    4. Test Adapter zigbee2mqtt
      A Former User @biker1602 last edited by
      @biker1602 da fehlt eine Zeile.
      [Unit]
      Description=zigbee2mqtt
      After=network.target
      [Service]
      Environment=NODE_ENV=production
      ExecStart=/usr/bin/npm start
      WorkingDirectory=/opt/zigbee2mqtt
      StandardOutput=inherit
      # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
      StandardError=inherit
      Restart=always
      RestartSec=10s
      User=pi
      [Install]
      WantedBy=multi-user.target
      Danach
      sudo systemctl start zigbee2mqtt
      Und Ergebnis von
      systemctl status zigbee2mqtt.service
        biker1602 @Guest last edited by
        @ciddi89
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Tue Dec 20 08:45:59 2022 from 192.168.57.120
        #pi@raspberrypi:~ $ sudo systemctl enable zigbee2mqtt.service
        pi@raspberrypi:~ $ sudo nano /etc/systemd/system/zigbee2mqtt.service
        pi@raspberrypi:~ $ sudo systemctl start zigbee2mqtt
        Warning: The unit file, source configuration file or drop-ins of zigbee2mqtt.service changed on disk. Run 'systemctl daemon-reload' to reload units.
        pi@raspberrypi:~ $ systemctl status zigbee2mqtt.service
        ● zigbee2mqtt.service - zigbee2mqtt
           Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
           Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:07:18 CET; 10s ago
          Process: 5532 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
         Main PID: 5532 (code=exited, status=203/EXEC)
        pi@raspberrypi:~ $
          @biker1602
          Mach mal
          Und dann noch mal
          Und Ergebnis von
            @ciddi89 said in Test Adapter zigbee2mqtt:
            Authentication is required to reload the systemd state.
            Multiple identities can be used for authentication:
             1.  ,,, (pi)
             2.  root
            Choose identity to authenticate as (1-2): Failed to reload daemon: Method call timed out
            Was soll ich da nehmen 1 oder 2?
              @biker1602 pi
                A Former User @Guest last edited by
                @ciddi89 wenn das nicht geht dann mit sudo. Hatte ich vergessen.
                sudo systemctl daemon-reload
                  @ciddi89
                     Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:21:49 CET; 7s ago
                    Process: 7179 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                   Main PID: 7179 (code=exited, status=203/EXEC)
                  pi@raspberrypi:~ $
                    @biker1602 vielleicht bist du zu schnell 😬 da steht noch activating. Mach jetzt noch mal
                      @ciddi89
                        Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC
                       Main PID: 8239 (code=exited, status=203/EXEC)
                      lines 1-5/5 (END)
                         Active: activating (auto-restart) (Result: exit-code) since Tue 2022-12-20 09:29:51 CET; 3s ago
                        Process: 8239 ExecStart=/usr/local/bin/npm start (code=exited, status=203/EXEC)
                      crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                        @ciddi89
                        Bin mal kurz weg
                          @biker1602 ja irgendwie startet er den Dienst nicht. Vielleicht weiß @IdleBit noch was 🤔
                            crunchip Forum Testing Most Active @biker1602 last edited by
                            @biker1602 sagte in Test Adapter zigbee2mqtt:
                            liegt das denn in dem Pfad?
                              Thomas Braun Most Active @biker1602 last edited by
                              @biker1602
                              Nodejs./npm-Installation prüfen.
                              Da scheinen mal wieder die falschen Pfade vorzuliegen (ergo falsch installiert).
                                biker1602 @Thomas Braun last edited by
                                Behebt er das mit dem Fixer?
                                  Thomas Braun Most Active @biker1602 last edited by Thomas Braun
                                  @biker1602
                                  Nein, der Fixer behebt keine krumme Installation von nodejs.
                                  Status jetzt ist?
                                  Mit
                                  sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                  uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  nachschauen.
                                    biker1602 @crunchip last edited by
                                    @crunchip said in Test Adapter zigbee2mqtt:
                                    Ich bin eben mal mit WinSCP auf das Verzeichnis gegangen und unter
                                    /usr/local/bin ist nichts drin
                                      pi@raspberrypi:/opt/zigbee2mqtt $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                      pi@raspberrypi:/opt/zigbee2mqtt $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      armv7l
                                      Kein Docker
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.19.0
                                      v16.19.0
                                      8.19.3
                                      4.0.23
                                      pi
                                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                      tty
                                      /opt/zigbee2mqtt
                                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                                      Reading package lists... Done
                                      Building dependency tree
                                      97 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                      nodejs:
                                        @biker1602
                                        Das ist nicht vollständig, dein Betriebssystem ist tot und es stehen 97 Updates in der Pipeline.
                                          @thomas-braun said in Test Adapter zigbee2mqtt:
                                          @biker1602
                                          Verzeihung da fehlte noch etwas
                                          armv7l
                                          Kein Docker
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.19.0
                                          v16.19.0
                                          8.19.3
                                          4.0.23
                                          pi
                                          tty
                                          /opt/zigbee2mqtt
                                          nodejs:
                                            Installed: 16.19.0-deb-1nodesource1
                                            Candidate: 16.19.0-deb-1nodesource1
                                            Version table:
                                           *** 16.19.0-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                                  100 /var/lib/dpkg/status
                                               10.24.0~dfsg-1~deb10u2 500
                                            @biker1602
                                            Dann reduziert es sich auf:
                                            zigbee zigbee 3.0 zigbee2mqtt
                                            52
                                            526
                                            103493
