    4. Test Adapter micronova easy connect plus
      Kusi @tombox last edited by
      @tombox Achso, ich verstehe es langsam.
      Mich würde sehr interessieren, wie man einen solchen Adapter erstellt...
        picky @Kusi last edited by picky
        @kusi said in Test Adapter micronova easy connect plus:
        @picky
        Hast du folgenden Log-Eintrag auch?
        micronova.0
        2022-12-01 18:53:19.628	info	receive 401 error. Refresh Token in 30 seconds
        Die Fehlermeldungen hatte ich nur als ich parallel die App benutzt habe.
        Das Log zeigt mir im Augenblick nur an im Debug Modus.
        micronova.0
        3085	2022-12-02 08:40:17.908	debug	{"Success":true,"Text":"DEVICE_JOB_STATUS_OK","jobRequestStatus":"completed","jobAnswerStatus":"completed","jobAnswerPayload":{"id":1669966804755,"jid":"C8C9A3C50204","pl":{"BufferId":1,"cmd":"GetBufferReading"},"type":"node"},"jobAnswerData":{"BufferId":1,"Items":[32894,33,33017,32893,6,52,33016,1,33020,32798,33021,32823,232,32795,33018,33019,2,32845,32895,51],"Values":[0,9,16,44,0,8,5,37,18,1,34,20,8,20,37,2,0,1,3,16],"cmd":"GetBufferReading"}}
        micronova.0
        3085	2022-12-02 08:40:17.774	debug	Waiting for response
        micronova.0
        3085	2022-12-02 08:40:04.772	debug	{"Success":true,"Text":"DEVICE_ENQUEUE_MESSAGE_OK","idRequest":"4576f259-607a-4a2d-9e31-e95b560fc32d"}
        micronova.0
        3085	2022-12-02 08:36:17.948	debug	{"Success":true,"Text":"DEVICE_JOB_STATUS_OK","jobRequestStatus":"completed","jobAnswerStatus":"completed","jobAnswerPayload":{"id":1669966564797,"jid":"C8C9A3C50204","pl":{"BufferId":1,"cmd":"GetBufferReading"},"type":"node"},"jobAnswerData":{"BufferId":1,"Items":[32894,33,33017,32893,6,52,33016,1,33020,32798,33021,32823,232,32795,33018,33019,2,32845,32895,51],"Values":[51,9,16,44,0,8,5,37,18,1,34,20,8,20,33,2,0,1,3,16],"cmd":"GetBufferReading"}}
        micronova.0
        3085	2022-12-02 08:36:17.816	debug	Waiting for response
        micronova.0
        3085	2022-12-02 08:36:04.814	debug	{"Success":true,"Text":"DEVICE_ENQUEUE_MESSAGE_OK","idRequest":"ec0e9b50-4523-490b-8f31-f6e8f1625451"}
          Kusi @tombox last edited by Kusi
          @tombox
          Über Nacht kein einziger Logeintrag.
          Um 06.55 Uhr wurde der Pelletofen von einem Skript gestartet (gut so).
          Seit 10.50 Uhr erscheinen wiederkehrende Log-Einträge, fortlaufend bis jetzt...
          micronova.0
          2022-12-02 10:52:07.377	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
          micronova.0
          2022-12-02 10:50:37.956	info	Login successful
          micronova.0
          2022-12-02 10:50:07.404	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
          micronova.0
          2022-12-02 10:32:07.741	info	Login successful
          micronova.0
          2022-12-02 06:56:02.191	info	Update devices
          Habe nun die Instanz neu gestartet, der Fehler bleibt allerdings.
          micronova.0
          2022-12-02 11:15:31.101	info	Login successful
          micronova.0
          2022-12-02 11:15:00.533	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
          micronova.0
          2022-12-02 11:11:31.077	info	Login successful
          micronova.0
          2022-12-02 11:11:00.515	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
          micronova.0
          2022-12-02 11:08:47.111	info	Found 1 devices
          micronova.0
          2022-12-02 11:08:47.016	info	Login successful
          micronova.0
          2022-12-02 11:08:46.339	info	Login to Easy Connect Plus
          micronova.0
          2022-12-02 11:08:46.273	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.micronova#173e3f3601ff0ca61c776329702007e75e45703e) in /opt/iobroker/node_modules/iobroker.micronova, node: v16.18.1, js-controller: 4.0.23
          Das Skript (Blockly) hat soeben den Pelletofen ausgeschaltet, was einwandfrei funktioniert. Auch die Rückmeldung (Values02) funktioniert einwandfrei, trotz Log-Meldungen.
          micronova.0
          2022-12-02 12:59:31.108	info	Login successful
          micronova.0
          2022-12-02 12:59:00.537	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
          micronova.0
          2022-12-02 12:57:32.425	info	Update devices
          micronova.0
          2022-12-02 12:57:22.424	info	{"Success":true,"Text":"DEVICE_ENQUEUE_MESSAGE_OK","idRequest":"fb17950d-d7a8-4d3a-a9b7-1a9dfac03694"}
          micronova.0
          2022-12-02 12:57:22.338	info	Send data: {"id_product":"B99F243F-CD0B-4D25-BE52-19D193F685F1","id_device":"AF217968-77DC-420C-9D55-7521B6D67497","Protocol":"RWMSmaster","BitData":[8],"Endianess":["L"],"Items":[232],"Masks":[65535],"Values":[170]}
          micronova.0
          2022-12-02 12:55:31.096	info	Login successful
          micronova.0
          2022-12-02 12:55:00.533	info	receive 401 error. Refresh Token in 30 seconds. Please select other operation system to avoid logouts
          micronova.0
          2022-12-02 12:51:31.150	info	Login successful
          P K 2 Replies Last reply Reply Quote 0
            @kusi Mit der neuen Version, logt er sich immer aus, aber scheinbar keine Fehler.
            micronova.0
            3348	2022-12-02 11:54:08.987	info	Login successful
            micronova.0
            3348	2022-12-02 11:53:38.393	info	Adapter is logged out. Relogin in 30seconds.
            micronova.0
            3348	2022-12-02 11:50:31.241	info	Update devices
            micronova.0
            3348	2022-12-02 11:50:21.237	info	{"Success":true,"Text":"DEVICE_ENQUEUE_MESSAGE_OK","idRequest":"30cf0532-9138-495c-9c95-ef6d1dd47d54"}
            micronova.0
            3348	2022-12-02 11:50:21.087	info	Send data: {"id_product":"C13DA328-6288-4931-A6B0-878F53417223","id_device":"D35FD861-42D2-4C5B-92AA-EDB0E3A2D53B","Protocol":"RWMSmaster","BitData":[8],"Endianess":["L"],"Items":[232],"Masks":[65535],"Values":[170]}
            micronova.0
            3348	2022-12-02 11:50:09.138	info	Login successful
            micronova.0
            3348	2022-12-02 11:49:38.394	info	Adapter is logged out. Relogin in 30seconds.
            micronova.0
            3348	2022-12-02 11:46:09.034	info	Login successful
            micronova.0
            3348	2022-12-02 11:45:38.432	info	Adapter is logged out. Relogin in 30seconds.
            micronova.0
            3348	2022-12-02 11:42:09.077	info	Login successful
            micronova.0
            3348	2022-12-02 11:41:38.407	info	Adapter is logged out. Relogin in 30seconds.
            micronova.0
            3348	2022-12-02 11:37:24.710	info	Found 1 devices
            micronova.0
            3348	2022-12-02 11:37:24.558	info	Login successful
            micronova.0
            3348	2022-12-02 11:37:23.835	info	Login to Easy Connect Plus
            micronova.0
            3348	2022-12-02 11:37:23.790	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.micronova#7f72c1f4bba2109671773d2caae11a7b9a3e12b4) in /opt/iobroker/node_modules/iobroker.micronova, node: v16.18.1, js-controller: 4.0.23
            Was mir aber aufgefallen ist, wenn ich die Relogzeit von 4 auf 2 Minuten runter setze, bekomme ich auch Errors, also der Relog darf nicht zu schnell sein.
            micronova.0
            1081	2022-12-02 11:35:32.315	error	{"Success":false,"Error":"1106","Text":"UNAUTHORIZED"}
            micronova.0
            1081	2022-12-02 11:35:32.313	error	AxiosError: Request failed with status code 401
            micronova.0
            1081	2022-12-02 11:33:49.814	info	Login successful
            micronova.0
            1081	2022-12-02 11:33:19.220	info	Adapter is logged out. Relogin in 30seconds.
            micronova.0
            1081	2022-12-02 11:31:32.298	error	{"Success":false,"Error":"1106","Text":"UNAUTHORIZED"}
            micronova.0
            1081	2022-12-02 11:31:32.297	error	AxiosError: Request failed with status code 401
            micronova.0
            1081	2022-12-02 11:29:49.770	info	Login successful
              Kusi @picky last edited by Kusi
              @picky Ich habe das Aktualisierungsintervall auf 2 Minuten. Komisch dass die Log-Meldungen erst Stunden später kommen...
              Error-Meldungen habe ich zur Zeit keine.
                @kusi Habe von Android auf "IOS ECP" umgestellt, und scheint damit stabiler zu laufen bei mir, Loggt sich bis jetzt nicht mehr aus.
                  @picky @tombox
                  Zur Info:
                  Der Datenpunkt "micronova.0.*.status.Values19" ist die Heizleistung.
                  Steuern/Ändern lässt sich diese mit dem Befehl "32895,x" (x ersetzen mit der Heizstufe).
                    Kusi @Kusi last edited by Kusi
                    @tombox Seit heute habe ich ein komisches Verhalten...
                    Sämtliche Values haben den gleichen Wert.
                    Gestrige Änderungen waren lediglich die Adapter-Updates von "Admin" und "backitup".
                    Ich habe den Admin-Adapter auf die Version 6.2.23 zurückgespielt, dies ergab jedoch keine Änderung.
                    Hast du @tombox eine Idee?
                    Edit: Fehler gefunden!
                    Der Ofen/ioBroker ist 120 km von mir entfernt, ich mache lediglich die Wartung. Der Pelletofen wurde vom Strom genommen, da die darunterliegende Glasplatte kaputt ist.
                    Warum aber die Micronova-Cloud nun solche Werte liefert, ist merkwürdig.
                    Werde die Micronova-Instanz stoppen, bis der Ofen wieder in Betrieb geht.
                      toralt last edited by
                      @tombox besteht da irgendwie die Möglichkeit LaNordica/Extraflame mit der Total Control App ebenfalls zu integrieren. Ich versuche schon die ganze Zeit verzweifelt meinen Pelletofen via homebridge irgendwie zum laufen zu bekommen. Aber dafür benötige ich wohl einen customer code, den mir der Hersteller nicht zur Verfügung stellt. Da Extraflame ebenfalls via agua IoT kommuniziert, müsste Dein Adapter ja eigentlich auch mit diesem kommunizieren können, oder?
                        tombox @toralt last edited by
                        @toralt
                        total control app ist Komplett was anderes
                        Total Control 2.0
                        https://appapi.extraflame.it/stoves
                        Total Control
                        https://totalcontrol.extraflame.it/api/stove-list.jsp?token=3B4DC8AA
                        T P 2 Replies Last reply Reply Quote 0
                          toralt @tombox last edited by
                          @tombox Ich dachte Dein micronova Adapter nutzt ebenfalls die agua iot Schnittstelle. Basierend auf https://github.com/fredericvl/py-agua-iot
                          Hatte gehofft, wenn dort endlich der customer code hinterlegt wäre, dass das dann automatisch in Deinem Adapter auch integriert wäre.
                            @toralt Nutz er aber Total Control nutz nicht agua man müsste ein eignen adapter schreiben
                              @tombox Total Control 2.0 (Sorry für das Missverständis, meine App ist die total control 2.0) greift auf https://extraflame.agua-iot.com zu. Ich habe an meinem Ofen ebenfalls eine Micronova Navel 2.0
                              Aber so lange mir der Customer Code nicht bekannt ist, nutzt das alles so oder so nichts. Aber Danke für die Info.
                                Semmy @toralt last edited by
                                Hallo
                                Also die Register für Gebläse und Flamme habe ich gefunden (32894 und 32895) Gebläse ist bei Value 49 zu finden, aber Value für Flamme (32895) kann ich nicht finden. Wie und wo kann man das denn am besten finden?
                                Viele Grüße
                                Semmy
                                  Patrick 1 @tombox last edited by Patrick 1
                                  Total Control
                                  Hallo, Gibt es irgendwo eine komplette Liste der API Komandos?
                                  Da keine Antwort, habe ich ein wenig herumexperimentiert.
                                  Ich kann bis jetzt, aufzeichnen, wenn was zum Offen gesendet wird.
                                  Nur sind meine programmier Kenntnisse veraltet (eingerostet).
                                  Nun, hier, was ich bis jetzt herausgefunden hab.
                                  Habe den wifi adapter (weißes etikett) geöfnet.
                                  Und fand 3 pins beim ESP32.
                                  GND ist gezeichnet musste nur rx und tx finden.
                                  Also in meinem fall jetzt ( Blau = GND Orange = RX Gelb = TX )
                                  Ihr braucht einen 3,3v usb2uart.
                                  Hier nochmals die pins.
                                  Dann mit putty, serial port des usb2uart, baudrate 115200 verbinden,
                                  und hier ist das log.
                                  extraflame.txt
                                  Das ist der stand bis jetzt.
                                  Github:
                                  https://github.com/jeng37/Total-Control-app-to-HA/
                                    majawe @Patrick 1 last edited by
                                    @patrick-1 hey bist du hier weiter gekommen? Würde auch gerne mein Ofen streuen können….
                                    31.7k
                                    79.8k
                                    5223
