    4. Test ioBroker Fixer mit JSONL-Compression
    • Dr. Bakterius
      Dr. Bakterius Most Active @apollon77 last edited by Dr. Bakterius
      @apollon77 sagte in Test ioBroker Fixer mit JSONL-Compression:
      iob fix
      Funktioniert! objects.jsonl von 32751637 -> 20090424, states.jsonl von 20246420 -> 3260086
      iob diag
      Da bekomme ich folgenden Fehler:
      bash: line 1: syntax error near unexpected token `<'
      bash: line 1: `<!doctype html><html lang="en"><head><meta charset="utf-8"/><link rel="icon" href="/www/favicon.ico"/><meta name="viewport" content="width=device-width,initial-scale=1"/><meta name="theme-color" content="#2196F3"><meta name="description" content="Remote access to personal ioBroker server via ioBroker.cloud"/><link rel="apple-touch-icon" href="/www/logo192.png"/><link rel="manifest" href="/www/manifest.json"/><title>ioBroker Cloud</title><style>#root,body,html{height:100%;width:100%;display:flex;overflow:hidden}</style><script defer="defer" src="/www/static/js/main.ae982c84.js"></script><link href="/www/static/css/main.59da0ebb.css" rel="stylesheet"></head><body><noscript>You need to enable JavaScript to run this app.</noscript><div id="root"></div></body></html>'
        apollon77 @Dr. Bakterius last edited by
        @dr-bakterius Danke, lasse es Bluefox nochmal prüfen
          bommel_030 @apollon77 last edited by
          @apollon77
          für iob diag wie @Dr-Bakterius
          bash: Zeile 1: Syntaxfehler beim unerwarteten Symbol »<«
          bash: Zeile 1: `<!doctype html><html lang="en"><head><meta charset="utf-8"/><link rel="icon" href="/www/favicon.ico"/><meta name="viewport" content="width=device-width,initial-scale=1"/><meta name="theme-color" content="#2196F3"><meta name="description" content="Remote access to personal ioBroker server via ioBroker.cloud"/><link rel="apple-touch-icon" href="/www/logo192.png"/><link rel="manifest" href="/www/manifest.json"/><title>ioBroker Cloud</title><style>#root,body,html{height:100%;width:100%;display:flex;overflow:hidden}</style><script defer="defer" src="/www/static/js/main.ae982c84.js"></script><link href="/www/static/css/main.59da0ebb.css" rel="stylesheet"></head><body><noscript>You need to enable JavaScript to run this app.</noscript><div id="root"></div></body></html>'
          für iob fix auf meinem vermanschten System
          vorher:
          bommel@iobroker:~$ ls -lah /opt/iobroker/iobroker-data/*.jsonl
          -rw-rw-r--+ 1 iobroker iobroker  54M 13. Dez 10:52 /opt/iobroker/iobroker-data/objects.jsonl
          -rw-rw-r--+ 1 iobroker iobroker 218M 13. Dez 10:52 /opt/iobroker/iobroker-data/states.jsonl
          nachher:
          bommel@iobroker:/opt/iobroker$ ls -lah /opt/iobroker/iobroker-data/*.jsonl
          -rw-rw-r--+ 1 iobroker iobroker 31M 13. Dez 10:53 /opt/iobroker/iobroker-data/objects.jsonl
          -rw-rw-r--+ 1 iobroker iobroker 15M 13. Dez 10:53 /opt/iobroker/iobroker-data/states.jsonl
            So, "iob diag" sollte jetzt gefixt sein!!
            Latzi 1 Reply Last reply Reply Quote 0
            • Latzi
              Latzi @apollon77 last edited by Latzi
              jup, so ist es! 👏
              Edit: Leider wird alles vor der summary in meiner putty-session gelöscht (ich kann zumindest nicht mehr hochscrollen), ist das so gewollt?
                mrjeschke @Latzi last edited by
                @latzi
                Das Script soll beim Start und vor summary auf einen Tastendruck warten.
                Das macht es aber leider nicht.
                  Thomas Braun Most Active @mrjeschke last edited by Thomas Braun
                  @mrjeschke
                  Richtig, sollte es.
                  Tut es auf meiner lokalen Version auch. Muss ich mal buddeln was da jetzt auf dem Server gelandet ist.
                  echad@chet:~/iob_diag $ diff iob_diag diag.sh
                  8c8
                  < SKRIPTV="0.0.8"; #version of this script
                  > SKRIPTV="2022-12-09"; #version of this script
                  Bis auf der angepasste Versionsnummer ist das gleich. Keine Ahnung warum das nicht wie vorgesehen funktioniert.
                    mrjeschke @Thomas Braun last edited by
                    Seltsam, wenn ich das Script mit
                    curl -sLf https://iobroker.net/diag.sh > diag.sh
                    runterlade und lokal ausführe wartet es auf Tastendruck.
                    Mit
                    curl -sLf https://iobroker.net/diag.sh | bash -
                    aber nicht.
                      @mrjeschke
                      Kannst du mal versuchen ob es so richtig herunterkommt:
                      curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                      Mit Ausgabe in ein log file:
                      curl -sLf -o .diag.sh https://iobroker.net/diag.sh && bash .diag.sh | tee iob_diag.log
                        Ja, das läuft jetzt wie es soll.
                          @mrjeschke
                          Hmmm, danke. Dann muss ich mal schauen wie das richtig umgesetzt werden kann.
                            @mrjeschke
                            Jetzt läuft iob diag, auch mit Warterei auf Tastatureingaben.
                            O M 2 Replies Last reply Reply Quote 1
                            • O
                              oFbEQnpoLKKl6mbY5e13 @Thomas Braun last edited by
                              Kann/darf man den Befehl auch bei laufenden iobroker ausführen?
                                Thomas Braun Most Active @oFbEQnpoLKKl6mbY5e13 last edited by Thomas Braun
                                @ofbeqnpolkkl6mby5e13
                                Ja, der liest nur Werte aus und schreibt nichts in die Konfig.
                                Wenn der iobroker läuft geht es etwas schneller, weil dann schon viel im RAM ist, was bei gestopptem iobroker erst noch geladen werden müsste.
                                Bei einem Bestandssystem muss nur einmal per
                                iobroker fix
                                der aktuelle Stand geladen werden. Dafür muss der ioBroker natürlich wie üblich gestoppt sein.
                                  Wenn ich
                                  iob diag
                                  eingebe, läuft das Script immer noch ohne Stop durch.
                                    @mrjeschke
                                    Vorher
                                    iobroker fix
                                    damit der richtige Aufruf geladen wird.
                                      Alles klar, jetzt läuft es.
                                        @mrjeschke
                                        Und legt dir auch ein Log nach
                                        /home/iobroker/iob_diag.log
                                          Ja, Log wird erstellt.
                                          • Gaspode
                                            Gaspode last edited by
                                            @apollon77 said in Test ioBroker Fixer mit JSONL-Compression:
                                            Der Fixer ist jetzt auch unter Windows verfügbar! Wäre cool wenn ich da ggf auch Tester finden ...
                                            Also, wie schon im anderen Thread geschrieben, bekomme auch ich unter Windows den schon bekannten Fehler:
                                            F:\ioBrokerTest>npx @iobroker/fix
                                            Need to install the following packages:
                                              @iobroker/fix@4.2.1
                                            Ok to proceed? (y) y
                                            "(" kann syntaktisch an dieser Stelle nicht verarbeitet werden.
                                            Wenn ich jetzt das Package nicht per npx ausführe, sondern installiere
                                            F:\ioBrokerTest>npm install @iobroker/fix
                                            Und dann das Script direkt starte:
                                            F:\ioBrokerTest>node node_modules\@iobroker\fix\lib-npx\install.js fix
                                            Läuft der Fixer erstmal los(!?), meldet am Ende aber einen Fehler:
                                            Windows installation starting... (fixing = true)
                                            NPM version: 8.19.3
                                            Write "iobroker start" to start the ioBroker
                                            npm install node-windows@1.0.0-beta.8 --force --loglevel error --production --save --prefix "F:/ioBrokerTest"
                                            up to date, audited 524 packages in 9s
                                            36 packages are looking for funding
                                              run `npm fund` for details
                                            20 vulnerabilities (2 low, 16 moderate, 2 high)
                                            To address issues that do not require attention, run:
                                              npm audit fix
                                            To address all issues (including breaking changes), run:
                                              npm audit fix --force
                                            Run `npm audit` for details.
                                            Running Admin shell
                                            ioBroker wird beendet.
                                            ioBroker wurde erfolgreich beendet.
                                            ioBroker service is already installed.
                                            Running Admin shell
                                            ioBroker wird gestartet.
                                            ioBroker wurde erfolgreich gestartet.
                                            ioBroker service installed and started. Go to http://localhost:8081 to open the admin UI.
                                            To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
                                            NPM version: 8.19.3
                                            No path given, using F:\ioBrokerTest\iobroker-data
                                            Compressing F:\ioBrokerTest\iobroker-data\states.jsonl
                                            Cannot compress states.jsonl: Error: Failed to lock DB file "F:\ioBrokerTest\iobroker-data\states.jsonl"!
                                                at JsonlDB.open (C:\Users\OnkelAdmin\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@alcalzone\jsonl-db\build\lib\db.js:185:19)
                                                at async compressDB (C:\Users\OnkelAdmin\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:37:9)
                                                at async main (C:\Users\OnkelAdmin\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:78:17)
                                            Compressing F:\ioBrokerTest\iobroker-data\objects.jsonl
                                            Cannot compress objects.jsonl: Error: Failed to lock DB file "F:\ioBrokerTest\iobroker-data\objects.jsonl"!
                                                at async main (C:\Users\OnkelAdmin\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:93:17)
                                            No relevant JSONL files found to compress, skip
                                            Hilft das irgendwie weiter?
                                            31.7k
                                            79.8k
                                            84
                                            5506
