    4. Test Adapter zigbee2mqtt
      Thomas Braun Most Active @biker1602 last edited by
      @biker1602
      Das ist nicht vollständig, dein Betriebssystem ist tot und es stehen 97 Updates in der Pipeline.
        biker1602 @Thomas Braun last edited by
        @thomas-braun said in Test Adapter zigbee2mqtt:
        @biker1602
        Verzeihung da fehlte noch etwas
        pi@raspberrypi:/opt/zigbee2mqtt $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        Kein Docker
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.19.0
        v16.19.0
        8.19.3
        4.0.23
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        tty
        /opt/zigbee2mqtt
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
        Reading package lists... Done
        Building dependency tree
        97 packages can be upgraded. Run 'apt list --upgradable' to see them.
        nodejs:
          Installed: 16.19.0-deb-1nodesource1
          Candidate: 16.19.0-deb-1nodesource1
          Version table:
         *** 16.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u2 500
          @biker1602
          Dann reduziert es sich auf:
            biker1602 last edited by biker1602
            @biker1602
            pi@raspberrypi:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker                                                               && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm                                                               && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SES                                                              SION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sud                                                              o apt update && apt policy nodejs
            armv7l
            Kein Docker
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.19.0
            v16.19.0
            8.19.3
            4.0.23
            pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g                                                              pio i2c spi iobroker
            tty
            /home/pi
            All packages are up to date.
            nodejs:
              Version table:
            pi@raspberrypi:~ $
            Ich verstehe das nicht, mit System ist tot. Ich habe jetzt alle Updates gemacht.
            Ist es so besser?
              @biker1602
              Das Buster Release ist im September abgekündigt worden. Installier da Bullseye.
                @biker1602
                Aber da muss ich alles neu aufsetzen oder?
                Asgothian Thomas Braun 2 Replies Last reply Reply Quote 0
                  crunchip Forum Testing Most Active @biker1602 last edited by crunchip
                  @biker1602 sagte in Test Adapter zigbee2mqtt:
                  /usr/local/bin ist nichts drin
                  logisch, sonst hätte es ja auch gegriffen
                  du musst das anpassen
                  sudo nano /etc/systemd/system/zigbee2mqtt.service
                  und den Pfad ändern, von
                  ExecStart=/usr/local/bin/npm start
                  auf
                  ExecStart=/usr/bin/npm start
                  kann man, oder update
                  z.b.
                  https://linuxhint.com/upgrade-raspberry-pi-os-buster-to-bullseye/
                  • Asgothian
                    Asgothian Developer @biker1602 last edited by Asgothian
                    @biker1602
                    Nein, du kannst ein update machen.
                    Musst du aber nicht. Das ursprüngliche Problem wird sich mit einer Neuinstallation des Systems NICHT beheben.
                    Wenn das System aktuell läuft dann musst du das nicht zwingend aktualisieren - auch wenn @thomas-braun Meinung ist das nur ein System auf dem aktuellen Stand lebensfähig ist.
                    Läuft dein zigbee2mqtt Dienst denn jetzt ? Wenn nein, Poste noch mal bitte genau das was du in der Datei
                    auf deinem System drin stehen hast.
                    Nachtrag: Das was @crunchip geschrieben hat vermute ich aktuell auch als Ursache für Dein Problem.
                    A.
                      @asgothian
                      [Unit]
                      Description=zigbee2mqtt
                      After=network.target
                      [Service]
                      Environment=NODE_ENV=production
                      WorkingDirectory=/opt/zigbee2mqtt
                      StandardOutput=inherit
                      # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
                      StandardError=inherit
                      Restart=always
                      RestartSec=10s
                      User=pi
                      [Install]
                      WantedBy=multi-user.target
                      So habe den Pfad geändert
                      pi@raspberrypi:/opt/zigbee2mqtt $ npm start
                      > zigbee2mqtt@1.28.0 start
                      > node index.js
                      Zigbee2MQTT:info  2022-12-20 13:13:06: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-12-20.13-13-06' filename: log.txt
                      Zigbee2MQTT:info  2022-12-20 13:13:06: Starting Zigbee2MQTT version 1.28.0 (commit #03ba647)
                      Zigbee2MQTT:info  2022-12-20 13:13:06: Starting zigbee-herdsman (0.14.62)
                      Zigbee2MQTT:info  2022-12-20 13:13:07: zigbee-herdsman started (resumed)
                      Zigbee2MQTT:info  2022-12-20 13:13:07: Coordinator firmware version: '{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20190608,"transportrev":2},"type":"zStack12"}'
                      Zigbee2MQTT:info  2022-12-20 13:13:07: Currently 1 devices are joined:
                      Zigbee2MQTT:info  2022-12-20 13:13:07: IKEA Smart Home Button (0x84fd27fffe1f7496): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                      Zigbee2MQTT:info  2022-12-20 13:13:07: Zigbee: disabling joining new devices.
                      Zigbee2MQTT:info  2022-12-20 13:13:07: Connecting to MQTT server at mqtt://localhost
                      Zigbee2MQTT:info  2022-12-20 13:13:07: Connected to MQTT server
                      Zigbee2MQTT:info  2022-12-20 13:13:07: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
                      Zigbee2MQTT:info  2022-12-20 13:13:07: MQTT publish: topic 'zigbee2mqtt/IKEA Smart Home Button/availability', payload '{"state":"offline"}'
                      Zigbee2MQTT:info  2022-12-20 13:13:07: Started frontend on port 0.0.0.0:8080
                      Gestartet Adapter ist Grün und sobald ich die Konsole schließe ist er wieder Gelb
                      Asgothian crunchip 2 Replies Last reply Reply Quote 0
                        @biker1602
                        Jein.
                        Die Empfehlung geht zu 'alles neu', du kannst aber auch ein Distributions-Upgrade versuchen. Hab ich mal vor geraumer Zeit was zu geschrieben.
                          Thomas Braun Most Active @Asgothian last edited by
                          @asgothian sagte in Test Adapter zigbee2mqtt:
                          Zumindest macht es das Leben leichter mit noch unterstützen Systemen herumzuhantieren.
                          • Asgothian
                            @biker1602 solange du das Programm immer direkt per npm startet bleibt es so
                            Du musst schon den Dienst starten. Nachdem du die Datei angepasst hast solltest du nochmal das versuchen was @ciddi89 weiter oben geschrieben hat:
                            @ciddi89 sagte in Test Adapter zigbee2mqtt:
                            @biker1602
                            Mach mal
                            systemctl daemon-reload
                            Und dann noch mal
                            sudo systemctl start zigbee2mqtt
                            Und Ergebnis von
                            systemctl status zigbee2mqtt.service
                            • Asgothian
                              Asgothian Developer @Thomas Braun last edited by
                              @thomas-braun sagte in Test Adapter zigbee2mqtt:
                              Grundsatzdiskussion - will ich hier nicht führen. Wir haben da unterschiedliche Ansichten.
                                Verify that the configuration works:
                                Start Zigbee2MQTT
                                Show status
                                Now that everything works, we want systemctl to start Zigbee2MQTT automatically on boot, this can be done by executing:
                                sudo systemctl enable zigbee2mqtt.service
                                ansonsten mach mal ein reboot
                                  @asgothian
                                  Da gibt es ja auch nix zu diskutieren, grundsätzlich ist es natürlich schwieriger ein System nach dem EOL am laufen zu halten als ein aktuell vom Hersteller noch unterstütztes.
                                    @asgothian said in Test Adapter zigbee2mqtt:
                                    @biker1602
                                    Mach mal
                                    Und dann noch mal
                                    Und Ergebnis von
                                    Das war es jetzt bleibt er grün. 👌 Jetzt ist zwar der IKEA Button Offline aber vielleicht erholt er sich ja noch. Oder muss der neiu angelernt werden?
                                    • Asgothian
                                      @asgothian
                                      Da gibt es viel zu diskutieren. Der OP hat kein problem damit sein System am laufen zu halten - es läuft. Er hat ein problem damit aus einer nicht auf sein System zugeschnittenen Anleitung zusätzliche Software zum laufen zu kriegen. Das wäre bei dem neu aufgesetzten System genau so geblieben, da sich an dem eigentlichen Fehler absolut NICHTS durch das neue System ändert.
                                      Die Frage ist also nicht ob ein neues System einfacher zu warten ist, sondern ob das neu installieren das Problem des OP's löst. Tut es nicht.
                                      A.
                                        Thomas Braun Most Active @Asgothian last edited by Thomas Braun
                                        @asgothian
                                        Richtig, die Service-Datei ist hüben wie drüben falsch.
                                        Trotzdem wird ein abgekündigtes System künstlich am Leben gehalten, die Aufgabe das Release zu wechseln stellt sich früher oder später ohnehin.
                                        Je länger das herausgezögert wird desto komplexer wird das aber erfahrungsgemäß. Deswegen beizeiten wechseln und nicht das EOL eintreten lassen. Dafür gibt es ja den Übergangszeitraum von über einem Jahr bei Debian von Release zu Release. Kommt ja nicht aus heiterem Himmel.
                                        Die 'große' Operation ist jetzt mit einem Pflästerchen etwas herausgezögert worden. Aber wie viele Pflaster willste da noch draufpappen?
                                          arteck Developer Most Active @Thomas Braun last edited by
                                          aber im andern thread... und nicht HIER
                                            toralt @IdleBit last edited by
                                            @idlebit mal eine generelle Frage:
                                            Ich habe zigbee2mqtt auf die neueste Version upgedatet (28.5) und bekomme anschließen jede Minute einen disconnect des Adapters wegen websocket error. Adapter ist aktuell bei 2.5.0.
                                            Ich habe nun meine Backup VM gestartet und bin somit wieder auf Version 28.4 bei zigbee2mqtt. Nun funktioniert wieder alles wie vorher. Muss ich nach dem Update von zigbee2mqtt wieder irgendwas in der config anpassen bevor der Adapter wieder funktioniert? In der Dokumentation von @nox309 konnte ich hierzu nichts finden.
                                            ? arteck 2 Replies Last reply Reply Quote 0
                                            zigbee zigbee 3.0 zigbee2mqtt
                                            52
                                            526
                                            103197
