    4. Node-Red
    5. TR064 - PROBLEME
    TR064 - PROBLEME
      chris877 last edited by
      Er schaltet immer auf grün für 1 sek und dann wieder auf rot. ich weis einfach nicht mehr weiter..
        Jan1 @chris877 last edited by
        @chris877
        da gibts ne überführte Version in die Community, nimm die
        C spicer 2 Replies Last reply Reply Quote 0
          $ ./iobroker upgrade tr-064
          Update tr-064 from @0.1.12 to @0.4.14
          NPM version: 6.9.0
          npm install iobroker.tr-064@0.4.14 --production --save --prefix "/opt/iobroker" (System call)
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-extnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/sprintf-js
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef
          npm
          ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-extnpm ERR! code EACCES
          npm ERR! errno -13npm ERR! syscall access
          npm
          ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext']
          npm ERR! stack:
          npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'',
          npm ERR! errno: -13,npm ERR! code: 'EACCES',
          npm ERR! syscall: 'access',
          npm ERR! path:
          npm ERR! '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext' }
          npm ERR! npm ERR! The operation was rejected by your operating system.
          npm ERR! It is likely you do not have the permissions to access this file as the current user
          npm ERR!
          npm ERR! If you believe this might be a permissions issue, please double-check the
          npm ERR! permissions of the file and its containing directories, or try running
          npm ERR! the command again as root/Administrator (though this is not recommended).
          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-06-04T07_59_42_178Z-debug.log
          ERROR: host.raspberrypi Cannot install iobroker.tr-064@0.4.14: 243
          ERROR: process exited with code 25
          Diese Meldung bekomm ich wenn ich den adapter Updaten möchte auf dem web inter. http://ip:8081
            chris877 @Jan1 last edited by
            @Jan1 wie genau meinst du das?
            bin leider noch nicht so fit in dem thema...
              @chris877
              https://github.com/iobroker-community-adapters/ioBroker.tr-064-community
              das über IOBroker Github (Katze oben, dann bei beliebig einfügen) installieren.
              C siggi85 2 Replies Last reply Reply Quote 1
                @Jan1 Vielen Dank!
                Jetzt leuft es wieder !
                gruss
                • siggi85
                  siggi85 @Jan1 last edited by
                  @Jan1 Hatt heute auch Probleme mit meinem TR064, konnte diese aber lösen.
                  Bin jetzt aber auf diese Community Version gestoßen. Kann mir jemand sagen, was es damit auf sich hat? Sollte ich auch umschwenken, auch wenn meine noch läuft? Und wenn es die "recommended" version ist, warum wird sie nicht ins stable Repo aufgenommen?
                  • Jey Cee
                    Jey Cee Developer @siggi85 last edited by
                    @siggi85 sagte in TR064 - PROBLEME:
                    So lange du keine Probleme hast bleib bei der alten.
                    Die originale wird nicht mehr gepflegt. Aktuell bedarf es noch vieler Korrekturen und deswegen gib es noch keine neue Stable Version. Langfristig wird die community Version die alte ersetzen.
                    siggi85 1 Reply Last reply Reply Quote 0
                    • siggi85
                      siggi85 @Jey Cee last edited by
                      @Jey-Cee Danke für die Info und die schnelle Antwort!! So werde ich das machen. 🙂
                      • spicer
                        spicer @Jan1 last edited by spicer
                        @Jan1 Habe genau dieses Problem jetzt.
                        Wie installiere ich die "überführte" Version?
                        Die Kommunikation scheint aber zu laufen!
                        (kann leider keinen Printscreen posten)
                          Thomas Braun Most Active @spicer last edited by
                          @spicer
                          iob update
                          sagt?
                          spicer 1 Reply Last reply Reply Quote 0
                          • spicer
                            spicer @Thomas Braun last edited by spicer
                            [code]
                            pi@raspberrypi:~ $ iob update
                            Used repository: stable
                            Adapter    "admin"        : 6.3.3    , installed 6.3.3
                            Adapter    "backitup"     : 2.5.9    , installed 2.5.9
                            Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                            Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                            Adapter    "flot"         : 1.11.0   , installed 1.11.0
                            Adapter    "history"      : 2.2.0    , installed 2.2.0
                            Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                            Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
                            Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
                            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                            [/code]
                              Thomas Braun Most Active @spicer last edited by Thomas Braun
                              @spicer
                              Bitte in CodeTags setzen.
                              4.2.16 ist die aktuelle stabile Version. Wenn du ein Problem hast, dann ein anderes als das hier in diesem uralt Thread behandelte.
                              • spicer
                                komme mit eurem forum nicht klar.
                                xenforo ist da viel einfacher! (ist auch mein forum)
                                keine bbCodes...siehst Du?
                                  @spicer
                                  Dann schau dir an, wie man damit umgeht.
                                    @spicer
                                    Die bbcodes heißen hier halt für Code CodeTags. So what? Sind drei Back Ticks. Oder das entsprechende Icon. </>
                                    • spicer
                                      hab das gelöscht 😉
                                        @spicer
                                        Dann lass es halt.
                                          Homoran Global Moderator Administrators @spicer last edited by
                                          @spicer sagte in TR064 - PROBLEME:
                                          und nicht mit exotischer syntax rumpröbeln.
                                          ist erstens nicht exotisch sondern verbreitetes Markdown.
                                          und zweitens gibt es dafür einen Button.
                                          • spicer
                                            ok
                                            4766
