    5. solved: 3x Ausführung im Log - schaltet aber gar nicht
      Homoran Global Moderator Administrators @ch90045 last edited by
      @ch90045 sagte in 3x Ausführung im Log - schaltet aber gar nicht:
      @homoran Habe ich schon lange
      kannst du bitte den Post mit dem Output davon verlinken?
      ich finde ihn nicht.
      ch90045 1 Reply Last reply Reply Quote 0
      • ch90045
        ch90045 @Homoran last edited by
        @homoran Here we go:
        setState("deconz.0.Lights.19.on"/*Küchen Boiler on*/, true);
        console.log('Schalte Boiler an');
        //JTNDeG1sJTIweG1sbnMlM0QlMjJodHRwcyUzQSUyRiUyRmRldmVsb3BlcnMuZ29vZ2xlLmNvbSUyRmJsb2NrbHklMkZ4bWwlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb250cm9sJTIyJTIwaWQlM0QlMjJpMy0lNjBjOCUyQyU1Qmg4U0MlN0RkJTIzNXpMdlAlMjIlMjB4JTNEJTIyNTg4JTIyJTIweSUzRCUyMjE4OCUyMiUzRSUzQ211dGF0aW9uJTIweG1sbnMlM0QlMjJodHRwJTNBJTJGJTJGd3d3LnczLm9yZyUyRjE5OTklMkZ4aHRtbCUyMiUyMGRlbGF5X2lucHV0JTNEJTIyZmFsc2UlMjIlM0UlM0MlMkZtdXRhdGlvbiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMk9JRCUyMiUzRWRlY29uei4wLkxpZ2h0cy4xOS5vbiUzQyUyRmZpZWxkJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyV0lUSF9ERUxBWSUyMiUzRUZBTFNFJTNDJTJGZmllbGQlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJWQUxVRSUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmxvZ2ljX2Jvb2xlYW4lMjIlMjBpZCUzRCUyMl8lMjNLSSU3Ql9tSn4zJTdCT3BIWWlneXVNJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyQk9PTCUyMiUzRVRSVUUlM0MlMkZmaWVsZCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0NuZXh0JTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyZGVidWclMjIlMjBpZCUzRCUyMkslMkJaKCl0VGRVcFE4N0E3OCU2MHZXMyUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMlNldmVyaXR5JTIyJTNFbG9nJTNDJTJGZmllbGQlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJURVhUJTIyJTNFJTNDc2hhZG93JTIwdHlwZSUzRCUyMnRleHQlMjIlMjBpZCUzRCUyMkxYWjVvNDd2Q1pGdUVMbVUlMkNwQy4lMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJURVhUJTIyJTNFU2NoYWx0ZSUyMEJvaWxlciUyMGFuJTNDJTJGZmllbGQlM0UlM0MlMkZzaGFkb3clM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGeG1sJTNF
        Vor Auslösung:
          "type": "state",
          "common": {
            "name": "Küchen Boiler on",
            "type": "boolean",
            "role": "switch",
            "read": true,
            "write": true
          "native": {},
          "from": "system.adapter.deconz.0",
          "user": "system.user.admin",
          "ts": 1659936853320,
          "_id": "deconz.0.Lights.19.on",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.iwona",
        Danach
          "type": "state",
          "common": {
            "type": "boolean",
            "role": "switch",
            "read": true,
            "write": true
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636,
        Und ja, der Boiler ist an und war vorher aus. Es gab auch nur einen Logeintrag
          @ch90045 echt strange!
          da würde ich jetzt wirklich die Kiste rebooten
            paul53 @ch90045 last edited by paul53
            @ch90045 sagte: Danach
            Das statische Datenpunkt-Objekt ändert sich nicht durch "steuere".
            @ch90045 sagte: der Boiler ist an und war vorher aus. Es gab auch nur einen Logeintrag
            Dann schalte den Boiler aus und packe die beiden Blöcke in einen Zeitplan, der in Kürze triggert.
            • ch90045
              ch90045 @paul53 last edited by
              Läuft, aber war ja auch mit den anderen jobs im orginal Blockly der Fall - neu ist, dass nur ein Logeintrag auftaucht 😄
                @ch90045 root user.?
                warum?
                  @ch90045 sagte: neu ist, dass nur ein Logeintrag auftaucht
                  Das hat sicherlich der Neustart von ioBroker bewirkt. Das Skript wird nun wahrscheinlich auch um 6:00 Uhr funktionieren.
                  • ch90045
                    @homoran warum nicht?
                      weil das die Rechte verbiegen kann, dass der Systemuser iobroker Probleme bekommt.
                      Bitte als normaler user einloggen und dann
                      iobroker stop
                      iobroker fix
                      iobroker start
                      nacheinander ausführen um die Rechte wieder zu fixen.
                      • ch90045
                        @homoran auf dem System gibt es keinen anderen user
                        • BananaJoe
                          BananaJoe Most Active last edited by
                          Öhm, wenn er Debug-Einträge aus dem Blockly-Skript hat ist auch der Debug Modus im Editor an.
                          Wie dann da schon irgendwo als Meldung steht schaltet er im Debug Modus nicht wirklich sondern schreibt nur.
                          Also, ist der Debug Modus an? Wenn ja => ausschalten und dann sollte es auch gehen.
                          ch90045 Homoran 2 Replies Last reply Reply Quote 0
                          • ch90045
                            ch90045 @BananaJoe last edited by
                            @bananajoe was soll gehen? Drei croneinträge im gleichen blockly gehen nur einer nicht, alle haben den gleichen Debug Haken.
                              dann leg einen an
                                Homoran Global Moderator Administrators @BananaJoe last edited by Homoran
                                @bananajoe sagte in 3x Ausführung im Log - schaltet aber gar nicht:
                                wieso?
                                wenn der debug Block auf debug gestellt wäre, landet es im log auch als debug.
                                Aber wo siehst du das?
                                • BananaJoe
                                  BananaJoe Most Active @ch90045 last edited by
                                  @ch90045 ok, ich hab die bisherigen Post nicht genau genug gelesen und interpretiert das keiner von denen geht
                                    Wildbill @ch90045 last edited by
                                    Da sollte man aber wissen, dass man sich niemals als root anmeldet und immer mit einem normalen User, der bei Bedarf erweiterte Rechte bekommt, wenn das hier stimmt:
                                    @paul53 Paul, ICH weiss das 😉 Ich arbeite seit 1999 mit Solaris/Linux
                                    Gruss, Jürgen
                                    • BananaJoe
                                      BananaJoe Most Active @Homoran last edited by
                                      @homoran sagte in 3x Ausführung im Log - schaltet aber gar nicht:
                                      wieso?
                                      Ich habe mich total verguckt, war am Thema vorbei was ich geschrieben hatte
                                      • ch90045
                                        ch90045 @Wildbill last edited by
                                        @wildbill Ich bin mir durchaus bewusst, was der root user ist und ich habe mich bewusst für den root user entschieden. Das system ist nur in meinem LAN erreichbar und nur ich komme auf das System - ich sehe die Problematik nicht.
                                        Bei einem Multiuser Systems wäre ich mit dem user root vorsichtiger - hier sehe ich keine Notwendigkeit.
                                          Wildbill @ch90045 last edited by Wildbill
                                          @ch90045 Dann hast Du die ganzen Jahre aber nicht verstanden, worum es geht. Es geht nicht nur um das Thema Sicherheit (oder erst in zweiter Instanz) sondern einfach darum in welchem User-Kontext was läuft. Iobroker ist mittlerweile seit geraumer Zeit darauf ausgelegt, als user iobroker in ganz normalem User-Kontext zu laufen. Bei Bedarf holt sich dieser User (unter Linux) per sudo erweiterte Berechtigungen. Wenn Du da jetzt als root angemeldet bist und so beispielsweise iobroker administrierst oder Ordner oder Dateien anlegst, oder einen Adapter installierst, so übernehmen die neuen Dateien logischerweise die Berechtigungen von root. Dass Dir das dann irgendwann auf die Füße fällt, wenn der user iobroker darauf keinen Zugriff erhält, weil die Dateien eben root gehören, sollte nach so vielen Jahren Erfahrung offensichtlich sein. Zum Thema Sicherheit muss ich nichts sagen, root darf so gut wie alles, und damit natürlich auch alle Skripte und Programme, die in seinem Umfeld gestartet werden. Von obigem mal angesehen würde ich so ein System definitiv nicht in irgendein Netzwerk hängen, schon gar nicht mit möglicher Verbindung ins Internet. Das sollte "einem Profi" auch klar sein.
                                          Also entweder flunkerst Du mit der jahrzehntelangen Erfahrung mit Solaris/Linux, wurdest da ursprünglich von Jemandem ausgebildet, der so absolut keine Ahnung hatte und nie was dazugelernt, oder ignorierst mit purer Absicht alles, was von Anfang an als best practice gilt.
                                          Sei es, wie es ist, wer sich als root anmeldet, nicht versteht, warum das eine ganz schlechte Idee ist, der hat es nicht verstanden und verdient es vermutlich, früher oder später auf diverse Probleme zu stoßen.
                                          Wer sich bewusst dazu entschieden hat, der hat irgendwo irgendwas gewaltig missverstanden!
                                          Gruss, Jürgen
                                          • ch90045
                                            @wildbill Erkläre mir mal bitte, wie root den Zugriff auf Objekte verlieren sollen, die root gehören ...
                                            Ob du in der Position bist, über meinen beruflichen Werdegang von 1999-2011 bei Sun Microsystems und danach bei NetApp im technischen Support urteilen kannst, überlasse ich dir selber, habe aber meine eigene Meinung drüber. Danke für deinen Input "offtopic" zu dem Orginalthema.
                                            3753
