    4. [2.5.9 Fehler existiert] - Backup-Adapter erzeugt Fehler
      Thomas Braun Most Active @skinni last edited by
      @skinni
      Buster ist tot. Installier da das aktuelle stable release 'Bullseye'.
        Siggi0904 last edited by
        Bei mir tritt das Problem auf, sobald ich einen Adapter aktualisiert habe.
        Dann hilft nur ein Neustart des ganzen Systems.
          skinni @Thomas Braun last edited by
          @thomas-braun hab jetzt auch im backup adapter den Fehler, das bullseye upgrade werde ich dieses WE angehen, erst mal sd-card klonen
          ted iobroker ...
          [DEBUG] [mount] - mount activ... umount is started before mount!!
          [DEBUG] [mount] - umount successfully completed
          [DEBUG] [mount] - noserverino option: false
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=pi,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.88.110/PIBackup /opt/iobroker/backups"
          [DEBUG] [mount] - mount successfully completed
          [DEBUG] [mount] - done
          [ERROR] [iobroker] - node:internal/bootstrap/switches/does_own_process_state:126
              cachedCwd = rawMethods.cwd();
          Error: ENOENT: no such file or directory, uv_cwd
              at process.wrappedCwd (node:internal/bootstrap/switches/does_own_process_state:126:28)
              at Object.process.cwd (/opt/iobroker/node_modules/graceful-fs/polyfills.js:10:19)
              at fe.Yargs (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:61304)
              at Argv (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:12:16)
              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:7:1)
              at Module._compile (node:internal/modules/cjs/loader:1155:14)
              at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
              at Module.load (node:internal/modules/cjs/loader:1033:32)
              at Function.Module._load (node:internal/modules/cjs/loader:868:12)
              at Module.require (node:internal/modules/cjs/loader:1057:19) {
            errno: -2,
            code: 'ENOENT',
            syscall: 'uv_cwd'
            Siggi0904 @skinni last edited by
            @skinni Start mal den Rechner neu. Du wirst sehen, dann ist der Fehler weg.
              skinni @Siggi0904 last edited by
              @siggi0904 Der Fehler verschwindet auch von alleine, genauso wie er kommt. Das soll nicht meine Lösung sein. Hab jetzt mal das Update auf bullseye gemacht, das lief überraschend gut. Hab mich dabei an die Anleitung https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye gehalten
              Thomas Braun S 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @skinni last edited by Thomas Braun
                @skinni
                Jag den Fixer mal drüber.
                iob stop
                iob fix
                iob start
                Und wie startest du das Backup?
                  @thomas-braun Die Frage versteh ich nicht. Ich starte das Backup eigentlich gar nicht, das macht ja der backitup Adapter jede Nacht und ist dabei erfolgreich, oder manchmal auch nicht. Das da oben hatte ich im backitup Adapter manuell gestartet durch Klick auf "Jetzt sichern" unter iobroker im backitup Adapter. Das funktioniert jetzt aktuell auch gerade wieder - bis es dann in ein paar Tragen vermutlich nicht mehr geht 😉
                  Den fixer hatte ich heute nach dem bullseye upgrade schon drüber laufen lassen, sicher ist sicher.
                  Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                    @skinni sagte in [wieder geöffnet] - Backup-Adapter erzeugt Fehler:
                    Das war genau die Frage. Die Meldung kommt eigentlich wenn man da mit einem user in einem Verzeichnis steht, dieses verändert wird und das dann alles 'in der Luft' hängt.
                      @skinni Bei mir verschwindet der Fehler nicht automatisch.
                      Wenn er einmal auftritt, bleibt er bis zum Neustart stehen.
                        skinni last edited by skinni
                        Lief jetzt bis heute ohne Probleme, musste aber erstmal zurück auf buster weil mein conbee II nicht mehr funktioniert hat 😕
                          Das ist kein Grund, der läuft natürlich auch unter 'bullseye'.
                          • simatec
                            simatec Developer Most Active @Siggi0904 last edited by
                            @siggi0904 Tritt der Fehler in v2.5.9 bei dir noch auf?
                            S 3 Replies Last reply Reply Quote 0
                            • simatec
                              simatec Developer Most Active @skinni last edited by
                              @skinni Welche Version von Backitup ist installiert? In v2.5.9 ist etwas eingebaut, um den fehler abzufangen.
                              Wenn der Fehler auftreten sollte, starte mal den Adapter neu und poste den Debug Log
                                Siggi0904 @simatec last edited by
                                @simatec Ich habe erst gerade die neue Version erhalten.
                                Das muss ich erst testen. Danke für den Hinweis.
                                  @simatec Tests sind durch, auch die automatischen Backups liefen heute ohne Probleme durch.
                                  Ich hatte bei der alten Version den Fehler, ohne Neustart mit der neuen Version läuft alles super.
                                  Ich setze das Thema auf erledigt.
                                    @simatec Das Problem ist heute wieder aufgetreten. 😠
                                    • simatec
                                      @siggi0904 Kannst du bitte den Log posten?
                                      Das Problem muss tiefer liegen und mit großer Wahrscheinlichkeit in nodejs liegen
                                      • simatec
                                        @siggi0904 Wurde der Adapter vor auftreten des Problems neu gestartet? Wenn ja auch hier bitte den Debuglog vom restart des Adapters posten
                                          @simatec Hallo, nein. Ich hab über das System auf die neue Version aktualisiert und am folgenden Tag (vor 3 Tagen) lief es sauber durch.
                                          Heute Morgen ist der Fehler aufgetreten.
                                          Hast du eine Mail-Adresse, an die ich das senden kann?
                                          Ist ja erstens viel und zweitens mit persönlichen Daten.
                                          • simatec
                                            @siggi0904 Bitte poste hier nur den teil des Backups. Da sind keine Daten sichtbar
                                            5651
