    • Armilar
      Armilar Most Active Forum Testing @coto last edited by Armilar
      @coto
      So im Spoiler ist ein Blockly. Hoffe ich habe da alles korrekt geschrieben
        <variables>
          <variable id="%/xR(^)g5^9E^=:iOg`*">userdataPath</variable>
        </variables>
        <block type="variables_set" id="X-j`W}}BF!)o-3+*efc-" x="-138" y="-462">
          <field name="VAR" id="%/xR(^)g5^9E^=:iOg`*">userdataPath</field>
            <block type="text" id="27EXAifV@j[WLi|X89v}">
              <field name="TEXT">0_userdata.0.Homatic.Thermostate.OEQ0667828.4.</field>
            <block type="comment" id=",uvQcLX`j6C.AA75DrZW">
              <field name="COMMENT">Am NSPanel wird auf Auto geschaltet </field>
                <block type="on_ext" id="j{K~|bW6;I@lofgT4vd$">
                  <value name="OID0">
                    <shadow type="field_oid" id="UL3m@7$weS]7=yq(I?P0">
                    <block type="text_join" id="Gys1,yJgxvc6*zDXIGVA">
                      <value name="ADD0">
                        <block type="variables_get" id="[8diiUW8Ym4)4=KQ$s=H">
                      <value name="ADD1">
                        <block type="text" id="[)sRA~!%$1n=Fz#{QE:O">
                          <field name="TEXT">Automatic</field>
                    <block type="control_ex" id="rHON.R*}k%w0VO)Q@U5," inline="true">
                      <value name="OID">
                        <shadow type="field_oid" id="-2GGVvyn8C)-7s]y!iFC">
                          <field name="oid">Object ID</field>
                        <block type="text" id="5+BLW_qM@Lr+~7M[@#L-">
                          <field name="TEXT">hm-rpc.0.OEQ0667828.4.AUTO_MODE</field>
                        <shadow type="logic_boolean" id="`naj-n,uyc0.)vdOJ$rH">
                        <block type="logic_boolean" id="9jTx$$DZvix^u]0-#_C(">
                      <value name="DELAY_MS">
                        <shadow type="math_number" id="CU}e7)/uBktOHiK/i^}r">
                          <field name="NUM">0</field>
                        <block type="control_ex" id="A=8psqHjhHW$);in.k0O" inline="true">
                          <value name="OID">
                            <shadow type="field_oid">
                            <block type="text_join" id="LmoSZw/CjrQed[4-l=bN">
                              <value name="ADD0">
                                <block type="variables_get" id="f]x+|[f!W}GNzf0KVu}f">
                              <value name="ADD1">
                                <block type="text" id="GzG^:cECXD^-jPam+|Cm">
                                  <field name="TEXT">Manual</field>
                            <shadow type="logic_boolean">
                            <block type="logic_boolean" id="eKG~%BD/0r3!hGgZ?4H/">
                            <shadow type="math_number" id="/xUS7X!_0tHjQ/lYYlj9">
                    <block type="comment" id=".^0uHrUM+21EPMnW@/Aa">
                      <field name="COMMENT">Am NSPanel wird auf Temperatur geändert</field>
                        <block type="on_ext" id="rnf$MuxnU`senfY-F8SM">
                          <value name="OID0">
                            <shadow type="field_oid" id="rJx5Vxq(4|Y~.;2F6D!)">
                            <block type="text_join" id="Ec_?0i@=m]@]L5gEjOi?">
                              <value name="ADD0">
                                <block type="variables_get" id=".LVxszhxY,x/Y[ht(2Dk">
                              <value name="ADD1">
                                <block type="text" id="qIz$pgvJ|fZU}eKV%H@;">
                                  <field name="TEXT">Setpoint</field>
                            <block type="control_ex" id="VAa5[r[!O|XD?h2zs4.L" inline="true">
                              <value name="OID">
                                <shadow type="field_oid" id="vteW+w!_2:C,eGV!!1De">
                                <block type="text_join" id="P:53ISJM8Wt12`LLp5C?">
                                  <value name="ADD0">
                                    <block type="variables_get" id="^8EdIaZlvDJ`Z:PxenQJ">
                                  <value name="ADD1">
                                    <block type="text" id="rpq:atBJz,=pL/Tpfk?j">
                                <block type="logic_boolean" id="l1zqaM6/jSPS#ZF2YQT]">
                                <shadow type="math_number" id="gzX:oq*R46?@J;sEN^Y{">
                                <block type="control_ex" id="a!%A#%_448?cbF0#E20I" inline="true">
                                  <value name="OID">
                                    <block type="text_join" id="Z=X7ZS=5{oFLhPFl$6J*">
                                      <value name="ADD0">
                                        <block type="variables_get" id="LNZ/Yu]eOv*pYj!.D^Hp">
                                      <value name="ADD1">
                                        <block type="text" id="f(?W0s5a%=`*e.bl+U;j">
                                    <block type="logic_boolean" id="C;jj4,F7s4Dh0_q^GJ(p">
                                    <shadow type="math_number" id="cY5}Nl-3}~q8av0Z,^:%">
                                    <block type="control_ex" id="vOC7f,;-wN|E6q66A#y5" inline="true">
                                      <value name="OID">
                                        <shadow type="field_oid" id="33Vhu-2{oMtX)_7C5xNJ">
                                        <block type="text" id="cwRLYaGfnesiWV4ME~02">
                                          <field name="TEXT">hm-rpc.0.OEQ0667828.4.SET_TEMPERATUR</field>
                                        <shadow type="logic_boolean" id="R6~2VB4nRpE-=epf^!.2">
                                        <block type="on_source" id="{iIWE58cs91`J:+%zsHP">
                                        <shadow type="math_number" id="IX574hj%MQ)uiFy(QXfC">
                            <block type="comment" id="~k%4o/5,IR_W}Vo9z5E5">
                              <field name="COMMENT">Am NSPanel wird auf Boost geschaltet</field>
                                <block type="on_ext" id="$[COE^lL{IylevSK@r$N">
                                  <value name="OID0">
                                    <block type="text_join" id="2E}4*|Pr_c6QxjZlXL#4">
                                      <value name="ADD0">
                                        <block type="variables_get" id="H{sw([OtBhyRLVy[WQ?@">
                                      <value name="ADD1">
                                        <block type="text" id="ae-^6mBM`wUFkV9]!SUJ">
                                          <field name="TEXT">Boost</field>
                                    <block type="control_ex" id="t6(RKz=ul#7hL#Yd2xW?" inline="true">
                                      <value name="OID">
                                        <block type="text" id="?Z[Yyrpj|OUCHpbA[r2b">
                                          <field name="TEXT">hm-rpc.0.OEQ0667828.4.BOOST_MODE</field>
                                        <block type="logic_boolean" id="ILc-KKS#II*=$?-)1@5;">
                                        <shadow type="math_number" id="b*rW5=g.eIn$UGCXpk{)">
                                    <block type="comment" id="pq{0z}/,!fFo[r=xL?3^">
                                      <field name="COMMENT">BATTERY_STATE im Adapter ändert sich</field>
                                        <block type="on_ext" id="2!C]E4+ZovPwb#O![]o0">
                                          <value name="OID0">
                                            <shadow type="field_oid" id="v%SYL`)0SR7QG+O,}p:}">
                                            <block type="text" id="@*2/Gs5Z=d`=xtxpdg9l">
                                              <field name="TEXT">hm-rpc.0.OEQ0667828.4.BATTERY_STATE</field>
                                            <block type="comment" id="7aIa7fh7F8,20!qIV:aN">
                                              <field name="COMMENT">Wert 2,5 ist ausgedacht.</field>
                                                <block type="comment" id="E{Eyaw120U8hRFMQTPP)">
                                                  <field name="COMMENT">Keine Ahnung wann die Batterie wirklich leer ist</field>
                                                    <block type="controls_if" id="Bx%+dY))9YYdkklHAAqI">
                                                        <block type="logic_compare" id="THZ:h0AIFqeS8a4Q^/o^">
                                                          <field name="OP">LT</field>
                                                            <block type="on_source" id="duq;S)%o5XaWTSmW}n}y">
                                                            <block type="math_number" id="ie`:G}d9,(LC{q[i_J4h">
                                                              <field name="NUM">2.5</field>
                                                        <block type="control_ex" id="LClKu=C?jxEn~Ee]Wzc5" inline="true">
                                                          <value name="OID">
                                                            <shadow type="field_oid" id="Nw]~t%7!gKT6i=E)Map8">
                                                            <block type="text_join" id="Q!0.BP9.%/0bX%]!wNfV">
                                                              <value name="ADD0">
        <block type="variables_get" id="Tz3eTQdyBs9l;(pW(]]8">
                                                              <value name="ADD1">
        <block type="text" id="VmE~0^%|++P{ynPp?AHc">
        <field name="TEXT">Lowbat</field>
                                                            <block type="logic_boolean" id="Y}ZJdf5QlTB0=@nDq(%;">
                                                            <shadow type="math_number" id="a!J*o-:pD($Y=(^YE_{K">
                                                      <statement name="ELSE">
                                                        <block type="control_ex" id=":s;z=CrWiuSM}Cs,l3*z" inline="true">
                                                          <value name="OID">
                                                            <block type="text_join" id="]c1m)N,]xKl.D]m+I9*w">
                                                              <value name="ADD0">
        <block type="variables_get" id="4!qxcx`M[}GZ)~@7_a9Q">
                                                              <value name="ADD1">
        <block type="text" id="lYU+fpFo*l7D0xn;oqp^">
                                                            <block type="logic_boolean" id="8RyZCBo`8%N/(/cJq@c@">
                                                            <shadow type="math_number" id="U=O6uX|-`QW%X}YaBD5]">
                                            <block type="comment" id="n`y@58sQ`+Ip[R!kBjk-">
                                              <field name="COMMENT">FAULT_REPORTING im Adapter ändert sich</field>
                                                <block type="on_ext" id="f,5_N)xx_4E,RbWQiq-I">
                                                  <value name="OID0">
                                                    <block type="text" id="wO|:^@umOB:5.+=xrC:T">
                                                      <field name="TEXT">hm-rpc.0.OEQ0667828.4.FAULT_REPORTING</field>
                                                    <block type="controls_if" id="^Lti.NU)S9tV^JvxY#|V">
                                                        <block type="logic_compare" id="twb2_~HKNJLw*t~iei7*">
                                                            <block type="on_source" id="q;QmlW4j0L@[8SiNG(}!">
                                                            <block type="math_number" id="P}F@tPT`pXxiD2`1ik,`">
                                                        <block type="control_ex" id="lb15K]4z_=8NE6}RgxvS" inline="true">
                                                          <value name="OID">
                                                            <block type="text_join" id="Yy}ZGz$j4Xx;mzJEgM/*">
                                                              <value name="ADD0">
        <block type="variables_get" id="#/N|`jy=,]jS#IOHI=F;">
                                                              <value name="ADD1">
        <block type="text" id="TQ?,RMkzfr{;,2bsh[=H">
        <field name="TEXT">Maintain</field>
                                                            <block type="logic_boolean" id="l;aa[h.esax%Z[EZy-|`">
                                                            <shadow type="math_number" id="hN}}Siq_!z-@{iHHt-Do">
                                                        <block type="control_ex" id="8=!5C.CtxhZqLmN=dqOs" inline="true">
                                                          <value name="OID">
                                                            <block type="text_join" id="q~qtEzni;`24R0C%!2ck">
                                                              <value name="ADD0">
        <block type="variables_get" id="$f.qJVIwYLj4nvyEMxAB">
                                                              <value name="ADD1">
        <block type="text" id="[WKkJ8E,SMv|]t_Su1:~">
                                                            <block type="logic_boolean" id="^GMa:eYG*G{gdNUyOK2t">
                                                            <shadow type="math_number" id="p#O@u,+TIl4_)K|MmXI-">
      Das Blockly geht davon aus, dass du folgende Datenpunkte angelegt hast (Falls andere Pfad gewünscht, dann abändern; im Blockly auch):
      0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Automatic (boolean)
      0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Manual (boolean)
      0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Boost (boolean)
      0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Setpoint (number)
      0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Lowbat (boolean)
      0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Maintain (boolean)
      Dann benötigst du einen ALIAS vom Gerätetypen Thermostat.
      SET auf 0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Setpoint
      ACTUAL auf den bevorzugten Raumtemperatursensor
      BOOST auf 0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Boost
      Zusätzliche im ALIAS anlegen
      LOWBAT auf 0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Lowbat
      MAINTAIN auf 0_userdata.0.Homatic.Thermostate.OEQ0667828.4.Maintain
      unter Mode im ALIAS
      --> auf Control_Mode im Adapter
      0 = AUTO
      1 = MANUAL
      2 = PARTY
      3 = BOOST
      Hoffe dann funktioniert schon alles. Kann es leider nicht testen!
        coto @Armilar last edited by
        @armilar
        Danke, das werde ich morgen dann mal in Ruhe ausprobieren.
        Zu Frage 2)
        Die Seiten müssen in der Config eingetragen sein. Sind die drin unter Subpages?
        Ich weiß jetzt nicht ob wir da aneinander vorbei sprechen.
        Die Config ist fast Original. Ich fange gerade an mich da durchzutesten,
        TypeScript v3.6.0.4 zur Steuerung des SONOFF NSPanel mit dem ioBroker by @Armilar/@Sternmiere/@Britzelpuf
        - abgestimmt auf TFT 45 / v3.6.0 / BerryDriver 6 / Tasmota 12.2.0
        @joBr99 Projekt: https://github.com/joBr99/nspanel-lovelace-ui/tree/main/ioBroker
        NsPanelTs.ts (dieses TypeScript in ioBroker) Stable: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
        icon_mapping.ts: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/icon_mapping.ts (TypeScript muss in global liegen)
        ioBroker-Unterstützung: https://forum.iobroker.net/topic/50888/sonoff-nspanel
        WIKI zu diesem Projekt unter: https://github.com/joBr99/nspanel-lovelace-ui/wiki (siehe Sidebar)
        Icons unter: https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/master/cheatsheet.html
        Achtung Änderung des Sonoff ESP-Temperatursensors
        !!! Bitte "SetOption146 1" in der Tasmota-Console ausführen !!!
        ReleaseNotes:
            Bugfixes und Erweiterungen:
                - cardQR (für Gäste WLAN)
                - cardThermo (Neues Design für Alias Thermostat und zusätzlich für Alias Klimaanlage)
                - 08.05.2022 - v2.9.0 - Menüpfeile bei HardwareButtons (button1Page; button2Page) mit Navigation auf Page 0
                - 08.05.2022 - v2.9.0 - Standard-Brightness über neuen Parameter active einstellbar (Test mit 2.9.3)
                - 08.05.2022 - v2.9.0 - Schalter (Licht, Dimmer, Hue, etc) in cardGrid lassen sich wieder schalten
                - 14.06.2022 - v2.9.0 - Aktion auf Submenüs schaltet unmittelbar auf vorheriges Mainmenu (Many thanks to Grrzzz)
                - 14.06.2022 - v2.9.0 - Menü-Pfeile in Subpages (z.B. card QR, cardMedia, etc) (Many thanks to Grrzzz)
                - 15.06.2022 - v3.0.0 - Date/Time im Screensaver auf Basis localString (de-DE/en-EN/nl-NL/etc.)
                - 16.06.2022 - v3.0.0 - Multilingual - config.locale (en-EN, de-DE, nl-NL, da-DK, es-ES, fr-FR, it-IT, ru-RU, etc.)
                - 16.06.2022 - v3.0.0 - Bugfix by Grrzzz - Subpages
                - 18.06.2022 - v3.1.0 - Längere Textfelder in cardEntities
                - 18.06.2022 - V3.1.0 - Detail-Page Lights/Shutter hat neuen Parameter "id"
                - 19.06.2022 - v3.1.0 - Bugfix toLocalTimeString in en-EN/en-US
                - 19.06.2022 - v3.1.0 - Fehler in findLocale abgefangen
                - 19.06.2022 - v3.1.0 - Umstellung auf "Home Assistant" Sprachfile
                - 19.06.2022 - v3.1.0 - Alias "light" und "socket" haben optionalen Parameter icon2 für negative Zustände
                - 29.06.2022 - v3.1.1 - Bugfix Github #286 (Active Page) + Bugfix pageThermo, pageMedia, pageAlarm as first Page
                - 25.08.2022 - v3.1.0 - Code-Verbesserungen (klein0r)
                - 26.08.2022 - v3.2.0 - pageItem mit CIE (XY) Parameter für ColorWheel (Steuerung für z.B Deconz-Farben bei denen Hue nicht greift)
                - 28.08.2022 - v3.2.0 - Wechsel zwischen Weather-Forecast und eigenen Datenpunkten im Screensaver (minütlich)
                - 28.08.2022 - v3.2.0 - Bugfix für 3.2.0 in GenerateDetailPage: Color-Language nicht über findLocales, da nicht in Sprachfile enthalten
                - 29.08.2022 - v3.3.0 - Upgrade TFT 40
                - 29.08.2022 - v3.3.1 - Upgrade TFT 41
                - 04.09.2022 - v3.3.1 - Überarbeitung und BugFix für cardAlarm
                - 13.09.2022 - v3.3.1.3 BugFix Screensaver Toggle
                - 13.09.2022 - v3.3.1.3 Überarbeitung und BugFix und Refresh Features für cardMedia (Breaking Changes)
                - 13.09.2022 - v3.3.1.3 Hinzufügen von SpotifyPremium, Sonos und Chromecast (Google home) zur cardMedia-Logik
                - 15.09.2022 - V3.4.0 - BugFix Dimmode
                - 15.09.2022 - v3.4.0   Upgrade TFT 42
                - 15.09.2022 - V3.4.0 - Colormode für Screensaver + AutoColor WeatherForecast
                - 16.09.2022 - v3.4.0.1 Visualisierung der Relay Zustände (MRIcons) im Screensaver + Bugfix Screensaver MRIcon2
                - 17.09.2022 - v3.4.0.2 Bugfix for screensaver icons with scaled colors
                - 17.09.2022 - v3.4.0.3 Bugfix bNext / bPrev by joBr99
                - 18.09.2022 - v3.4.0.4 Add On/Off Colors in config.mrIcon1ScreensaverEntity and config.mrIcon2ScreensaverEntity
                - 19.09.2022 - v3.4.0.5 Add Mode to cardThermo (Alias Thermostat)
                - 03.10.2022 - v3.4.0.6 Add 5 Entities in US Panel Version to cardEntities
                - 03.10.2022 - v3.4.0.6 Fix screenSaverDoubleClick
                - 03.10.2022 - v3.4.0.6 Add cardPower (experimental)
                - 05.10.2022 - v3.4.0.6 Add sueezeboxrpc to cardMedia
                - 07.10.2022 - v3.4.0.6 Time-configurable change for screensaver icons
                - 07.10.2022 - v3.5.0   Upgrade TFT 43
                - 07.10.2022 - v3.5.0   Add Backgroundcolor to Pages
                - 08.10.2022 - v3.5.0   Add Tilt-Slider and TILT_Fucntions (Open/Stop/Close) to Blinds/Cover/Shutter popUp
                - 12.10.2022 - v3.5.0   Add PageNavigation via Datapoint
                - 25.10.2022 - v3.5.0   Add New Parameters to popUpNotify / Layout 2
                - 26.10.2022 - v3.5.0.1 Fix Thermostat for tado Support (by Sternmiere)
                - 27.10.2022 - v3.5.0.1 Add VirtualDevice Gate
                - 27.10.2022 - v3.5.0.2 Applied Boy Scout Rule (Fixed some typos, changed var to let, fixed min/max colorTemp Bug)
                - 30.10.2022 - v3.5.0.3 Fixed Media Play/Pause icon for alexa (and others) devices
                - 31.10.2022 - v3.5.0.4 Reengineering Media Subscriptions
                - 02.11.2022 - v3.5.0.5 Page navigation continues with page 0 from the last page
                - 04.11.2022 - v3.5.0.5 Create Auto-Alias for Service Pages
                - 07.11.2022 - v3.5.0.5 Create Auto-Alias for Alexa2, Spotify-Premium, Sonos
                - 08.11.2022 - v3.5.0.5 Create Auto-Alias for Wheather-Forcast (Screensaver Big-Icon)
                - 07.10.2022 - v3.6.0   Upgrade TFT 45
                - 09.11.2022 - v3.6.0   Add new Alias-DeviceTyp cie (control colors with XY)
                - 16.11.2022 - v3.6.0   Control Relay 1 + 2 via Datapoints
                - 17.11.2022 - v3.6.0   Add Datapoint to Control Screensaver-Dimmode
                - 17.11.2022 - v3.6.0   Change to Page after bExit
                - 18.11.2022 - v3.6.0   Add cardChart by fumanchi (only on DEV)
                - 24.11.2022 - v3.6.0   Add Background Color Switch via DP
                - 26.11.2022 - v3.6.0   Add cardMedia Colors
                - 26.11.2022 - v3.6.0   Add cardThermostat Popup
                - 28.11.2022 - v3.6.0.1 Bugfix in bExit
                - 29.11.2022 - v3.6.0.2 Update Berry Version 6
                - 30.11.2022 - v3.6.0.3 Bugfix string/number compare current BerryDriver (DP as string)
                - 05.12.2022 - v3.6.0.4 Add bHome to Navigation
                - 05.12.2022 - v3.6.0.4 Add changeable Center-Icon in cardPower with Color and Value
                - 08.12.2022 - v3.6.0.4 Bugfix - Use MRIcons in Screensaver with null
                - 11.12.2022 - v3.6.0.4 Add new DP to show active page
                - 13.12.2022 - v3.6.0.4 Add Sensor-Values to cardGrid
                - 13.12.2022 - v3.6.0.4 Hotfix - Update screensaver temperature without weather forecast
                Implemented in 3.6.1 DEV
                - XX.12.2022 - v3.6.1   Add cardChart on PROD (implemented but working with v3.6.1 --> next TFT)
                - XX.12.2022 - v3.6.1   Add Shuffle to Media Player
                - XX.12.2022 - v3.6.1   Remove Speakerlist and Add 5 GridCard PageItems
                - XX.12.2022 - v3.6.1   Add In_Sel PopUp
                Todo's for 3.6.1
                - XX.12.2022 - v3.6.1 Add Fan
        * Falls Aliase durch das Skript erstellt werden sollen, muss in der JavaScript Instanz "setObect" gesetzt sein! *
        Wenn Rule definiert, dann können die Hardware-Tasten ebenfalls für Seitensteuerung (dann nicht mehr als Relais) genutzt werden
        Tasmota Konsole:
            Rule2 on Button1#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button2"} endon
            Rule2 1 (Rule aktivieren)
            Rule2 0 (Rule deaktivieren)
        Mögliche Seiten-Ansichten:
            screensaver Page    - wird nach definiertem Zeitraum (config) mit Dimm-Modus aktiv (Uhrzeit, Datum, Aktuelle Temperatur mit Symbol)
                                  (die 4 kleineren Icons können als Wetter-Vorschau + 4Tage (Symbol + Höchsttemperatur) oder zur Anzeige definierter Infos konfiguriert werden)
            cardEntities Page   - 4 vertikale angeordnete Steuerelemente - auch als Subpage
            cardGrid Page       - 6 horizontal angeordnete Steuerelemente in 2 Reihen a 3 Steuerelemente - auch als Subpage
            cardThermo Page     - Thermostat mit Solltemperatur, Isttemperatur, Mode - Weitere Eigenschaften können im Alias definiert werden
            cardMedia Page      - Mediaplayer - Ausnahme: Alias sollte mit Alias-Manager automatisch über Alexa-Verzeichnis Player angelegt werden
            cardAlarm Page      - Alarmseite mit Zustand und Tastenfeld
            cardPower Page      - Energiefluss
        Popup-Pages:
            popupLight Page     - in Abhängigkeit zum gewählten Alias werden "Helligkeit", "Farbtemperatur" und "Farbauswahl" bereitgestellt
            popupShutter Page   - die Shutter-Position (Rollo, Jalousie, Markise, Leinwand, etc.) kann über einen Slider verändert werden.
            popupNotify Page    - Info - Seite mit Headline Text und Buttons - Intern für manuelle Updates / Extern zur Befüllung von Datenpunkten unter 0_userdata
            screensaver Notify  - Über zwei externe Datenpunkte in 0_userdata können "Headline" und "Text" an den Screensaver zur Info gesendet werden
        Mögliche Aliase: (Vorzugsweise mit ioBroker-Adapter "Geräte verwalten" konfigurieren, da SET, GET, ACTUAL, etc. verwendet werden)
            Info                - Werte aus Datenpunkt
            Schieberegler       - Slider numerische Werte (SET/ACTUAL)
            Lautstärke          - Volume (SET/ACTUAL) und MUTE
            Lautstärke-Gruppe   - analog Lautstärke
            Licht               - An/Aus (Schalter)
            Steckdose           - An/Aus (Schalter)
            Dimmer              - An/Aus, Brightness
            Farbtemperatur      - An/Aus, Farbtemperatur und Brightness
            HUE-Licht           - Zum Schalten von Color-Leuchtmitteln über HUE-Wert, Brightness, Farbtemperatur, An/Aus (HUE kann auch fehlen)
            RGB-Licht           - RGB-Leuchtmitteln/Stripes welche Rot/Grün/ und Blau separat benötigen (Tasmota, WifiLight, etc.) + Brightness, Farbtemperatur
            RGB-Licht-einzeln   - RGB-Leuchtmitteln/Stripes welche HEX-Farbwerte benötigen (Tasmota, WifiLight, etc.) + Brightness, Farbtemperatur
            Jalousien           - Up, Stop, Down, Position
            Fenster             - Sensor open
            Tür                 - Sensor open
            Verschluss          - Türschloss SET/ACTUAL/OPEN
            Taste               - Für Szenen oder Radiosender, etc. --> Nur Funktionsaufruf - Kein Taster wie MonoButton - True/False
            Tastensensor        - analog Taste
            Thermostat          - Aktuelle Raumtemperatur, Setpoint, etc.
            Klimaanlage         - Buttons zur Steuerung der Klimaanlage im unteren Bereich
            Temperatur          - Anzeige von Temperatur - Datenpunkten, analog Info
            Feuchtigkeit        - Anzeige von Humidity - Datenpunkten, analog Info
            Medien              - Steuerung von Alexa - Über Alias-Manager im Verzeichnis Player automatisch anlegen (Geräte-Manager funktioniert nicht)
            Wettervorhersage    - Aktuelle Außen-Temperatur (Temp) und aktuelles AccuWeather-Icon (Icon) für Screensaver
        Interne Sonoff-Sensoren (über Tasmota):
            ESP-Temperatur      - wird in 0_userdata.0. abgelegt, kann als Alias importiert werden --> SetOption146 1
            Temperatur          - Raumtemperatur - wird in 0_userdata.0. abgelegt, kann als Alias importiert werden
                                  (!!! Achtung: der interne Sonoff-Sensor liefert keine exakten Daten, da das NSPanel-Board und der ESP selbst Hitze produzieren !!!
                                  ggf. Offset einplanen oder besser einen externen Sensor über Zigbee etc. verwenden)
            Timestamp           - wird in 0_userdata.0. Zeitpunkt der letzten Sensorübertragung
        Tasmota-Status0 - (zyklische Ausführung)
            liefert relevanten Tasmota-Informationen und kann bei Bedarf in "function get_tasmota_status0()" erweitert werden. Daten werden in 0_userdata.0. abgelegt
        Erforderliche Adapter:
            AccuWeather:        - Bei Nutzung der Wetterfunktionen (und zur Icon-Konvertierung) im Screensaver
            Alexa2:             - Bei Nutzung der dynamischen SpeakerList in der cardMedia
            Geräte verwalten    - Für Erstellung der Aliase
            Alias-Manager       - !!! ausschließlich für MEDIA-Alias
            MQTT-Adapter        - Für Kommunikation zwischen Skript und Tasmota
            JavaScript-Adapter
        Upgrades in Konsole:
            Tasmota BerryDriver     : Backlog UpdateDriverVersion https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
            TFT EU STABLE Version   : FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.6.0.tft
        let Icons = new IconsSelector();
        let timeoutSlider: any;
        let manually_Update = false;
        const autoCreateAlias = true;  //Für diese Option muss der Haken in setObjects in deiner javascript.X. Instanz gesetzt sein.
        const NSPanel_Path = '0_userdata.0.NSPanel.1.';
        const NSPanel_Alarm_Path = '0_userdata.0.NSPanel.'; //Neuer Pfad für gemeinsame Nutzung durch mehrere Panels (bei Nutzung der cardAlarm)
        let AliasPath: string = 'alias.0.' + NSPanel_Path.substring(13, NSPanel_Path.length);
        const Debug = false;
        // Variablen zur Steuerung der Wettericons auf dem Screensaver (Steuerung in 0_userdata.0.XPANELX.ScreensaverInfo)
        // Wenn weatherForecastTimer auf true, dann Wechsel zwischen Datenpunkten und Wettervorhersage (30 Sekunden nach Minute (Zeit))
        // Wenn weatherForecastTimer auf false, dann Möglichkeit über weatherForecast, ob Datenpunkte oder Wettervorhersage (true = WeatherForecast/false = Datenpunkte)
        let weatherForecast: boolean; // Änderung zum Video --> Einstellung siehe Wiki
        const HMIOff:           RGB = { red:  68, green: 115, blue: 158 };     // Blau-Off - Original Entity Off
        const HMIOn:            RGB = { red:   3, green: 169, blue: 244 };     // Blau-On
        const HMIDark:          RGB = { red:  29, green:  29, blue:  29 };     // Original Background Color
        const Off:              RGB = { red: 253, green: 128, blue:   0 };     // Orange-Off - schönere Farbübergänge
        const On:               RGB = { red: 253, green: 216, blue:  53 };
        const MSRed:            RGB = { red: 251, green: 105, blue:  98 };
        const MSYellow:         RGB = { red: 255, green: 235, blue: 156 };
        const MSGreen:          RGB = { red: 121, green: 222, blue: 121 };
        const Red:              RGB = { red: 255, green:   0, blue:   0 };
        const White:            RGB = { red: 255, green: 255, blue: 255 };
        const Yellow:           RGB = { red: 255, green: 255, blue:   0 };
        const Green:            RGB = { red:   0, green: 255, blue:   0 };
        const Blue:             RGB = { red:   0, green:   0, blue: 255 };
        const DarkBlue:         RGB = { red:   0, green:   0, blue: 136 };
        const Gray:             RGB = { red: 136, green: 136, blue: 136 };
        const Black:            RGB = { red:   0, green:   0, blue:   0 };
        const colorSpotify:     RGB = { red:  30, green: 215, blue:  96 };
        const colorAlexa:       RGB = { red:  49, green: 196, blue: 243 };
        const colorRadio:       RGB = { red: 255, green: 127, blue:   0 };
        const BatteryFull:      RGB = { red:  96, green: 176, blue:  62 };
        const BatteryEmpty:     RGB = { red: 179, green:  45, blue:  25 };
        //Dynamische Indikatoren
        const colorScale0:      RGB = { red:   99, green: 190, blue: 123 };
        const colorScale1:      RGB = { red:  129, green: 199, blue: 126 };
        const colorScale2:      RGB = { red:  161, green: 208, blue: 127 };
        const colorScale3:      RGB = { red:  129, green: 217, blue: 126 };
        const colorScale4:      RGB = { red:  222, green: 226, blue: 131 };
        const colorScale5:      RGB = { red:  254, green: 235, blue: 132 };
        const colorScale6:      RGB = { red:  255, green: 210, blue: 129 };
        const colorScale7:      RGB = { red:  251, green: 185, blue: 124 };
        const colorScale8:      RGB = { red:  251, green: 158, blue: 117 };
        const colorScale9:      RGB = { red:  248, green: 131, blue: 111 };
        const colorScale10:     RGB = { red:  248, green: 105, blue: 107 };
        //Screensaver Default Theme Colors
        const scbackground:     RGB = { red:   0, green:    0, blue:   0};
        const scbackgroundInd1: RGB = { red: 255, green:   0,  blue:   0};
        const scbackgroundInd2: RGB = { red: 121, green: 222,  blue: 121};
        const scbackgroundInd3: RGB = { red: 255, green: 255,  blue:   0};
        const sctime:           RGB = { red: 255, green:  255, blue: 255};
        const sctimeAMPM:       RGB = { red: 255, green:  255, blue: 255};
        const scdate:           RGB = { red: 255, green:  255, blue: 255};
        const sctMainIcon:      RGB = { red: 255, green:  255, blue: 255};
        const sctMainText:      RGB = { red: 255, green:  255, blue: 255};
        const sctForecast1:     RGB = { red: 255, green:  255, blue: 255};
        const sctForecast2:     RGB = { red: 255, green:  255, blue: 255};
        const sctForecast3:     RGB = { red: 255, green:  255, blue: 255};
        const sctForecast4:     RGB = { red: 255, green:  255, blue: 255};
        const sctF1Icon:        RGB = { red: 255, green:  235, blue: 156};
        const sctF2Icon:        RGB = { red: 255, green:  235, blue: 156};
        const sctF3Icon:        RGB = { red: 255, green:  235, blue: 156};
        const sctF4Icon:        RGB = { red: 255, green:  235, blue: 156};
        const sctForecast1Val:  RGB = { red: 255, green:  255, blue: 255};
        const sctForecast2Val:  RGB = { red: 255, green:  255, blue: 255};
        const sctForecast3Val:  RGB = { red: 255, green:  255, blue: 255};
        const sctForecast4Val:  RGB = { red: 255, green:  255, blue: 255};
        const scbar:            RGB = { red: 255, green:  255, blue: 255};
        const sctMainIconAlt:   RGB = { red: 255, green:  255, blue: 255};
        const sctMainTextAlt:   RGB = { red: 255, green:  255, blue: 255};
        const sctTimeAdd:       RGB = { red: 255, green:  255, blue: 255};
        //Auto-Weather-Colors
        const swClearNight:     RGB = { red: 150, green: 150, blue: 100};
        const swCloudy:         RGB = { red:  75, green:  75, blue:  75};
        const swExceptional:    RGB = { red: 255, green:  50, blue:  50};
        const swFog:            RGB = { red: 150, green: 150, blue: 150};
        const swHail:           RGB = { red: 200, green: 200, blue: 200};
        const swLightning:      RGB = { red: 200, green: 200, blue:  0};
        const swLightningRainy: RGB = { red: 200, green: 200, blue: 150};
        const swPartlycloudy:   RGB = { red: 150, green: 150, blue: 150};
        const swPouring:        RGB = { red:  50, green:  50, blue: 255};
        const swRainy:          RGB = { red: 100, green: 100, blue: 255};
        const swSnowy:          RGB = { red: 150, green: 150, blue: 150};
        const swSnowyRainy:     RGB = { red: 150, green: 150, blue: 255};
        const swSunny:          RGB = { red: 255, green: 255, blue:   0};
        const swWindy:          RGB = { red: 150, green: 150, blue: 150};
        let vwIconColor = [];
        //-- Anfang der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ----------------
        let Seite1_Broker: PageEntities =
            "type": "cardEntities",
            "heading": "Meine 1 Seite",
            "useColor": true,
            "subPage": false,
            "parent": undefined,
            "items": [
                <PageItem>{ id: "alias.0.NSPanel1.SZLampe", name: "Schlafzimmer Lampe", interpolateColor: true},
                <PageItem>{ id: "alias.0.NSPanel1.SZLampe", name: "RGB-Licht", minValueBrightness: 0, maxValueBrightness: 100, interpolateColor: true},
                <PageItem>{ id: "alias.0.NSPanel1.SZLampe", name: "HUE-Licht-CT", minValueBrightness: 0, maxValueBrightness: 70, minValueColorTemp: 500, maxValueColorTemp: 6500, interpolateColor: true},
                <PageItem>{ id: "alias.0.NSPanel1.SZLampe", name: "HUE-Licht-Color", minValueColorTemp: 500, maxValueColorTemp: 6500, interpolateColor: true}
        let SensorGrid: PageGrid =
            "type": "cardGrid",
            "heading": "Sensor Werte",
            "useColor": true,
            "subPage": false,
            "items": [
                <PageItem>{ id: "alias.0.NSPanel_1.TestTemperatur", name: "Außentemp. °C", offColor: MSRed, onColor: MSGreen, useValue: true },
                <PageItem>{ id: "alias.0.NSPanel_1.TestFeuchtigkeit", name: "Luftfeuchte %", offColor: MSYellow, onColor: MSYellow , useValue: true },
                <PageItem>{ id: "alias.0.NSPanel_1.Taupunkt", name: "Taupunkt °C", offColor: MSRed, onColor: MSGreen, useValue: true },
                <PageItem>{ id: "alias.0.NSPanel_1.UV_Index", name: "UV Index", offColor: White , onColor: White, useValue: true },
                <PageItem>{ id: "alias.0.NSPanel_1.Windstaerke", name: "Windstärke bft", offColor: White , onColor: White, useValue: true },
                <PageItem>{ id: "alias.0.NSPanel_1.Luftdruck", name: "Luftdruck hPa", offColor: White , onColor: White, useValue: true }
        //Only DEV --> Test
        let ChartDemo: PageChart =
            "type": "cardChart",
            "heading": "Charts Demo",
            "useColor": true,
            "subPage": false,
            "items": [<PageItem>{
                        yAxis: 'Gas [kWh]',
                        yAxisTicks: [2,4,6,8,10,12,14],
                        onColor: Yellow
        let CardPowerExample: PagePower =
            "type": "cardPower",
            "heading": "cardPower Emulator",
            "useColor": true,
            "subPage": false,
            "items": [
                <PageItem>{ id: 'alias.0.NSPanel_1.Power.PowerCard' },
        let Test_Licht2: PageEntities =
            "heading": "Color Aliase 2",
            "useColor": true,
            "subPage": false,
            "items": [
                //Beispiel für RGB Light mit neuem PageItem-Parameter colormode: "xy" alternativ colormode: "rgb" oder weglassen
                //Steuert im z.B. DeConz Adapter unter Lampen die Farben per CIE (XY)
                <PageItem>{ id: "alias.0.NSPanel_2.WZ_E14_Fenster_rechts", name: "Fensterbank rechts", minValueBrightness: 0, maxValueBrightness: 100, minValueColorTemp: 500, maxValueColorTemp: 150, interpolateColor: true, colormode: "xy"},
                <PageItem>{ id: "alias.0.NSPanel_1.TestFarbtemperatur", name: "Farbtemperatur", interpolateColor: true},
        let Test_Funktionen: PageEntities =
            "heading": "Sonstige Aliase",
            "useColor": true,
            "subPage": false,
            "items": [
                <PageItem>{ id: "alias.0.NSPanel_1.TestLautstärke", offColor: MSRed, onColor: MSGreen, name: "Echo Spot Büro", minValue: 0, maxValue: 100 },
                <PageItem>{ id: "alias.0.NSPanel_1.TestTemperatur",name: "Temperatur außen", icon: "thermometer", onColor: White },
                <PageItem>{ id: "alias.0.NSPanel_1.TestFeuchtigkeit", name: "Luftfeuchte außen", icon: "water-percent", unit: "%H", onColor: White },
                <PageItem>{ id: "alias.0.NSPanel_1.TestInfo", name: "Windstärke", icon: "wind-power-outline", offColor: MSRed, onColor: MSGreen, unit: "bft", minValue: 0, maxValue: 12, interpolateColor: true, useColor: true }
        let Buero_Seite_1: PageEntities =
            "heading": "Büro",
            "useColor": true,
            "subPage": false,
            "items": [
                <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe", interpolateColor: true},
                <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung", interpolateColor: true},
                <PageItem>{ id: "alias.0.NSPanel_1.Testlampe2", name: "Filamentlampe", minValueBrightness: 0, maxValueBrightness: 70, interpolateColor: true},
                <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power", icon2: "power",offColor: MSRed, onColor: MSGreen}
        let Fenster_1: PageEntities =
            "heading": "Fenster und Türen",
            "useColor": true,
            "subPage": false,
            "items": [
                <PageItem>{ id: "alias.0.NSPanel_1.TestFenster", offColor: MSRed, onColor: MSGreen, name: "Büro Fenster"},
                <PageItem>{ id: "alias.0.NSPanel_1.Haustuer", offColor: MSRed, onColor: MSGreen, name: "Haustür"},
                <PageItem>{ id: "alias.0.NSPanel_1.TestBlind", icon: "blinds-horizontal", offColor: White, onColor: Yellow, name: "Büro", secondRow: "Hier Text für 2. Zeile"},
                <PageItem>{ id: "alias.0.NSPanel_1.TestDoorlock", offColor: MSRed, onColor: MSGreen, name: "Türschloss"},
        //<PageItem>{ id: "alias.0.NS-Panel.Buero.Rollade", icon: "blinds-horizontal", offColor: White, onColor: Yellow, name: "Büro", secondRow: "Hier Text für 2. Zeile"},
        let Button_1: PageEntities =
            "heading": "Button Aliase",
            "useColor": true,
            "subPage": false,
            "items": [
                <PageItem>{ id: "alias.0.NSPanel_1.TestTastensensor", name: "Tastensensor (FFN)"},
                <PageItem>{ id: "alias.0.NSPanel_1.Radio.NDR2", icon: "radio", name: "Taste (NDR2)", onColor: colorRadio},
                <PageItem>{ id: "alias.0.NSPanel_1.TestVentil1", icon: "valve-open", icon2: "valve-closed",offColor: MSRed, onColor: MSGreen, name: "Test-Ventil 1"},
                <PageItem>{ id: "alias.0.NSPanel_1.Radio.NDR2", icon: 'alarm-light', name: "Alert mit Zielseite", offColor: MSGreen, onColor: MSRed, targetPage: 'Abfall', buttonText: 'Popup'},
        let Subpages_1: PageEntities =
            "heading": "Test Subpages",
            "useColor": true,
            "subPage": false,
            "items": [
                <PageItem>{ navigate: true, id: "Abfall", onColor: White, name: "Abfallkalender"},
                <PageItem>{ navigate: true, id: "WLAN", onColor: White, name: "Gäste WLAN"},
                //Subpage 1 von Subpages_1
                let Abfall: PageEntities =
                    "heading": "Abfallkalender",
                    "useColor": true,
                    "subPage": true,
                    "parent": Subpages_1,
                    "items": [
                        <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event1",icon: "trash-can"},
                        <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event2",icon: "trash-can"},
                        <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event3",icon: "trash-can"},
                        <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event4",icon: "trash-can"}
                //Subpage 2 von Subpages_1
                let WLAN: PageQR =
                    "type": "cardQR",
                    "heading": "Gäste WLAN",
                    "useColor": true,
                    "subPage": true,
                    "items": [<PageItem>{ id: "alias.0.NSPanel_1.Guest_Wifi", hidePassword: true }]
        let Buero_Seite_2: PageGrid =
            "type": "cardGrid",
            "heading": "Büro 2",
            "useColor": true,
            "subPage": false,
            "items": [
                <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe", name: "Schreibtisch"},
                <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung", name: "Deckenlampe"},
                <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power", offColor: MSRed, onColor: MSGreen},
                <PageItem>{ id: "alias.0.NSPanel_1.TestBlind", icon: "projector-screen", onColor: White, name: "Beamer", secondRow: "auch Text"},
                <PageItem>{ id: "alias.0.NSPanel_1.Radio.Bob", icon: "play", onColor: White, name: "TuneIn"}
        let Radiosender: PageGrid =
            "type": "cardGrid",
            "useColor": true,
            "subPage": false,
            "items": [<PageItem>{ id: "alias.0.NSPanel_1.Radio.Bob", icon: "radio", name: "Radio BOB", onColor: colorRadio}]
        // NEW: Neue Definition von Medien-Aliasen
        // adapterPlayerInstance = alexa2.0. or spotify-premium.0. or sonos.0. or chromecast.0.
        // MEDIA ALIASE können auch per JS-Script erstellt werden https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen#medien---cardmedia
        let Alexa: PageMedia =
            'type': 'cardMedia',
            'heading': 'Alexa',
            'useColor': true,
            'subPage': false,
            'parent': undefined,
            'items': [<PageItem>{
                        id: AliasPath + 'Media.PlayerAlexa',
                        adapterPlayerInstance: 'alexa2.0.',
                        mediaDevice: 'G0XXXXXXXXXXXXXX',
                        speakerList: ['Überall','Gartenhaus','Esszimmer','Heimkino','Echo Dot Küche','Echo Spot Buero'],
                        autoCreateALias : true
        let Sonos: PageMedia =
            'heading': 'Sonos',
            'useColor': true,
            'subPage': false,
                        id: AliasPath + 'Media.PlayerSonos',
                        adapterPlayerInstance: "sonos.0.",
                        mediaDevice: "192_168_1_212",
                        speakerList: ['Terrasse'],
        let SpotifyPremium: PageMedia =
            "type": "cardMedia",
            "heading": "Spotify-Premium",
            "useColor": true,
            "subPage": false,
                        id: AliasPath + 'Media.PlayerSpotifyPremium',
                        adapterPlayerInstance: "spotify-premium.0.",
                        speakerList: ['LENOVO-W11-01','Terrasse','Überall','Gartenhaus','Esszimmer','Heimkino','Echo Dot Küche','Echo Spot Buero'],
                        colorMediaIcon: colorSpotify,
                        colorMediaArtist: Yellow,
                        colorMediaTitle: Yellow,
        let SqueezeboxRPC: PageMedia =
            "heading": "SqueezeboxRPC",
            "useColor": true,
            "subPage": false,
                        adapterPlayerInstance: "squeezeboxrpc.0.Players.SqueezePlay.",
                        speakerList: ['SqueezePlay']
        let WZ_Heizung: PageThermo =
            "type": "cardThermo",
            "heading": "WZ Thermostat",
            "useColor": true,
            "subPage": false,
            "items": [<PageItem>{ id: "alias.0.NSPanel1.HeizungWZ", minValue: 50, maxValue: 300 }]
        let Buero_Klimaanlage: PageThermo =
            "heading": "Test Klimaanlage",
            "useColor": true,
            "subPage": false,
                        minValue: 50,
                        maxValue: 250,
                        popupThermoMode1: ['Auto','0','1','2','3'],
                        popupThermoMode2: ['Auto','0','1','2','3','4','5'],
                        popupThermoMode3: ['Auto','Manual','Boost',],
                        popUpThermoName: ["Schwenk-Modus", 'Speed', 'Temperatur'],
                        icon: 'fan',
                        setThermoAlias: ['MODE1','MODE2','MODE3'],
                        //setThermoDestTemp2: 'ACTUAL2'
        let Buero_Alarm: PageAlarm =
            "type": "cardAlarm",
            "heading": "Alarm",
            "useColor": true,
            "subPage": false,
            "items": [<PageItem>{ id: "alias.0.Alarm" }]
        let button1Page: PageGrid =
            'type': 'cardGrid',
            'heading': 'Radio',
            'useColor': true,
            'subPage': false,
            'items': [
                <PageItem>{ id: 'alias.0.NSPanel_1.Radio.FFN', icon: 'radio', name: 'FFN', onColor: colorRadio},
                <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Antenne' , icon: 'radio', name: 'Antenne Nds.', onColor: colorRadio},
                <PageItem>{ id: 'alias.0.NSPanel_1.Radio.NDR2', icon: 'radio', name: 'NDR2', onColor: colorRadio},
                <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Bob', icon: 'radio', name: 'Radio BOB', onColor: colorRadio},
                <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Spotify', icon: 'spotify', name: 'Party Playlist', onColor: colorSpotify},
                <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Alexa', icon: 'playlist-music', name: 'Playlist 2021', onColor: colorAlexa}
        let button2Page: PageEntities =
            'type': 'cardEntities',
            'heading': 'Büro',
            'useColor': true,
            'subPage': false,
            'items': [
                <PageItem>{ id: 'alias.0.NSPanel_1.Schreibtischlampe'},
                <PageItem>{ id: 'alias.0.NSPanel_1.Deckenbeleuchtung'}
        //-- ENDE der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ------------------
        //Service Pages mit Auto-Alias (Nachfolgende Seiten werden mit Alias automatisch angelegt)
        let Service: PageEntities =
            "heading": "NSPanel Service",
            "useColor": true,
            "subPage": false,
            "items": [
                <PageItem>{ id: AliasPath + 'autoUpdate', name: "Auto-Updates" ,icon: "update", offColor: MSRed, onColor: MSGreen},
                <PageItem>{ navigate: true, id: "NSPanel_Infos", icon: "information-outline", onColor: White, name: "NSPanel Infos"},
                <PageItem>{ navigate: true, id: "NSPanel_Firmware_Info", icon: "update", onColor: White, name: "Firmware Infos"},
                <PageItem>{ navigate: true, id: "NSPanel_Einstellungen", icon: "wrench-outline", onColor: White, name: "Screensaver"}
                //Subpage 1 von Subpages_2
                let NSPanel_Infos: PageEntities =
                    "heading": "NSPanel Infos",
                    "useColor": true,
                    "subPage": true,
                    "parent": Service,
                    "items": [
                        <PageItem>{ id: AliasPath + 'Tasmota.Hardware', name: 'Hardware', icon: 'memory', offColor: MSYellow, onColor: MSYellow, useColor: true},
                        <PageItem>{ id: AliasPath + 'Sensor.ESP32.Temperature', name: "ESP Temperatur", icon: "thermometer", unit: "°C", offColor: MSYellow, onColor: MSYellow, useColor: true},
                        <PageItem>{ id: AliasPath + 'Tasmota.Uptime', name: "Uptime", icon: "timeline-clock-outline", offColor: MSYellow, onColor: MSYellow, useColor: true},
                        <PageItem>{ id: AliasPath + 'Tasmota.Wifi.RSSI', name: "Wifi-Signal", icon: "signal-distance-variant", unit: "dBm", offColor: MSYellow, onColor: MSYellow, useColor: true}
                //Subpage 2 von Subpages_2
                let NSPanel_Einstellungen: PageEntities =
                    'heading': 'Screensaver',
                    'useColor': true,
                    'subPage': true,
                    'parent': Service,
                    'items': [
                        <PageItem>{ id: AliasPath + 'Dimmode.brightnessDay', name: 'Brightness Tag', icon: 'brightness-5', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 5, maxValue: 10},
                        <PageItem>{ id: AliasPath + 'Dimmode.brightnessNight', name: 'Brightness Nacht', icon: 'brightness-4', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 4},
                        <PageItem>{ id: AliasPath + 'Dimmode.hourDay', name: 'Stunde Tag', icon: 'sun-clock', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23},
                        <PageItem>{ id: AliasPath + 'Dimmode.hourNight', name: 'Stunde Nacht', icon: 'sun-clock-outline', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23}
                //Subpage 3 von Subpages_2
                let NSPanel_Firmware_Info: PageEntities =
                    'heading': 'Firmware-Updates',
                    'useColor': true,
                    'subPage': true,
                    'parent': Service,
                    'items': [
                        <PageItem>{ id: AliasPath + 'Tasmota.Version', name: 'Tasmota Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                        <PageItem>{ id: AliasPath + 'Display.TFTVersion', name: 'TFT-Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                        <PageItem>{ id: AliasPath + 'Display.BerryDriver', name: 'Berry-Treiber', offColor: MSYellow, onColor: MSYellow, useColor: true},
                        <PageItem>{ id: AliasPath + 'Display.Model', name: 'NSPanel Version', offColor: MSYellow, onColor: MSYellow, useColor: true}
        export const config: Config = {
            panelRecvTopic: 'mqtt.0.SmartHome.NSPanel_1.tele.RESULT',       // anpassen
            panelSendTopic: 'mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend',   // anpassen
            firstScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Hourly.h0.PrecipitationProbability', ScreensaverEntityIcon: 'weather-pouring', ScreensaverEntityText: 'Regen', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100} },
            secondScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.WindSpeed', ScreensaverEntityIcon: 'weather-windy', ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'km/h', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} },
            thirdScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.UVIndex', ScreensaverEntityIcon: 'solar-power', ScreensaverEntityText: 'UV', ScreensaverEntityUnitText: '', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 9} },
            fourthScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity', ScreensaverEntityIcon: 'water-percent', ScreensaverEntityText: 'Luft', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
            alternativeScreensaverLayout: false,
            autoWeatherColorScreensaverLayout: true,
            mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.SmartHome.NSPanel_1.stat.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
            mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.SmartHome.NSPanel_1.stat.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
            timeoutScreensaver: 10,
            dimmode: 20,
            active: 100, //Standard-Brightness TFT
            screenSaverDoubleClick: true,
            locale: 'de-DE',                    // en-US, de-DE, nl-NL, da-DK, es-ES, fr-FR, it-IT, ru-RU, etc.
            timeFormat: '%H:%M',                // currently not used
            dateFormat: '%A, %d. %B %Y',        // currently not used
            weatherEntity: 'alias.0.Wetter.Ullendorf',    // Dieser Alias muss erstellt werden, damit die 4 kleineren Icons (Wetter oder DP) angezeigt werden können
            defaultOffColor: Off,
            defaultOnColor: On,
            defaultColor: Off,
            defaultBackgroundColor: Black,    //New Parameter
            temperatureUnit: '°C',
            pages: [
                    Seite1_Broker,        //Beispiel-Seite
                    Buero_Seite_1,      //Beispiel-Seite
                    SensorGrid,         //Beispiel-Seite
                    //CardPowerExample,   //Beispiel-Seite
                    //SqueezeboxRPC,      //Beispiel-Seite
                    //Sonos,              //Beispiel-Seite
                    //SpotifyPremium,     //Beispiel-Seite
                    //Alexa,              //Beispiel-Seite
                    Buero_Seite_2,      //Beispiel-Seite
                    //Buero_Klimaanlage,  //Beispiel-Seite
                    Button_1,           //Beispiel-Seite
                    Test_Licht2,        //Beispiel-Seite
                    Test_Funktionen,    //Beispiel-Seite
                    Fenster_1,          //Beispiel-Seite
                    Subpages_1,         //Beispiel-Seite
                    WZ_Heizung,    //Beispiel-Seite
                    Buero_Alarm,        //Beispiel-Seite
                    Service             //Auto-Alias Service Page
            subPages: [
                        Abfall,                     //Beispiel-Unterseite
                        WLAN,                       //Beispiel-Unterseite
                        NSPanel_Infos,              //Auto-Alias Service Page
                        NSPanel_Einstellungen,      //Auto-Alias Service Page
                        NSPanel_Firmware_Info       //Auto-Alias Service Page
            button1Page: button1Page,   //Beispiel-Seite auf Button 1, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
            button2Page: button2Page    //Beispiel-Seite auf Button 2, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
        // _________________________________ Ab hier keine Konfiguration mehr _____________________________________
        • Armilar
          @coto
          Eine weitere Frage, die Subpages von ServicePage "NSPanel Service" sind bei mir leer. Muss da auch was Manuel angelegt werden?
          "Service Pages mit Auto-Alias (Nachfolgende Seiten werden mit Alias automatisch angelegt)"
          Versuche nur nebenher nachzuvollziehen, warum die nicht angezeigt werden. Die Antwort hierzu ist: Nein muss nichts manuell angelegt werden.
          Aber das ein Alias automatisch und vollständig erzeugt werden kann, dazu benötigt das Script die Einstellung setObjects als Berechtigung im JS-Adapter.
          Sollten die also immer noch nicht zu sehen sein. Dann bitte mal checken, ob für die Seiten Aliase angelegt wurden.
          z.B. ein alias.0.NSPanel.1.Sensor.ESP32.Temperature
            @armilar
            Danke für dein Hilfe.
            Die Datenpunkte sind alle erstellt, außer
            'Dimmode.hourDay'
            'Dimmode.hourNight'
            Die Einstellung setObjects hatte ich noch nicht gesetzt. Mit gesetzter Einstellung funktioniert es jetzt auch mit der Anzeige auf dem NSPanel.
            Die Screensaver SubPage funktionert allerdings nicht wegen der fehlenden Datenpunkte. Die werden wohl nicht automatisch angelegt. Hier sieht die Struktur auch anders aus.
            T Armilar 2 Replies Last reply Reply Quote 0
              TT-Tom @coto last edited by TT-Tom
              @coto
              hast du das Script noch einmal neu gestartet? Eigentlich werden sie automatisch angelegt.
              • Armilar
                @coto
                Sollte in etwa so aussehen
                Falls nicht, dann den ganzen 0_userdata-Baum und Alias-Baum löschen und neu anlegen lassen.
                C T 2 Replies Last reply Reply Quote 0
                  @armilar
                  Hab alles noch mal gelöscht und geht jetzt.
                  Danke euch. Für heute reicht das dann erstmal 😊
                    TT-Tom @Armilar last edited by TT-Tom
                    @armilar
                    So krass wollte ich nicht gleich rangehen. 😊
                    Frage: wie kann man die Farbe von Icon wechseln bei diesem pageItem? Ich wollte als Übersicht das Icon Rot Weden lassen, wenn mein DP größer 1 ist.
                    <PageItem>{ navigate: true, id: 'Fenster', icon: 'window-closed-variant', onColor: MSGreen, offColor: MSRed, name: 'Fenster'}
                    • Armilar
                      Armilar Most Active Forum Testing @TT-Tom last edited by
                      @tt-tom
                      Da kenne ich nix 😊
                      Habe es nie ausprobiert, wüsste aber auch keinen Grund warum es nicht gehen sollte...
                        @armilar
                        die ID ist ja eine Subpage.
                        • Armilar
                          @tt-tom
                          Aber es ist doch immer noch ein pageItem. Das hat eigentlich mit der Seitenstruktur nichts zu tun.
                            @armilar
                            ja aber bei ID steht doch die Subpage drin und nicht der DP
                            • Armilar
                              Armilar Most Active Forum Testing @TT-Tom last edited by Armilar
                              @tt-tom
                              ich brauchte etwas länger... stimmt - wie soll der einen Wert bekommen?
                              Das wird wohl dann doch nicht gehen...
                                @armilar ich habe grade bei der Type Pageitem das gefunden
                                targetPage: (string | undefined)
                                wofür wird dies genutzt? eventuell kann man diesen ja für 'navigate:true' nutzen, dann bleibt ID für Datenpunkt.
                                • Armilar
                                  Armilar Most Active Forum Testing last edited by
                                  @tt-tom
                                  Wäre möglich. Keine Ahnung wo der herkommt. Wahrscheinlich noch aus einer früheren Navigation.
                                  Naja war eigentlich auch nie gedacht, ein Navigations-Item einzufärben 😊
                                  Hast du schon eine Idee? Sonst bastel mal ne Runde... Ich muss aktuell noch ans Christmas-Release... hoffe das schaffen wir noch...
                                    @armilar hat erstmal Zeit. Ich werde es morgen, ne übermorgen mal zusammenschreiben, wofür es genutzt werden kann und mir dann mal den Code ansehen. schönen Abend noch
                                    • Armilar
                                      @tt-tom
                                      Super, dir auch
                                      • I
                                        io_andre @joBr99 last edited by io_andre
                                        @jobr99 Hallo, ich verzweifel gerade ebenfalls schon mehrere Tage am Punkt "Waiting for content". Die Anleitung ist wirklich 1. Klasse, ich bekomme es aber einfach nicht hin.
                                        Eine Frage zum Grundverständnis. Wenn die richtige Tasmota Version läuft, das Display geflasht ist und der Berry-Treiber richtig installiert ist, dann müsste doch ohne MQTT Server auch schon durch Eingabe von „CustomSend time~12:00“ in der Tasmota Console die Anzeige auf die Uhrzeit wechseln? Habe ich das richtig verstenden? VG Andre
                                        GELÖST: Wenn die Verzweiflung am größten ist geht es auf einmal - Ich habe den Datenpunkt "CustomSend" noch einmal über den ioBroker Expertenmodus und nicht im MQTT-Explorer oder über die Tasmota Console angelegt. Optisch sieht das Ergebnis genau so aus, nur das es nun geht!
                                        • Armilar
                                          Armilar Most Active Forum Testing @io_andre last edited by
                                          @io_andre
                                          Schön das es funktioniert... Und weiterhin viel Spaß damit...
                                          Zu deiner Frage, die du wahrscheinlich schon beantwortet hast:
                                          Die MQTT-Kommunikation muss funktionieren, da "alle" Inhalte für das NSPanel vom ioBroker kommen. Sogar die Zeit und das Datum.
                                          Falls weitere Fragen aufkommen, zögere nicht sie hier zu stellen... 😊
                                            tobiasp @Wuschl last edited by
                                            Grüßt euch,
                                            bei mir läuft alles soweit. Nur mit den Popups bin ich am Ende meines Lateins.
                                            Ich habe verstanden ich muss ein Script schreiben um es anzeigen lassen zu können. Richtig?
                                            Hat jemand ein Script für die Updaten ?
                                            Dankeschön für die Hilfe
                                            lovelace ui nspanel sonoff
                                            270
                                            7630
                                            6241287
