    4. Test Adapter zigbee2mqtt
      A Former User @biker1602 last edited by
      @biker1602 wenn zigbee2mqtt nicht in einem Container läuft dann ja
        biker1602 last edited by biker1602
        @ciddi89
        Habe den Raspi neu gestartet aber kein Erfolg der Adapter bleibt gelb
        Konsole gestartet
        cd /opt/zigbee2mqtt
        npm start
        Adapter sofort grün
          @biker1602 was fürn raspberry ist das? 0, 1 oder höher?
            biker1602 @Guest last edited by biker1602
            @ciddi89 said in Test Adapter zigbee2mqtt:
            Raspi 4 ohne SD-Karte, sondern mit SSD Festplatte.
              @biker1602 wie sieht die config aus?
              sudo nano /etc/systemd/system/zigbee2mqtt.service
                @ciddi89
                [Unit]
                Description=zigbee2mqtt
                After=network.target
                [Service]
                ExecStart=/usr/local/bin/npm start
                WorkingDirectory=/opt/zigbee2mqtt
                StandardOutput=inherit
                # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
                StandardError=inherit
                Restart=always
                RestartSec=10s
                User=pi
                [Install]
                WantedBy=multi-user.target
                  @biker1602 da fehlt eine Zeile.
                  [Unit]
                  [Service]
                  Environment=NODE_ENV=production
                  ExecStart=/usr/bin/npm start
                  Restart=always
                  RestartSec=10s
                  User=pi
                  [Install]
                  Danach
                  sudo systemctl start zigbee2mqtt
                  Und Ergebnis von
                  systemctl status zigbee2mqtt.service
                    @ciddi89
                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                    permitted by applicable law.
                    Last login: Tue Dec 20 08:45:59 2022 from 192.168.57.120
                    #pi@raspberrypi:~ $ sudo systemctl enable zigbee2mqtt.service
                    pi@raspberrypi:~ $ sudo nano /etc/systemd/system/zigbee2mqtt.service
                    pi@raspberrypi:~ $ sudo systemctl start zigbee2mqtt
                    Warning: The unit file, source configuration file or drop-ins of zigbee2mqtt.service changed on disk. Run 'systemctl daemon-reload' to reload units.
                    pi@raspberrypi:~ $ systemctl status zigbee2mqtt.service
                    ● zigbee2mqtt.service - zigbee2mqtt
                       Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
                       Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:07:18 CET; 10s ago
                      Process: 5532 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                     Main PID: 5532 (code=exited, status=203/EXEC)
                    pi@raspberrypi:~ $
                      @biker1602
                      Mach mal
                      Und dann noch mal
                      Und Ergebnis von
                        Authentication is required to reload the systemd state.
                        Multiple identities can be used for authentication:
                         1.  ,,, (pi)
                         2.  root
                        Choose identity to authenticate as (1-2): Failed to reload daemon: Method call timed out
                        Was soll ich da nehmen 1 oder 2?
                          @biker1602 pi
                            A Former User @Guest last edited by
                            @ciddi89 wenn das nicht geht dann mit sudo. Hatte ich vergessen.
                            sudo systemctl daemon-reload
                              @ciddi89
                                 Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:21:49 CET; 7s ago
                                Process: 7179 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                               Main PID: 7179 (code=exited, status=203/EXEC)
                              pi@raspberrypi:~ $
                                @biker1602 vielleicht bist du zu schnell 😬 da steht noch activating. Mach jetzt noch mal
                                  @ciddi89
                                    Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC
                                   Main PID: 8239 (code=exited, status=203/EXEC)
                                  lines 1-5/5 (END)
                                     Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:29:51 CET; 3s ago
                                    Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                                  crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                    @ciddi89
                                    Bin mal kurz weg
                                      @biker1602 ja irgendwie startet er den Dienst nicht. Vielleicht weiß @IdleBit noch was 🤔
                                        crunchip Forum Testing Most Active @biker1602 last edited by
                                        @biker1602 sagte in Test Adapter zigbee2mqtt:
                                        liegt das denn in dem Pfad?
                                          Thomas Braun Most Active @biker1602 last edited by
                                          @biker1602
                                          Nodejs./npm-Installation prüfen.
                                          Da scheinen mal wieder die falschen Pfade vorzuliegen (ergo falsch installiert).
                                            biker1602 @Thomas Braun last edited by
                                            Behebt er das mit dem Fixer?
                                            zigbee zigbee 3.0 zigbee2mqtt
                                            52
                                            526
                                            103176
