    3. Entwicklung
    4. Adapter: Worx Landroid v2.x.x
    • Meistertr
      @bku:
      Hallo MeisterTR,
      leider bekomme ich die Version 0.3.0 nicht installiert, mache ich was falsch?
      instance system.adapter.vis.0 terminated while should be started once
      vis.0	2017-08-07 19:45:51.251	info	vis license is OK.
      vis.0	2017-08-07 19:45:51.012	info	starting. Version 0.15.5 in /opt/iobroker/node_modules/iobroker.vis, node: v4.8.0
      host.DiskStation	2017-08-07 19:45:50.246	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      iobroker	2017-08-07 19:45:50.032	info	exit 0
      iobroker	2017-08-07 19:45:49.953	info	upload [0] landroid-s /opt/iobroker/node_modules/iobroker.landroid-s/www/README.md README.md text/x-markdown
      iobroker	2017-08-07 19:45:49.896	info	upload [1] landroid-s /opt/iobroker/node_modules/iobroker.landroid-s/www/index.html index.html text/html
      iobroker	2017-08-07 19:45:49.875	info	Adapter "system.adapter.vis.0" restarted.got /opt/iobroker/node_modules/iobroker.landroid-s/www
      host.DiskStation	2017-08-07 19:45:49.849	info	"system.adapter.vis.0" enabled
      host.DiskStation	2017-08-07 19:45:49.848	info	object change system.adapter.vis.0
      host.DiskStation	2017-08-07 19:45:49.830	info	"system.adapter.vis.0" disabled
      host.DiskStation	2017-08-07 19:45:49.830	info	object change system.adapter.vis.0
      iobroker	2017-08-07 19:45:49.717	info	upload [0] landroid-s.admin /opt/iobroker/node_modules/iobroker.landroid-s/admin/index.html index.html text/html
      iobroker	2017-08-07 19:45:49.646	info	upload [1] landroid-s.admin /opt/iobroker/node_modules/iobroker.landroid-s/admin/landroid-s.png landroid-s.png image/png
      iobroker	2017-08-07 19:45:49.554	info	upload [2] landroid-s.admin /opt/iobroker/node_modules/iobroker.landroid-s/admin/words.js words.js application/javascript
      iobroker	2017-08-07 19:45:49.528	info	got /opt/iobroker/node_modules/iobroker.landroid-s/admin
      iobroker	2017-08-07 19:45:49.197	info	└── mqtt@1.3.5 (inherits@2.0.3, xtend@4.0.1, minimist@1.2.0, commist@1.0.0, readable-stream@1.0.34, end-of-stream@1.4.0, mqtt-connection@2.1.1, mqtt-packet@3.4.8, help-me@0.1.0, concat-stream@1.6.0, w
      iobroker	2017-08-07 19:45:49.197	info	├── aws-iot-device-sdk@2.0.1 (minimist@1.2.0, crypto-js@3.1.6, websocket-stream@3.3.3, mqtt@2.2.1)
      iobroker	2017-08-07 19:45:49.197	info	├── najax@1.0.3 (lodash.defaultsdeep@4.6.0, jquery-deferred@0.3.1, qs@6.5.0)
      iobroker	2017-08-07 19:45:49.197	info	├── pem@1.9.7 (os-tmpdir@1.0.2, which@1.3.0)
      iobroker	2017-08-07 19:45:49.197	info	iobroker.landroid-s@0.3.0 iobroker/node_modules/iobroker.landroid-s├── uuid@3.1.0
      iobroker	2017-08-07 19:45:40.098	info	WARN optional dep failed, continuing bufferutil@1.1.0
      iobroker	2017-08-07 19:45:40.095	info	npm
      iobroker	2017-08-07 19:45:40.093	info	WARN optional dep failed, continuing utf-8-validate@1.1.0
      iobroker	2017-08-07 19:45:40.092	info
      iobroker	2017-08-07 19:45:40.087	info	npm
      iobroker	2017-08-07 19:45:40.073	info	gyp ERR! not ok
      iobroker	2017-08-07 19:45:40.073	info	gyp ERR! node-gyp -v v3.4.0
      iobroker	2017-08-07 19:45:40.073	info	ERR! cwd /opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutilgyp ERR! node -v v4.8.0
      iobroker	2017-08-07 19:45:40.069	info	gyp
      iobroker	2017-08-07 19:45:40.069	info	gyp ERR! System Linux 3.10.102gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      iobroker	2017-08-07 19:45:40.068	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      iobroker	2017-08-07 19:45:40.067	info	gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      iobroker	2017-08-07 19:45:40.067	info	gyp ERR! stack at emitTwo (events.js:87:13)
      iobroker	2017-08-07 19:45:40.067	info	gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      iobroker	2017-08-07 19:45:40.062	info	gyp ERR! build error
      iobroker	2017-08-07 19:45:40.061	info	make: Leaving directory '/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/build'make: *** [Release/obj.target/buf
      iobroker	2017-08-07 19:45:40.059	info	bufferutil.target.mk:98: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
      iobroker	2017-08-07 19:45:39.833	info	^
      iobroker	2017-08-07 19:45:39.833	info	return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
      iobroker	2017-08-07 19:45:39.833	info	../node_modules/nan/nan.h:683:12: error: 'Use' is not a member of 'node::Buffer'
      iobroker	2017-08-07 19:45:39.833	info	../node_modules/nan/nan.h: In function 'v8::Local NanBufferUse(char*, uint32_t)':
      iobroker	2017-08-07 19:45:39.833	info	return node::Buffer::New(v8::Isolate::GetCurrent(), size);
      iobroker	2017-08-07 19:45:39.833	info	../node_modules/nan/nan.h:676:61: error: could not convert 'node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))' from 'v8::MaybeLocal' to 'v8::Local'
      iobroker	2017-08-07 19:45:39.833	info	In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(uint32_t)':
      iobroker	2017-08-07 19:45:39.832	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/.node-gyp/4.8.0/include/node/node_buffer.h:46:40: note: no know
      iobroker	2017-08-07 19:45:39.832	info	^
      iobroker	2017-08-07 19:45:39.832	info	NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
      iobroker	2017-08-07 19:45:39.832	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/.node-gyp/4.8.0/include/node/node_buffer.h:46:40: note: v8::Maybe
      iobroker	2017-08-07 19:45:39.832	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/.node-gyp/4.8.0/include/node/node_buffer.h:34:40: note: no know
      iobroker	2017-08-07 19:45:39.832	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/.node-gyp/4.8.0/include/node/node_buffer.h:34:40: note: v8::Maybe
      iobroker	2017-08-07 19:45:39.832	info	In file included from ../src/bufferutil.cc:10:0:
      iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h:672:67: note: candidates are:
      iobroker	2017-08-07 19:45:39.832	info	return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
      iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h:672:67: error: call of overloaded 'New(v8::Isolate*, const char*&, uint32_t&)' is ambiguous
      iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(const char*, uint32_t)':
      iobroker	2017-08-07 19:45:39.832	info	v8::Isolate::GetCurrent(), data, length, callback, hint);
      iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h:665:60: error: 'hint' was not declared in this scope
      iobroker	2017-08-07 19:45:39.832	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(char*, size_t, int)':../node_modules/nan/nan.h:665:50: error: 'callback' was not declared in this scope
      iobroker	2017-08-07 19:45:39.831	info	^
      iobroker	2017-08-07 19:45:39.831	info	, node::smalloc::FreeCallback callback
      iobroker	2017-08-07 19:45:39.831	info	../node_modules/nan/nan.h:661:35: error: expected ',' or '...' before 'callback'
      iobroker	2017-08-07 19:45:39.831	info	../node_modules/nan/nan.h:661:13: error: 'node::smalloc' has not been declared , node::smalloc::FreeCallback callback
      iobroker	2017-08-07 19:45:39.814	info	^
      iobroker	2017-08-07 19:45:39.814	info	../node_modules/nan/nan.h:256:25: note: 'template v8::Local _NanEnsureLocal(v8::Handle)' previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
      iobroker	2017-08-07 19:45:39.813	info	^
      iobroker	2017-08-07 19:45:39.813	info	NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
      iobroker	2017-08-07 19:45:39.813	info	In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:261:25: error: redefinition of 'template v8::Local _NanEnsureLocal(v8::Local)'
      iobroker	2017-08-07 19:45:39.047	info	CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
      iobroker	2017-08-07 19:45:39.043	info	make: Entering directory '/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil/build'
      iobroker	2017-08-07 19:45:36.893	info	WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/4.8.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker
      iobroker	2017-08-07 19:45:36.891	info
      iobroker	2017-08-07 19:45:36.888	info	gyp
      iobroker	2017-08-07 19:45:35.817	info	> node-gyp rebuild
      iobroker	2017-08-07 19:45:35.817	info	> bufferutil@1.1.0 install /opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/bufferutil
      iobroker	2017-08-07 19:45:35.804	info	gyp ERR! not ok
      iobroker	2017-08-07 19:45:35.804	info	ERR! node -v v4.8.0gyp ERR! node-gyp -v v3.4.0
      iobroker	2017-08-07 19:45:35.801	info	gyp
      iobroker	2017-08-07 19:45:35.801	info	gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_module
      iobroker	2017-08-07 19:45:35.799	info	gyp ERR! System Linux 3.10.102
      iobroker	2017-08-07 19:45:35.798	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      iobroker	2017-08-07 19:45:35.798	info	gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      iobroker	2017-08-07 19:45:35.798	info	gyp ERR! stack at emitTwo (events.js:87:13)
      iobroker	2017-08-07 19:45:35.798	info	ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      iobroker	2017-08-07 19:45:35.797	info	gyp
      iobroker	2017-08-07 19:45:35.786	info	gyp ERR! build error
      iobroker	2017-08-07 19:45:35.785	info	make: Leaving directory '/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/build'make: *** [Release/obj.target
      iobroker	2017-08-07 19:45:35.784	info	validation.target.mk:98: recipe for target 'Release/obj.target/validation/src/validation.o' failed
      iobroker	2017-08-07 19:45:35.626	info	^
      iobroker	2017-08-07 19:45:35.626	info	return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
      iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:683:12: error: 'Use' is not a member of 'node::Buffer'
      iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h: In function 'v8::Local NanBufferUse(char*, uint32_t)':
      iobroker	2017-08-07 19:45:35.626	info	return node::Buffer::New(v8::Isolate::GetCurrent(), size);
      iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:676:61: error: could not convert 'node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))' from 'v8::MaybeLocal' to 'v8::Local'
      iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(uint32_t)':
      iobroker	2017-08-07 19:45:35.626	info	In file included from ../src/validation.cc:15:0:
      iobroker	2017-08-07 19:45:35.626	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/.node-gyp/4.8.0/include/node/node_buffer.h:46:40: note: no
      iobroker	2017-08-07 19:45:35.626	info	NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
      iobroker	2017-08-07 19:45:35.626	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/.node-gyp/4.8.0/include/node/node_buffer.h:46:40: note: v8::M
      iobroker	2017-08-07 19:45:35.626	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/.node-gyp/4.8.0/include/node/node_buffer.h:34:40: note: no
      iobroker	2017-08-07 19:45:35.626	info	/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/.node-gyp/4.8.0/include/node/node_buffer.h:34:40: note: v8::M
      iobroker	2017-08-07 19:45:35.626	info	In file included from ../src/validation.cc:10:0:
      iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:672:67: note: candidates are:
      iobroker	2017-08-07 19:45:35.626	info	return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
      iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:672:67: error: call of overloaded 'New(v8::Isolate*, const char*&, uint32_t&)' is ambiguous
      iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(const char*, uint32_t)':
      iobroker	2017-08-07 19:45:35.626	info	v8::Isolate::GetCurrent(), data, length, callback, hint);
      iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h:665:60: error: 'hint' was not declared in this scope
      iobroker	2017-08-07 19:45:35.626	info	../node_modules/nan/nan.h: In function 'v8::Local NanNewBufferHandle(char*, size_t, int)':../node_modules/nan/nan.h:665:50: error: 'callback' was not declared in this scope
      iobroker	2017-08-07 19:45:35.625	info	^
      iobroker	2017-08-07 19:45:35.625	info	, node::smalloc::FreeCallback callback
      iobroker	2017-08-07 19:45:35.625	info	../node_modules/nan/nan.h:661:35: error: expected ',' or '...' before 'callback'
      iobroker	2017-08-07 19:45:35.625	info	../node_modules/nan/nan.h:661:13: error: 'node::smalloc' has not been declared , node::smalloc::FreeCallback callback
      iobroker	2017-08-07 19:45:35.610	info	^
      iobroker	2017-08-07 19:45:35.610	info	../node_modules/nan/nan.h:256:25: note: 'template v8::Local _NanEnsureLocal(v8::Handle)' previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
      iobroker	2017-08-07 19:45:35.609	info	^
      iobroker	2017-08-07 19:45:35.609	info	NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
      iobroker	2017-08-07 19:45:35.609	info	In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:261:25: error: redefinition of 'template v8::Local _NanEnsureLocal(v8::Local)'
      iobroker	2017-08-07 19:45:34.855	info	CXX(target) Release/obj.target/validation/src/validation.o
      iobroker	2017-08-07 19:45:34.852	info	make: Entering directory '/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate/build'
      iobroker	2017-08-07 19:45:32.228	info	WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate
      iobroker	2017-08-07 19:45:32.226	info	WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/4.8.0"gyp
      iobroker	2017-08-07 19:45:32.222	info	gyp
      iobroker	2017-08-07 19:45:31.056	info	> node-gyp rebuild
      iobroker	2017-08-07 19:45:31.056	info	> utf-8-validate@1.1.0 install /opt/iobroker/node_modules/iobroker.landroid-s/node_modules/mqtt/node_modules/websocket-stream/node_modules/ws/node_modules/utf-8-validate
      iobroker	2017-08-07 19:45:18.710	info	npm install https://github.com/MeisterTR/iobroker.landroid-s/tarball/master --production --prefix "/opt/iobroker" (System call)
      iobroker	2017-08-07 19:45:18.501	info	install https://github.com/MeisterTR/iobroker.landroid-s/tarball/master
      javascript.0	2017-08-07 19:45:18.415	info	script.js.bku.Info.StromDverbrauch: --> Solar: 246 Zähler: 167 VB-akt: 79 VB-avg: 135
      iobroker	2017-08-07 19:45:17.820	info	url "https://github.com/MeisterTR/iobroker.landroid-s" --debug
      Danke und Gruß,
      Bernd `
      Bist du sich dass sie nicht inslalliert ist? der Log sagt was anderes. dass da ein paar fehlermeldungen kommen ist "normal" aber installirt sollte er eigentlich sein.
        Stoni last edited by
        Changelog im Vergleich zur 0.25?
        Gesendet von meinem ONEPLUS A3003 mit Tapatalk
        • lobomau
          lobomau last edited by
          @Stoni:
          Gesendet von meinem ONEPLUS A3003 mit Tapatalk Steht doch auf github: > 0.3.0 (05.08.2017)
          (MeisterTR) add rawData `
          Für Normaluser wie mich wohl eher nicht so wichtig.
          • Meistertr
            Viele Kleinigkeiten, Testmodis entfernt Und die Rohdaten und senden als Objekt hinzugefügt zur schnellen Weiterverarbeitung in Scripten (ins besondere Mahlzeiten ändern für vis so kann man die Daten leicht aus den Rohdaten ziehen anstatt alle Datenpunkte abzuarbeiten).
            Gesendet von meinem Handy
            • lobomau
              Adapter ist wieder verbunden nachdem ich die Handy-App ausprobiert habe.
              Der Adapter hat sich um 11:20 Uhr abgemeldet und verbindet sich seitdem nicht mehr. Habe nichts gemacht. Ich schwör 🙂
              Über Handy-App verbinden funktioniert.
              landroid-s.0	2017-08-08 11:54:07.369	info	Connected to MQTT broker - subscribing to DB510/MAC-Adresse/commandOut
              landroid-s.0	2017-08-08 11:54:06.911	info	Connecting to MQTT broker
              landroid-s.0	2017-08-08 11:54:06.750	info	Fetching root CA
              landroid-s.0	2017-08-08 11:54:06.672	info	Certificate retrieved
              landroid-s.0	2017-08-08 11:54:06.361	info	API token set to token2
              landroid-s.0	2017-08-08 11:54:06.360	info	Logged in as email@gmail.com - user token retrieved from API
              landroid-s.0	2017-08-08 11:54:05.845	info	API token set to token1
              landroid-s.0	2017-08-08 11:54:05.843	info	Downloaded guest token
              landroid-s.0	2017-08-08 11:54:05.623	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.2
              landroid-s.0	2017-08-08 11:53:58.696	info	terminating
              landroid-s.0	2017-08-08 11:53:58.677	info	cleaned everything up...
              landroid-s.0	2017-08-08 11:53:28.716	info	Connected to MQTT broker - subscribing to DB510/MAC-Adresse/commandOut
              landroid-s.0	2017-08-08 11:53:28.246	info	Connecting to MQTT broker
              landroid-s.0	2017-08-08 11:53:27.606	info	Fetching root CA
              landroid-s.0	2017-08-08 11:53:27.548	info	Certificate retrieved
              landroid-s.0	2017-08-08 11:53:27.197	info	API token set to token2
              landroid-s.0	2017-08-08 11:53:27.196	info	Logged in as email@gmail.com - user token retrieved from API
              landroid-s.0	2017-08-08 11:53:26.666	info	API token set to token1
              landroid-s.0	2017-08-08 11:53:26.662	info	Downloaded guest token
              landroid-s.0	2017-08-08 11:53:26.071	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.2
              landroid-s.0	2017-08-08 11:53:22.218	info	terminating
              landroid-s.0	2017-08-08 11:53:22.205	info	cleaned everything up...
              landroid-s.0	2017-08-08 11:20:49.699	info	Disconnect from mower
              landroid-s.0	2017-08-08 10:40:06.797	info	Connected to mower
              landroid-s.0	2017-08-08 10:39:49.474	info	Disconnect from mower
              hab nur paar Daten verfremdet, wie email, token und mac-adresse
              • Meistertr
                @lobomau:
                hab nur paar Daten verfremdet, wie email, token und mac-adresse ` Und nun geht's wieder? Bei mir ist es anders herum. Wenn der Adapter verbunden ist, bekomme ich nur manchmal Verbindung zur App. Welche fw hast du drauf?
                • lobomau
                  Ja, geht wieder. Kurz nach 12 Uhr war es weiterhin etwas unruhig… der Adapter hatte paar Mal die Verbindung verloren, aber nach 1s wieder verbunden.
                  Ich kann immer auch gleichzeitig per App drauf zu greifen.
                  FW ist 2.75.. war mit 2.59 auch so.
                    Sebastian last edited by
                    Schau mal hier:
                    https://github.com/MeisterTR/iobroker.l … /README.md
                    0.3.0 (05.08.2017)
                    Sebastian
                      Stefan1984 last edited by
                      Etwas Offtopic:
                      Kann mir jemand sagen, wie ich die Variablen in die CCU bekomme? Ich möchte gern die Gartenbewässerung erst schalten, wenn der Mäher in der Station steht. Rasi ist zwar gerade in der Reparatur, aber das heißt ja nicht, dass ich untätig sein muss. [emoji6] Cux ist installiert. Über eine kurze Anleitung wäre ich dankbar.
                      Scripte sind leider nicht so meins.
                      Vielen Dank im Voraus.
                      Grüße,
                      Stefan
                      • lobomau
                        Ja, ist etwas offtopic.
                        Hast du den hm-rega-Adapter installiert? Damit siehst du alle Variablen der CCU und kannst diese schalten. Musst nur die Variablen in der CCU anlegen. Das Programm für die Gartenbewässerung läuft wahrscheinlich schon auf der CCU, ansonsten kannst du ja ein Programm in ioBroker machen. Ist auch schwieriger, ich finde sogar einfacher als mit homematic.
                        CuxD brauchst du nicht, um die Variablen der CCU zu sehen/steuern.
                        Edit: um ein kleines Programm in ioB kommst du ja nicht drumherum, welches die Variable in der CCU schaltet.
                        Edit2: hier wurde das Thema behandelt:
                        http://forum.iobroker.net/viewtopic.php … ble#p78274
                          Die Bewässerung steuere ich normal über Homematic Schaltaktor. Entsprechende Programme sind in der CCU hinterlegt. Generell habe ich alle Programme in der CCU. Ich würde gern vermeiden, dass ich die Programme mal hier und mal da habe. Den Rega hab ich installiert, da bekomme ich alle Variablen in io.Broker angezeigt. Aber eigentlich möchte ich es gern anders herum. Ist das auch ohne weiteres möglich?
                            MeraLuna last edited by
                            Hi Zusammen erstmal super cool der Adapter und Läuft genial, mit IoBroker befasse ich mich noch nicht so lange erst 1 Woche ca. also Neuer Neuling.
                            mein Tab was ich zur Steuerung benutze sieht so aus wie auf dem Bild unten, ich würde jedoch gern noch einbauen was er gerade macht also ob Tornado lädt fährt oder Warnmeldungen Stecke fest, das heist die States im Grunde das schaffe ich aber nur zur Ausgabe als zahl nicht der betreffende Text also z.b 7 was heist das er Fährt usw.
                            geht das mit wingets ? oder mus ich das mit nen Skript umwandeln also 0 heist das usw. ?
                            LG Luna
                              Mighty last edited by
                              Habe jetzt auf die neuste Version geupdated. Dazu den alten Adapter gelöscht und neu installiert. Dabei gehen alle History Einstellungen verloren.
                              Geht das auch einfacher?
                              Grüße Mighty
                              ps kleiner Schreibfehler:
                              landroid-s.0.areas.actualAreaIndecator -> landroid-s.0.areas.actualAreaIndicator
                              • Meistertr
                                @Mighty:
                                Grüße Mighty
                                landroid-s.0.areas.actualAreaIndecator -> landroid-s.0.areas.actualAreaIndicator ` Ja seit 0.2.0 waren die Grundelemente alle enthalten und seit dem brauchst du nur updaten ohne löschen.
                                • Meistertr
                                  Hab den Schreibfehler geändert, nach update einfach den state mit dem Schreibfehler in den Objekten löschen.
                                    Danke, hat geklappt.
                                    Grüße Mighty
                                      Strizz last edited by
                                      Ich sehe gerade, dass mein "Otto" bereits über 150.000 km gefahren sein soll. Die Betriebszeit liegt bei ca. 9.000 Stunden. Da gibt es wohl einen Fehler bei den Dimensionen. Das müssten wohl Meter und Minuten sein. Oder?
                                      Strizz
                                      • Meistertr
                                        @Strizz:
                                        Strizz `
                                        wenn du in der config Meter und min einen haken gesetzt hast, sind es m und min. ich suche noch eine elegante Lösung die Einheiten zu ändern ohne das Object komplett neu an zu legen
                                          @Meistertr:
                                          @Strizz:
                                          Strizz wenn du in der config Meter und min einen haken gesetzt hast, sind es m und min. ich suche noch eine elegante Lösung die Einheiten zu ändern ohne das Object komplett neu an zu legen
                                          Hallo MeisterTr,
                                          danke für den Hinweis. Hatte ich übersehen. Wenn sich mit dem Häkchen auch die Dimensionen ändern würden, wäre es ja perfekt. Aber 150.000 km ist eben falsch.
                                          Noch eine Frage: Ich hatte mit der Installation des Adapters meiner Erinnerung nach ein Object 'area'. Das ist plötzlich verschwunden. Habe ich da auch einen Haken falsch gesetzt oder kommt das wieder, wenn ich die Zonen eingerichtet habe?
                                          Strizz
                                          Gesendet von iPad mit Tapatalk Pro
                                          • Meistertr
                                            @Strizz:
                                            @Meistertr:
                                            @Strizz:
                                            Hallo MeisterTr,
                                            Noch eine Frage: Ich hatte mit der Installation des Adapters meiner Erinnerung nach ein Object 'area'. Das ist plötzlich verschwunden. Habe ich da auch einen Haken falsch gesetzt oder kommt das wieder, wenn ich die Zonen eingerichtet habe? `
                                            Bei der aktuellen Version sehen die Objete aus wie auf dem Bild. einen Object was area hieß hat es nicht gegeben.
                                            1194
                                            452030
