Ich habe jetzt einfach solche Verlängerungsleitung benutzt: http://www.ebay.de/itm/40pcs-2-54mm-21c … 1913639446
                                Hatte ich noch rumliegen und war eine schnelle Möglichkeit das zu testen.
                                  Kaum ist man mal zum Grillen im Garten kommt die Wahrheit ans Licht 😄
                                  @MaikB85:
                                  Vielleicht sind das auch Störfrequenzen. `
                                  Das war ja auch meine Vermutung, wenn da etwas synchron mit Schwankungen bei IAQ auftrat.
                                  @MaikB85:
                                  Ich hoffe nicht, dass es ein thermisches Problem ist, weil dies mein ganzes Konzept durcheinander bringt. `
                                  meins dann auch, ich wollte die nächsten Platinen sogar ohne Buchsenleisten aufbauen um Platz zu sparen.
                                  Das Ergebnis soll ja auch wohnraumfreundlich aussehen.
                                  @klassisch:
                                  @MaikB85 :
                                  Sensor wohl umsonst bestellt… `
                                  Der BME280 ist schon ein ordentlicher Sensor. `
                                  Sonst nehme ich sie dir ab, brauche dann aber eine andere Noob-freundliche Lösung
                                  @klassisch:
                                  Meine erste Spekulation geht in Richtung thermischer Beeinflussung. `
                                  @Maik: Was passiert denn wenn du den Sensor abgesetzt in die nähe der Paltine bringst.
                                  ich kann nicht glauben, dass der BME, der ja etwa 15mm über der Platine schwebt Probleme mit der Wärme hat. Die nächste Wärmequelle wäre der Teensy, der noch mal 15mm auf der anderen Seite der Platine auf Sockeln steh, da ist ja eher der IAQ 15mm seitlich neben dem BMEnoch dichter dran (und sendet Störungen ???)
                                  Rainer
                                    Teensy war mir kein Begriff. Sehe, da steckt eine ganze Famile dahinter. Schön viele i/Os - daran krankt der WeMos etwas. Und es gibt 2 (teure) Derivate mit Ethernet. Das wäre für mich auch praktisch weil ich einige Positionen habe, wo nebendran eine Ethernetleitung und sogar Switch ist und ich arbeite mit separatem Netzteil und WLAN. Aber der Preis ist abschreckend im Vergleich zum WeMos und der ESP32 läuft schon langsam an.
                                    Habe aber nicht gefunden, wie die Boards versorgt werden und wieviel Strom die kompletten Boards ziehen.
                                    Vielleicht kannst Du das etwas entschärfen, wenn Du das Netzteil auslagerst und direkt 3.3V einspeist. Der WeMos hat einen 5V->3.3V Linearregler an Bord, so etwas ist thermisch unschön.
                                    Eine günstige externe Versorgung könnte sein: https://www.pollin.de/p/steckernetzteil … -mm-351843 und https://de.aliexpress.com/item/5Pcs-TL0 ... 79397.html . Aber vorsicht, man muß die Bahn zum Trimmer aufkratzen und dann die Lötbrücke setzen.
                                    @Rainer: Mit den WeMos gibt es etliche einfache Lösungen....
                                      Werde die Tage nochmal gucken nach einer geeigneten Position des BME280. Schon 10mm mehr Abstand zur Platine macht einen deutlichen Unterschied bei der Temperatur. Kann so noch nicht ganz eingrenzen was die Ursache ist.
                                      Denke aber auf jeden Fall dass es dafür eine Lösung geben wird.
                                      Schön wäre jetzt eine gute Wärmebildkamera. Ich gucke Mal ob ich die aus der Firma nochmal ausleihen kann…
                                        Oder Testo 845 damit kann man auch punktgenau messen .
                                        Gesendet von meinem ZTE A2016 mit Tapatalk
                                          Habe mir das ganze Gerade Mal mit der Fluke Wärmebildkamera angesehen. Der Prozessor des Teensy ist wie erwartet am wärmsten mit ca. 45°C. Ich denke das wird auch die Hauptursache sein. Da die Platine ja auch nicht sehr groß ist wird sich die Wärme über die Leiterbahnen weiter verteilen. Die Platine selber ist bei ca. 28°C laut Kamera. Da der BME280 nur ca 10mm Abstand zur Platine hat erklärt dass auch die erhöhte Temperatur. Also man wird da nicht drum rum kommen und den BME280 etwas auf Abstand zu bringen.
                                          Der BME280 wird übrigens kein bisschen warm. Der iAQ schon ein wenig aber das ist ja klar.
                                          Ich habe mir auch Mal den Spannungsregler angesehen. Bei 24V ist die Temperatur etwa bei 38°C. Bei 12V sind es locker 5°C weniger. Also werde ich definitiv, allein schon der Effizienz wegen, auf 12V Gleichstromnetz gehen.
                                          Morgen werde ich mal ein paar Bilder dazu posten.
                                          Gruß Maik
                                          Gesendet von meinem SM-G925F mit Tapatalk
                                            Hallo Maik,
                                            danke für die Info. Ich habe das Thema Interferenzen noch nicht ganz aus den Augen verloren. Grund ist meine Aufzeichnung:
                                            Mich wundert, dass beide Sensoren zeitgleich stark zittern (1) oder ruhig sind (2). Mag sein dass ich mich irre, aber das wirkt auf mich eher wie eine mögliche (hochfrequente) Interferenz.
                                            Ob das auf die Höhe der Werte des BME einen Einfluß hat kann ich so einfach nicht nachstellen. Um wenigstens zu sehen, wo diese herkommen habe ich auf einem Board den IAQ entfernt (heute 17:30-18:30) und keinerlei Veränderung der zugehörigen BME-Werte feststellen können.
                                            Sollte das Teensy eine Interferenz abstrahlen müsste man die Sensoren lang verkabeln, wobei dann ebenfalls der thermische Einfluss entfernt wird, wobei ich ja den Teensy direkt mit 5V betreibe und somit auch der Spannungsregler keine Wärmequelle sein kann.
                                            Rainer
                                            226
                                            53601
