    3. Entwicklung
    4. Adapter für Broadlink RM 3 Mini/RM3 Pro - Infrarot/IR
      MauriceSG last edited by
      ![](</s><URL url=)http://up.picr.de/29951836nx.jpg" />
      • BBTown
        BBTown last edited by
        sorry, der code war unvollständig, hier nun der vollständige.
        Aber, es ist ein Blockly-code !!
        <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="nE(du3aXY2owO0nkeK8B" x="-338" y="13"><mutation items="1"></mutation>
        <value name="OID0"><shadow type="field_oid" id="xkUcu,a7(QU24];C9QRX"><field name="oid">MultiMedia.0.Fernsehen</field></shadow></value>
        <statement name="STATEMENT"><block type="controls_if" id="OAAw8/5t%l.nG/muy8zg"><value name="IF0"><block type="logic_compare" id="}j@Q?Ld3iXz/yB;,I{%f"><field name="OP">EQ</field>
                <value name="A"><block type="get_value" id="Dmta#S:Ep7wjtv5C|0aJ"><field name="ATTR">val</field>
                    <field name="OID">MultiMedia.0.Fernsehen</field></block></value>
                <value name="B"><block type="logic_boolean" id="DAE/tbn%~!dm+!S7)}(J"><field name="BOOL">TRUE</field></block></value></block></value>
            <statement name="DO0"><block type="control" id="Z#BpaV~U)dUL?{f7qzc7"><mutation delay_input="false"></mutation>
                <field name="OID">broadlink.0.SamsungPlasmaTV.CODE_2600d200949413371237133712121213121212131212123713371238121212121213121212121337121212131138123812121213113812131138123812121212123812381212120006009494123713371238121212121213121212121238123713371212121312121213121212371312121212381237121311131238121212371238121213121237123812121200060094941238123713371212121312121212121312371238123713121212121311131212123812121213113812381212121212381212123812371312121212381237121312000d050000000000000000</field>
                <value name="VALUE"><block type="logic_boolean" id="BFo8Fb]r_`Oy`F=]/E8x"><field name="BOOL">TRUE</field></block></value></block></statement>
            <next><block type="controls_if" id="jC{;1-EC{hm6;vt2zje~"><value name="IF0"><block type="logic_compare" id="lOR*##:dhdI0B@xkdHmQ"><field name="OP">EQ</field>
                    <value name="A"><block type="get_value" id=",AUwj/EP!:KC|^tAw,`@"><field name="ATTR">val</field>
                    <value name="B"><block type="logic_boolean" id="WAnR-@A}Hg`|N6HxY]5t"><field name="BOOL">FALSE</field></block></value></block></value>
                <statement name="DO0"><block type="control" id="AfC_gx?2nTg_SurB8dE,"><mutation delay_input="false"></mutation>
                    <field name="OID">broadlink.0.SamsungPlasmaTV.CODE_2600d200969413361337123812121212131211131113123812381237131210141212121310141113121311131136153712131014123713371238133612131113123712381212120006009494123813361436121311131212121310141237133712381311121212131113121211141113121212381238131111131139123713371337111311131139123713121200060094941336123813361411121212131113121212381237133712121213111312121312111312131113123712381311121311381238123713371212121311381337121212000d050000000000000000</field>
                    <value name="VALUE"><block type="logic_boolean" id="w+kXam(Wq0ga^N}NdDuT"><field name="BOOL">TRUE</field></block></value></block></statement></block></next></block></statement></block></xml>
        [1917_script_importieren.png](/assets/uploads/files/1917_script_importieren.png)
        [1917_script_anlegen.png](/assets/uploads/files/1917_script_anlegen.png)
          script scheint zu gehen aber das mit dem Objekt???
          wenn ich ein objekt erstelle habe Ich folgende auswahl:
          Typ:
          Datenpunkt / Kanal / Gerät
          Bei Kanal keine weitere Auswahl!
          Bei Datenpunkt:
          ~~![](</s><URL url=)http://up.picr.de/29953035ir.jpg" />
          aber bei keiner Kombination erscheint bei mir das Feld smartName~~
          • BBTown
            Weshalb hälst Du dich nicht einfach an die Anleitung?
            Es wird von nichts anderen als einem Datenpunkt gesprochen
            Der smartName wird automatisch vom cloud-Adapter eingetragen wenn Du den Datenpunkt im Cloud-Adapter hinzugefügt hast.
            Ich habe dir lediglch gezeigt wie man über die Eigenschaften des Datenpunktes den Cloud-Adaper-Eintrag wieder entfernen kann.
            Nirgends in der Anleitung ist ein Hinweis darauf, dass Du einen Eintrag in ein Feld smartName tätigen mußt.
            1. Datenpunkt anlegen
            • Name: "Fernsehen"
            • role=switch
            • type: Logikwert)
            2. Im cloud-Adapter ein Smart-Gerät anlegen
            • Name: "Fernsehen" (mit diesem Namen erfolgt die Ansprache in Alexa)
            • Verküpfung mit dem unter 1.) angelegten Datenpunkt "Fernsehen"
            3.) in der Alexa App prüfen ob es bereits eine Gerät namens "Fernsehen" gibt,
            • falls ja -> verwerfen (entfernen)
            • falls nein (oder nach dem entfernen) in der Alexa App nach Geräten suchen
            • prüfen ob "Fernsehen" angekommen ist
            4.) Script erstellen:
            • was soll geschehen wenn "Fernsehen" = wahr
            • was soll geschehen wenn "Fernsehen" = unwahr
            Ein Beispielscript habe ich dir zum Import angefügt.
            Da mein Datenpunkt "Fernsehen" aber an einer ganz anderen Stelle in der "Objekte-Liste" liegt als der Deine, mußt Du natürlich diese Verknüpfung korrigieren (draufklicken und auswählen) und zwar an allen drei Stellen an denen sich auf "Fernsehen" bezogen wird.
            Das gleiche gilt für die Datenpunkte "TV ein" und "TV aus", die heißen bei dir ganz anders ("Fernseher_schalten"???) und liegen auch an einer anderen stelle, also draufklicken und korrekte Verknüpfung auswählen.
            Mach es doch einfach wie es da steht.
              Läuft jetzt alles super Danke nochmal!
              Sorry das Ich so genervt habe, war Gestern zu sehr Durch den Wind und habe nichts mehr in den Kopf bekommen!
              Gruß Maurice
              • BBTown
                Moin Maurice,
                und ein ebensolches sorry auch von mir, ich wurde sichtlich ungeduldig 8-)
                Dann können wir ja nun zur "Kür" kommen :lol:
                Der besondere Vorteil von der Vorgehensweise mit dem "Hilfs-Datenpunkt" liegt darin, dass Du über das Script natürlich nicht nur einen einzigen Befehl absetzen kannst, sondern gleich ein ganzes Feuerwerk 🙂
                Ich hatte gesehen, dass Du z.B. "Sky" als weitere "Broadlink"-Taste eingerichtet hattest (so sah es jedesfalls aus).
                Wieso also nicht in deinem (Blockly)-Script nach dem "steuere - TV ein = wahr" auch sofort "steuere - Sky ein = wahr" hinterherschicken?!
                So mußt Du hierfür nicht ein separates Alexa-Kommando geben.
                Schau dir gern noch einmal den ersten Screenshot meines Blockly-Scriptes an:
                Über "Alexa, schalte Fernsehen ein" lasse ich also in einem Rutsch:
                • TV = ein
                • TV Eingangsquelle = HDMI-1
                • AV-Receiver = Eingangsquelle TV
                • Subwoofer = Voreinstellung TV
                • LED-Stripe hinter dem TV = ein
                • LED hinter dem TV Farbe = ocker
                ausführen.
                Wenn Du das einmal verinnerlicht hast, dann steht dir die Welt von ioBroker für noch viele spannende Lösungen offen!! 😄
                • BBTown
                  Moinsens,
                  ich habe per Zufall herausgefunden, dass es sehrwohl für die meisten Samsung TV`s unterschiedliche Codes für das Einschalten und Ausschalten gibt, obgleich die Fernbedienung lediglich eine "toggle-Taste" anbietet.
                  Folgende Broadlink-Codes sollten funktionieren:
                  Samsung TV = on
                  Samsung TV = off
                  Vielleicht kann das der Eine oder Andere ja verwenden?!
                  • metaxa
                    metaxa last edited by
                    <size size="150">chapeau</size>
                    Das ist endlich eine Lösung für meinen alten (und neuen) BENQ. Habe sogar mit Blocky schon ein Script angelegt das auf eine SysVar der CCU reagiert. Funktioniert auf Anhieb, tolle Arbeit. Lieben Dank!
                    (das Importieren eines vorgefertigten "remote panel" über die Bridge schaffe ich leider nicht, ist aber nicht so tragisch)
                    Bin gerade dabei mich tiefer Einzuarbeiten, scheitere aber offensichtlich an Basics. Ja, glaubt mir, ich habe u.v.A. auch diesen Thread schon mehrfach durchgekaut (sonst wäre ich nicht soweit :D)
                    Frage1: Bitte, wie bekomme ich einen angelernten Code (Objekt?) in eine andere Struktur? 488_adapt_broadlink.jpg
                    So nicht, dann funktioniert der Code (Datenpunkt?) nicht mehr. 488_adapt_broadlink_1.jpg 488_adapt_broadlink_2.jpg
                    Frage2: Welche Rolle ist für das Ausführen der Codes die Richtige? 488_adapt_broadlink_3.jpg "State" tut, aber genauso wie "Action" oder "Button", ich verstehe nur die Zusammenhänge dahinter nicht.
                    Lieben Dank, mxa
                    • BBTown
                      @metaxa:
                      Bitte, wie bekomme ich einen angelernten Code (Objekt?) in eine andere Struktur? `
                      Moin metaxa,
                      deine Vorgehensweise ist genau richtig. Der Unterschied zu meiner Struktur ist jedoch, dass Du "Geraete" und "SOKI" als "Kanal (Channel)" und nicht als ""Gerät (Device)" angelegt hast.
                      Ich habe mir angewöhnt die angelernten Fernbedienungstasten als "button" anzulegen.
                      Wenn Du in der Objekte-Übersicht die Taste siehst, dann kannst Du diese sofort durch klick auf das Symbol auslösen und musst den Datenpunkt nicht erst von "false" auf "true" setzen - gerade beim Testen oder sonstigen manuellen Auslösen für mich sehr hilfreich.
                      "Action" kannte ich bisher gar nicht 🙂
                      • metaxa
                        Hi Heiko!
                        Wahrscheinlich war das~~@BBTown:~~
                        und nicht als ""Gerät (Device)" angelegt hast. ` die Lösung. Oder ich hatte auch schon zu lange herumgedoktert.
                        Fakt ist, es passt und funkt (besser "Infrarotet") jetzt dort wo angedacht! :idea: 488_adapt_broadlink_4.jpg
                        Danke für deine Erklärungen!
                        LG, mxa
                          LaGra last edited by
                          Hallo @ all.
                          Ich habe mich mangels anständigen, bzw deutschsprachigen Broadlink Skill für Alexa damit auseinandergesetzt, dies über ioBroker zu
                          realisieren. Jetzt bin ich aber auf ein Problem gestoßen.
                          Wenn ich einen neuen Code anlerne, wird der alte ständig überschrieben.
                          hat jemand das selbe Phänomen beobachten können? Kennt jemand Lösungsansätze?
                          Mit dem RM-Plugin für Android ist es zudem möglich Makros, also eine Folge nacheinander ausgeführter Signale zu senden.
                          Kennt da jemand Möglichkeit dies im Broker umzusetzen?
                          Mfg LaGra
                            weimaraner last edited by
                            Gibst Du dem angelernten Signal sofort einen richtigen Namen? Dnn dürfte das nämlich nicht passieren.
                            Grüße Andreas
                            Edit: schau mal hier http://forum.iobroker.net/viewtopic.php … =40#p61998 Da wurde die Frage auch schonmal gestellt
                            • BBTown
                              @LaGra:
                              hat jemand das selbe Phänomen beobachten können? Kennt jemand Lösungsansätze? ` Du mußt den Code nach dem Anlernen natürlich noch Anpassen.
                              Als ID nimmst Du "CODE_xxxxxx" wobei hier "xxxx" der tatsächiche Code ist.
                              Als Namen vergibts Du dann idealerweise noch etwas leicht erkennbares wie "TV ein"
                              Am besten legst Du dir eine Struktur an.
                              Ich habe beispielsweise eine Objektgruppe (Device) "MultiMedia.0" angelegt
                              Da drunter befindet sich die Gruppe (Device) "Samsung Plasma TV"
                              und dort drunter befinden sich dann wiederum die ganzen Steuerocdes (Datenpunkte) meines Samsung Plasma TV
                              usw.
                              @LaGra:
                              Kennt da jemand Möglichkeit dies im Broker umzusetzen? `
                              Dafür installierst Du dir den "javascrip" Adapter und benutzt den "Blockly" Editor (wenn Du dir diesen ganzen Fred von Anfang bis Ende durchliest verstehst Du die Vorgehensweise).
                              Optional kannst Du das auch über "Szenen" in ioBroker umsetzen.
                              Auch das wird hier im Forum ausgiebig behandelt.
                              • BBTown
                                http://forum.iobroker.net/viewtopic.php?f=24&t=5461&p=80494#p78591 als Screenshot zu sehen.
                                • O
                                  oif last edited by
                                  @Muchul:
                                  Guten Morgen zusammen,
                                  dies ist mein erstes Post in diesem Forum.
                                  Ich bin absoluter Neuling in der Materie und habe keine Ahnung von Programmieren und null Englisch Kenntnisse.
                                  Daher ist die Entscheidung für iobroker gefallen, da hier wenigstens deutsch geschrieben wird.
                                  Ich bitte jetzt schon um Entschuldigung wenn ich zukünftig mit Banalen Fragen komme, und auch für meine nur rudimentären Deutschkenntnisse, wobei mein türkisch sogar noch schlechter ist 🙂
                                  Daher ein Großes Dankeschöön dafür.
                                  Ich habe den iobroker auf einem Rasppery Pi 3 installiert.
                                  Bisher habe ich nur MQTT und den Broadlink Adapter aktiviert.
                                  Das Anlernen von IR Signalen funktioniert problemlos, auch das Senden klappt.
                                  Allerdings habe ich neben IR und 433 Mhz auch noch mehrere TC2 Lichtschalter und noch drei SP2 von Broadlink.
                                  Ich habe leider nicht gefunden, wie ich die TC2 bzw. SP2 Codes raus bekommen kann.
                                  Hat das eventuell jemand schon gemacht und kann mir einen Tip geben?
                                  Ich habe auch die RM-Bridge auf dem Handy installiert und falls Logs benötigt werden, stelle ich diese sehr gerne zur Verfügung.
                                  Herzlichen Dank im voraus. `
                                  Hast du schon eine Lösung gefunden?
                                  ich habe die TC2 codes per rm plugin ausgelesen, aber schaffe sie nicht zu senden.
                                  hab mir auch diesen thread https://community.home-assistant.io/t/b … h/7904/155 durchgelesen, jedoch hilft mir da nichts.
                                  hab versucht den aus und ein code zu einem zusammenzufügen, 0000 dranzuhängen, zu konvertieren, vervielfachen, … nichts hilft...
                                    Muchul last edited by
                                    Leider nein, bisher nutzte ich die html bridge.
                                      RandyAndy last edited by
                                      ich verwende den Broadlink um 3 Klimaanlagen zu steuern. Das funktioniert auch soweit recht zuverlässig.
                                      Was mir allerdings aufgefallen ist, dass sich von Zeit zu Zeit (insb. wenn der Raspberry neu gestartet wird) die Broadlinks nicht mehr aus dem ioBroker ansprechen lassen. Ein neu starten des ioBroker hilft da auch nicht. Offensichtlich hängt das irgendwie mit der IP Konfiguration zusammen. In meinem Fall ist der Broadlink auf die IP Adresse 192.168.178.6 eingestellt.
                                      Wenn ich in den Einstellungen des Broadlinks im ioBroker die IP Adresse ändere z.B. von 192.168.178.6 auf 192.168.178.200 und die Instanz neu neu starte und danach die IP Adresse wieder zurück stelle auf 192.168.178.6 und die Instanz wieder neu starte dann ist alles wieder gut und die Steuerung funktioniert wieder.
                                      Ich habe schon mal in den Systemparametern nachgesehen, aber da scheint alles ok zu sein.
                                      Vielleicht hat ja irgendwer eine Idee
                                      Andreas
                                      • BBTown
                                        @RandyAndy:
                                        die Broadlinks nicht mehr aus dem ioBroker ansprechen lassen. Ein neu starten des ioBroker hilft da auch nicht ` sorry, ich habe so ein Problem noch nicht feststellen können, daher habe ich nich die geringste Idee wie ich dir eine Hilfestellung geben könnte 😞
                                          crepp last edited by
                                          Ich muss mich hier mal dranhängen, weiss allerdings nicht ob es der richtige Fred ist…
                                          Habe den broadlink pro jetzt erfolgreich in Betrieb genommen und es funzt soweit alles. Ein Problem habe ich aber noch nicht in den Griff bekommen:
                                          Ich möchte die Codes übersichtlich in einer "Ordner"-Struktur haben. Kann ich die eigentlich auch im Nachhinein anlegen u. sozusagen die Codes dorthin verschieben oder muss ich meine Codes jetzt noch mal anlernen? Wenn ja wie mache ich das - habs nicht allein (über Anlegen Objekt, Device Channel) hinbekommen. Vieleicht gibt's ja auch schon eine Anleitung im Forum - Wäre dann für einen Link dankbar ...
                                          Torsten
                                          • BBTown
                                            @crepp:
                                            Ich möchte die Codes übersichtlich in einer "Ordner"-Struktur haben. Kann ich die eigentlich auch im Nachhinein anlegen u. sozusagen die Codes dorthin verschieben ` ja, das kannst Du über das Register "raw" in den Eigenschaften des Datenpunktes anpassen. Einfach den Pfad unter "_id:" entsprechend aktualisieren.
                                            [EDIT] Du musst dabei auch nicht in der Rubrik "broadlink.0" bleiben, Du kannst auch eine völlig neue Struktur z.B. "Geräte.0" anlegen und darunter dann deine angelernten Geräte strukturieren.
                                            220
                                            62853
