Adapter: Worx Landroid v2.x.x
Adapter ist wieder verbunden nachdem ich die Handy-App ausprobiert habe.
Der Adapter hat sich um 11:20 Uhr abgemeldet und verbindet sich seitdem nicht mehr. Habe nichts gemacht. Ich schwör
Über Handy-App verbinden funktioniert.
landroid-s.0 2017-08-08 11:54:07.369 info Connected to MQTT broker - subscribing to DB510/MAC-Adresse/commandOut landroid-s.0 2017-08-08 11:54:06.911 info Connecting to MQTT broker landroid-s.0 2017-08-08 11:54:06.750 info Fetching root CA landroid-s.0 2017-08-08 11:54:06.672 info Certificate retrieved landroid-s.0 2017-08-08 11:54:06.361 info API token set to token2 landroid-s.0 2017-08-08 11:54:06.360 info Logged in as email@gmail.com - user token retrieved from API landroid-s.0 2017-08-08 11:54:05.845 info API token set to token1 landroid-s.0 2017-08-08 11:54:05.843 info Downloaded guest token landroid-s.0 2017-08-08 11:54:05.623 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.2 landroid-s.0 2017-08-08 11:53:58.696 info terminating landroid-s.0 2017-08-08 11:53:58.677 info cleaned everything up... landroid-s.0 2017-08-08 11:53:28.716 info Connected to MQTT broker - subscribing to DB510/MAC-Adresse/commandOut landroid-s.0 2017-08-08 11:53:28.246 info Connecting to MQTT broker landroid-s.0 2017-08-08 11:53:27.606 info Fetching root CA landroid-s.0 2017-08-08 11:53:27.548 info Certificate retrieved landroid-s.0 2017-08-08 11:53:27.197 info API token set to token2 landroid-s.0 2017-08-08 11:53:27.196 info Logged in as email@gmail.com - user token retrieved from API landroid-s.0 2017-08-08 11:53:26.666 info API token set to token1 landroid-s.0 2017-08-08 11:53:26.662 info Downloaded guest token landroid-s.0 2017-08-08 11:53:26.071 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.2 landroid-s.0 2017-08-08 11:53:22.218 info terminating landroid-s.0 2017-08-08 11:53:22.205 info cleaned everything up... landroid-s.0 2017-08-08 11:20:49.699 info Disconnect from mower landroid-s.0 2017-08-08 10:40:06.797 info Connected to mower landroid-s.0 2017-08-08 10:39:49.474 info Disconnect from mowerhab nur paar Daten verfremdet, wie email, token und mac-adresse
landroid-s.0 2017-08-08 11:54:07.369 info Connected to MQTT broker - subscribing to DB510/MAC-Adresse/commandOut landroid-s.0 2017-08-08 11:54:06.911 info Connecting to MQTT broker landroid-s.0 2017-08-08 11:54:06.750 info Fetching root CA landroid-s.0 2017-08-08 11:54:06.672 info Certificate retrieved landroid-s.0 2017-08-08 11:54:06.361 info API token set to token2 landroid-s.0 2017-08-08 11:54:06.360 info Logged in as email@gmail.com - user token retrieved from API landroid-s.0 2017-08-08 11:54:05.845 info API token set to token1 landroid-s.0 2017-08-08 11:54:05.843 info Downloaded guest token landroid-s.0 2017-08-08 11:54:05.623 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.2 landroid-s.0 2017-08-08 11:53:58.696 info terminating landroid-s.0 2017-08-08 11:53:58.677 info cleaned everything up... landroid-s.0 2017-08-08 11:53:28.716 info Connected to MQTT broker - subscribing to DB510/MAC-Adresse/commandOut landroid-s.0 2017-08-08 11:53:28.246 info Connecting to MQTT broker landroid-s.0 2017-08-08 11:53:27.606 info Fetching root CA landroid-s.0 2017-08-08 11:53:27.548 info Certificate retrieved landroid-s.0 2017-08-08 11:53:27.197 info API token set to token2 landroid-s.0 2017-08-08 11:53:27.196 info Logged in as email@gmail.com - user token retrieved from API landroid-s.0 2017-08-08 11:53:26.666 info API token set to token1 landroid-s.0 2017-08-08 11:53:26.662 info Downloaded guest token landroid-s.0 2017-08-08 11:53:26.071 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.2 landroid-s.0 2017-08-08 11:53:22.218 info terminating landroid-s.0 2017-08-08 11:53:22.205 info cleaned everything up... landroid-s.0 2017-08-08 11:20:49.699 info Disconnect from mower landroid-s.0 2017-08-08 10:40:06.797 info Connected to mower landroid-s.0 2017-08-08 10:39:49.474 info Disconnect from mowerhab nur paar Daten verfremdet, wie email, token und mac-adresse ` Und nun geht's wieder? Bei mir ist es anders herum. Wenn der Adapter verbunden ist, bekomme ich nur manchmal Verbindung zur App. Welche fw hast du drauf?
Gesendet von meinem Handy
Ja, geht wieder. Kurz nach 12 Uhr war es weiterhin etwas unruhig… der Adapter hatte paar Mal die Verbindung verloren, aber nach 1s wieder verbunden.
Ich kann immer auch gleichzeitig per App drauf zu greifen.
FW ist 2.75.. war mit 2.59 auch so.
Schau mal hier:
https://github.com/MeisterTR/iobroker.l … /README.md
0.3.0 (05.08.2017)
(MeisterTR) add rawData
Sebastian
Etwas Offtopic:
Kann mir jemand sagen, wie ich die Variablen in die CCU bekomme? Ich möchte gern die Gartenbewässerung erst schalten, wenn der Mäher in der Station steht. Rasi ist zwar gerade in der Reparatur, aber das heißt ja nicht, dass ich untätig sein muss. [emoji6] Cux ist installiert. Über eine kurze Anleitung wäre ich dankbar.
Scripte sind leider nicht so meins.
Vielen Dank im Voraus.
Grüße,
Stefan
Ja, ist etwas offtopic.
Hast du den hm-rega-Adapter installiert? Damit siehst du alle Variablen der CCU und kannst diese schalten. Musst nur die Variablen in der CCU anlegen. Das Programm für die Gartenbewässerung läuft wahrscheinlich schon auf der CCU, ansonsten kannst du ja ein Programm in ioBroker machen. Ist auch schwieriger, ich finde sogar einfacher als mit homematic.
CuxD brauchst du nicht, um die Variablen der CCU zu sehen/steuern.
Edit: um ein kleines Programm in ioB kommst du ja nicht drumherum, welches die Variable in der CCU schaltet.
Edit2: hier wurde das Thema behandelt:
Die Bewässerung steuere ich normal über Homematic Schaltaktor. Entsprechende Programme sind in der CCU hinterlegt. Generell habe ich alle Programme in der CCU. Ich würde gern vermeiden, dass ich die Programme mal hier und mal da habe. Den Rega hab ich installiert, da bekomme ich alle Variablen in io.Broker angezeigt. Aber eigentlich möchte ich es gern anders herum. Ist das auch ohne weiteres möglich?
Hi Zusammen erstmal super cool der Adapter und Läuft genial, mit IoBroker befasse ich mich noch nicht so lange erst 1 Woche ca. also Neuer Neuling.
mein Tab was ich zur Steuerung benutze sieht so aus wie auf dem Bild unten, ich würde jedoch gern noch einbauen was er gerade macht also ob Tornado lädt fährt oder Warnmeldungen Stecke fest, das heist die States im Grunde das schaffe ich aber nur zur Ausgabe als zahl nicht der betreffende Text also z.b 7 was heist das er Fährt usw.
geht das mit wingets ? oder mus ich das mit nen Skript umwandeln also 0 heist das usw. ?
LG Luna
3254_monitor.jpg -
Habe jetzt auf die neuste Version geupdated. Dazu den alten Adapter gelöscht und neu installiert. Dabei gehen alle History Einstellungen verloren.
Geht das auch einfacher?
Grüße Mighty
ps kleiner Schreibfehler:
landroid-s.0.areas.actualAreaIndecator -> landroid-s.0.areas.actualAreaIndicator
Grüße Mighty
landroid-s.0.areas.actualAreaIndecator -> landroid-s.0.areas.actualAreaIndicator ` Ja seit 0.2.0 waren die Grundelemente alle enthalten und seit dem brauchst du nur updaten ohne löschen.
Hab den Schreibfehler geändert, nach update einfach den state mit dem Schreibfehler in den Objekten löschen.
Danke, hat geklappt.
Grüße Mighty
Ich sehe gerade, dass mein "Otto" bereits über 150.000 km gefahren sein soll. Die Betriebszeit liegt bei ca. 9.000 Stunden. Da gibt es wohl einen Fehler bei den Dimensionen. Das müssten wohl Meter und Minuten sein. Oder?
Strizz
Strizz `
wenn du in der config Meter und min einen haken gesetzt hast, sind es m und min. ich suche noch eine elegante Lösung die Einheiten zu ändern ohne das Object komplett neu an zu legen -
Strizz
wenn du in der config Meter und min einen haken gesetzt hast, sind es m und min. ich suche noch eine elegante Lösung die Einheiten zu ändern ohne das Object komplett neu an zu legenHallo MeisterTr,
danke für den Hinweis. Hatte ich übersehen. Wenn sich mit dem Häkchen auch die Dimensionen ändern würden, wäre es ja perfekt. Aber 150.000 km ist eben falsch.
Noch eine Frage: Ich hatte mit der Installation des Adapters meiner Erinnerung nach ein Object 'area'. Das ist plötzlich verschwunden. Habe ich da auch einen Haken falsch gesetzt oder kommt das wieder, wenn ich die Zonen eingerichtet habe?
Strizz
Gesendet von iPad mit Tapatalk Pro
Strizz
Noch eine Frage: Ich hatte mit der Installation des Adapters meiner Erinnerung nach ein Object 'area'. Das ist plötzlich verschwunden. Habe ich da auch einen Haken falsch gesetzt oder kommt das wieder, wenn ich die Zonen eingerichtet habe? `
Bei der aktuellen Version sehen die Objete aus wie auf dem Bild. einen Object was area hieß hat es nicht gegeben.
1768_2017-08-19_05h25_56.png -
wenn du in der config Meter und min einen haken gesetzt hast, sind es m und min. ich suche noch eine elegante Lösung die Einheiten zu ändern ohne das Object komplett neu an zu legen `
Hallo MeisterTr,
Bei der aktuellen Version sehen die Objete aus wie auf dem Bild. einen Object was area hieß hat es nicht gegeben.Hallo MeisterTr,
ich meine den Punkt 'Landroid-s.0.areas' mit den entsprechenden Unterpunkten. Dieser Block war nach der Installation vorhanden und ist später wie von Geisterhand wieder verschwunden. Werde den Adapter später noch mal neu installieren.
Strizz
EDIT: Habe herausgefunden, dass mein Problem hausgemacht war. Auf meinem Desktop-Rechner waren alle areas-Objekte noch vorhanden, nur auf meinem iPad nicht. Nach dem Löschen des Browser-Cache habe ich die Objekt dort auch wieder.
Morgen Idittmar81,
würde gerne Deinen Worx Adapter Code als Beispiel/Basis verwenden um einen Adapter für Gardena Sileno (mit Robonect HX) zu erstellen.
Ich hoffe es ist dir Recht?
Leider sind die APIs nicht gleich und es wird mit GET statt mit POST zugegriffen, müßte aber klappen.
Eine Frage noch…welchen Debugger hast du verwendet? Webstorm? Atom?
Stefan
Hallo MeisterTr,
bei mir funktioniert das "setzen" von neuer "workTime" <u>nicht</u> - das "setzen" von "startTime" aber funktioniert (v 0.3.1).
Kannst du da bitte nochmal schauen?
Gruß Bernd
! landroid-s.0 2017-08-24 19:41:08.970 info h: 00 m: 10
! landroid-s.0 2017-08-24 19:41:08.969 info stateChange landroid-s.0.calendar.sunday.startTime {"val":"00:10","ack":false,"ts":1503596468965,"q":0,"from":"system.adapter.web.0","lc":1503596468965}
! landroid-s.0 2017-08-24 19:40:20.410 info stateChange landroid-s.0.calendar.sunday.workTime {"val":"60","ack":false,"ts":1503596420407,"q":0,"from":"system.adapter.web.0","lc":1503596420407} -
@bku:Hallo MeisterTr,
Gruß Bernd
! landroid-s.0 2017-08-24 19:40:20.410 info stateChange landroid-s.0.calendar.sunday.workTime {"val":"60","ack":false,"ts":1503596420407,"q":0,"from":"system.adapter.web.0","lc":1503596420407} `habe es gerade getestet und es funktioniert bei mir wunderbar, kannst du den adapter mal auf debug stellen und das log erneut posten.
