Test Adapter Midea Dimstal Klimaanlagen v0.0.x
super das update war es.@tombox weißt ob jemand an die Integration von der AC Freedom app arbeitet ?
leider kommt alle 5 Minuten im Log der fehler
2022-10-06 17:28:17.602 error *** PY *** Python Error Call to 'appliance_state' failed: > appliance_state = await this.midea_beautiful.appliance_state$({ at Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:156:29) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.midea/main.js:226:9) ... across the bridge ... > six.raise_from(e, None) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:445) at raise_from (<string>:3) > httplib_response = conn.getresponse() at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:440) > response.begin() at getresponse (/usr/lib/python3.9/http/client.py:1347) > version, status, reason = self._read_status() at begin (/usr/lib/python3.9/http/client.py:307) > line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1") at _read_status (/usr/lib/python3.9/http/client.py:268) > return self._sock.recv_into(b) at readinto (/usr/lib/python3.9/socket.py:704) > return self.read(nbytes, buffer) at recv_into (/usr/lib/python3.9/ssl.py:1241) > return self._sslobj.read(len, buffer) at read (/usr/lib/python3.9/ssl.py:1099) > resp = conn.urlopen( at send (/usr/lib/python3/dist-packages/requests/adapters.py:439) > retries = retries.increment( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:755) > raise six.reraise(type(error), error, _stacktrace) at increment (/usr/lib/python3/dist-packages/urllib3/util/retry.py:532) > raise value at reraise (/usr/lib/python3/dist-packages/six.py:719) > httplib_response = self._make_request( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:699) > self._raise_timeout(err=e, url=url, timeout_value=read_timeout) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:447) > raise ReadTimeoutError( at _raise_timeout (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:336) > response = requests.post( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:273) > return request('post', url, data=data, json=json, **kwargs) at post (/usr/lib/python3/dist-packages/requests/api.py:119) > return session.request(method=method, url=url, **kwargs) at request (/usr/lib/python3/dist-packages/requests/api.py:61) > resp = self.send(prep, **send_kwargs) at request (/usr/lib/python3/dist-packages/requests/sessions.py:542) > r = adapter.send(request, **kwargs) at send (/usr/lib/python3/dist-packages/requests/sessions.py:655) > raise ReadTimeout(e, request=request) at send (/usr/lib/python3/dist-packages/requests/adapters.py:529) > appliance.identify(cloud, use_cloud) at appliance_state (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:1046) > self.refresh(cloud if use_cloud else None) at identify (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:831) > responses = self._status(cmd, cloud) at refresh (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:381) > responses = cloud.appliance_transparent_send(self.appliance_id, data) at _status (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:538) > response = self.api_request( at appliance_transparent_send (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:526) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > self._retry_check(endpoint, cause) at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:335) > raise CloudRequestError( at _retry_check (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:350) *** JS *** midea_beautiful.exceptions.CloudRequestError: Too many retries while calling /v1/appliance/transparent/send, last error HTTPSConnectionPool(host='mapp.appsmb.com', port=443): Read timed out. (read timeout=2) midea.0 2022-10-06 17:28:17.601 error ErrorDie Datenpunkte werden jetzt zwar angezeigt aber die Klima reagiert nicht drauf.
Setz das bitte in CodeTags.
Habe ich erledigt oder doch lieber ein Screenshot? -
@marc9025 Ist das bei allen apps die du in den Einstellungen auswählen kannst
@tombox
wie meinst du das ?
alles andern apps funktionieren ganz normal -
@marc9025 du kannst in den adapter Einstellungen verschiedene apps auswählen
Meine neue Dimstal / Midea AC lässt sich mit dem Adapter nicht steuern.
Datenpunkte werden angelegt, die angezeigten Werte passen auch, sobald ich aber die Anlage steuern will, passiert nichts.
Hier z.B. Powerstate von "false" -> "true"2022-10-14 09:06:53.480 - debug: midea.0 (3198) Command: {"data":[170,30,172,0,0,0,0,0,3,2,64,67,138,20,127,127,0,63,0,0,0,0,0,0,0,0,0,0,0,156]} 2022-10-14 09:06:53.481 - debug: midea.0 (3198) Command + Header: [90,90,1,16,90,0,32,0,1,0,0,0,189,179,57,14,12,5,20,20,29,129,0,0,0,16,0,0,0,4,2,0,0,1,0,0,0,0,0,0,170,30,172,0,0,0,0,0,3,2,64,67,138,20,127,127,0,63,0,0,0,0,0,0,0,0,0,0,0,156,55,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0] 2022-10-14 09:07:03.080 - debug: midea.0 (3198) {"errorCode":"3176","msg":"The asyn reply does not exist ","result":null}- Adapter version: 0.0.7
 - JS-Controller version: 4.0.23
 - Node version: v16.14.2
 - Operating system: Ubuntu 18.04.6 LTS
@raducanu: gleiches Problem hier. Auch auf git kommen keine Reaktionen mehr, keine Ahnung ob am Adapter noch etwas gemacht wird.
Habe leider ebenfalls ein Problem mit dem Adapter. Habe mir letzte Woche den Comfee Luftentfeuchter 20L/24h MDDF-20DEN7-WF gekauft. Steuerung über NetHome Plus App (klappt einwandfrei und zuverlässig).
Heute ioBroker Midea Adapter ausprobiert. Login scheint einwandfrei zu klappen nachdem ich meine Daten eingegeben habe (ich vermute der erste Loginfehler-Eintrag aus den Logs kommt nach der Installation des Adapter bevor man seine Daten eingibt?). Danach kommen allerdings dann eine von Warnungen im Log.
Der Adapter wird unter Objekte angelegt und er erkennt dass ich eine Klimaanlage registriert habe.
Allerdings werden lediglich unter unter "general" ein paar Daten angelegt.
Im wichtigen Teil unter Status bleiben die meisten Datenpunkte leider auf null.
Ich vermute der Adapter kennt den Gerätetyp nicht und legt deswegen keine spezifischen Werte an?!
Wird der Adapter noch weiterentwickelt wo man ggf. helfen kann das Gerät einzupflegen?
Oder haben andere ähnliche Schwierigkeiten und das ist kein Problem meines spezifischen Geräts? -
@sushbone Also ich nutze für dieses Geräte den "HAM Adapter" im Wrapper Modus mit dem Plugin "homebridge-midea-air@1.7.0".
Da gab es vor kurzen ein Update für dieses Plugin und mit diesen funktioniert es wunderbar.Die Einstellungen im Plugin sind dann folgende:
"platform": "midea-air"
"supportedSwingMode": "None",
"temperatureSteps": 1,
"minTemp": 17,
"maxTemp": 30,
"fanOnlyMode": false,
"OutdoorTemperature": false,
"useFahrenheit": false,
"audibleFeedback": false,
"deviceId": "AUS DER NEThome APP NEHMEN, ziemlich lange Nummer" -
@draexler
Wie komme ich an den Adapter? Und wie installiere ich ihn…?
Habe ihn nicht gefunden
Bzw das Plugin homebrige-midea-air
Finde nichts in der RichtungSo versucht zu installieren … bekomme aber den Fehlern komme nicht weiter…
Kann mir jemand helfen?ERROR: Process exited with code 25 weniger mehr $ iobroker url https://github.com/hillaliy/homebridge-midea-air --host IoBroker-Admin-5 --debug install hillaliy/homebridge-midea-air#294aca018fb817ad6d49907486fa39c3bc0a598f Installing hillaliy/homebridge-midea-air#294aca018fb817ad6d49907486fa39c3bc0a598f... (System call) npm ERR! notsup Not compatible with your version of node/npm: homebridge-midea-air@1.6.5npm ERR! notsup Not compatible with your version of node/npm: homebridge-midea-air@1.6.5npm ERR! notsup Required: {"node":">=16.0.0","homebridge":">=1.5.0"}npm ERR! notsup Actual: {"npm":"6.14.16","node":"14.19.1"} npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-12-18T12_47_19_910Z-debug.log host.IoBroker-Admin-5 Cannot install hillaliy/homebridge-midea-air#294aca018fb817ad6d49907486fa39c3bc0a598f: 1 ERROR: Process exited with code 25 -
Dein nodejs ist zu alt. Update auf Version 16.
Ist eh die empfohlene Version für den ioBroker. -
@jens-meyer thomas hat ja schon geschrieben… aber ganz wichtig…. die 1.7.0 installieren. Du kannst über die Instanzeinstellung ein Plugin hinzufügen „name@version“-> also die Versionsnummer mit einem @ hinter dem Namen.
Ah ok, danke da werde ich mal auf 16 updaten.. -
@draexler
Hab ich noch nie gemacht..
In der Konsole oder wie funktioniert das mit dem Plugin und Version Nummer -
@jens-meyer Ganz einfach, du gibst einfach in der Instanzeinstellung hier:
homebridge-midea-air@1.7.0 ein.
Dann installiert er auch diese Version.
Die restlichen Angaben kannst du dann hier machen:
habe genau das gleiche Problem,
habe bei Instance HAM - Schlüsselsymbol - Haupteinstellungen
NPMmodul hinzufügen "homebridge-midea-air" eingetragen und Häckchen beim nächsten Start aktualisieren, Polling intervall 5 Sek (keine Ahnung){
"user": "MIDEA_ACCOUNT_EMAIL",
"password": "MIDEA_PASSWORD",
"registeredApp": "NetHomePlus",
"interval": 30,
"devices": [
"deviceId": "DeviceID-1",
"supportedSwingMode": "Both",
"minTemp": 17,
"maxTemp": 30,
"deviceId": "DeviceID-2",
"minTemp": 17,
"maxTemp": 30,
Dazu noch die Konfigurationsdatei erstellt mit meinen Daten, aber unter Objekte kommen keine neuen Datenpunkte.
Über die Konsole kommt beim Versuch immer eine Fehlermeldung.
Vermutlich versuche am falschen Ort zu installieren. -
@tom10web sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
Eine geheime? Dann sei vorsichtig!
Streng geheim , heut zutage muss man vorsichtig sein....
Hab 5 Minuten zu früh gepostet, bin jetzt schlauer, ist installiert
ob´s funktioniert ? erst mal Elfmeter schießen.
