    4. Adapter "smartmeter"
      Homoran Global Moderator Administrators @haselchen last edited by
      @haselchen sagte in Adapter "smartmeter":
      diese CRC Meldung geht mir auf die Nüs.....
      welche?
      • haselchen
        haselchen Most Active @Homoran last edited by
        Der CRC Check aus dem Screenshot
        Bin gerade am Handy
        • haselchen
          haselchen Most Active @haselchen last edited by haselchen
          @Homoran
          @apollon77
          smartmeter.0	2022-12-19 20:38:55.032	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:38:54.568	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          smartmeter.0	2022-12-19 20:38:33.984	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:38:33.572	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          smartmeter.0	2022-12-19 20:38:12.650	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:38:12.556	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          smartmeter.0	2022-12-19 20:37:52.117	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:37:51.561	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          smartmeter.0	2022-12-19 20:37:31.030	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:37:30.572	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          smartmeter.0	2022-12-19 20:37:09.637	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:37:09.562	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          smartmeter.0	2022-12-19 20:36:49.086	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:36:48.557	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          smartmeter.0	2022-12-19 20:36:27.894	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:36:27.556	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          smartmeter.0	2022-12-19 20:36:06.654	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:36:06.572	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          smartmeter.0	2022-12-19 20:35:50.153	info	(3672) Received 5 values, 2 updated
          smartmeter.0	2022-12-19 20:35:45.572	info	(3672) CRC MISMATCH IN SML MESSAGE IGNORED!
          Sehe gerade das der Wert nicht aktualisiert wird. Auf dem Display sind es 5 kw/h
          • O
            ObiTobi @haselchen last edited by
            @haselchen
            Mussten es nicht 8 Bit sein?. Im Screenshot hast 7 stehen.
              Homoran Global Moderator Administrators @ObiTobi last edited by
              @obitobi sagte in Adapter "smartmeter":
              @haselchen
              @haselchen
              wieso hast du da überhaupt etwas eingetragen?
              • haselchen
                Sage ja, dass ich rumprobiert habe, bis Werte erschienen.
                  Itron Zweirichtungszähler
                  der hier?
                  https://wiki.volkszaehler.org/hardware/channels/meters/power/edl-ehz/itron_ace3000_type_260
                    apollon77 @haselchen last edited by
                    @haselchen wegen log Message: github issue bitte
                    • haselchen
                      haselchen Most Active @apollon77 last edited by haselchen
                      @apollon77
                      @Homoran
                      Mit den Einstellungen habe ich ihn geknackt
                      Keine CRC Message mehr im Log.
                      Und die 0 kw/h stand für die Einspeisung. Die haben wir ja nicht.
                      Mit den neuen Einstellungen habe ich jetzt auch den aktuellen kw/h Stand als Datenpunkt.
                      Danke @ObiTobi für den Denkanstoss
                        siehste mit Default geht's
                        nur noch Baudrate ist manuell. warum?
                        Ist es dann eher dieser?
                        https://wiki.volkszaehler.org/hardware/channels/meters/power/edl-ehz/itron_hz1_c50d
                        • haselchen
                          haselchen Most Active last edited by haselchen
                          Im Netz findet man den anscheinend nicht
                          3.HZ-BC-H4-B1-12
                          Ich brauche noch kurz deine Hilfe, wie bekomme ich das per Blockly hin, dass eine volle Zahl in den DP geschrieben wird.
                          Jetzt habe ich z.B. 6,4235 kW/h.
                          Damit kann ich nicht meine Auswertungsblockly benutzen.
                          Ich brauche eine volle Zahl ohne Komma.
                            Homoran Global Moderator Administrators @haselchen last edited by Homoran
                            wie voll soll sie denn sein 🍷 ?
                            gerundet?
                            auf/ab?
                            oder nur die Zahl vor dem Komma, egal was dann kommt?
                            BTW das ist keine Geschwindigkeit sondern schwere Arbeit
                              3.HZ-BC-H4-B1-12
                              doch!
                              Datenschnittstelle / Kommunikation
                              An der Frontseite des Zählers befindet sich eine frei zugängliche Info-Schnitt-
                              stelle (Infrarot-Kommunikationsschnittstelle nach DIN EN 62056-21). Über
                              diese Schnittelle erfolgt kontinuierlich die Ausgabe von Zählerdaten (unidirek-
                              tional; 9600 Baud). Für weitere Informationen zur Nutzung dieser Schnittstelle
                              wenden sie sich bitte an ihren Messstellenbetreiber.
                              Datensatzauswahl
                              Der Umfang der über die Info-Schnittstelle ausgegebenen Daten lässt sich än-
                              dern. Durch mehrmaliges Betätigen der optischen Taste ist zunächst „Inf“ in
                              die Anzeige zu bringen. Inf „off“ signalisiert die Ausgabe eines verkürzten Da-
                              tensatzes. In dieser Betriebsart werden Zählerstände ohne Dezimalstellen und
                              mit der Einheit kWh ausgegeben. Es erfolgt keine Ausgabe der Momentanleis-
                              tung. Inf „on“ signalisiert die Ausgabe eines erweiterten Datensatzes. Zähler-
                              stände werden mit Nachkommastellen ausgegeben. Außerdem ist die Momen-
                              tanleistung im Datensatz enthalten.
                              Wird bei Anzeige von Inf „On“ bzw. Inf „Off“ die optische Taste für 5 Sekunden
                              betätigt, dann schaltet der Zähler in den jeweils anderen Zustand. Nach einem
                              Spannungsausfall startet der Zähler grundsätzlich mit Ausgabe des verkürzten
                              Datensatzes.
                              Abhängig von der Parametrierung des Zählers ist nach Spannungsausfall der
                              verkürzte Datensatz aktiviert oder der Zustand vor Spannungsausfall bleibt er-
                              halten.
                              haselchen 1 Reply Last reply Reply Quote 1
                              • haselchen
                                Da haben wir ja die 9600 baud 🙂
                                Ich möchte nix runden sondern das Komma soll weg.
                                Nur eine volle Zahl.
                                Aus 6,5432 soll 6 werden.
                                und wenn 6,9999 ist soll als nächstes 7 kommen.
                                  @haselchen dann nimm den Block runde aus dem beteich Mathematik.
                                  • haselchen
                                    Genau den nicht, ich will nix runden.
                                    Ich möchte in dem DP keine Kommastellen. NUR DIE VOLLE ZAHL. Und nix gerundet.
                                      @haselchen gerundet ist auch eine volle Zahl!
                                      aber ich vermute du meinst das hier
                                      oder deutlicher
                                      Codierknecht 1 Reply Last reply Reply Quote 1
                                      • Codierknecht
                                        Codierknecht Developer Most Active @Homoran last edited by Codierknecht
                                        @homoran oder so:
                                        [EDIT]
                                        Oder in JS:
                                        var ganzZahl = Math.trunc(7.815423);
                                        • haselchen
                                          Du hast den ...äh Du bist der Grösste 🙂
                                          Bisher genau wie ich es wollte.
                                          Interessant wird es , wenn es auf die 7 kw/h zugeht.
                                          Bisher 6,7039.
                                          Ich warte bis es umswitched. Dann müsste nach deiner Formel aus der 6 eine 7 werden und ich kann endlich wieder berechnen.
                                            Homoran Global Moderator Administrators @Codierknecht last edited by Homoran
                                            @codierknecht sagte in Adapter "smartmeter":
                                            oder so:
                                            ich wusste doch dass es den gibt, hab ihn nicht gefunden 😢
                                            hab echt den pulldown Pfeil nicht gesehen 👓
                                            1.0k
                                            3625
                                            2310530
