    4. Test Adapter zigbee2mqtt
      A Former User @biker1602 last edited by
      @biker1602 was fürn raspberry ist das? 0, 1 oder höher?
        biker1602 @Guest last edited by biker1602
        @ciddi89 said in Test Adapter zigbee2mqtt:
        Raspi 4 ohne SD-Karte, sondern mit SSD Festplatte.
          @biker1602 wie sieht die config aus?
          sudo nano /etc/systemd/system/zigbee2mqtt.service
            @ciddi89
            [Unit]
            Description=zigbee2mqtt
            After=network.target
            [Service]
            ExecStart=/usr/local/bin/npm start
            WorkingDirectory=/opt/zigbee2mqtt
            StandardOutput=inherit
            # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
            StandardError=inherit
            Restart=always
            RestartSec=10s
            User=pi
            [Install]
            WantedBy=multi-user.target
              @biker1602 da fehlt eine Zeile.
              [Unit]
              [Service]
              Environment=NODE_ENV=production
              ExecStart=/usr/bin/npm start
              Restart=always
              RestartSec=10s
              User=pi
              [Install]
              Danach
              sudo systemctl start zigbee2mqtt
              Und Ergebnis von
              systemctl status zigbee2mqtt.service
                @ciddi89
                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                permitted by applicable law.
                Last login: Tue Dec 20 08:45:59 2022 from 192.168.57.120
                #pi@raspberrypi:~ $ sudo systemctl enable zigbee2mqtt.service
                pi@raspberrypi:~ $ sudo nano /etc/systemd/system/zigbee2mqtt.service
                pi@raspberrypi:~ $ sudo systemctl start zigbee2mqtt
                Warning: The unit file, source configuration file or drop-ins of zigbee2mqtt.service changed on disk. Run 'systemctl daemon-reload' to reload units.
                pi@raspberrypi:~ $ systemctl status zigbee2mqtt.service
                ● zigbee2mqtt.service - zigbee2mqtt
                   Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
                   Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:07:18 CET; 10s ago
                  Process: 5532 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                 Main PID: 5532 (code=exited, status=203/EXEC)
                pi@raspberrypi:~ $
                  @biker1602
                  Mach mal
                  Und dann noch mal
                  Und Ergebnis von
                    Authentication is required to reload the systemd state.
                    Multiple identities can be used for authentication:
                     1.  ,,, (pi)
                     2.  root
                    Choose identity to authenticate as (1-2): Failed to reload daemon: Method call timed out
                    Was soll ich da nehmen 1 oder 2?
                      @biker1602 pi
                        A Former User @Guest last edited by
                        @ciddi89 wenn das nicht geht dann mit sudo. Hatte ich vergessen.
                        sudo systemctl daemon-reload
                          @ciddi89
                             Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:21:49 CET; 7s ago
                            Process: 7179 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                           Main PID: 7179 (code=exited, status=203/EXEC)
                          pi@raspberrypi:~ $
                            @biker1602 vielleicht bist du zu schnell 😬 da steht noch activating. Mach jetzt noch mal
                              @ciddi89
                                Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC
                               Main PID: 8239 (code=exited, status=203/EXEC)
                              lines 1-5/5 (END)
                                 Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:29:51 CET; 3s ago
                                Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                              crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                @ciddi89
                                Bin mal kurz weg
                                  @biker1602 ja irgendwie startet er den Dienst nicht. Vielleicht weiß @IdleBit noch was 🤔
                                    crunchip Forum Testing Most Active @biker1602 last edited by
                                    @biker1602 sagte in Test Adapter zigbee2mqtt:
                                    liegt das denn in dem Pfad?
                                      Thomas Braun Most Active @biker1602 last edited by
                                      @biker1602
                                      Nodejs./npm-Installation prüfen.
                                      Da scheinen mal wieder die falschen Pfade vorzuliegen (ergo falsch installiert).
                                        biker1602 @Thomas Braun last edited by
                                        Behebt er das mit dem Fixer?
                                          Thomas Braun Most Active @biker1602 last edited by Thomas Braun
                                          @biker1602
                                          Nein, der Fixer behebt keine krumme Installation von nodejs.
                                          Status jetzt ist?
                                          Mit
                                          sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                          uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          nachschauen.
                                            biker1602 @crunchip last edited by
                                            @crunchip said in Test Adapter zigbee2mqtt:
                                            Ich bin eben mal mit WinSCP auf das Verzeichnis gegangen und unter
                                            /usr/local/bin ist nichts drin
                                            zigbee zigbee 3.0 zigbee2mqtt
                                            52
                                            526
                                            103177
