    3. Einsteigerfragen
    4. Installation
    5. BackItUp Adapter Probem
    • DJMarc75
      DJMarc75 @Kippe last edited by
      @kippe @Thomas-Braun hat oben schon geschrieben dass da "noServerInfo" angehakt sein muss.
        Thomas Braun Most Active @DJMarc75 last edited by
        @djmarc75
        Und SMB-Version 3.1.1.
        Auch schon geschrieben.
          Kippe @Thomas Braun last edited by
          Habe ich auch versucht, aber das selbe Problem
            Thomas Braun Most Active last edited by
            @kippe sagte in BackItUp Adapter Probem:
            Dann bitte die Konsolenausgabe dazu.
            Bei anderen Einstellungen muss das auch da anders aussehen.
              @thomas-braun sagte in BackItUp Adapter Probem:
              Konsolenausgabe
              admin.0
              	2022-12-16 20:04:51.918	info	<== Disconnect system.user.admin from ::ffff:192.168.178.58
              admin.0
              	2022-12-16 19:04:51.918	info	<== Disconnect system.user.admin from ::ffff:192.168.178.58
              backitup.0
              	2022-12-16 19:03:03.183	error	Error: Command failed: sudo mount -t cifs -o username=Backup1,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/boot/backup /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              backitup.0
              	2022-12-16 19:02:44.305	error	Error: Command failed: sudo mount -t cifs -o username=Backup1,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/boot/backup /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              backitup.0
              	2022-12-16 18:57:06.960	error	[iobroker] Error: Command failed: sudo mount -t cifs -o username=Backup1,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/boot/backup /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              backitup.0
              	2022-12-16 18:57:06.960	error	[iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              backitup.0
              	2022-12-16 18:57:06.960	error	[iobroker/mount] mount error(1): Operation not permitted
              backitup.0
              	2022-12-16 18:57:06.960	error	[iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Backup1,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/boot/backup /opt/iobroker/backups
              backitup.0
              backitup.0
              	2022-12-16 18:57:06.959	error	[iobroker/mount] mount error(1): Operation not permitted
              backitup.0
              	2022-12-16 18:57:06.959	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup1,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/boot/backup /opt/iobroker/backups
              backitup.0
              	2022-12-16 18:56:54.589	error	Error: Command failed: sudo mount -t cifs -o username=Backup1,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/boot/backup /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              backitup.0
              	2022-12-16 18:56:49.096	error	Error: Command failed: sudo mount -t cifs -o username=Backup1,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/boot/backup /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              admin.0
              	2022-12-16 18:56:45.400	info	==> Connected system.user.admin from ::ffff:192.168.178.58
              backitup.0
              	2022-12-16 18:56:42.935	error	Error: Command failed: sudo mount -t cifs -o username=Backup1,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/boot/backup /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
              backitup.0
              	2022-12-16 18:56:42.716	info	[iobroker] backup was activated at 02:40 every 1 day(s)
              backitup.0
              	2022-12-16 18:56:42.681	info	starting. Version 2.5.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.21.1, js-controller: 4.0.23
              host.ioBroker
              	2022-12-16 18:56:42.120	info	instance system.adapter.backitup.0 started with pid 1525
              host.ioBroker
              	2022-12-16 18:56:39.582	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              admin.0
              	2022-12-16 18:56:39.345	info	<== Disconnect system.user.admin from ::ffff:192.168.178.58
              host.ioBroker
              	2022-12-16 18:56:39.106	info	stopInstance system.adapter.backitup.0 send kill signal
              backitup.0
              	2022-12-16 18:56:39.067	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              backitup.0
              	2022-12-16 18:56:39.067	info	terminating
              backitup.0
              	2022-12-16 18:56:39.066	info	cleaned everything up...
                Thomas Braun Most Active @Kippe last edited by
                Und der user Backup1 (oder Backup) oder wie der gerade auf deiner FritzBüchse heißt hat auch entsprechende Berechtigungen?
                    @kippe
                    Backup ist nicht Backup1
                      Ja ich habe 2 Benutzer Backup und Backup1
                      Habe mal beide versucht
                      Thomas Braun K 2 Replies Last reply Reply Quote 0
                        @kippe
                        Und die Einstellungen für den Backup1 ?
                          Kippe @Kippe last edited by
                          Und hier in der Fritz Box der usb Stick mit den Backups !!
                            Habe jetzt wieder af Bachup gestellt mit den Originalen Einstellungen wie es immer lief
                              Oder kann das mit dem Contaner zusammenhängen in Proxmox
                              Thomas Braun Homoran E 3 Replies Last reply Reply Quote 0
                                @kippe
                                smbclient -L fritz.box -U Backup
                                sagt?
                                  Homoran Global Moderator Administrators @Kippe last edited by
                                  warum kommt das jetzt erst, obwohl ich schon ganz zu Beginn gefragt habe
                                  @homoran sagte in BackItUp Adapter Probem:
                                  Jetzt habe ich den Broker auf mein Proxmox System gemacht
                                  heisst genau was?
                                    Was soll ich jetzt genau machen?
                                    Thomas Braun simatec 2 Replies Last reply Reply Quote 0
                                      @kippe
                                      Den Befehl in dein Terminal auf dem Client hacken.
                                        Einstein67 @Kippe last edited by
                                        @kippe said in BackItUp Adapter Probem:
                                        Ich vermute mal das ist ein unprivilegierter Container?
                                          Thomas Braun Most Active @Einstein67 last edited by
                                          Bei Containern bin ich auch raus.
                                            darkiop Most Active last edited by
                                            https://www.thushanfernando.com/notes/proxmox-cifs-setup/
                                            hilfe
                                            1278
