    4. Test Adapter zigbee2mqtt
      biker1602 @Thomas Braun last edited by
      pi@raspberrypi:/opt/zigbee2mqtt $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      pi@raspberrypi:/opt/zigbee2mqtt $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      Kein Docker
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.19.0
      v16.19.0
      8.19.3
      4.0.23
      pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      tty
      /opt/zigbee2mqtt
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
      Reading package lists... Done
      Building dependency tree
      97 packages can be upgraded. Run 'apt list --upgradable' to see them.
      nodejs:
        Thomas Braun Most Active @biker1602 last edited by
        @biker1602
        Das ist nicht vollständig, dein Betriebssystem ist tot und es stehen 97 Updates in der Pipeline.
          @thomas-braun said in Test Adapter zigbee2mqtt:
          @biker1602
          Verzeihung da fehlte noch etwas
          armv7l
          Kein Docker
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.19.0
          v16.19.0
          8.19.3
          4.0.23
          pi
          tty
          /opt/zigbee2mqtt
          nodejs:
            Installed: 16.19.0-deb-1nodesource1
            Candidate: 16.19.0-deb-1nodesource1
            Version table:
           *** 16.19.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u2 500
            @biker1602
            Dann reduziert es sich auf:
              biker1602 last edited by biker1602
              @biker1602
              pi@raspberrypi:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker                                                               && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm                                                               && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SES                                                              SION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sud                                                              o apt update && apt policy nodejs
              armv7l
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.19.0
              v16.19.0
              8.19.3
              4.0.23
              pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g                                                              pio i2c spi iobroker
              tty
              /home/pi
              All packages are up to date.
              nodejs:
                Version table:
              pi@raspberrypi:~ $
              Ich verstehe das nicht, mit System ist tot. Ich habe jetzt alle Updates gemacht.
              Ist es so besser?
                @biker1602
                Das Buster Release ist im September abgekündigt worden. Installier da Bullseye.
                  @biker1602
                  Aber da muss ich alles neu aufsetzen oder?
                  Asgothian Thomas Braun 2 Replies Last reply Reply Quote 0
                    crunchip Forum Testing Most Active @biker1602 last edited by crunchip
                    @biker1602 sagte in Test Adapter zigbee2mqtt:
                    /usr/local/bin ist nichts drin
                    logisch, sonst hätte es ja auch gegriffen
                    du musst das anpassen
                    sudo nano /etc/systemd/system/zigbee2mqtt.service
                    und den Pfad ändern, von
                    ExecStart=/usr/local/bin/npm start
                    auf
                    ExecStart=/usr/bin/npm start
                    kann man, oder update
                    z.b.
                    https://linuxhint.com/upgrade-raspberry-pi-os-buster-to-bullseye/
                    • Asgothian
                      Asgothian Developer @biker1602 last edited by Asgothian
                      @biker1602
                      Nein, du kannst ein update machen.
                      Musst du aber nicht. Das ursprüngliche Problem wird sich mit einer Neuinstallation des Systems NICHT beheben.
                      Wenn das System aktuell läuft dann musst du das nicht zwingend aktualisieren - auch wenn @thomas-braun Meinung ist das nur ein System auf dem aktuellen Stand lebensfähig ist.
                      Läuft dein zigbee2mqtt Dienst denn jetzt ? Wenn nein, Poste noch mal bitte genau das was du in der Datei
                      auf deinem System drin stehen hast.
                      Nachtrag: Das was @crunchip geschrieben hat vermute ich aktuell auch als Ursache für Dein Problem.
                      A.
                        @asgothian
                        [Unit]
                        Description=zigbee2mqtt
                        After=network.target
                        [Service]
                        Environment=NODE_ENV=production
                        WorkingDirectory=/opt/zigbee2mqtt
                        StandardOutput=inherit
                        # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
                        StandardError=inherit
                        Restart=always
                        RestartSec=10s
                        User=pi
                        [Install]
                        WantedBy=multi-user.target
                        So habe den Pfad geändert
                        pi@raspberrypi:/opt/zigbee2mqtt $ npm start
                        > zigbee2mqtt@1.28.0 start
                        > node index.js
                        Zigbee2MQTT:info  2022-12-20 13:13:06: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-12-20.13-13-06' filename: log.txt
                        Zigbee2MQTT:info  2022-12-20 13:13:06: Starting Zigbee2MQTT version 1.28.0 (commit #03ba647)
                        Zigbee2MQTT:info  2022-12-20 13:13:06: Starting zigbee-herdsman (0.14.62)
                        Zigbee2MQTT:info  2022-12-20 13:13:07: zigbee-herdsman started (resumed)
                        Zigbee2MQTT:info  2022-12-20 13:13:07: Coordinator firmware version: '{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20190608,"transportrev":2},"type":"zStack12"}'
                        Zigbee2MQTT:info  2022-12-20 13:13:07: Currently 1 devices are joined:
                        Zigbee2MQTT:info  2022-12-20 13:13:07: IKEA Smart Home Button (0x84fd27fffe1f7496): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                        Zigbee2MQTT:info  2022-12-20 13:13:07: Zigbee: disabling joining new devices.
                        Zigbee2MQTT:info  2022-12-20 13:13:07: Connecting to MQTT server at mqtt://localhost
                        Zigbee2MQTT:info  2022-12-20 13:13:07: Connected to MQTT server
                        Zigbee2MQTT:info  2022-12-20 13:13:07: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
                        Zigbee2MQTT:info  2022-12-20 13:13:07: MQTT publish: topic 'zigbee2mqtt/IKEA Smart Home Button/availability', payload '{"state":"offline"}'
                        Zigbee2MQTT:info  2022-12-20 13:13:07: Started frontend on port 0.0.0.0:8080
                        Gestartet Adapter ist Grün und sobald ich die Konsole schließe ist er wieder Gelb
                        Asgothian crunchip 2 Replies Last reply Reply Quote 0
                          @biker1602
                          Jein.
                          Die Empfehlung geht zu 'alles neu', du kannst aber auch ein Distributions-Upgrade versuchen. Hab ich mal vor geraumer Zeit was zu geschrieben.
                            Thomas Braun Most Active @Asgothian last edited by
                            @asgothian sagte in Test Adapter zigbee2mqtt:
                            Zumindest macht es das Leben leichter mit noch unterstützen Systemen herumzuhantieren.
                            • Asgothian
                              @biker1602 solange du das Programm immer direkt per npm startet bleibt es so
                              Du musst schon den Dienst starten. Nachdem du die Datei angepasst hast solltest du nochmal das versuchen was @ciddi89 weiter oben geschrieben hat:
                              @ciddi89 sagte in Test Adapter zigbee2mqtt:
                              @biker1602
                              Mach mal
                              systemctl daemon-reload
                              Und dann noch mal
                              sudo systemctl start zigbee2mqtt
                              Und Ergebnis von
                              systemctl status zigbee2mqtt.service
                              • Asgothian
                                Asgothian Developer @Thomas Braun last edited by
                                @thomas-braun sagte in Test Adapter zigbee2mqtt:
                                Grundsatzdiskussion - will ich hier nicht führen. Wir haben da unterschiedliche Ansichten.
                                  Verify that the configuration works:
                                  Start Zigbee2MQTT
                                  Show status
                                  Now that everything works, we want systemctl to start Zigbee2MQTT automatically on boot, this can be done by executing:
                                  sudo systemctl enable zigbee2mqtt.service
                                  ansonsten mach mal ein reboot
                                    @asgothian
                                    Da gibt es ja auch nix zu diskutieren, grundsätzlich ist es natürlich schwieriger ein System nach dem EOL am laufen zu halten als ein aktuell vom Hersteller noch unterstütztes.
                                      @asgothian said in Test Adapter zigbee2mqtt:
                                      @biker1602
                                      Mach mal
                                      Und dann noch mal
                                      Und Ergebnis von
                                      Das war es jetzt bleibt er grün. 👌 Jetzt ist zwar der IKEA Button Offline aber vielleicht erholt er sich ja noch. Oder muss der neiu angelernt werden?
                                      • Asgothian
                                        @asgothian
                                        Da gibt es viel zu diskutieren. Der OP hat kein problem damit sein System am laufen zu halten - es läuft. Er hat ein problem damit aus einer nicht auf sein System zugeschnittenen Anleitung zusätzliche Software zum laufen zu kriegen. Das wäre bei dem neu aufgesetzten System genau so geblieben, da sich an dem eigentlichen Fehler absolut NICHTS durch das neue System ändert.
                                        Die Frage ist also nicht ob ein neues System einfacher zu warten ist, sondern ob das neu installieren das Problem des OP's löst. Tut es nicht.
                                        A.
                                          Thomas Braun Most Active @Asgothian last edited by Thomas Braun
                                          @asgothian
                                          Richtig, die Service-Datei ist hüben wie drüben falsch.
                                          Trotzdem wird ein abgekündigtes System künstlich am Leben gehalten, die Aufgabe das Release zu wechseln stellt sich früher oder später ohnehin.
                                          Je länger das herausgezögert wird desto komplexer wird das aber erfahrungsgemäß. Deswegen beizeiten wechseln und nicht das EOL eintreten lassen. Dafür gibt es ja den Übergangszeitraum von über einem Jahr bei Debian von Release zu Release. Kommt ja nicht aus heiterem Himmel.
                                          Die 'große' Operation ist jetzt mit einem Pflästerchen etwas herausgezögert worden. Aber wie viele Pflaster willste da noch draufpappen?
                                            arteck Developer Most Active @Thomas Braun last edited by
                                            aber im andern thread... und nicht HIER
                                            zigbee zigbee 3.0 zigbee2mqtt
                                            52
                                            526
                                            93695
