    3. Off Topic
    4. Proxmox
    5. Proxmox VM mit IOBroker OWServer
      Laser @Thomas Braun last edited by Laser
      OWServer deinstalliert und als Normalbenutzer wieder installiert. Exakt das gleiche Fehlverhalten. (Zumindest für mich)
      otto@debian11:~$ sudo systemctl restart owserver
      Job for owserver.service failed because the service did not take the steps required by its unit configuration.
      See "systemctl status owserver.service" and "journalctl -xe" for details.
      otto@debian11:~$ ^C
      otto@debian11:~$ systemctl status owserver.service
      ● owserver.service - Backend server for 1-wire control
           Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor pres>
           Active: failed (Result: protocol) since Sat 2022-12-17 14:48:28 CET; 10s a>
      TriggeredBy: ● owserver.socket
             Docs: man:owserver(1)
          Process: 642 ExecStart=/usr/bin/owserver --foreground -c /etc/owfs.conf (co>
         Main PID: 642 (code=exited, status=0/SUCCESS)
              CPU: 19ms
        Thomas Braun Most Active @Laser last edited by
        @laser
        Da fehlt rechts Output.
        Und was steht im journal?
          Output fehlt? kann man nicht nach rechts scrollen?
          Dez 17 14:48:28 debian11 systemd[1]: Stopped Backend server for 1-wire control.
          ░░ Subject: A stop job for unit owserver.service has finished
          ░░ Defined-By: systemd
          ░░ Support: https://www.debian.org/support
          ░░ A stop job for unit owserver.service has finished.
          ░░ The job identifier is 1064 and the job result is done.
          Dez 17 14:48:28 debian11 systemd[1]: owserver.service: Start request repeated t>
          Dez 17 14:48:28 debian11 systemd[1]: owserver.service: Failed with result 'prot>
          ░░ Subject: Unit failed
          ░░ The unit owserver.service has entered the 'failed' state with result 'protoc>
          Dez 17 14:48:28 debian11 systemd[1]: Failed to start Backend server for 1-wire >
          ░░ Subject: A start job for unit owserver.service has failed
          ░░ A start job for unit owserver.service has finished with a failure.
          ░░ The job identifier is 1064 and the job result is failed.
            @laser
            Siehst du nicht das es da am Ende Text fehlt?
            Da kann ich scrollen wie ich will, du musst dein Terminal breiter ziehen.
              OK, Terminal so breit gezogen, dass Alles reinpasst
                   Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled)
                   Active: failed (Result: protocol) since Sat 2022-12-17 14:48:28 CET; 8min ago
                  Process: 642 ExecStart=/usr/bin/owserver --foreground -c /etc/owfs.conf (code=exited, status=0/SUCCESS)
                      CPU: 19ms
                @laser sagte in Proxmox VM mit IOBroker OWServer:
                owserver.service
                Hab das gerade mal bei mir installiert. Läuft auf Anhieb.
                sudo apt update
                apt policy owserver
                sagt?
                  otto@debian11:~$ sudo apt update
                  OK:1 http://deb.debian.org/debian bullseye InRelease
                  OK:2 http://security.debian.org/debian-security bullseye-security InRelease
                  OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                  OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Paketlisten werden gelesen… Fertig
                  Abhängigkeitsbaum wird aufgebaut… Fertig
                  Statusinformationen werden eingelesen… Fertig
                  Alle Pakete sind aktuell.
                  otto@debian11:~$ apt policy owserver
                  owserver:
                    Installiert:           3.2p4+dfsg1-4+b1
                    Installationskandidat: 3.2p4+dfsg1-4+b1
                    Versionstabelle:
                   *** 3.2p4+dfsg1-4+b1 500
                          500 http://deb.debian.org/debian bullseye/main amd64 Packages
                          100 /var/lib/dpkg/status
                    @laser
                    ls -la /etc/systemd/system/multi-user.target.wants/owserver.service
                    ls -la /etc/systemd/system/sockets.target.wants/owserver.socket
                      otto@debian11:~$ ls -la /etc/systemd/system/multi-user.target.wants/owserver.service
                      lrwxrwxrwx 1 root root 36 17. Dez 12:30 /etc/systemd/system/multi-user.target.wants/owserver.service -> /lib/systemd/                                           system/owserver.service
                      otto@debian11:~$ ls -la /etc/systemd/system/sockets.target.wants/owserver.socket
                      lrwxrwxrwx 1 root root 35 17. Dez 12:30 /etc/systemd/system/sockets.target.wants/owserver.socket -> /lib/systemd/syst                                           em/owserver.socket
                        Thomas Braun Most Active @Laser last edited by Thomas Braun
                        @laser
                        ls -la /usr/bin/owserver
                          otto@debian11:~$ ls -la /usr/bin/owserver
                          -rwxr-xr-x 1 root root 43288  8. Nov 2020  /usr/bin/owserver
                            @laser
                            Und was steht in der
                            /etc/owfs.conf
                            drin? Da wird ja die Hardware konfiguriert. Hast du da was geändert?
                              muß erst mal sehen, wie ich das Alles hier rein bekomme...
                              otto@debian11:/etc$ nano owfs.conf
                                GNU nano 5.4                                         owfs.conf
                              ######################### OWFS ##########################
                              #mountpoint = /mnt/1wire
                              #allow_other
                              ####################### OWHTTPD #########################
                              http: port = 2121
                              ####################### OWFTPD ##########################
                              ftp: port = 2120
                              ####################### OWSERVER ########################
                              server: port = 192.168.2.103:4304
                              #server: port = 192.0.0.1:4304
                                @laser
                                Meine default-Datei schaut ganz anders aus:
                                ######################## SOURCES ########################
                                # With this setup, any client (but owserver) uses owserver on the
                                # local machine...
                                ! server: server = localhost:4304
                                # ...and owserver uses the real hardware, by default fake devices
                                # This part must be changed on real installation
                                server: FAKE = DS18S20,DS2405
                                # USB device: DS9490
                                #server: usb = all
                                # Serial port: DS9097
                                #server: device = /dev/ttyS1
                                # owserver tcp address
                                #server: server = 192.168.10.1:3131
                                # random simulated device
                                #server: FAKE = DS18S20,DS2405
                                #allow_other
                                http: port = 2121
                                ftp: port = 2120
                                server: port = localhost:4304
                                  OK, oben der Teil ist bei mir abgeschnitten. Mit server: port = "localhost"
                                  habe ich probiert. Ging nie. Mit realer Ip- Adresse: funktionierte. Beim RAspberry Pi.
                                  Jetzt so probiert, wie es angezeigt wird. funktioniert auch nicht.
                                  otto@debian11:/etc$ cat owfs.conf
                                  # Sample configuration file for the OWFS suite for Debian GNU/Linux.
                                  # This is the main OWFS configuration file. You should read the
                                  # owfs.conf(5) manual page in order to understand the options listed
                                  # here.
                                  # local machine...
                                  server: usb = all
                                  #allow_other
                                  http: port = 2121
                                  ftp: port = 2120
                                    @laser
                                    Dann musst du dir wohl die Anleitung dazu durchlesen und für deine Situation passend umsetzen:
                                    You should read the owfs.conf(5) manual page in order to understand the options listed here.
                                    man owfs.conf
                                      OK. Mache ich. Der Fehler liegt zu 99 % in der owfs.conf? OWFS muß ja auch ohne IOBroker erst mal funktionieren.
                                        @laser
                                        Ich würde sagen, da steht was falsches drin.
                                          habe die funktionierende OWFS.conf vom Raspi und die nicht funktionierende der VM mit CAT dargestellt und im Editor eingefügt. Nebeneinander gestellt.
                                          Ausser, dass ich natürlich die Adresse des Rechners anpassen muß, finde ich, ist Alles gleich. Für mich. Nun ist das schon lange her, daß ich den Pi konfiguriert habe. Ganz weit entfernt: Zu Schluß mußte ich das Ganze als root ausführen und ganz unten die echte Adresse des Rechners angeben.
                                          Aber Ehrlich- warum es zum Schluss funktionierte, weiß ich nicht sicher!
                                            Laser @Laser last edited by
                                            @Ich werde nochmal bei Null anfangen. Mit Debian neu als VM installieren.
                                            81.1k
                                            14823
